Hello build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/17644
Change subject: lib/edid.c: Remove trailing space from detailed mode output ......................................................................
When the bit for interlaced mode is not set, a trailing space is added to the end.
As the space is already accounted for in `" interlaced"`, remove that space.
TEST=Boot on Lenovo X60t, and verify the trailing space in the detailed mode is gone.
Change-Id: I4114c9e61a040fa005c806404ec51c12e2f02f4d Signed-off-by: Paul Menzel paulepanter@users.sourceforge.net --- M src/lib/edid.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/17644/2
