Attention is currently required from: Jamie Chen. Hello Jamie Chen,
https://review.coreboot.org/c/coreboot/+/56336
Change subject: soc/intel/jasperlake: add pcie modphy settings ......................................................................
This patch expose some pcie modphy UPDs/configuration to be filled from devicetree. It's for fine tune pcie port signal quality.
BUG=b:192716633 BRANCH=NONE TEST=build dedede variant coreboot with fw_debug enable and chekc if these settings have been changed successfully on fsp debug log.
Change-Id: I80a91d45f9dd8ef218846e1284fdad309313e831 Signed-off-by: Jamie Chen jamie.chen@intel.com --- M src/soc/intel/jasperlake/chip.h M src/soc/intel/jasperlake/romstage/fsp_params.c 2 files changed, 40 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/56336/1
diff --git a/src/soc/intel/jasperlake/chip.h b/src/soc/intel/jasperlake/chip.h index 36e9a13..1e6a300 100644 --- a/src/soc/intel/jasperlake/chip.h +++ b/src/soc/intel/jasperlake/chip.h @@ -101,6 +101,22 @@ uint8_t PchHdaIDispLinkFrequency; uint8_t PchHdaIDispCodecDisconnect;
+ /* PCIe ModPHY related */ + uint8_t PchPcieHsioRxSetCtleEnable[24]; + uint8_t PchPcieHsioRxSetCtle[24]; + uint8_t PchPcieHsioTxGen1DownscaleAmpEnable[24]; + uint8_t PchPcieHsioTxGen1DownscaleAmp[24]; + uint8_t PchPcieHsioTxGen2DownscaleAmpEnable[24]; + uint8_t PchPcieHsioTxGen2DownscaleAmp[24]; + uint8_t PchPcieHsioTxGen3DownscaleAmpEnable[24]; + uint8_t PchPcieHsioTxGen3DownscaleAmp[24]; + uint8_t PchPcieHsioTxGen1DeEmphEnable[24]; + uint8_t PchPcieHsioTxGen1DeEmph[24]; + uint8_t PchPcieHsioTxGen2DeEmph3p5Enable[24]; + uint8_t PchPcieHsioTxGen2DeEmph3p5[24]; + uint8_t PchPcieHsioTxGen2DeEmph6p0Enable[24]; + uint8_t PchPcieHsioTxGen2DeEmph6p0[24]; + /* PCIe Root Ports */ uint8_t PcieRpEnable[CONFIG_MAX_ROOT_PORTS]; /* PCIe output clocks type to PCIe devices. diff --git a/src/soc/intel/jasperlake/romstage/fsp_params.c b/src/soc/intel/jasperlake/romstage/fsp_params.c index c1208e3..4c2c925 100644 --- a/src/soc/intel/jasperlake/romstage/fsp_params.c +++ b/src/soc/intel/jasperlake/romstage/fsp_params.c @@ -27,6 +27,30 @@ m_cfg->SaGv = config->SaGv; m_cfg->RMT = config->RMT;
+ /* PCIe ModPhy configuration */ + for (i = 0; i < ARRAY_SIZE(config->PchPcieHsioRxSetCtleEnable); i++) { + if (config->PchPcieHsioRxSetCtleEnable[i]) + m_cfg->PchPcieHsioRxSetCtle[i] = config->PchPcieHsioRxSetCtle[i]; + if (config->PchPcieHsioTxGen1DownscaleAmpEnable[i]) + m_cfg->PchPcieHsioTxGen1DownscaleAmp[i] = + config->PchPcieHsioTxGen1DownscaleAmp[i]; + if (config->PchPcieHsioTxGen2DownscaleAmpEnable[i]) + m_cfg->PchPcieHsioTxGen2DownscaleAmp[i] = + config->PchPcieHsioTxGen2DownscaleAmp[i]; + if (config->PchPcieHsioTxGen3DownscaleAmp[i]) + m_cfg->PchPcieHsioTxGen3DownscaleAmp[i] = + config->PchPcieHsioTxGen3DownscaleAmp[i]; + if (config->PchPcieHsioTxGen1DeEmphEnable[i]) + m_cfg->PchPcieHsioTxGen1DeEmph[i] = + config->PchPcieHsioTxGen1DeEmph[i]; + if (config->PchPcieHsioTxGen2DeEmph3p5Enable[i]) + m_cfg->PchPcieHsioTxGen2DeEmph3p5[i] = + config->PchPcieHsioTxGen2DeEmph3p5[i]; + if (config->PchPcieHsioTxGen2DeEmph6p0Enable[i]) + m_cfg->PchPcieHsioTxGen2DeEmph6p0[i] = + config->PchPcieHsioTxGen2DeEmph6p0[i]; + } + /* PCIe root port configuration */ for (i = 0; i < ARRAY_SIZE(config->PcieRpEnable); i++) { if (config->PcieRpEnable[i])
