Alexandru Gagniuc (mr.nuke.me@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4563
commit fbd198b619cab4d08a18b7000e823e5e10882533 Author: Alexandru Gagniuc mr.nuke.me@gmail.com Date: Sun Dec 22 18:51:29 2013 -0500
cpu/allwinner/a10: Clear the usage of SRAM during the bootblock
We have 32KiB of usable SRAM right when we boot. The first 24KiB can be loaded with our bootblock, while the other 8KiB can be used as stack during the bootblock stage.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com Change-Id: I48d3a37869031c3c1dbc1fab71204d473d64deeb --- src/cpu/allwinner/a10/Kconfig | 10 +++++++--- src/cpu/allwinner/a10/Makefile.inc | 15 ++++++++------- 2 files changed, 15 insertions(+), 10 deletions(-)
diff --git a/src/cpu/allwinner/a10/Kconfig b/src/cpu/allwinner/a10/Kconfig index 646fe80..f40fa26 100644 --- a/src/cpu/allwinner/a10/Kconfig +++ b/src/cpu/allwinner/a10/Kconfig @@ -30,18 +30,22 @@ config ROMSTAGE_BASE hex default SYS_SDRAM_BASE
-# Keep the stack in SRAM +# Keep the stack in SRAM block A2. +# SRAM blocks A1 (0-16KiB) and A2 (16KiB-32KiB) are always accessible to the +# CPU. This gives us 32KiB of SRAM to boot with. The BROM bootloader will use up +# to 24KiB to load our bootblock, which leaves us the area from 24KiB to 32 KiB +# to use however we see fit. config STACK_TOP hex default 0x00008000
config STACK_BOTTOM hex - default 0x00004000 + default 0x00006000
config STACK_SIZE hex - default 0x00004000 + default 0x00002000
## TODO Change this to some better address not overlapping bootblock when ## cbfstool supports creating header in arbitrary location. diff --git a/src/cpu/allwinner/a10/Makefile.inc b/src/cpu/allwinner/a10/Makefile.inc index 48f3110..9f7208a 100644 --- a/src/cpu/allwinner/a10/Makefile.inc +++ b/src/cpu/allwinner/a10/Makefile.inc @@ -21,15 +21,16 @@ get_bootblock_size= \ sed 's/[^0-9 ]//g')) \ $(shell echo $$(($(word 2, $(strip $(bb_s))))))
-# The boot ROM in the SoC will start loading code if a special boot0 header is +# The boot ROM in the SoC will start loading code if a special BOOT0 header is # found (at an offset of 8KiB in either NAND or SD), and the checksum is -# correct. this header is normally added by the 'mxsunxiboot' tool. The file -# passed to mksunxiboot should only include the bootblock due to size -# limitations. -# FIXME: Figure out how to safely integrate in coreboot.rom. For now, only copy -# the first 15 KiB of coreboot.rom (This will not collide with stack) +# correct. This header is normally added by the 'mxsunxiboot' tool. The boot ROM +# will load at most 24KiB of data to SRAM, so limit the file size accordingly. +# The BOOT0 header takes 32 bytes, so limit our file to 24KiB - 32 bytes. +# FIXME: Figure out how to safely integrate in coreboot.rom. +# FIXME: The file passed to mksunxiboot should only include the bootblock due +# to size limitations. $(obj)/BOOT0: $(obj)/coreboot.rom @printf " BOOT0 $(subst $(obj)/,,$(^))\n" touch $@ - dd if=$^ of=$^.tmp bs=1024 count=15 + dd if=$^ of=$^.tmp bs=24544 count=1 -mksunxiboot $^.tmp $@
