Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9283
commit 103123ddd26cd206ab84c05f6a5f7c691346d7f4 Author: Julius Werner jwerner@chromium.org Date: Wed Aug 20 15:29:56 2014 -0700
New mechanism to define SRAM/memory map with automatic bounds checking
This patch creates a new mechanism to define the static memory layout (primarily in SRAM) for a given board, superseding the brittle mass of Kconfigs that we were using before. The core part is a memlayout.ld file in the mainboard directory (although boards are expected to just include the SoC default in most cases), which is the primary linker script for all stages (though not rmodules for now). It uses preprocessor macros from <memlayout.h> to form a different valid linker script for all stages while looking like a declarative, boilerplate-free map of memory addresses to the programmer. Linker asserts will automatically guarantee that the defined regions cannot overlap. Stages are defined with a maximum size that will be enforced by the linker. The file serves to both define and document the memory layout, so that the documentation cannot go missing or out of date.
The mechanism is implemented for all boards in the ARM, ARM64 and MIPS architectures, and should be extended onto all systems using SRAM in the future. The CAR/XIP environment on x86 has very different requirements and the layout is generally not as static, so it will stay like it is and be unaffected by this patch (save for aligning some symbol names for consistency and sharing the new common ramstage linker script include).
BUG=None TEST=Booted normally and in recovery mode, checked suspend/resume and the CBMEM console on Falco, Blaze (both normal and vboot2), Pinky and Pit. Compiled Ryu, Storm and Urara, manually compared the disassemblies with ToT and looked for red flags.
Change-Id: Ifd2276417f2036cbe9c056f17e42f051bcd20e81 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: f1e2028e7ebceeb2d71ff366150a37564595e614 Original-Change-Id: I005506add4e8fcdb74db6d5e6cb2d4cb1bd3cda5 Original-Signed-off-by: Julius Werner jwerner@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/213370 --- Makefile.inc | 5 + src/arch/arm/Makefile.inc | 9 +- src/arch/arm/armv4/bootblock.S | 20 +--- src/arch/arm/armv7/bootblock.S | 20 +--- src/arch/arm/armv7/mmu.c | 5 +- src/arch/arm/bootblock.ld | 62 ----------- src/arch/arm/include/arch/header.ld | 35 ++++++ src/arch/arm/include/arch/memlayout.h | 38 +++++++ src/arch/arm/include/arch/stages.h | 2 +- src/arch/arm/ramstage.ld | 137 ------------------------ src/arch/arm/romstage.ld | 80 -------------- src/arch/arm/stages.c | 8 +- src/arch/arm/verstage.ld | 67 ------------ src/arch/arm64/Makefile.inc | 6 +- src/arch/arm64/bootblock.ld | 65 ----------- src/arch/arm64/include/arch/header.ld | 33 ++++++ src/arch/arm64/include/arch/memlayout.h | 35 ++++++ src/arch/arm64/ramstage.ld | 122 --------------------- src/arch/arm64/romstage.ld | 88 --------------- src/arch/mips/Makefile.inc | 15 ++- src/arch/mips/bootblock.S | 6 +- src/arch/mips/bootblock.ld | 58 ---------- src/arch/mips/include/arch/header.ld | 33 ++++++ src/arch/mips/include/arch/memlayout.h | 31 ++++++ src/arch/mips/ramstage.ld | 122 --------------------- src/arch/mips/romstage.ld | 73 ------------- src/arch/mips/stages.c | 2 +- src/arch/x86/boot/boot.c | 6 +- src/arch/x86/init/romstage.ld | 8 +- src/arch/x86/lib/c_start.S | 2 +- src/arch/x86/ramstage.ld | 118 ++------------------ src/console/Kconfig | 10 -- src/cpu/x86/lapic/lapic_cpu_init.c | 1 + src/cpu/x86/mp_init.c | 1 + src/cpu/x86/smm/smm.ld | 4 +- src/cpu/x86/smm/smm_tseg.ld | 2 + src/include/lib.h | 5 - src/include/memlayout.h | 105 ++++++++++++++++++ src/include/symbols.h | 76 +++++++++++++ src/lib/Makefile.inc | 8 ++ src/lib/bootblock.ld | 48 +++++++++ src/lib/cbfs_spi.c | 5 +- src/lib/cbmem_console.c | 9 +- src/lib/loaders/load_and_run_payload.c | 1 + src/lib/ramstage.ld | 114 ++++++++++++++++++++ src/lib/rmodule.ld | 10 +- src/lib/romstage.ld | 58 ++++++++++ src/lib/selfboot.c | 9 +- src/mainboard/emulation/qemu-armv7/Kconfig | 35 ------ src/mainboard/emulation/qemu-armv7/Makefile.inc | 4 + src/mainboard/emulation/qemu-armv7/media.c | 3 +- src/mainboard/emulation/qemu-armv7/memlayout.ld | 47 ++++++++ src/mainboard/google/daisy/Makefile.inc | 4 + src/mainboard/google/daisy/mainboard.c | 14 ++- src/mainboard/google/daisy/memlayout.ld | 1 + src/mainboard/google/nyan/Kconfig | 8 -- src/mainboard/google/nyan/Makefile.inc | 4 + src/mainboard/google/nyan/mainboard.c | 5 +- src/mainboard/google/nyan/memlayout.ld | 1 + src/mainboard/google/nyan/romstage.c | 24 +++-- src/mainboard/google/nyan_big/Kconfig | 8 -- src/mainboard/google/nyan_big/Makefile.inc | 4 + src/mainboard/google/nyan_big/mainboard.c | 5 +- src/mainboard/google/nyan_big/memlayout.ld | 1 + src/mainboard/google/nyan_big/romstage.c | 24 +++-- src/mainboard/google/nyan_blaze/Kconfig | 8 -- src/mainboard/google/nyan_blaze/Makefile.inc | 5 + src/mainboard/google/nyan_blaze/mainboard.c | 5 +- src/mainboard/google/nyan_blaze/memlayout.ld | 1 + src/mainboard/google/nyan_blaze/romstage.c | 24 +++-- src/mainboard/google/peach_pit/Makefile.inc | 4 + src/mainboard/google/peach_pit/mainboard.c | 14 ++- src/mainboard/google/peach_pit/memlayout.ld | 1 + src/mainboard/google/rush/Makefile.inc | 4 + src/mainboard/google/rush/memlayout.ld | 1 + src/mainboard/google/rush_ryu/Makefile.inc | 4 + src/mainboard/google/rush_ryu/memlayout.ld | 1 + src/mainboard/google/storm/Kconfig | 8 -- src/mainboard/google/storm/Makefile.inc | 4 + src/mainboard/google/storm/mainboard.c | 11 +- src/mainboard/google/storm/memlayout.ld | 1 + src/mainboard/google/urara/Kconfig | 4 - src/mainboard/google/urara/Makefile.inc | 3 + src/mainboard/google/urara/memlayout.ld | 1 + src/mainboard/google/veyron_pinky/Kconfig | 8 -- src/mainboard/google/veyron_pinky/Makefile.inc | 5 + src/mainboard/google/veyron_pinky/mainboard.c | 5 +- src/mainboard/google/veyron_pinky/memlayout.ld | 1 + src/mainboard/google/veyron_pinky/romstage.c | 19 ++-- src/soc/imgtec/pistachio/Kconfig | 31 ------ src/soc/imgtec/pistachio/Makefile.inc | 2 +- src/soc/imgtec/pistachio/memlayout.ld | 38 +++++++ src/soc/nvidia/tegra124/Kconfig | 87 --------------- src/soc/nvidia/tegra124/Makefile.inc | 2 +- src/soc/nvidia/tegra124/bootblock_asm.S | 20 +--- src/soc/nvidia/tegra124/cbfs.c | 4 +- src/soc/nvidia/tegra124/clock.c | 3 +- src/soc/nvidia/tegra124/memlayout.ld | 48 +++++++++ src/soc/nvidia/tegra124/sdram.c | 3 +- src/soc/nvidia/tegra124/soc.c | 7 +- src/soc/nvidia/tegra124/verstage.c | 7 +- src/soc/nvidia/tegra132/Kconfig | 44 -------- src/soc/nvidia/tegra132/Makefile.inc | 2 +- src/soc/nvidia/tegra132/addressmap.c | 3 +- src/soc/nvidia/tegra132/bootblock_asm.S | 14 +-- src/soc/nvidia/tegra132/cbfs.c | 4 +- src/soc/nvidia/tegra132/memlayout.ld | 44 ++++++++ src/soc/nvidia/tegra132/romstage_asm.S | 14 +-- src/soc/nvidia/tegra132/stack.S | 18 ++-- src/soc/qualcomm/ipq806x/Kconfig | 40 ------- src/soc/qualcomm/ipq806x/Makefile.inc | 2 +- src/soc/qualcomm/ipq806x/cbmem.c | 4 +- src/soc/qualcomm/ipq806x/memlayout.ld | 40 +++++++ src/soc/qualcomm/ipq806x/soc.c | 7 +- src/soc/rockchip/rk3288/Kconfig | 59 ---------- src/soc/rockchip/rk3288/media.c | 15 +-- src/soc/rockchip/rk3288/memlayout.ld | 48 +++++++++ src/soc/samsung/exynos5250/Kconfig | 55 ---------- src/soc/samsung/exynos5250/alternate_cbfs.c | 28 ++--- src/soc/samsung/exynos5250/alternate_cbfs.h | 12 --- src/soc/samsung/exynos5250/cpu.h | 3 +- src/soc/samsung/exynos5250/memlayout.ld | 46 ++++++++ src/soc/samsung/exynos5420/Kconfig | 74 ------------- src/soc/samsung/exynos5420/alternate_cbfs.c | 28 ++--- src/soc/samsung/exynos5420/alternate_cbfs.h | 12 --- src/soc/samsung/exynos5420/cpu.h | 3 +- src/soc/samsung/exynos5420/memlayout.ld | 49 +++++++++ src/vendorcode/google/chromeos/Makefile.inc | 2 + src/vendorcode/google/chromeos/chromeos.c | 3 +- src/vendorcode/google/chromeos/memlayout.h | 47 ++++++++ src/vendorcode/google/chromeos/symbols.h | 32 ++++++ src/vendorcode/google/chromeos/verstage.ld | 58 ++++++++++ src/vendorcode/google/chromeos/verstub.c | 7 +- 133 files changed, 1410 insertions(+), 1770 deletions(-)
diff --git a/Makefile.inc b/Makefile.inc index 7abcbdf..ee4088a 100644 --- a/Makefile.inc +++ b/Makefile.inc @@ -458,6 +458,11 @@ tools: $(objutil)/kconfig/conf $(objutil)/cbfstool/cbfstool $(objutil)/cbfstool/ # Common recipes for all stages ###########################################################################
+# loadaddr can determine the load address of a stage, which may be needed for +# platform-specific image headers (only works *after* the stage has been built) +loadaddr = $(shell $(OBJDUMP_$(1)) -p $(objcbfs)/$(1).debug | \ + sed -ne '/LOAD/s/^.*vaddr 0x([0-9a-fA-F]{8}).*$$/0x\1/p') + # find-substr is required for stages like romstage_null and romstage_xip to # eliminate the _* part of the string find-substr = $(word 1,$(subst _, ,$(1))) diff --git a/src/arch/arm/Makefile.inc b/src/arch/arm/Makefile.inc index 25f764c..450cab9 100644 --- a/src/arch/arm/Makefile.inc +++ b/src/arch/arm/Makefile.inc @@ -64,7 +64,7 @@ bootblock-y += clock.c
$(objcbfs)/bootblock.debug: $(src)/arch/arm/bootblock.ld $(obj)/ldoptions $$(bootblock-objs) $$(VERSTAGE_LIB) @printf " LINK $(subst $(obj)/,,$(@))\n" - $(LD_bootblock) --gc-sections -static -o $@ -L$(obj) --start-group $(bootblock-objs) --end-group -T $(src)/arch/arm/bootblock.ld + $(LD_bootblock) --gc-sections -static -o $@ -L$(obj) --start-group $(bootblock-objs) --end-group -T $(src)/mainboard/$(MAINBOARDDIR)/memlayout.bootblock.ld
endif # CONFIG_ARCH_BOOTBLOCK_ARM
@@ -74,7 +74,7 @@ endif # CONFIG_ARCH_BOOTBLOCK_ARM
$(objcbfs)/verstage.debug: $$(verstage-objs) $(src)/arch/arm/verstage.ld $(obj)/ldoptions $$(VB2_LIB) @printf " LINK $(subst $(obj)/,,$(@))\n" - $(LD_verstage) --gc-sections -static -o $@ -L$(obj) --start-group $(verstage-objs) --end-group -T $(src)/arch/arm/verstage.ld + $(LD_verstage) --gc-sections -static -o $@ -L$(obj) --start-group $(verstage-objs) --end-group -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.verstage.ld
verstage-y += div0.c verstage-y += eabi_compat.c @@ -105,7 +105,7 @@ VBOOT_STUB_DEPS += $(obj)/arch/arm/eabi_compat.rmodules_arm.o
$(objcbfs)/romstage.debug: $$(romstage-objs) $(src)/arch/arm/romstage.ld $(obj)/ldoptions @printf " LINK $(subst $(obj)/,,$(@))\n" - $(LD_romstage) -nostdlib --gc-sections -static -o $@ -L$(obj) --start-group $(romstage-objs) --end-group -T $(src)/arch/arm/romstage.ld + $(LD_romstage) -nostdlib --gc-sections -static -o $@ -L$(obj) --start-group $(romstage-objs) --end-group -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.romstage.ld
endif # CONFIG_ARCH_ROMSTAGE_ARM
@@ -125,6 +125,7 @@ ramstage-y += memset.S ramstage-y += memcpy.S ramstage-y += memmove.S ramstage-y += clock.c + rmodules_arm-y += memset.S rmodules_arm-y += memcpy.S rmodules_arm-y += memmove.S @@ -137,6 +138,6 @@ $(objcbfs)/ramstage.debug: $$(ramstage-objs) $(src)/arch/arm/ramstage.ld $(obj)/
$(objgenerated)/ramstage.o: $(stages_o) $$(ramstage-objs) @printf " CC $(subst $(obj)/,,$(@))\n" - $(LD_ramstage) -nostdlib --gc-sections -r -o $@ --start-group $(ramstage-objs) --end-group + $(LD_ramstage) -nostdlib --gc-sections -r -o $@ --start-group $(ramstage-objs) --end-group -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.ramstage.ld
endif # CONFIG_ARCH_RAMSTAGE_ARM diff --git a/src/arch/arm/armv4/bootblock.S b/src/arch/arm/armv4/bootblock.S index e4d4302..1a30dda 100644 --- a/src/arch/arm/armv4/bootblock.S +++ b/src/arch/arm/armv4/bootblock.S @@ -44,10 +44,8 @@ ENTRY(_start) * Initialize the stack to a known value. This is used to check for * stack overflow later in the boot process. */ - ldr r0, .Stack - ldr r1, .Stack_size - sub r0, r0, r1 - ldr r1, .Stack + ldr r0, =_stack + ldr r1, =_estack ldr r2, =0xdeadbeef init_stack_loop: str r2, [r0] @@ -57,7 +55,7 @@ init_stack_loop:
/* Set stackpointer in internal RAM to call bootblock main() */ call_bootblock: - ldr sp, .Stack /* Set up stack pointer */ + ldr sp, =_estack /* Set up stack pointer */ ldr r0,=0x00000000 /* * The current design of cpu_info places the @@ -75,15 +73,3 @@ call_bootblock: */ bl main ENDPROC(_start) - -/* we do it this way because it's a 32-bit constant and - * in some cases too far away to be loaded as just an offset - * from IP - */ -.align 2 -.Stack: - .word CONFIG_STACK_TOP -.align 2 -/* create this size the same way we do in coreboot_ram.ld: top-bottom */ -.Stack_size: - .word CONFIG_STACK_TOP - CONFIG_STACK_BOTTOM diff --git a/src/arch/arm/armv7/bootblock.S b/src/arch/arm/armv7/bootblock.S index a15d167..b468e15 100644 --- a/src/arch/arm/armv7/bootblock.S +++ b/src/arch/arm/armv7/bootblock.S @@ -62,10 +62,8 @@ ENTRY(_thumb_start) * Initialize the stack to a known value. This is used to check for * stack overflow later in the boot process. */ - ldr r0, .Stack - ldr r1, .Stack_size - sub r0, r0, r1 - ldr r1, .Stack + ldr r0, =_stack + ldr r1, =_estack ldr r2, =0xdeadbeef init_stack_loop: str r2, [r0] @@ -75,7 +73,7 @@ init_stack_loop:
/* Set stackpointer in internal RAM to call bootblock main() */ call_bootblock: - ldr sp, .Stack /* Set up stack pointer */ + ldr sp, =_estack /* Set up stack pointer */ ldr r0,=0x00000000 /* * The current design of cpu_info places the struct at the top of the @@ -89,15 +87,3 @@ wait_for_interrupt: wfi mov pc, lr @ back to my caller ENDPROC(_thumb_start) - -/* we do it this way because it's a 32-bit constant and - * in some cases too far away to be loaded as just an offset - * from IP - */ -.align 2 -.Stack: - .word CONFIG_STACK_TOP -.align 2 -/* create this size the same way we do in coreboot_ram.ld: top-bottom */ -.Stack_size: - .word CONFIG_STACK_TOP - CONFIG_STACK_BOTTOM diff --git a/src/arch/arm/armv7/mmu.c b/src/arch/arm/armv7/mmu.c index bd12946..e9c6815 100644 --- a/src/arch/arm/armv7/mmu.c +++ b/src/arch/arm/armv7/mmu.c @@ -31,6 +31,7 @@ #include <config.h> #include <stdlib.h> #include <stdint.h> +#include <symbols.h>
#include <cbmem.h> #include <console/console.h> @@ -90,7 +91,7 @@ typedef uint32_t pmd_t; static const unsigned int denom = 1; #endif /* CONFIG_ARM_LPAE */
-static pmd_t *const ttb_buff = (pmd_t *)CONFIG_TTB_BUFFER; +static pmd_t *const ttb_buff = (pmd_t *)_ttb;
/* * mask/shift/size for pages and blocks @@ -186,7 +187,7 @@ void mmu_config_range(unsigned long start_mb, unsigned long size_mb, void mmu_init(void) { if (CONFIG_ARM_LPAE) { - pgd_t *const pgd_buff = (pgd_t*)(CONFIG_TTB_BUFFER + 16*KiB); + pgd_t *const pgd_buff = (pgd_t*)(_ttb + 16*KiB); pmd_t *pmd = ttb_buff; int i;
diff --git a/src/arch/arm/bootblock.ld b/src/arch/arm/bootblock.ld deleted file mode 100644 index 23d66f1..0000000 --- a/src/arch/arm/bootblock.ld +++ /dev/null @@ -1,62 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2006 Advanced Micro Devices, Inc. - * Copyright (C) 2008-2010 coresystems GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -INCLUDE ldoptions - -PHDRS -{ - to_load PT_LOAD; -} - -ENTRY(_start) -TARGET(binary) -SECTIONS -{ - . = CONFIG_BOOTBLOCK_BASE; - - .bootblock . : { - *(.text._start); - KEEP(*(.id)); - *(.text); - *(.text.*); - *(.rodata); - *(.rodata.*); - *(.data); - *(.data.*); - *(.bss); - *(.bss.*); - *(.sbss); - *(.sbss.*); - _end = .; - } : to_load = 0xff - - preram_cbmem_console = CONFIG_CONSOLE_PRERAM_BUFFER_BASE; - - /DISCARD/ : { - *(.comment) - *(.note) - *(.comment.*) - *(.note.*) - *(.ARM.*) - } -} diff --git a/src/arch/arm/include/arch/header.ld b/src/arch/arm/include/arch/header.ld new file mode 100644 index 0000000..b90795f --- /dev/null +++ b/src/arch/arm/include/arch/header.ld @@ -0,0 +1,35 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* We use ELF as output format. So that we can debug the code in some form. */ +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +INCLUDE ldoptions + +PHDRS +{ + to_load PT_LOAD; +} + +#ifdef __BOOTBLOCK__ +ENTRY(_start) +TARGET(binary) +#else +ENTRY(stage_entry) +#endif diff --git a/src/arch/arm/include/arch/memlayout.h b/src/arch/arm/include/arch/memlayout.h new file mode 100644 index 0000000..9f5b383 --- /dev/null +++ b/src/arch/arm/include/arch/memlayout.h @@ -0,0 +1,38 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file contains macro definitions for memlayout.ld linker scripts. */ + +#ifndef __ARCH_MEMLAYOUT_H +#define __ARCH_MEMLAYOUT_H + +#define TTB(addr, size) \ + REGION(ttb, addr, size, 16K) \ + _ = ASSERT(size >= 16K + IS_ENABLED(CONFIG_ARM_LPAE) * 32, \ + "TTB must be 16K (+ 32 for LPAE)!"); + +/* ARM stacks need 8-byte alignment and stay in one place through ramstage. */ +#define STACK(addr, size) REGION(stack, addr, size, 8) + +#define DMA_COHERENT(addr, size) \ + REGION(dma_coherent, addr, size, (1 + IS_ENABLED(CONFIG_ARM_LPAE)) * 1M) \ + _ = ASSERT(size % ((1 + IS_ENABLED(CONFIG_ARM_LPAE)) * 1M) == 0, \ + "DMA coherency buffer must fit exactly in full superpages!"); + +#endif /* __ARCH_MEMLAYOUT_H */ diff --git a/src/arch/arm/include/arch/stages.h b/src/arch/arm/include/arch/stages.h index 39fed99..1a0dcc1 100644 --- a/src/arch/arm/include/arch/stages.h +++ b/src/arch/arm/include/arch/stages.h @@ -22,7 +22,7 @@
extern void main(void);
-void stage_entry(void) __attribute__((section(".text.stage_entry.arm"))); +void stage_entry(void); void stage_exit(void *);
#endif diff --git a/src/arch/arm/ramstage.ld b/src/arch/arm/ramstage.ld deleted file mode 100644 index 5e0607d..0000000 --- a/src/arch/arm/ramstage.ld +++ /dev/null @@ -1,137 +0,0 @@ -/* - * Memory map: - * - * CONFIG_RAMSTAGE_BASE : text segment - * : rodata segment - * : data segment - * : bss segment - * : stack - * : heap - */ -/* - * Bootstrap code for the STPC Consumer - * Copyright (c) 1999 by Net Insight AB. All Rights Reserved. - */ - -/* - * Written by Johan Rydberg, based on work by Daniel Kahlin. - * Rewritten by Eric Biederman - * 2005.12 yhlu add ramstage cross the vga font buffer handling - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ -INCLUDE ldoptions - -ENTRY(stage_entry) - -PHDRS -{ - to_load PT_LOAD; -} - -SECTIONS -{ - . = CONFIG_RAMSTAGE_BASE; - /* First we place the code and read only data (typically const declared). - * This could theoretically be placed in rom. - */ - .text : { - _text = .; - _start = .; - *(.text.stage_entry.arm); - *(.text); - *(.text.*); - . = ALIGN(16); - _etext = .; - } : to_load - - .ctors : { - . = ALIGN(0x100); - __CTOR_LIST__ = .; - KEEP(*(.ctors)); - LONG(0); - __CTOR_END__ = .; - } - - .rodata : { - _rodata = .; - . = ALIGN(4); - pci_drivers = . ; - KEEP(*(.rodata.pci_driver)); - epci_drivers = . ; - cpu_drivers = . ; - KEEP(*(.rodata.cpu_driver)); - ecpu_drivers = . ; - _bs_init_begin = .; - KEEP(*(.bs_init)); - LONG(0); - _bs_init_end = .; - *(.rodata) - *(.rodata.*) - /* kevinh/Ispiri - Added an align, because the objcopy tool - * incorrectly converts sections that are not long word aligned. - */ - . = ALIGN(4); - - _erodata = .; - } - /* After the code we place initialized data (typically initialized - * global variables). This gets copied into ram by startup code. - * __data_start and __data_end shows where in ram this should be placed, - * whereas __data_loadstart and __data_loadend shows where in rom to - * copy from. - */ - .data : { - _data = .; - *(.data) - *(.data.*) - _edata = .; - } - - /* bss does not contain data, it is just a space that should be zero - * initialized on startup. (typically uninitialized global variables) - * crt0.S fills between _bss and _ebss with zeroes. - */ - .bss . : { - _bss = .; - *(.bss) - *(.bss.*) - *(.sbss) - *(.sbss.*) - _ebss = .; - } - _end = .; - - /* coreboot really "ends" here. Only heap and stack are placed after - * this line. - */ - - .heap . : { - _heap = .; - /* Reserve CONFIG_HEAP_SIZE bytes for the heap */ - . = CONFIG_HEAP_SIZE ; - . = ALIGN(4); - _eheap = .; - } - - /* The ram segment. This includes all memory used by the memory - * resident copy of coreboot, except the tables that are produced on - * the fly, but including stack and heap. - */ - _ram_seg = _text; - _eram_seg = _eheap; - - /* The stack lives in SRAM in a different location, so keep - * it out of ram_seg - */ - _stack = CONFIG_STACK_BOTTOM; - _estack = CONFIG_STACK_TOP; - - /* Discard the sections we don't need/want */ - - /DISCARD/ : { - *(.comment) - *(.note) - *(.note.*) - } -} diff --git a/src/arch/arm/romstage.ld b/src/arch/arm/romstage.ld deleted file mode 100644 index 873b8e0..0000000 --- a/src/arch/arm/romstage.ld +++ /dev/null @@ -1,80 +0,0 @@ -/* - * Memory map: - * - * CONFIG_ROMSTAGE_BASE : text segment - * : rodata segment - * : data segment - * : bss segment - * : stack - * : heap - */ -/* - * Bootstrap code for the STPC Consumer - * Copyright (c) 1999 by Net Insight AB. All Rights Reserved. - */ - -/* - * Written by Johan Rydberg, based on work by Daniel Kahlin. - * Rewritten by Eric Biederman - * 2005.12 yhlu add ramstage cross the vga font buffer handling - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -INCLUDE ldoptions - -ENTRY(stage_entry) - -PHDRS -{ - to_load PT_LOAD; -} - -SECTIONS -{ - . = CONFIG_ROMSTAGE_BASE; - - .romtext . : { - _start = .; - *(.text.stage_entry.arm); - *(.text.startup); - *(.text); - *(.text.*); - } : to_load - - .romdata . : { - *(.rodata); - *(.rodata.*); - *(.data); - *(.data.*); - . = ALIGN(8); - } - - /* bss does not contain data, it is just a space that should be zero - * initialized on startup. (typically uninitialized global variables) - * crt0.S fills between _bss and _ebss with zeroes. - */ - .bss . : { - . = ALIGN(8); - _bss = .; - *(.bss) - *(.bss.*) - *(.sbss) - *(.sbss.*) - _ebss = .; - } - - _end = .; - - preram_cbmem_console = CONFIG_CONSOLE_PRERAM_BUFFER_BASE; - - /* Discard the sections we don't need/want */ - /DISCARD/ : { - *(.comment) - *(.note) - *(.comment.*) - *(.note.*) - *(.eh_frame); - } -} diff --git a/src/arch/arm/stages.c b/src/arch/arm/stages.c index 47f13fa..11acc9b 100644 --- a/src/arch/arm/stages.c +++ b/src/arch/arm/stages.c @@ -22,10 +22,10 @@ * execution (bootblock entry and ramstage exit will depend on external * loading). * - * Entry points must be placed at the location the previous stage jumps - * to (the lowest address in the stage image). This is done by giving - * stage_entry() its own section in .text and placing it first in the - * linker script. + * Entry points should be set in the linker script and honored by CBFS, + * so text section layout shouldn't matter. Still, it doesn't hurt to put + * stage_entry first (which XXXstage.ld will do automatically through the + * .text.stage_entry section created by -ffunction-sections). */
#include <arch/stages.h> diff --git a/src/arch/arm/verstage.ld b/src/arch/arm/verstage.ld deleted file mode 100644 index f0e88e5..0000000 --- a/src/arch/arm/verstage.ld +++ /dev/null @@ -1,67 +0,0 @@ -/* - * Memory map: - * - * CONFIG_VERSTAGE_BASE : text segment - * : rodata segment - * : data segment - * : bss segment - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -INCLUDE ldoptions - -PHDRS -{ - to_load PT_LOAD; -} - -ENTRY(stage_entry) - -SECTIONS -{ - . = CONFIG_VERSTAGE_BASE; - - .romtext . : { - _start = .; - *(.text.stage_entry.arm); - *(.text.startup); - *(.text); - *(.text.*); - } : to_load - - .romdata . : { - *(.rodata); - *(.rodata.*); - *(.data); - *(.data.*); - . = ALIGN(8); - } - - /* bss does not contain data, it is just a space that should be zero - * initialized on startup. (typically uninitialized global variables) - */ - .bss . : { - . = ALIGN(8); - _bss = .; - *(.bss) - *(.bss.*) - *(.sbss) - *(.sbss.*) - _ebss = .; - } - - _end = .; - - preram_cbmem_console = CONFIG_CONSOLE_PRERAM_BUFFER_BASE; - - /* Discard the sections we don't need/want */ - /DISCARD/ : { - *(.comment) - *(.note) - *(.comment.*) - *(.note.*) - *(.eh_frame); - } -} diff --git a/src/arch/arm64/Makefile.inc b/src/arch/arm64/Makefile.inc index 6d23dab..9895e64 100644 --- a/src/arch/arm64/Makefile.inc +++ b/src/arch/arm64/Makefile.inc @@ -71,7 +71,7 @@ bootblock-y += ../../lib/memmove.c
$(objcbfs)/bootblock.debug: $(src)/arch/arm64/bootblock.ld $(obj)/ldoptions $$(bootblock-objs) $(obj)/config.h @printf " LINK $(subst $(obj)/,,$(@))\n" - $(LD_bootblock) --gc-sections -static -o $@ -L$(obj) --start-group $(bootblock-objs) --end-group -T $(src)/arch/arm64/bootblock.ld + $(LD_bootblock) --gc-sections -static -o $@ -L$(obj) --start-group $(bootblock-objs) --end-group -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.bootblock.ld
endif # CONFIG_ARCH_BOOTBLOCK_ARM64
@@ -102,7 +102,7 @@ VBOOT_STUB_DEPS += $(obj)/arch/arm/eabi_compat.rmodules_arm64.o
$(objcbfs)/romstage.debug: $$(romstage-objs) $(src)/arch/arm64/romstage.ld $(obj)/ldoptions @printf " LINK $(subst $(obj)/,,$(@))\n" - $(LD_romstage) -nostdlib --gc-sections -static -o $@ -L$(obj) --start-group $(romstage-objs) --end-group -T $(src)/arch/arm64/romstage.ld + $(LD_romstage) -nostdlib --gc-sections -static -o $@ -L$(obj) --start-group $(romstage-objs) --end-group -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.romstage.ld
endif # CONFIG_ARCH_ROMSTAGE_ARM64
@@ -149,6 +149,6 @@ $(objcbfs)/ramstage.debug: $$(ramstage-objs) $(src)/arch/arm64/ramstage.ld $(obj
endif # CONFIG_ARCH_RAMSTAGE_ARM64 diff --git a/src/arch/arm64/bootblock.ld b/src/arch/arm64/bootblock.ld deleted file mode 100644 index 775111b..0000000 --- a/src/arch/arm64/bootblock.ld +++ /dev/null @@ -1,65 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2006 Advanced Micro Devices, Inc. - * Copyright (C) 2008-2010 coresystems GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ -OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") -OUTPUT_ARCH(aarch64) -INCLUDE ldoptions - -PHDRS -{ - to_load PT_LOAD; -} - -ENTRY(stage_entry) -TARGET(binary) -SECTIONS -{ - . = CONFIG_BOOTBLOCK_BASE; - - .bootblock . : { - *(.text.stage_entry); - KEEP(*(.id)); - *(.text); - *(.text.*); - *(.rodata); - *(.rodata.*); - *(.data); - *(.data.*); - *(.bss); - *(.bss.*); - *(.sbss); - *(.sbss.*); - } : to_load = 0xff - - /* arm64 chipsets need to define CONFIG_BOOTBLOCK_STACK_(TOP|BOTTOM) */ - _stack = CONFIG_BOOTBLOCK_STACK_BOTTOM; - _estack = CONFIG_BOOTBLOCK_STACK_TOP; - - preram_cbmem_console = CONFIG_CONSOLE_PRERAM_BUFFER_BASE; - - /DISCARD/ : { - *(.comment) - *(.note) - *(.comment.*) - *(.note.*) - *(.ARM.*) - } -} diff --git a/src/arch/arm64/include/arch/header.ld b/src/arch/arm64/include/arch/header.ld new file mode 100644 index 0000000..5867732 --- /dev/null +++ b/src/arch/arm64/include/arch/header.ld @@ -0,0 +1,33 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* We use ELF as output format. So that we can debug the code in some form. */ +OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") +OUTPUT_ARCH(aarch64) +INCLUDE ldoptions + +PHDRS +{ + to_load PT_LOAD; +} + +#ifdef __BOOTBLOCK__ +TARGET(binary) +#endif +ENTRY(stage_entry) diff --git a/src/arch/arm64/include/arch/memlayout.h b/src/arch/arm64/include/arch/memlayout.h new file mode 100644 index 0000000..328156b --- /dev/null +++ b/src/arch/arm64/include/arch/memlayout.h @@ -0,0 +1,35 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file contains macro definitions for memlayout.ld linker scripts. */ + +#ifndef __ARCH_MEMLAYOUT_H +#define __ARCH_MEMLAYOUT_H + +/* TODO: add SRAM TTB region and figure out the correct size/alignment for it */ + +/* ARM64 stacks need 16-byte alignment. The ramstage will set up its own stacks + * in BSS, so this is only used for the SRAM stages. */ +#ifdef __PRE_RAM__ +#define STACK(addr, size) REGION(stack, addr, size, 16) +#else +#define STACK(addr, size) REGION(preram_stack, addr, size, 16) +#endif + +#endif /* __ARCH_MEMLAYOUT_H */ diff --git a/src/arch/arm64/ramstage.ld b/src/arch/arm64/ramstage.ld deleted file mode 100644 index d767778..0000000 --- a/src/arch/arm64/ramstage.ld +++ /dev/null @@ -1,122 +0,0 @@ -/* - * Memory map: - * - * CONFIG_RAMBASE : text segment - * : rodata segment - * : data segment - * : bss segment - * : stack - * : heap - */ -/* - * Copyright 2013 Google Inc. - * Bootstrap code for the STPC Consumer - * Copyright (c) 1999 by Net Insight AB. All Rights Reserved. - */ - -/* - * Written by Johan Rydberg, based on work by Daniel Kahlin. - * Rewritten by Eric Biederman - * 2005.12 yhlu add ramstage cross the vga font buffer handling - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ -INCLUDE ldoptions - -ENTRY(stage_entry) - -PHDRS -{ - to_load PT_LOAD; -} - -SECTIONS -{ - . = CONFIG_RAMSTAGE_BASE; - - .text : { - _text = .; - _start = .; - *(.text.stage_entry); - *(.text); - *(.text.*); - . = ALIGN(16); - _etext = .; - } : to_load - - .ctors : { - . = ALIGN(0x100); - __CTOR_LIST__ = .; - KEEP(*(.ctors)); - LONG(0); - LONG(0); - __CTOR_END__ = .; - } - - .rodata : { - . = ALIGN(64); - _rodata = .; - console_drivers = .; - KEEP(*(.rodata.console_drivers)); - econsole_drivers = . ; - . = ALIGN(64); - pci_drivers = . ; - KEEP(*(.rodata.pci_driver)); - epci_drivers = . ; - cpu_drivers = . ; - KEEP(*(.rodata.cpu_driver)); - ecpu_drivers = . ; - _bs_init_begin = .; - KEEP(*(.bs_init)); - LONG(0); - LONG(0); - _bs_init_end = .; - . = ALIGN(64); - *(.rodata) - *(.rodata.*) - _erodata = .; - } - - .data : { - . = ALIGN(64); - _data = .; - *(.data) - *(.data.*) - . = ALIGN(64); - _edata = .; - } - - .bss : { - . = ALIGN(64); - _bss = .; - *(.bss) - *(.bss.*) - *(.sbss.*) - *(COMMON) - . = ALIGN(64); - _ebss = .; - } - - .heap : { - _heap = .; - /* Reserve CONFIG_HEAP_SIZE bytes for the heap */ - . = . + CONFIG_HEAP_SIZE ; - . = ALIGN(64); - _eheap = .; - } - - /* The ram segment. This includes all memory used by the memory - * resident copy of coreboot, except the tables that are produced on - * the fly, but including stack and heap. - */ - _ram_seg = _text; - _eram_seg = _eheap; - - /* Discard the sections we don't need/want */ - - /DISCARD/ : { - *(.comment) - *(.note) - *(.note.*) - } -} diff --git a/src/arch/arm64/romstage.ld b/src/arch/arm64/romstage.ld deleted file mode 100644 index c56d5ad..0000000 --- a/src/arch/arm64/romstage.ld +++ /dev/null @@ -1,88 +0,0 @@ -/* - * Memory map: - * - * CONFIG_ROMSTAGE_BASE : text segment - * : rodata segment - * : data segment - * : bss segment - * : stack - * : heap - */ -/* - * Bootstrap code for the STPC Consumer - * Copyright (c) 1999 by Net Insight AB. All Rights Reserved. - */ - -/* - * Written by Johan Rydberg, based on work by Daniel Kahlin. - * Rewritten by Eric Biederman - * 2005.12 yhlu add ramstage cross the vga font buffer handling - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ -OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") -OUTPUT_ARCH(aarch64) -INCLUDE ldoptions - -PHDRS -{ - to_load PT_LOAD; -} - -ENTRY(stage_entry) - -SECTIONS -{ - . = CONFIG_ROMSTAGE_BASE; - - .romtext . : { - _start = .; - *(.text.stage_entry); - *(.text.startup); - *(.text); - *(.text.*); - } : to_load - - .romdata . : { - *(.rodata); - *(.rodata.*); - *(.machine_param); - *(.data); - *(.data.*); - . = ALIGN(8); - _erom = .; - } - - __image_copy_end = .; - - /* bss does not contain data, it is just a space that should be zero - * initialized on startup. (typically uninitialized global variables) - * crt0.S fills between _bss and _ebss with zeroes. - */ - .bss . : { - . = ALIGN(8); - _bss = .; - *(.bss) - *(.bss.*) - *(.sbss) - *(.sbss.*) - _ebss = .; - } - - _end = .; - - /* arm64 chipsets need to define CONFIG_ROMSTAGE_STACK_(TOP|BOTTOM) */ - _stack = CONFIG_ROMSTAGE_STACK_BOTTOM; - _estack = CONFIG_ROMSTAGE_STACK_TOP; - - preram_cbmem_console = CONFIG_CONSOLE_PRERAM_BUFFER_BASE; - - /* Discard the sections we don't need/want */ - /DISCARD/ : { - *(.comment) - *(.note) - *(.comment.*) - *(.note.*) - *(.eh_frame); - } -} diff --git a/src/arch/mips/Makefile.inc b/src/arch/mips/Makefile.inc index 159d0e0..ca8519b 100644 --- a/src/arch/mips/Makefile.inc +++ b/src/arch/mips/Makefile.inc @@ -43,17 +43,15 @@ bootblock-y += ../../lib/memcpy.c bootblock-y += ../../lib/memmove.c bootblock-y += ../../lib/memset.c
-bootblock-y += bootblock.ld - # Much of the assembly code is generated by the compiler, and may contain # terms which the preprocessor will happily go on to replace. For example # "mips" would be replaced with "1". Clear all the built in definitions to # prevent that. bootblock-S-ccopts += -undef
-$(objcbfs)/bootblock.debug: $(src)/arch/mips/bootblock.ld $$(bootblock-objs) $(obj)/config.h $(obj)/ldoptions +$(objcbfs)/bootblock.debug: $$(bootblock-objs) $(obj)/config.h $(obj)/ldoptions $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.bootblock.ld @printf " LINK $(subst $(obj)/,,$(@))\n" - $(LD_bootblock) --gc-sections -static -o $@ -L$(obj) -T $(src)/arch/mips/bootblock.ld --start-group $(bootblock-objs) --end-group + $(LD_bootblock) --gc-sections -static -o $@ -L$(obj) -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.bootblock.ld --start-group $(bootblock-objs) --end-group
endif # CONFIG_ARCH_BOOTBLOCK_MIPS
@@ -71,9 +69,9 @@ romstage-y += ../../lib/memcpy.c romstage-y += ../../lib/memmove.c romstage-y += ../../lib/memset.c
-$(objcbfs)/romstage.debug: $$(romstage-objs) $(src)/arch/mips/romstage.ld $(obj)/ldoptions +$(objcbfs)/romstage.debug: $$(romstage-objs) $(obj)/ldoptions $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.romstage.ld @printf " LINK $(subst $(obj)/,,$(@))\n" - $(LD_romstage) --gc-sections -static -o $@ -L$(obj) -T $(src)/arch/mips/romstage.ld --start-group $(romstage-objs) --end-group + $(LD_romstage) --gc-sections -static -o $@ -L$(obj) -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.romstage.ld --start-group $(romstage-objs) --end-group
endif # CONFIG_ARCH_ROMSTAGE_MIPS
@@ -91,10 +89,11 @@ ramstage-y += timer.c ramstage-y += ../../lib/memcpy.c ramstage-y += ../../lib/memmove.c ramstage-y += ../../lib/memset.c + ramstage-srcs += $(wildcard src/mainboard/$(MAINBOARDDIR)/mainboard.c)
-$(objcbfs)/ramstage.debug: $$(ramstage-objs) $(src)/arch/mips/ramstage.ld $(obj)/ldoptions +$(objcbfs)/ramstage.debug: $$(ramstage-objs) $(obj)/ldoptions $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.ramstage.ld @printf " CC $(subst $(obj)/,,$(@))\n" - $(LD_ramstage) --gc-sections -static -o $@ -L$(obj) -T $(src)/arch/mips/ramstage.ld --start-group $(ramstage-objs) --end-group + $(LD_ramstage) --gc-sections -static -o $@ -L$(obj) -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.ramstage.ld --start-group $(ramstage-objs) --end-group
endif # CONFIG_ARCH_RAMSTAGE_MIPS diff --git a/src/arch/mips/bootblock.S b/src/arch/mips/bootblock.S index dbde803..3eb93b4 100644 --- a/src/arch/mips/bootblock.S +++ b/src/arch/mips/bootblock.S @@ -19,17 +19,17 @@
.set noreorder /* Prevent assembler from "optimizing" this code. */
-.section ".start", "ax", %progbits +.section ".text._start", "ax", %progbits .globl _start _start: /* Set the stack pointer */ - li $sp, CONFIG_BOOTBLOCK_STACK_TOP + la $sp, _estack
/* * Initialise the stack to a known value, used later to check for * overflow. */ - li $t0, CONFIG_BOOTBLOCK_STACK_BOTTOM + la $t0, _stack addi $t1, $sp, -4 li $t2, 0xdeadbeef 1: sw $t2, 0($t0) diff --git a/src/arch/mips/bootblock.ld b/src/arch/mips/bootblock.ld deleted file mode 100644 index 8e1b1e3..0000000 --- a/src/arch/mips/bootblock.ld +++ /dev/null @@ -1,58 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2006 Advanced Micro Devices, Inc. - * Copyright (C) 2008-2010 coresystems GmbH - * Copyright (C) 2014 Imagination Technologies - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -OUTPUT_ARCH(mips) -INCLUDE ldoptions - -ENTRY(_start) - -PHDRS -{ - to_load PT_LOAD; -} - -preram_cbmem_console = CONFIG_CBMEM_CONSOLE_PRERAM_BASE; - -SECTIONS -{ - . = CONFIG_BOOTBLOCK_BASE; - - /* This section might be better named .setup */ - .rom : { - _rom = .; - *(.start); - *(.id); - *(.text); - *(.text.*); - *(.rom.text); - *(.rom.data); - *(.rom.data.*); - *(.rodata.*); - _erom = .; - } : to_load = 0xff - - /DISCARD/ : { - *(.comment) - *(.note) - *(.comment.*) - *(.note.*) - } -} diff --git a/src/arch/mips/include/arch/header.ld b/src/arch/mips/include/arch/header.ld new file mode 100644 index 0000000..9607453 --- /dev/null +++ b/src/arch/mips/include/arch/header.ld @@ -0,0 +1,33 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* We use ELF as output format. So that we can debug the code in some form. */ +OUTPUT_ARCH(mips) +INCLUDE ldoptions + +PHDRS +{ + to_load PT_LOAD; +} + +#ifdef __BOOTBLOCK__ +ENTRY(_start) +#else +ENTRY(stage_entry) +#endif diff --git a/src/arch/mips/include/arch/memlayout.h b/src/arch/mips/include/arch/memlayout.h new file mode 100644 index 0000000..4cbbe1d --- /dev/null +++ b/src/arch/mips/include/arch/memlayout.h @@ -0,0 +1,31 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file contains macro definitions for memlayout.ld linker scripts. */ + +#ifndef __ARCH_MEMLAYOUT_H +#define __ARCH_MEMLAYOUT_H + +/* MIPS stacks need 8-byte alignment and stay in one place through ramstage. */ +/* TODO: Double-check that that's the correct alignment for our ABI. */ +#define STACK(addr, size) REGION(stack, addr, size, 8) + +/* TODO: Need to add DMA_COHERENT region like on ARM? */ + +#endif /* __ARCH_MEMLAYOUT_H */ diff --git a/src/arch/mips/ramstage.ld b/src/arch/mips/ramstage.ld deleted file mode 100644 index cba90eb..0000000 --- a/src/arch/mips/ramstage.ld +++ /dev/null @@ -1,122 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2014 Imagination Technologies - * - * Based on src/arch/arm/ramstage.ld: - * Written by Johan Rydberg, based on work by Daniel Kahlin. - * Rewritten by Eric Biederman - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - */ - -OUTPUT_ARCH(mips) -INCLUDE ldoptions - -ENTRY(stage_entry) - -PHDRS -{ - to_load PT_LOAD; -} - -SECTIONS -{ - . = CONFIG_SYS_SDRAM_BASE; - - .text : { - _text = .; - _start = .; - *(.text.stage_entry.mips); - *(.text); - *(.text.*); - . = ALIGN(16); - _etext = .; - } : to_load - - .ctors : { - . = ALIGN(0x100); - __CTOR_LIST__ = .; - *(.ctors); - LONG(0); - __CTOR_END__ = .; - } - - .rodata : { - _rodata = .; - . = ALIGN(4); - console_drivers = .; - KEEP(*(.rodata.console_drivers)); - econsole_drivers = . ; - . = ALIGN(4); - pci_drivers = . ; - KEEP(*(.rodata.pci_driver)); - epci_drivers = . ; - cpu_drivers = . ; - KEEP(*(.rodata.cpu_driver)); - ecpu_drivers = . ; - _bs_init_begin = .; - KEEP(*(.bs_init)); - _bs_init_end = .; - *(.rodata) - *(.rodata.*) - . = ALIGN(4); - _erodata = .; - } - - .data : { - _data = .; - *(.data) - _edata = .; - } - - /* bss will be cleared by cbfs_load_stage */ - _bss = .; - .bss . : { - *(.bss) - *(.sbss) - *(COMMON) - } - _ebss = .; - _end = .; - - /* - * coreboot from the perspective of the loader really "ends" - * here. Only symbols are placed after this. - */ - - _heap = .; - _eheap = . + CONFIG_HEAP_SIZE; - - _stack = CONFIG_STACK_BOTTOM; - _estack = CONFIG_STACK_TOP; - - /* - * The ram segment. This includes all memory used by the memory - * resident copy of coreboot, except the tables that are produced on - * the fly, but including stack and heap. - */ - _ram_seg = _text; - _eram_seg = _eheap; - - /* Discard the sections we don't need/want */ - - /DISCARD/ : { - *(.comment) - *(.note) - *(.note.*) - } -} diff --git a/src/arch/mips/romstage.ld b/src/arch/mips/romstage.ld deleted file mode 100644 index f776bc8..0000000 --- a/src/arch/mips/romstage.ld +++ /dev/null @@ -1,73 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2014 Imagination Technologies - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - */ - -OUTPUT_ARCH(mips) -INCLUDE ldoptions - -ENTRY(stage_entry) - -PHDRS -{ - to_load PT_LOAD; -} - -preram_cbmem_console = CONFIG_CBMEM_CONSOLE_PRERAM_BASE; - -SECTIONS -{ - . = CONFIG_ROMSTAGE_BASE; - - .romtext . : { - _rom = .; - _start = .; - *(.text.stage_entry.mips); - *(.text.startup); - *(.text); - } : to_load - - .romdata . : { - *(.rodata); - *(.data); - . = ALIGN(16); - _erom = .; - } - - /* bss will be cleared by cbfs_load_stage */ - .bss . : { - . = ALIGN(8); - _bss = .; - *(.bss) - *(.sbss) - *(COMMON) - } - - _ebss = .; - _end = .; - - /* Discard the sections we don't need/want */ - /DISCARD/ : { - *(.comment) - *(.note) - *(.comment.*) - *(.note.*) - *(.eh_frame); - } -} diff --git a/src/arch/mips/stages.c b/src/arch/mips/stages.c index ae10594..79b2ea4 100644 --- a/src/arch/mips/stages.c +++ b/src/arch/mips/stages.c @@ -20,7 +20,7 @@ #include <arch/stages.h> #include <arch/cache.h>
- __attribute__((section(".text.stage_entry.mips"))) void stage_entry(void) +void stage_entry(void) { main(); } diff --git a/src/arch/x86/boot/boot.c b/src/arch/x86/boot/boot.c index 8f7f0e0..7b92f36 100644 --- a/src/arch/x86/boot/boot.c +++ b/src/arch/x86/boot/boot.c @@ -3,6 +3,7 @@ #include <program_loading.h> #include <ip_checksum.h> #include <string.h> +#include <symbols.h>
/* When the ramstage is relocatable the elf loading ensures an elf image cannot * be loaded over the ramstage code. */ @@ -25,11 +26,10 @@ static void jmp_payload_no_bounce_buffer(void *entry)
static void jmp_payload(void *entry, unsigned long buffer, unsigned long size) { - extern unsigned char _ram_seg, _eram_seg; unsigned long lb_start, lb_size;
- lb_start = (unsigned long)&_ram_seg; - lb_size = (unsigned long)(&_eram_seg - &_ram_seg); + lb_start = (unsigned long)&_program; + lb_size = _program_size;
printk(BIOS_SPEW, "entry = 0x%08lx\n", (unsigned long)entry); printk(BIOS_SPEW, "lb_start = 0x%08lx\n", lb_start); diff --git a/src/arch/x86/init/romstage.ld b/src/arch/x86/init/romstage.ld index 95b9571..4ea20e7 100644 --- a/src/arch/x86/init/romstage.ld +++ b/src/arch/x86/init/romstage.ld @@ -60,12 +60,12 @@ SECTIONS *(.car.global_data); _car_data_end = .; /* The preram cbmem console area comes last to take advantage - * of a zero-sized array to hold the memconsole contents that - * grows to a bound of CONFIG_CONSOLE_PRERAM_BUFFER_SIZE. + * of a zero-sized array to hold the memconsole contents. * However, collisions within the cache-as-ram region cannot be * statically checked because the cache-as-ram region usage is * cpu/chipset dependent. */ - preram_cbmem_console = .; + _preram_cbmem_console = .; + _epreram_cbmem_console = . + 0xc00; }
/* Global variables are not allowed in romstage @@ -83,5 +83,5 @@ SECTIONS *(.sbss.*) }
- _bogus = ASSERT((SIZEOF(.car.data) + CONFIG_CONSOLE_PRERAM_BUFFER_SIZE <= CONFIG_DCACHE_RAM_SIZE), "Cache as RAM area is too full"); + _bogus = ASSERT((SIZEOF(.car.data) + 0xc00 <= CONFIG_DCACHE_RAM_SIZE), "Cache as RAM area is too full"); } diff --git a/src/arch/x86/lib/c_start.S b/src/arch/x86/lib/c_start.S index 675a09c..dbed123 100644 --- a/src/arch/x86/lib/c_start.S +++ b/src/arch/x86/lib/c_start.S @@ -16,7 +16,7 @@ thread_stacks: .space CONFIG_STACK_SIZE*CONFIG_NUM_THREADS #endif
- .section ".textfirst", "ax", @progbits + .section ".text._start", "ax", @progbits .code32 .globl _start .globl __rmodule_entry diff --git a/src/arch/x86/ramstage.ld b/src/arch/x86/ramstage.ld index 9c43bd7..ef79e71 100644 --- a/src/arch/x86/ramstage.ld +++ b/src/arch/x86/ramstage.ld @@ -8,124 +8,20 @@ * : stack * : heap */ -/* - * Bootstrap code for the STPC Consumer - * Copyright (c) 1999 by Net Insight AB. All Rights Reserved. - */ - -/* - * Written by Johan Rydberg, based on work by Daniel Kahlin. - * Rewritten by Eric Biederman - * 2005.12 yhlu add ramstage cross the vga font buffer handling - */ - -/* We use ELF as output format. So that we can debug the code in some form. */ INCLUDE ldoptions
ENTRY(_start)
+PHDRS +{ + to_load PT_LOAD; +} + SECTIONS { . = CONFIG_RAMBASE; - /* First we place the code and read only data (typically const declared). - * This could theoretically be placed in rom. - */ - .text : { - _text = .; - *(.textfirst); - *(.text); - *(.text.*); - . = ALIGN(16); - _etext = .; - } - - .ctors : { - . = ALIGN(0x100); - __CTOR_LIST__ = .; - KEEP(*(.ctors)); - LONG(0); - __CTOR_END__ = .; - } - - .rodata : { - _rodata = .; - . = ALIGN(4); - - /* If any changes are made to the driver start/symbols or the - * section names the equivalent changes need to made to - * rmodule.ld. */ - pci_drivers = . ; - KEEP(*(.rodata.pci_driver)); - epci_drivers = . ; - cpu_drivers = . ; - KEEP(*(.rodata.cpu_driver)); - ecpu_drivers = . ; - _bs_init_begin = .; - KEEP(*(.bs_init)); - LONG(0); - _bs_init_end = .; - - *(.rodata) - *(.rodata.*) - /* kevinh/Ispiri - Added an align, because the objcopy tool - * incorrectly converts sections that are not long word aligned. - */ - . = ALIGN(4); - - _erodata = .; - } - /* After the code we place initialized data (typically initialized - * global variables). This gets copied into ram by startup code. - * __data_start and __data_end shows where in ram this should be placed, - * whereas __data_loadstart and __data_loadend shows where in rom to - * copy from. - */ - .data : { - _data = .; - *(.data) - *(.data.*) - _edata = .; - } - - /* bss does not contain data, it is just a space that should be zero - * initialized on startup. (typically uninitialized global variables) - * crt0.S fills between _bss and _ebss with zeroes. - */ - _bss = .; - .bss . : { - *(.bss) - *(.bss.*) - *(.sbss) - *(.sbss.*) - *(COMMON) - } - _ebss = .; - - _heap = .; - .heap . : { - /* Reserve CONFIG_HEAP_SIZE bytes for the heap */ - . = CONFIG_HEAP_SIZE ; - . = ALIGN(4); - } - _eheap = .; - - /* The ram segment. This includes all memory used by the memory - * resident copy of coreboot, except the tables that are produced on - * the fly, but including stack and heap. - */ - _ram_seg = _text; - _eram_seg = _eheap; - - /* CONFIG_RAMTOP is the upper address of cached memory (among other - * things). We must not exceed beyond that address, there be dragons. - */ - _bogus = ASSERT( ( _eram_seg < (CONFIG_RAMTOP)) , "Please increase CONFIG_RAMTOP");
- /* Discard the sections we don't need/want */ + INCLUDE "lib/ramstage.ramstage.ld"
- /DISCARD/ : { - *(.comment) - *(.note) - *(.note.*) - } + _ = ASSERT( ( _eprogram < (CONFIG_RAMTOP)) , "Please increase CONFIG_RAMTOP"); } diff --git a/src/console/Kconfig b/src/console/Kconfig index 0a0e069..09cfb39 100644 --- a/src/console/Kconfig +++ b/src/console/Kconfig @@ -189,16 +189,6 @@ config CONSOLE_PRERAM_BUFFER_BASE default 0xabadbeef if !CACHE_AS_RAM || LATE_CBMEM_INIT default 0x0
-config CONSOLE_PRERAM_BUFFER_SIZE - hex - default 0x0 if CONSOLE_PRERAM_BUFFER_BASE = 0xabadbeef - default 0xc00 - help - Console is used before RAM is initialized. This is the room reserved - in the DCACHE based RAM, SRAM, etc. to keep console output before it - can be saved in a CBMEM buffer. 3K bytes should be enough even for - the BIOS_SPEW level. - endif
config CONSOLE_QEMU_DEBUGCON diff --git a/src/cpu/x86/lapic/lapic_cpu_init.c b/src/cpu/x86/lapic/lapic_cpu_init.c index 472d6ed..d4a9884 100644 --- a/src/cpu/x86/lapic/lapic_cpu_init.c +++ b/src/cpu/x86/lapic/lapic_cpu_init.c @@ -27,6 +27,7 @@ #include <halt.h> #include <lib.h> #include <string.h> +#include <symbols.h> #include <console/console.h> #include <device/device.h> #include <device/path.h> diff --git a/src/cpu/x86/mp_init.c b/src/cpu/x86/mp_init.c index 3e293f6..a5bbb98 100644 --- a/src/cpu/x86/mp_init.c +++ b/src/cpu/x86/mp_init.c @@ -39,6 +39,7 @@ #include <lib.h> #include <smp/atomic.h> #include <smp/spinlock.h> +#include <symbols.h> #include <thread.h>
#define MAX_APIC_IDS 256 diff --git a/src/cpu/x86/smm/smm.ld b/src/cpu/x86/smm/smm.ld index c198161..6d33fbe 100644 --- a/src/cpu/x86/smm/smm.ld +++ b/src/cpu/x86/smm/smm.ld @@ -11,6 +11,7 @@ SECTIONS */ . = 0xa0000; .handler (.): { + _program = .; /* Assembler stub */ *(.handler)
@@ -35,9 +36,10 @@ SECTIONS *(.sbss) *(.sbss.*)
- /* What is this? */ + /* What is this? (Something we don't need with -fno-common.) */ *(COMMON) . = ALIGN(4); + _eprogram = .; }
/* We are using the ASEG interleaved to stuff the SMM handlers diff --git a/src/cpu/x86/smm/smm_tseg.ld b/src/cpu/x86/smm/smm_tseg.ld index b57461c..4dedd2c 100644 --- a/src/cpu/x86/smm/smm_tseg.ld +++ b/src/cpu/x86/smm/smm_tseg.ld @@ -31,6 +31,7 @@ SECTIONS /* 16KB for the heap at 64KB */ . = 0x10000; .heap : { + _program = .; _heap = .; . = 0x4000; _eheap = .; @@ -65,6 +66,7 @@ SECTIONS . = ALIGN(4);
_smm_c_handler_end = .; + _eprogram = .; }
/DISCARD/ : { diff --git a/src/include/lib.h b/src/include/lib.h index 0cb2c0c..aa8fe4d 100644 --- a/src/include/lib.h +++ b/src/include/lib.h @@ -45,11 +45,6 @@ int primitive_memtest(uintptr_t base, uintptr_t size); /* Defined in src/lib/stack.c */ int checkstack(void *top_of_stack, int core);
-#ifndef __PRE_RAM__ // fails in bootblock compiled with romcc -/* currently defined by a ldscript */ -extern unsigned char _estack[]; -#endif - /* Defined in src/lib/hexdump.c */ void hexdump(const void *memory, size_t length); void hexdump32(char LEVEL, const void *d, size_t len); diff --git a/src/include/memlayout.h b/src/include/memlayout.h new file mode 100644 index 0000000..a80e03e --- /dev/null +++ b/src/include/memlayout.h @@ -0,0 +1,105 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file contains macro definitions for memlayout.ld linker scripts. */ + +#ifndef __MEMLAYOUT_H +#define __MEMLAYOUT_H + +#include <arch/memlayout.h> + +#define STR(x) #x + +#define SET_COUNTER(name, addr) \ + _ = ASSERT(. <= addr, STR(name overlaps the previous region!)); \ + . = addr; + +#define SYMBOL(name, addr) \ + SET_COUNTER(name, addr) \ + _##name = .; + +#define REGION(name, addr, size, expected_align) \ + SYMBOL(name, addr) \ + _ = ASSERT(. == ALIGN(expected_align), \ + STR(name must be aligned to expected_align!)); \ + SYMBOL(e##name, addr + size) + +/* Declare according to SRAM/DRAM ranges in SoC hardware-defined address map. */ +#define SRAM_START(addr) SYMBOL(sram, addr) + +#define SRAM_END(addr) SYMBOL(esram, addr) + +#define DRAM_START(addr) SYMBOL(dram, addr) + +#define PRERAM_CBMEM_CONSOLE(addr, size) \ + REGION(preram_cbmem_console, addr, size, 4) + +/* Use either CBFS_CACHE (unified) or both (PRERAM|POSTRAM)_CBFS_CACHE */ +#define CBFS_CACHE(addr, size) REGION(cbfs_cache, addr, size, 4) + +/* TODO: This only works if you never access CBFS in romstage before RAM is up! + * If you need to change that assumption, you have some work ahead of you... */ +#if defined(__PRE_RAM__) && !defined(__ROMSTAGE__) + #define PRERAM_CBFS_CACHE(addr, size) CBFS_CACHE(addr, size) + #define POSTRAM_CBFS_CACHE(addr, size) \ + REGION(unused_cbfs_cache, addr, size, 4) +#else + #define PRERAM_CBFS_CACHE(addr, size) \ + REGION(unused_cbfs_cache, addr, size, 4) + #define POSTRAM_CBFS_CACHE(addr, size) CBFS_CACHE(addr, size) +#endif + +/* Careful: 'INCLUDE <filename>' must always be at the end of the output line */ +#ifdef __BOOTBLOCK__ + #define BOOTBLOCK(addr, sz) \ + SET_COUNTER(bootblock, addr) \ + _ = ASSERT(_ebootblock - _bootblock <= sz, \ + STR(Bootblock exceeded its allotted size! (sz))); \ + INCLUDE "lib/bootblock.bootblock.ld" +#else + #define BOOTBLOCK(addr, sz) \ + SET_COUNTER(bootblock, addr) \ + . += sz; +#endif + +#ifdef __ROMSTAGE__ + #define ROMSTAGE(addr, sz) \ + SET_COUNTER(romstage, addr) \ + _ = ASSERT(_eromstage - _romstage <= sz, \ + STR(Romstage exceeded its allotted size! (sz))); \ + INCLUDE "lib/romstage.romstage.ld" +#else + #define ROMSTAGE(addr, sz) \ + SET_COUNTER(romstage, addr) \ + . += sz; +#endif + +#ifdef __RAMSTAGE__ + #define RAMSTAGE(addr, sz) \ + SET_COUNTER(ramstage, addr) \ + _ = ASSERT(_eramstage - _ramstage <= sz, \ + STR(Ramstage exceeded its allotted size! (sz))); \ + INCLUDE "lib/ramstage.ramstage.ld" +#else + #define RAMSTAGE(addr, sz) \ + SET_COUNTER(ramstage, addr) \ + . += sz; +#endif + +#endif /* __MEMLAYOUT_H */ diff --git a/src/include/symbols.h b/src/include/symbols.h new file mode 100644 index 0000000..c343fd9 --- /dev/null +++ b/src/include/symbols.h @@ -0,0 +1,76 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA, 02110-1301 USA + */ + +#ifndef __SYMBOLS_H +#define __SYMBOLS_H + +#include <types.h> + +extern u8 _sram[]; +extern u8 _esram[]; +#define _sram_size (_esram - _sram) + +extern u8 _dram[]; + +extern u8 _preram_cbmem_console[]; +extern u8 _epreram_cbmem_console[]; +#define _preram_cbmem_console_size \ + (_epreram_cbmem_console - _preram_cbmem_console) + +extern u8 _stack[]; +extern u8 _estack[]; +#define _stack_size (_estack - _stack) + +extern u8 _cbfs_cache[]; +extern u8 _ecbfs_cache[]; +#define _cbfs_cache_size (_ecbfs_cache - _cbfs_cache) + +extern u8 _payload[]; +extern u8 _epayload[]; +#define _payload_size (_epayload - _payload) + +/* Careful: _e<stage> and _<stage>_size only defined for the current stage! */ +extern u8 _bootblock[]; +extern u8 _ebootblock[]; +#define _bootblock_size (_ebootblock - _bootblock) + +extern u8 _romstage[]; +extern u8 _eromstage[]; +#define _romstage_size (_eromstage - _romstage) + +extern u8 _ramstage[]; +extern u8 _eramstage[]; +#define _ramstage_size (_eramstage - _ramstage) + +/* "program" always refers to the current execution unit, except for x86 ROM. */ +extern u8 _program[]; +extern u8 _eprogram[]; +#define _program_size (_eprogram - _program) + +/* Arch-specific, move to <arch/symbols.h> if they become too many. */ + +extern u8 _ttb[]; +extern u8 _ettb[]; +#define _ttb_size (_ettb - _ttb) + +extern u8 _dma_coherent[]; +extern u8 _edma_coherent[]; +#define _dma_coherent_size (_edma_coherent - _dma_coherent) + +#endif /* __SYMBOLS_H */ diff --git a/src/lib/Makefile.inc b/src/lib/Makefile.inc index 67cf577..afa36ed 100644 --- a/src/lib/Makefile.inc +++ b/src/lib/Makefile.inc @@ -122,6 +122,14 @@ ramstage-y += halt.c smm-y += halt.c secmon-y += halt.c
+ifneq ($(CONFIG_ARCH_X86),y) +# X86 bootblock and romstage use custom ldscripts that are all glued together, +# so we need to exclude it here or it would pick these up as well +bootblock-y += bootblock.ld +romstage-y += romstage.ld +endif +ramstage-y += ramstage.ld + ifeq ($(CONFIG_RELOCATABLE_MODULES),y) ramstage-y += rmodule.c romstage-$(CONFIG_RELOCATABLE_RAMSTAGE) += rmodule.c diff --git a/src/lib/bootblock.ld b/src/lib/bootblock.ld new file mode 100644 index 0000000..a1c2e71 --- /dev/null +++ b/src/lib/bootblock.ld @@ -0,0 +1,48 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file is included inside a SECTIONS block */ + +.bootblock . : { + _program = .; + _bootblock = .; + *(.text._start); + *(.text.stage_entry); + KEEP(*(.id)); + *(.text); + *(.text.*); + *(.rodata); + *(.rodata.*); + *(.data); + *(.data.*); + *(.bss); + *(.bss.*); + *(.sbss); + *(.sbss.*); + _ebootblock = .; + _eprogram = .; +} : to_load = 0xff + +/DISCARD/ : { + *(.comment) + *(.note) + *(.comment.*) + *(.note.*) + *(.ARM.*) +} diff --git a/src/lib/cbfs_spi.c b/src/lib/cbfs_spi.c index 2b3728e..81e6ec3 100644 --- a/src/lib/cbfs_spi.c +++ b/src/lib/cbfs_spi.c @@ -25,6 +25,7 @@
#include <cbfs.h> #include <spi_flash.h> +#include <symbols.h>
/* SPI flash as CBFS media. */ struct cbfs_spi_context { @@ -80,8 +81,8 @@ static int init_cbfs_media_context(void) if (!spi_context.spi_flash_info) return -1;
- spi_context.buffer.buffer = (void *)CONFIG_CBFS_CACHE_ADDRESS; - spi_context.buffer.size = CONFIG_CBFS_CACHE_SIZE; + spi_context.buffer.buffer = (void *)_cbfs_cache; + spi_context.buffer.size = _cbfs_cache_size; } return 0;
diff --git a/src/lib/cbmem_console.c b/src/lib/cbmem_console.c index 0c2722c..770c1d2 100644 --- a/src/lib/cbmem_console.c +++ b/src/lib/cbmem_console.c @@ -21,6 +21,7 @@ #include <console/cbmem_console.h> #include <cbmem.h> #include <arch/early_variables.h> +#include <symbols.h> #include <string.h>
/* @@ -44,11 +45,9 @@ static void copy_console_buffer(struct cbmem_console *old_cons_p, /* * While running from ROM, before DRAM is initialized, some area in cache as * ram space is used for the console buffer storage. The size and location of - * the area are defined in the config. + * the area are defined by the linker script with _(e)preram_cbmem_console. */
-extern struct cbmem_console preram_cbmem_console; - #else
/* @@ -112,8 +111,8 @@ void cbmemc_init(void) if (IS_ENABLED(CONFIG_BOOTBLOCK_CONSOLE)) flags = 0;
- init_console_ptr(&preram_cbmem_console, - CONFIG_CONSOLE_PRERAM_BUFFER_SIZE, flags); + init_console_ptr(_preram_cbmem_console, + _preram_cbmem_console_size, flags); #else /* * Initializing before CBMEM is available, use static buffer to store diff --git a/src/lib/loaders/load_and_run_payload.c b/src/lib/loaders/load_and_run_payload.c index 89b6da6..2813cb3 100644 --- a/src/lib/loaders/load_and_run_payload.c +++ b/src/lib/loaders/load_and_run_payload.c @@ -23,6 +23,7 @@ #include <fallback.h> #include <lib.h> #include <program_loading.h> +#include <symbols.h> #include <timestamp.h>
extern const struct payload_loader_ops vboot_payload_loader; diff --git a/src/lib/ramstage.ld b/src/lib/ramstage.ld new file mode 100644 index 0000000..9ad0e88 --- /dev/null +++ b/src/lib/ramstage.ld @@ -0,0 +1,114 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file is included inside a SECTIONS block */ + +/* First we place the code and read only data (typically const declared). + * This could theoretically be placed in rom. + */ +.text : { + _program = .; + _ramstage = .; + _text = .; + *(.text._start); + *(.text.stage_entry); + *(.text); + *(.text.*); + . = ALIGN(16); + _etext = .; +} : to_load + +#ifdef CONFIG_COVERAGE +.ctors : { + . = ALIGN(0x100); + __CTOR_LIST__ = .; + KEEP(*(.ctors)); + LONG(0); + LONG(0); + __CTOR_END__ = .; +} +#endif + +/* TODO: align data sections to cache lines? (is that really useful?) */ +.rodata : { + _rodata = .; + . = ALIGN(8); + + /* If any changes are made to the driver start/symbols or the + * section names the equivalent changes need to made to + * rmodule.ld. */ + console_drivers = .; + KEEP(*(.rodata.console_drivers)); + econsole_drivers = . ; + . = ALIGN(8); + pci_drivers = . ; + KEEP(*(.rodata.pci_driver)); + epci_drivers = . ; + cpu_drivers = . ; + KEEP(*(.rodata.cpu_driver)); + ecpu_drivers = . ; + _bs_init_begin = .; + KEEP(*(.bs_init)); + _bs_init_end = .; + + *(.rodata) + *(.rodata.*) + /* kevinh/Ispiri - Added an align, because the objcopy tool + * incorrectly converts sections that are not long word aligned. + */ + . = ALIGN(8); + + _erodata = .; +} + +.data : { + /* Move to different cache line to avoid false sharing with .rodata. */ + . = ALIGN(64); /* May not be actual line size, not that important. */ + _data = .; + *(.data) + *(.data.*) + _edata = .; +} + +.bss . : { + _bss = .; + *(.bss) + *(.bss.*) + *(.sbss) + *(.sbss.*) + _ebss = .; +} + +.heap . : { + _heap = .; + /* Reserve CONFIG_HEAP_SIZE bytes for the heap */ + . += CONFIG_HEAP_SIZE ; + . = ALIGN(4); + _eheap = .; + _eramstage = .; + _eprogram = .; +} + +/* Discard the sections we don't need/want */ + +/DISCARD/ : { + *(.comment) + *(.note) + *(.note.*) +} diff --git a/src/lib/rmodule.ld b/src/lib/rmodule.ld index 065b5b6..70a2d3d 100644 --- a/src/lib/rmodule.ld +++ b/src/lib/rmodule.ld @@ -22,18 +22,21 @@ SECTIONS
.payload : { /* C code of the module. */ - _ram_seg = .; - *(.textfirst); + _program = .; + *(.text._start); + *(.text.stage_entry); *(.text); *(.text.*); /* C read-only data. */ . = ALIGN(16);
+#ifdef CONFIG_COVERAGE __CTOR_LIST__ = .; *(.ctors); LONG(0); LONG(0); __CTOR_END__ = .; +#endif
/* The driver sections are to allow linking coreboot's * ramstage with the rmodule linker. Any changes made in @@ -68,6 +71,7 @@ SECTIONS . = ALIGN(8);
/* Data section. */ + . = ALIGN(64); /* Mirror cache line alignment from ramstage. */ _sdata = .; *(.data); *(.data.*); @@ -95,7 +99,7 @@ SECTIONS _heap = .; . = . + __heap_size; _eheap = .; - _eram_seg = .; + _eprogram = .; }
/DISCARD/ : { diff --git a/src/lib/romstage.ld b/src/lib/romstage.ld new file mode 100644 index 0000000..c3a2643 --- /dev/null +++ b/src/lib/romstage.ld @@ -0,0 +1,58 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file is included inside a SECTIONS block */ + +.text . : { + _program = .; + _romstage = .; + *(.text._start); + *(.text.stage_entry); + *(.text); + *(.text.*); +} : to_load + +.data . : { + *(.rodata); + *(.rodata.*); + *(.data); + *(.data.*); + . = ALIGN(8); +} + +.bss . : { + . = ALIGN(8); + _bss = .; + *(.bss) + *(.bss.*) + *(.sbss) + *(.sbss.*) + _ebss = .; + _eromstage = .; + _eprogram = .; +} + +/* Discard the sections we don't need/want */ +/DISCARD/ : { + *(.comment) + *(.note) + *(.comment.*) + *(.note.*) + *(.eh_frame); +} diff --git a/src/lib/selfboot.c b/src/lib/selfboot.c index b29a34e..3e416ba 100644 --- a/src/lib/selfboot.c +++ b/src/lib/selfboot.c @@ -24,17 +24,14 @@ #include <stdint.h> #include <stdlib.h> #include <string.h> +#include <symbols.h> #include <cbfs.h> #include <lib.h> #include <bootmem.h> #include <program_loading.h>
-/* from ramstage.ld: */ -extern unsigned char _ram_seg; -extern unsigned char _eram_seg; - -static const unsigned long lb_start = (unsigned long)&_ram_seg; -static const unsigned long lb_end = (unsigned long)&_eram_seg; +static const unsigned long lb_start = (unsigned long)&_program; +static const unsigned long lb_end = (unsigned long)&_eprogram;
struct segment { struct segment *next; diff --git a/src/mainboard/emulation/qemu-armv7/Kconfig b/src/mainboard/emulation/qemu-armv7/Kconfig index b275e88..c0e7095 100644 --- a/src/mainboard/emulation/qemu-armv7/Kconfig +++ b/src/mainboard/emulation/qemu-armv7/Kconfig @@ -49,45 +49,10 @@ config MAINBOARD_VENDOR string default "ARM Ltd."
-config SYS_SDRAM_BASE - hex "SDRAM base address" - default 0x01000000 - config DRAM_SIZE_MB int default 1024
-# Memory map for qemu vexpress-a9: -# -# 0x0000_0000: jump instruction (by qemu) -# 0x0001_0000: bootblock (entry of kernel / firmware) -# 0x0002_0000: romstage, assume up to 128KB in size. -# 0x0007_ff00: stack pointer -# 0x0010_0000: CBFS header -# 0x0011_0000: CBFS data -# 0x0100_0000: reserved for ramstage -# 0x1000_0000: I/O map address -# -config STACK_TOP - hex - default 0x00100000 - -config STACK_BOTTOM - hex - default 0x0007FF00 - -config BOOTBLOCK_BASE - hex - default 0x00010000 - -config ROMSTAGE_BASE - hex - default 0x00020000 - -config RAMSTAGE_BASE - hex - default SYS_SDRAM_BASE - config BOOTBLOCK_ROM_OFFSET hex default 0x0 diff --git a/src/mainboard/emulation/qemu-armv7/Makefile.inc b/src/mainboard/emulation/qemu-armv7/Makefile.inc index 4119f93..d5742e1 100644 --- a/src/mainboard/emulation/qemu-armv7/Makefile.inc +++ b/src/mainboard/emulation/qemu-armv7/Makefile.inc @@ -28,3 +28,7 @@ ramstage-y += timer.c bootblock-y += mmio.c romstage-y += mmio.c ramstage-y += mmio.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/emulation/qemu-armv7/media.c b/src/mainboard/emulation/qemu-armv7/media.c index 1168881..8e6cd46 100644 --- a/src/mainboard/emulation/qemu-armv7/media.c +++ b/src/mainboard/emulation/qemu-armv7/media.c @@ -14,6 +14,7 @@ */ #include <cbfs.h> #include <string.h> +#include <symbols.h> #include <console/console.h>
/* Simple memory-mapped ROM emulation. */ @@ -25,7 +26,7 @@ static int emu_rom_open(struct cbfs_media *media)
static void *emu_rom_map(struct cbfs_media *media, size_t offset, size_t count) { - return (void*)(offset + CONFIG_BOOTBLOCK_BASE); + return (void*)(offset + _bootblock); }
static void *emu_rom_unmap(struct cbfs_media *media, const void *address) diff --git a/src/mainboard/emulation/qemu-armv7/memlayout.ld b/src/mainboard/emulation/qemu-armv7/memlayout.ld new file mode 100644 index 0000000..8990afa --- /dev/null +++ b/src/mainboard/emulation/qemu-armv7/memlayout.ld @@ -0,0 +1,47 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> + +#include <arch/header.ld> + +/* + * Memory map for qemu vexpress-a9: + * + * 0x0000_0000: jump instruction (by qemu) + * 0x0001_0000: bootblock (entry of kernel / firmware) + * 0x0002_0000: romstage, assume up to 128KB in size. + * 0x0007_ff00: stack pointer + * 0x0010_0000: CBFS header + * 0x0011_0000: CBFS data + * 0x0100_0000: reserved for ramstage + * 0x1000_0000: I/O map address + */ + +SECTIONS +{ + /* TODO: does this thing emulate SRAM? */ + + BOOTBLOCK(0x10000, 64K) + ROMSTAGE(0x20000, 128K) + STACK(0x000FC000, 16K) + + DRAM_START(0x01000000) + RAMSTAGE(0x01000000) +} diff --git a/src/mainboard/google/daisy/Makefile.inc b/src/mainboard/google/daisy/Makefile.inc index df9b797..1f041ab 100644 --- a/src/mainboard/google/daisy/Makefile.inc +++ b/src/mainboard/google/daisy/Makefile.inc @@ -26,3 +26,7 @@ romstage-y += chromeos.c
ramstage-y += mainboard.c ramstage-y += chromeos.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/daisy/mainboard.c b/src/mainboard/google/daisy/mainboard.c index 5840e51..138e498 100644 --- a/src/mainboard/google/daisy/mainboard.c +++ b/src/mainboard/google/daisy/mainboard.c @@ -36,20 +36,17 @@ #include <soc/samsung/exynos5250/dp.h> #include <soc/samsung/exynos5250/periph.h> #include <soc/samsung/exynos5250/usb.h> +#include <symbols.h>
#include "exynos5250.h"
#define MMC0_GPIO_PIN (58)
/* convenient shorthand (in MB) */ -#define DRAM_START (CONFIG_SYS_SDRAM_BASE >> 20) +#define DRAM_START ((uintptr_t)_dram/MiB) #define DRAM_SIZE CONFIG_DRAM_SIZE_MB #define DRAM_END (DRAM_START + DRAM_SIZE) /* plus one... */
-/* Arbitrary range of DMA memory for depthcharge's drivers */ -#define DMA_START (0x77300000) -#define DMA_SIZE (0x00100000) - static struct edid edid = { .ha = 1366, .va = 768, @@ -333,7 +330,8 @@ static void mainboard_enable(device_t dev) mmu_init(); mmu_config_range(0, DRAM_START, DCACHE_OFF); mmu_config_range(DRAM_START, DRAM_SIZE, DCACHE_WRITEBACK); - mmu_config_range(DMA_START >> 20, DMA_SIZE >> 20, DCACHE_OFF); + mmu_config_range((uintptr_t)_dma_coherent/MiB, + _dma_coherent_size/MiB, DCACHE_OFF); mmu_config_range(DRAM_END, 4096 - DRAM_END, DCACHE_OFF); dcache_mmu_enable();
@@ -359,6 +357,6 @@ void lb_board(struct lb_header *header) dma = (struct lb_range *)lb_new_record(header); dma->tag = LB_TAB_DMA; dma->size = sizeof(*dma); - dma->range_start = (intptr_t)DMA_START; - dma->range_size = DMA_SIZE; + dma->range_start = (uintptr_t)_dma_coherent; + dma->range_size = _dma_coherent_size; } diff --git a/src/mainboard/google/daisy/memlayout.ld b/src/mainboard/google/daisy/memlayout.ld new file mode 100644 index 0000000..72c018e --- /dev/null +++ b/src/mainboard/google/daisy/memlayout.ld @@ -0,0 +1 @@ +#include <soc/samsung/exynos5250/memlayout.ld> diff --git a/src/mainboard/google/nyan/Kconfig b/src/mainboard/google/nyan/Kconfig index 864e577..082985d 100644 --- a/src/mainboard/google/nyan/Kconfig +++ b/src/mainboard/google/nyan/Kconfig @@ -42,14 +42,6 @@ config MAINBOARD_PART_NUMBER string default "Nyan"
-config DRAM_DMA_START - hex - default 0x90000000 - -config DRAM_DMA_SIZE - hex - default 0x00200000 - choice prompt "BCT boot media" default NYAN_BCT_CFG_SPI diff --git a/src/mainboard/google/nyan/Makefile.inc b/src/mainboard/google/nyan/Makefile.inc index de1e127..76ff76c 100644 --- a/src/mainboard/google/nyan/Makefile.inc +++ b/src/mainboard/google/nyan/Makefile.inc @@ -41,3 +41,7 @@ romstage-y += early_configs.c ramstage-y += boardid.c ramstage-y += mainboard.c ramstage-$(CONFIG_CHROMEOS) += chromeos.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/nyan/mainboard.c b/src/mainboard/google/nyan/mainboard.c index b534ea9..e52db83 100644 --- a/src/mainboard/google/nyan/mainboard.c +++ b/src/mainboard/google/nyan/mainboard.c @@ -30,6 +30,7 @@ #include <soc/nvidia/tegra124/pmc.h> #include <soc/nvidia/tegra124/spi.h> #include <soc/nvidia/tegra/usb.h> +#include <symbols.h> #include <vendorcode/google/chromeos/chromeos.h>
static struct clk_rst_ctlr *clk_rst = (void *)TEGRA_CLK_RST_BASE; @@ -268,6 +269,6 @@ void lb_board(struct lb_header *header) dma = (struct lb_range *)lb_new_record(header); dma->tag = LB_TAB_DMA; dma->size = sizeof(*dma); - dma->range_start = CONFIG_DRAM_DMA_START; - dma->range_size = CONFIG_DRAM_DMA_SIZE; + dma->range_start = (uintptr_t)_dma_coherent; + dma->range_size = _dma_coherent_size; } diff --git a/src/mainboard/google/nyan/memlayout.ld b/src/mainboard/google/nyan/memlayout.ld new file mode 100644 index 0000000..33ce644 --- /dev/null +++ b/src/mainboard/google/nyan/memlayout.ld @@ -0,0 +1 @@ +#include <soc/nvidia/tegra124/memlayout.ld> diff --git a/src/mainboard/google/nyan/romstage.c b/src/mainboard/google/nyan/romstage.c index fffe0de..358e248 100644 --- a/src/mainboard/google/nyan/romstage.c +++ b/src/mainboard/google/nyan/romstage.c @@ -39,6 +39,7 @@ #include <soc/addressmap.h> #include <soc/clock.h> #include <soc/display.h> +#include <symbols.h> #include <timestamp.h>
static void __attribute__((noinline)) romstage(void) @@ -52,24 +53,25 @@ static void __attribute__((noinline)) romstage(void) sdram_init(get_sdram_config());
/* used for MMU and CBMEM setup, in MB */ - u32 dram_start = (CONFIG_SYS_SDRAM_BASE >> 20); - u32 dram_end = sdram_max_addressable_mb(); /* plus one... */ - u32 dram_size = dram_end - dram_start; + u32 dram_start_mb = (uintptr_t)_dram/MiB; + u32 dram_end_mb = sdram_max_addressable_mb(); + u32 dram_size_mb = dram_end_mb - dram_start_mb;
configure_l2_cache(); mmu_init(); /* Device memory below DRAM is uncached. */ - mmu_config_range(0, dram_start, DCACHE_OFF); - /* SRAM is cached. Round the size up to 2MB, the LPAE page size. */ - mmu_config_range(0x40000000 >> 20, 2, DCACHE_WRITEBACK); + mmu_config_range(0, dram_start_mb, DCACHE_OFF); + /* SRAM is cached. MMU code will round size up to page size. */ + mmu_config_range((uintptr_t)_sram/MiB, div_round_up(_sram_size, MiB), + DCACHE_WRITEBACK); /* DRAM is cached. */ - mmu_config_range(dram_start, dram_size, DCACHE_WRITEBACK); + mmu_config_range(dram_start_mb, dram_size_mb, DCACHE_WRITEBACK); /* A window for DMA is uncached. */ - mmu_config_range(CONFIG_DRAM_DMA_START >> 20, - CONFIG_DRAM_DMA_SIZE >> 20, DCACHE_OFF); + mmu_config_range((uintptr_t)_dma_coherent/MiB, + _dma_coherent_size/MiB, DCACHE_OFF); /* The space above DRAM is uncached. */ - if (dram_end < 4096) - mmu_config_range(dram_end, 4096 - dram_end, DCACHE_OFF); + if (dram_end_mb < 4096) + mmu_config_range(dram_end_mb, 4096 - dram_end_mb, DCACHE_OFF); mmu_disable_range(0, 1); dcache_mmu_enable();
diff --git a/src/mainboard/google/nyan_big/Kconfig b/src/mainboard/google/nyan_big/Kconfig index 2968b01..7334472 100644 --- a/src/mainboard/google/nyan_big/Kconfig +++ b/src/mainboard/google/nyan_big/Kconfig @@ -44,14 +44,6 @@ config MAINBOARD_PART_NUMBER string default "Nyan Big"
-config DRAM_DMA_START - hex - default 0x90000000 - -config DRAM_DMA_SIZE - hex - default 0x00200000 - choice prompt "BCT boot media" default NYAN_BIG_BCT_CFG_SPI diff --git a/src/mainboard/google/nyan_big/Makefile.inc b/src/mainboard/google/nyan_big/Makefile.inc index 1eb5404..740d7ca 100644 --- a/src/mainboard/google/nyan_big/Makefile.inc +++ b/src/mainboard/google/nyan_big/Makefile.inc @@ -40,3 +40,7 @@ romstage-y += early_configs.c ramstage-y += boardid.c ramstage-y += mainboard.c ramstage-$(CONFIG_CHROMEOS) += chromeos.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/nyan_big/mainboard.c b/src/mainboard/google/nyan_big/mainboard.c index 86d9fe3..05f6fae 100644 --- a/src/mainboard/google/nyan_big/mainboard.c +++ b/src/mainboard/google/nyan_big/mainboard.c @@ -30,6 +30,7 @@ #include <soc/nvidia/tegra124/pmc.h> #include <soc/nvidia/tegra124/spi.h> #include <soc/nvidia/tegra/usb.h> +#include <symbols.h> #include <vendorcode/google/chromeos/chromeos.h>
static struct clk_rst_ctlr *clk_rst = (void *)TEGRA_CLK_RST_BASE; @@ -266,6 +267,6 @@ void lb_board(struct lb_header *header) dma = (struct lb_range *)lb_new_record(header); dma->tag = LB_TAB_DMA; dma->size = sizeof(*dma); - dma->range_start = CONFIG_DRAM_DMA_START; - dma->range_size = CONFIG_DRAM_DMA_SIZE; + dma->range_start = (uintptr_t)_dma_coherent; + dma->range_size = _dma_coherent_size; } diff --git a/src/mainboard/google/nyan_big/memlayout.ld b/src/mainboard/google/nyan_big/memlayout.ld new file mode 100644 index 0000000..33ce644 --- /dev/null +++ b/src/mainboard/google/nyan_big/memlayout.ld @@ -0,0 +1 @@ +#include <soc/nvidia/tegra124/memlayout.ld> diff --git a/src/mainboard/google/nyan_big/romstage.c b/src/mainboard/google/nyan_big/romstage.c index fffe0de..358e248 100644 --- a/src/mainboard/google/nyan_big/romstage.c +++ b/src/mainboard/google/nyan_big/romstage.c @@ -39,6 +39,7 @@ #include <soc/addressmap.h> #include <soc/clock.h> #include <soc/display.h> +#include <symbols.h> #include <timestamp.h>
diff --git a/src/mainboard/google/nyan_blaze/Kconfig b/src/mainboard/google/nyan_blaze/Kconfig index 5938e7e..3495919 100644 --- a/src/mainboard/google/nyan_blaze/Kconfig +++ b/src/mainboard/google/nyan_blaze/Kconfig @@ -45,14 +45,6 @@ config MAINBOARD_PART_NUMBER string default "Nyan Blaze"
-config DRAM_DMA_START - hex - default 0x90000000 - -config DRAM_DMA_SIZE - hex - default 0x00200000 - choice prompt "BCT boot media" default NYAN_BLAZE_BCT_CFG_SPI diff --git a/src/mainboard/google/nyan_blaze/Makefile.inc b/src/mainboard/google/nyan_blaze/Makefile.inc index 8cfa298..f5dfe5f 100644 --- a/src/mainboard/google/nyan_blaze/Makefile.inc +++ b/src/mainboard/google/nyan_blaze/Makefile.inc @@ -44,3 +44,8 @@ romstage-$(CONFIG_CHROMEOS) += chromeos.c ramstage-y += boardid.c ramstage-y += mainboard.c ramstage-$(CONFIG_CHROMEOS) += chromeos.c + +bootblock-y += memlayout.ld +verstage-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/nyan_blaze/mainboard.c b/src/mainboard/google/nyan_blaze/mainboard.c index ccbaf63..5f1cb49 100644 --- a/src/mainboard/google/nyan_blaze/mainboard.c +++ b/src/mainboard/google/nyan_blaze/mainboard.c @@ -30,6 +30,7 @@ #include <soc/nvidia/tegra124/pmc.h> #include <soc/nvidia/tegra124/spi.h> #include <soc/nvidia/tegra/usb.h> +#include <symbols.h> #include <vendorcode/google/chromeos/chromeos.h>
static struct clk_rst_ctlr *clk_rst = (void *)TEGRA_CLK_RST_BASE; @@ -266,6 +267,6 @@ void lb_board(struct lb_header *header) dma = (struct lb_range *)lb_new_record(header); dma->tag = LB_TAB_DMA; dma->size = sizeof(*dma); - dma->range_start = CONFIG_DRAM_DMA_START; - dma->range_size = CONFIG_DRAM_DMA_SIZE; + dma->range_start = (uintptr_t)_dma_coherent; + dma->range_size = _dma_coherent_size; } diff --git a/src/mainboard/google/nyan_blaze/memlayout.ld b/src/mainboard/google/nyan_blaze/memlayout.ld new file mode 100644 index 0000000..33ce644 --- /dev/null +++ b/src/mainboard/google/nyan_blaze/memlayout.ld @@ -0,0 +1 @@ +#include <soc/nvidia/tegra124/memlayout.ld> diff --git a/src/mainboard/google/nyan_blaze/romstage.c b/src/mainboard/google/nyan_blaze/romstage.c index 65596a2..20edbcd 100644 --- a/src/mainboard/google/nyan_blaze/romstage.c +++ b/src/mainboard/google/nyan_blaze/romstage.c @@ -39,6 +39,7 @@ #include <soc/addressmap.h> #include <soc/clock.h> #include <soc/display.h> +#include <symbols.h> #include <timestamp.h>
static void __attribute__((noinline)) romstage(void) @@ -52,29 +53,30 @@ static void __attribute__((noinline)) romstage(void) sdram_init(get_sdram_config());
#if !CONFIG_VBOOT2_VERIFY_FIRMWARE configure_l2_cache(); mmu_init(); /* Device memory below DRAM is uncached. */ - mmu_config_range(0, dram_start, DCACHE_OFF); - /* SRAM is cached. Round the size up to 2MB, the LPAE page size. */ - mmu_config_range(0x40000000 >> 20, 2, DCACHE_WRITEBACK); + mmu_config_range(0, dram_start_mb, DCACHE_OFF); + /* SRAM is cached. MMU code will round size up to page size. */ + mmu_config_range((uintptr_t)_sram/MiB, div_round_up(_sram_size, MiB), + DCACHE_WRITEBACK); /* The space above DRAM is uncached. */ - if (dram_end < 4096) - mmu_config_range(dram_end, 4096 - dram_end, DCACHE_OFF); + if (dram_end_mb < 4096) + mmu_config_range(dram_end_mb, 4096 - dram_end_mb, DCACHE_OFF); mmu_disable_range(0, 1); dcache_mmu_enable(); #endif
/* * A watchdog reset only resets part of the system so it ends up in diff --git a/src/mainboard/google/peach_pit/Makefile.inc b/src/mainboard/google/peach_pit/Makefile.inc index df9b797..1f041ab 100644 --- a/src/mainboard/google/peach_pit/Makefile.inc +++ b/src/mainboard/google/peach_pit/Makefile.inc @@ -26,3 +26,7 @@ romstage-y += chromeos.c
ramstage-y += mainboard.c ramstage-y += chromeos.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/peach_pit/mainboard.c b/src/mainboard/google/peach_pit/mainboard.c index 1a15bd2..b6f49e2 100644 --- a/src/mainboard/google/peach_pit/mainboard.c +++ b/src/mainboard/google/peach_pit/mainboard.c @@ -40,15 +40,12 @@ #include <drivers/parade/ps8625/ps8625.h> #include <ec/google/chromeec/ec.h> #include <stdlib.h> +#include <symbols.h>
-/* Arbitrary range of DMA memory for depthcharge's drivers */ -#define DMA_START (0x77300000) -#define DMA_SIZE (0x00100000) - static struct edid edid = { .ha = 1366, .va = 768, @@ -469,7 +466,8 @@ static void mainboard_enable(device_t dev)
/* set up caching for the DRAM */ mmu_config_range(DRAM_START, DRAM_SIZE, DCACHE_WRITEBACK); - mmu_config_range(DMA_START >> 20, DMA_SIZE >> 20, DCACHE_OFF); + mmu_config_range((uintptr_t)_dma_coherent/MiB, + _dma_coherent_size/MiB, DCACHE_OFF);
const unsigned epll_hz = 192000000; const unsigned sample_rate = 48000; @@ -493,6 +491,6 @@ void lb_board(struct lb_header *header) dma = (struct lb_range *)lb_new_record(header); dma->tag = LB_TAB_DMA; dma->size = sizeof(*dma); - dma->range_start = (intptr_t)DMA_START; - dma->range_size = DMA_SIZE; + dma->range_start = (uintptr_t)_dma_coherent; + dma->range_size = _dma_coherent_size; } diff --git a/src/mainboard/google/peach_pit/memlayout.ld b/src/mainboard/google/peach_pit/memlayout.ld new file mode 100644 index 0000000..565ba89 --- /dev/null +++ b/src/mainboard/google/peach_pit/memlayout.ld @@ -0,0 +1 @@ +#include <soc/samsung/exynos5420/memlayout.ld> diff --git a/src/mainboard/google/rush/Makefile.inc b/src/mainboard/google/rush/Makefile.inc index 2a1ce99..e41745f 100644 --- a/src/mainboard/google/rush/Makefile.inc +++ b/src/mainboard/google/rush/Makefile.inc @@ -40,3 +40,7 @@ ramstage-y += boardid.c ramstage-y += mainboard.c ramstage-y += reset.c ramstage-$(CONFIG_CHROMEOS) += chromeos.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/rush/memlayout.ld b/src/mainboard/google/rush/memlayout.ld new file mode 100644 index 0000000..b9def51 --- /dev/null +++ b/src/mainboard/google/rush/memlayout.ld @@ -0,0 +1 @@ +#include <soc/nvidia/tegra132/memlayout.ld> diff --git a/src/mainboard/google/rush_ryu/Makefile.inc b/src/mainboard/google/rush_ryu/Makefile.inc index 2fe12a4..67a3fac 100644 --- a/src/mainboard/google/rush_ryu/Makefile.inc +++ b/src/mainboard/google/rush_ryu/Makefile.inc @@ -41,3 +41,7 @@ ramstage-y += boardid.c ramstage-y += mainboard.c ramstage-y += reset.c ramstage-y += chromeos.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/rush_ryu/memlayout.ld b/src/mainboard/google/rush_ryu/memlayout.ld new file mode 100644 index 0000000..b9def51 --- /dev/null +++ b/src/mainboard/google/rush_ryu/memlayout.ld @@ -0,0 +1 @@ +#include <soc/nvidia/tegra132/memlayout.ld> diff --git a/src/mainboard/google/storm/Kconfig b/src/mainboard/google/storm/Kconfig index b0c064c..3e1e016 100644 --- a/src/mainboard/google/storm/Kconfig +++ b/src/mainboard/google/storm/Kconfig @@ -48,12 +48,4 @@ config DRAM_SIZE_MB default 512 if BOARD_VARIANT_AP148 default 1024
-config DRAM_DMA_START - hex - default 0x5a000000 - -config DRAM_DMA_SIZE - hex - default 0x00200000 - endif # BOARD_GOOGLE_STORM diff --git a/src/mainboard/google/storm/Makefile.inc b/src/mainboard/google/storm/Makefile.inc index 907638a..6ee0841 100644 --- a/src/mainboard/google/storm/Makefile.inc +++ b/src/mainboard/google/storm/Makefile.inc @@ -25,3 +25,7 @@ romstage-y += cdp.c ramstage-y += boardid.c ramstage-y += cdp.c ramstage-y += mainboard.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/storm/mainboard.c b/src/mainboard/google/storm/mainboard.c index 3da6f90..478e2a8 100644 --- a/src/mainboard/google/storm/mainboard.c +++ b/src/mainboard/google/storm/mainboard.c @@ -25,19 +25,20 @@ #include <device/device.h> #include <gpiolib.h> #include <string.h> +#include <symbols.h>
#include <soc/qualcomm/ipq806x/include/clock.h> #include <soc/qualcomm/ipq806x/include/gpio.h> #include <soc/qualcomm/ipq806x/include/usb.h>
/* convenient shorthand (in MB) */ -#define DRAM_START (CONFIG_SYS_SDRAM_BASE / MiB) +#define DRAM_START ((uintptr_t)_dram / MiB) #define DRAM_SIZE (CONFIG_DRAM_SIZE_MB) #define DRAM_END (DRAM_START + DRAM_SIZE)
/* DMA memory for drivers */ -#define DMA_START (CONFIG_DRAM_DMA_START / MiB) -#define DMA_SIZE (CONFIG_DRAM_DMA_SIZE / MiB) +#define DMA_START ((uintptr_t)_dma_coherent / MiB) +#define DMA_SIZE (_dma_coherent_size / MiB)
#define USB_ENABLE_GPIO 51
@@ -134,8 +135,8 @@ void lb_board(struct lb_header *header) dma = (struct lb_range *)lb_new_record(header); dma->tag = LB_TAB_DMA; dma->size = sizeof(*dma); - dma->range_start = CONFIG_DRAM_DMA_START; - dma->range_size = CONFIG_DRAM_DMA_SIZE; + dma->range_start = (uintptr_t)_dma_coherent; + dma->range_size = _dma_coherent_size; }
static int read_gpio(gpio_t gpio_num) diff --git a/src/mainboard/google/storm/memlayout.ld b/src/mainboard/google/storm/memlayout.ld new file mode 100644 index 0000000..1735835 --- /dev/null +++ b/src/mainboard/google/storm/memlayout.ld @@ -0,0 +1 @@ +#include <soc/qualcomm/ipq806x/memlayout.ld> diff --git a/src/mainboard/google/urara/Kconfig b/src/mainboard/google/urara/Kconfig index 231c97e..65b2c80 100644 --- a/src/mainboard/google/urara/Kconfig +++ b/src/mainboard/google/urara/Kconfig @@ -38,10 +38,6 @@ config MAINBOARD_PART_NUMBER string default "ImgTec Pistachio Virtual Platform"
-config SYS_SDRAM_BASE - hex "SDRAM base address" - default 0x80000000 - config DRAM_SIZE_MB int default 256 diff --git a/src/mainboard/google/urara/Makefile.inc b/src/mainboard/google/urara/Makefile.inc index 4ce6398..5a9dc02 100644 --- a/src/mainboard/google/urara/Makefile.inc +++ b/src/mainboard/google/urara/Makefile.inc @@ -21,3 +21,6 @@
+bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/urara/memlayout.ld b/src/mainboard/google/urara/memlayout.ld new file mode 100644 index 0000000..ab0b4dd --- /dev/null +++ b/src/mainboard/google/urara/memlayout.ld @@ -0,0 +1 @@ +#include <soc/imgtec/pistachio/memlayout.ld> diff --git a/src/mainboard/google/veyron_pinky/Kconfig b/src/mainboard/google/veyron_pinky/Kconfig index e2c9d1a..cddbf64 100644 --- a/src/mainboard/google/veyron_pinky/Kconfig +++ b/src/mainboard/google/veyron_pinky/Kconfig @@ -52,14 +52,6 @@ config BOOT_MEDIA_SPI_BUS int default 2
-config DRAM_DMA_START - hex - default 0x10000000 - -config DRAM_DMA_SIZE - hex - default 0x00200000 - config DRAM_SIZE_MB int default 2048 diff --git a/src/mainboard/google/veyron_pinky/Makefile.inc b/src/mainboard/google/veyron_pinky/Makefile.inc index 2d3f62f..095ceb5 100644 --- a/src/mainboard/google/veyron_pinky/Makefile.inc +++ b/src/mainboard/google/veyron_pinky/Makefile.inc @@ -30,3 +30,8 @@ ramstage-y += boardid.c ramstage-y += chromeos.c ramstage-y += mainboard.c ramstage-y += reset.c + +bootblock-y += memlayout.ld +verstage-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld diff --git a/src/mainboard/google/veyron_pinky/mainboard.c b/src/mainboard/google/veyron_pinky/mainboard.c index 4d647d3..c0ea474 100644 --- a/src/mainboard/google/veyron_pinky/mainboard.c +++ b/src/mainboard/google/veyron_pinky/mainboard.c @@ -22,6 +22,7 @@ #include <arch/cache.h> #include <delay.h> #include <edid.h> +#include <symbols.h> #include <vbe.h> #include <boot/coreboot_tables.h> #include <device/i2c.h> @@ -146,6 +147,6 @@ void lb_board(struct lb_header *header) dma = (struct lb_range *)lb_new_record(header); dma->tag = LB_TAB_DMA; dma->size = sizeof(*dma); - dma->range_start = CONFIG_DRAM_DMA_START; - dma->range_size = CONFIG_DRAM_DMA_SIZE; + dma->range_start = (uintptr_t)_dma_coherent; + dma->range_size = _dma_coherent_size; } diff --git a/src/mainboard/google/veyron_pinky/memlayout.ld b/src/mainboard/google/veyron_pinky/memlayout.ld new file mode 100644 index 0000000..a8b7465 --- /dev/null +++ b/src/mainboard/google/veyron_pinky/memlayout.ld @@ -0,0 +1 @@ +#include <soc/rockchip/rk3288/memlayout.ld> diff --git a/src/mainboard/google/veyron_pinky/romstage.c b/src/mainboard/google/veyron_pinky/romstage.c index e1062ca..e5e4765 100644 --- a/src/mainboard/google/veyron_pinky/romstage.c +++ b/src/mainboard/google/veyron_pinky/romstage.c @@ -30,6 +30,7 @@ #include <vendorcode/google/chromeos/chromeos.h> #include <soc/rockchip/rk3288/sdram.h> #include <soc/rockchip/rk3288/clock.h> +#include <symbols.h> #include "timer.h"
void main(void) @@ -42,9 +43,9 @@ void main(void) start_romstage_time = timestamp_get(); #endif /* used for MMU and CBMEM setup, in MB */ - u32 dram_start = (CONFIG_SYS_SDRAM_BASE >> 20); - u32 dram_size = CONFIG_DRAM_SIZE_MB; - u32 dram_end = dram_start + dram_size; + u32 dram_start_mb = (uintptr_t)_dram/MiB; + u32 dram_size_mb = CONFIG_DRAM_SIZE_MB; + u32 dram_end_mb = dram_start_mb + dram_size_mb;
console_init();
@@ -57,15 +58,15 @@ void main(void) #endif mmu_init(); /* Device memory below DRAM is uncached. */ - mmu_config_range(0, dram_start, DCACHE_OFF); + mmu_config_range(0, dram_start_mb, DCACHE_OFF); /* DRAM is cached. */ - mmu_config_range(dram_start, dram_size, DCACHE_WRITEBACK); + mmu_config_range(dram_start_mb, dram_size_mb, DCACHE_WRITEBACK); /* A window for DMA is uncached. */ - mmu_config_range(CONFIG_DRAM_DMA_START >> 20, - CONFIG_DRAM_DMA_SIZE >> 20, DCACHE_OFF); + mmu_config_range((uintptr_t)_dma_coherent/MiB, + _dma_coherent_size/MiB, DCACHE_OFF); /* The space above DRAM is uncached. */ - if (dram_end < 4096) - mmu_config_range(dram_end, 4096 - dram_end, DCACHE_OFF); + if (dram_end_mb < 4096) + mmu_config_range(dram_end_mb, 4096 - dram_end_mb, DCACHE_OFF); dcache_mmu_enable();
setup_chromeos_gpios(); diff --git a/src/soc/imgtec/pistachio/Kconfig b/src/soc/imgtec/pistachio/Kconfig index 83408bd..74ad894 100644 --- a/src/soc/imgtec/pistachio/Kconfig +++ b/src/soc/imgtec/pistachio/Kconfig @@ -35,40 +35,9 @@ config BOOTBLOCK_CPU_INIT string default "soc/imgtec/pistachio/bootblock.c"
-config BOOTBLOCK_BASE - hex - default 0x9b000000 - config CBFS_ROM_OFFSET # Effectively the maximum size of the bootblock hex default 0x4000
-config ROMSTAGE_BASE - hex - default 0x9b004000 - help - The address where romstage is supposed to be loaded, right above the - bootblock. - -config CBMEM_CONSOLE_PRERAM_BASE - hex "memory address of the CBMEM console buffer" - default 0x9b00f800 - help - Allocate 4KB to the pre-ram console buffer, we should be able to use - GRAM eventually and have a much larger buffer. - -config BOOTBLOCK_STACK_BOTTOM - hex - default 0x9b00e000 - help - This allocates 6KB of stack space. One needs to verify that this is - sufficient. - -config BOOTBLOCK_STACK_TOP - hex - default CBMEM_CONSOLE_PRERAM_BASE - help - Bootblock stack starts immediately under the CBMEM console buffer, - stack location might be changed by romstage. endif diff --git a/src/soc/imgtec/pistachio/Makefile.inc b/src/soc/imgtec/pistachio/Makefile.inc index b91bb1b5..d052c8f 100644 --- a/src/soc/imgtec/pistachio/Makefile.inc +++ b/src/soc/imgtec/pistachio/Makefile.inc @@ -51,5 +51,5 @@ $(objcbfs)/bootblock.raw: $(objcbfs)/bootblock.elf # Create a complete bootblock which will start up the system $(objcbfs)/bootblock.bin: $(objcbfs)/bootblock.raw $(BIMGTOOL) @printf " BIMGTOOL $(subst $(obj)/,,$(@))\n" - $(BIMGTOOL) $< $@ $(CONFIG_BOOTBLOCK_BASE) + $(BIMGTOOL) $< $@ $(call loadaddr,bootblock)
diff --git a/src/soc/imgtec/pistachio/memlayout.ld b/src/soc/imgtec/pistachio/memlayout.ld new file mode 100644 index 0000000..21c3d73 --- /dev/null +++ b/src/soc/imgtec/pistachio/memlayout.ld @@ -0,0 +1,38 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> + +#include <arch/header.ld> + +/* TODO: This should be revised by someone who understands the SoC better. */ + +SECTIONS +{ + CBFS_CACHE(0x0, 0) /* TODO: fix this, it was already broken before!!! */ + + DRAM_START(0x80000000) + RAMSTAGE(0x80000000, 128K) + + /* TODO: Does this SoC use SRAM? Add SRAM_START() and SRAM_END(). */ + BOOTBLOCK(0x9B000000, 16K) + ROMSTAGE(0x9B004000, 40K) + STACK(0x9B00E000, 6K) + PRERAM_CBMEM_CONSOLE(0x9B00F800, 3K) +} diff --git a/src/soc/nvidia/tegra124/Kconfig b/src/soc/nvidia/tegra124/Kconfig index 4fcc6b4..c691ee8 100644 --- a/src/soc/nvidia/tegra124/Kconfig +++ b/src/soc/nvidia/tegra124/Kconfig @@ -21,34 +21,6 @@ config BOOTBLOCK_CPU_INIT bootblock must load microcode or copy data from ROM before searching for the bootblock.
-# ROM image layout. -# -# 0x00000 Combined bootblock and BCT blob -# 0x18000 Master CBFS header. -# 0x18080 Free for CBFS data. -# -# iRAM (256k) layout. -# (Note: The BootROM uses the address range [0x4000_0000:0x4000_E000) itself, -# so the bootblock loading address must be placed after that. After the -# handoff that area may be reclaimed for other uses, e.g. CBFS cache.) -# -# 0x4000_0000 TTB (16K+32B). 32B is for L1 table of LPAE. -# 0x4000_4020 CBFS mapping cache (96K-32B) -# 0x4001_C000 Stack (16KB... don't reduce without comparing LZMA scratchpad!). -# 0x4002_0000 Bootblock (max 48KB). -# 0x4002_C000 ROM stage (max 80KB). -# 0x4003_FFFF End of iRAM. -# -# if VBOOT2_VERIFY_FIRMWARE, -# 0x4000_0000 TTB (16K+32B). 32B is for L1 table of LPAE. -# 0x4000_4020 CBMEM console area (8K-32B) -# 0x4000_6000 CBFS mapping cache (72K) -# 0x4001_8000 vboot work buffer (16K) -# 0x4001_C000 Stack (16KB... don't reduce without comparing LZMA scratchpad!). -# 0x4002_0000 bootblock and romstage (max 70KB). -# 0x4003_1000 verstage (max 60KB). -# 0x4003_FFFF End of iRAM. - config BOOTBLOCK_ROM_OFFSET hex default 0x0 @@ -61,65 +33,6 @@ config CBFS_ROM_OFFSET hex "offset of CBFS data in ROM" default 0x18080
-config SYS_SDRAM_BASE - hex - default 0x80000000 - -config BOOTBLOCK_BASE - hex - default 0x40020000 - -# this has to be big enough to leave room big enough for the larger of the -# bootblock and the romstage. -config VERSTAGE_BASE - hex - default 0x40031000 - -# with vboot2, romstage is loaded over to the bootblock space -config ROMSTAGE_BASE - hex - default 0x40020000 if VBOOT2_VERIFY_FIRMWARE - default 0x4002c000 - -config RAMSTAGE_BASE - hex - default 0x80200000 - -config STACK_TOP - hex - default 0x40020000 - -config STACK_BOTTOM - hex - default 0x4001c000 - -# This is the ramstage thread stack, *not* the same as above! Currently unused. -config STACK_SIZE - hex - default 0x800 - -# TTB needs to be aligned to 16KB. Stick it in iRAM. -config TTB_BUFFER - hex "memory address of the TTB buffer" - default 0x40000000 - -config CBFS_CACHE_ADDRESS - hex "memory address to put CBFS cache data" - default 0x40004020 - -config CBFS_CACHE_SIZE - hex "size of CBFS cache data" - default 0x00012000 if VBOOT2_VERIFY_FIRMWARE - default 0x00016000 - -config VBOOT_WORK_BUFFER_ADDRESS - hex "memory address of vboot work buffer" - default 0x40018000 - -config VBOOT_WORK_BUFFER_SIZE - hex "size of vboot work buffer" - default 0x00004000 - config TEGRA124_MODEL_TD570D bool "TD570D"
diff --git a/src/soc/nvidia/tegra124/Makefile.inc b/src/soc/nvidia/tegra124/Makefile.inc index d32580e..6de142d 100644 --- a/src/soc/nvidia/tegra124/Makefile.inc +++ b/src/soc/nvidia/tegra124/Makefile.inc @@ -103,6 +103,6 @@ $(objcbfs)/bootblock.bin: $(objcbfs)/bootblock.raw.bin $(BCT_BIN) $(CBOOTIMAGE) echo "Version = 1;" > $(BCT_WRAPPER) echo "Redundancy = 1;" >> $(BCT_WRAPPER) echo "Bctfile = $(BCT_BIN);" >> $(BCT_WRAPPER) - echo "BootLoader = $<,$(CONFIG_BOOTBLOCK_BASE),$(CONFIG_BOOTBLOCK_BASE),Complete;" >> $(BCT_WRAPPER) + echo "BootLoader = $<,$(call loadaddr,bootblock),$(call loadaddr,bootblock),Complete;" >> $(BCT_WRAPPER) @printf " CBOOTIMAGE $(subst $(obj)/,,$(@))\n" $(CBOOTIMAGE) $(BCT_WRAPPER) $@ diff --git a/src/soc/nvidia/tegra124/bootblock_asm.S b/src/soc/nvidia/tegra124/bootblock_asm.S index e4d4302..1a30dda 100644 --- a/src/soc/nvidia/tegra124/bootblock_asm.S +++ b/src/soc/nvidia/tegra124/bootblock_asm.S @@ -44,10 +44,8 @@ ENTRY(_start) * Initialize the stack to a known value. This is used to check for * stack overflow later in the boot process. */ - ldr r0, .Stack - ldr r1, .Stack_size - sub r0, r0, r1 - ldr r1, .Stack + ldr r0, =_stack + ldr r1, =_estack ldr r2, =0xdeadbeef init_stack_loop: str r2, [r0] @@ -57,7 +55,7 @@ init_stack_loop:
/* Set stackpointer in internal RAM to call bootblock main() */ call_bootblock: - ldr sp, .Stack /* Set up stack pointer */ + ldr sp, =_estack /* Set up stack pointer */ ldr r0,=0x00000000 /* * The current design of cpu_info places the @@ -75,15 +73,3 @@ call_bootblock: */ bl main ENDPROC(_start) - -/* we do it this way because it's a 32-bit constant and - * in some cases too far away to be loaded as just an offset - * from IP - */ -.align 2 -.Stack: - .word CONFIG_STACK_TOP -.align 2 -/* create this size the same way we do in coreboot_ram.ld: top-bottom */ -.Stack_size: - .word CONFIG_STACK_TOP - CONFIG_STACK_BOTTOM diff --git a/src/soc/nvidia/tegra124/cbfs.c b/src/soc/nvidia/tegra124/cbfs.c index 4497d6a..d56050d 100644 --- a/src/soc/nvidia/tegra124/cbfs.c +++ b/src/soc/nvidia/tegra124/cbfs.c @@ -19,12 +19,12 @@
#include <cbfs.h> /* This driver serves as a CBFS media source. */ +#include <symbols.h>
#include "spi.h"
int init_default_cbfs_media(struct cbfs_media *media) { return initialize_tegra_spi_cbfs_media(media, - (void*)CONFIG_CBFS_CACHE_ADDRESS, - CONFIG_CBFS_CACHE_SIZE); + _cbfs_cache, _cbfs_cache_size); } diff --git a/src/soc/nvidia/tegra124/clock.c b/src/soc/nvidia/tegra124/clock.c index fa33283..f5043af 100644 --- a/src/soc/nvidia/tegra124/clock.c +++ b/src/soc/nvidia/tegra124/clock.c @@ -20,6 +20,7 @@ #include <soc/addressmap.h> #include <soc/clock.h> #include <stdlib.h> +#include <symbols.h> #include <arch/clock.h> #include "clk_rst.h" #include "flow.h" @@ -485,7 +486,7 @@ void clock_cpu0_config(void *entry) { void * const evp_cpu_reset = (uint8_t *)TEGRA_EVP_BASE + 0x100;
- write32(CONFIG_STACK_TOP, &maincpu_stack_pointer); + write32((uintptr_t)_estack, &maincpu_stack_pointer); write32((uintptr_t)entry, &maincpu_entry_point); write32((uintptr_t)&maincpu_setup, evp_cpu_reset);
diff --git a/src/soc/nvidia/tegra124/memlayout.ld b/src/soc/nvidia/tegra124/memlayout.ld new file mode 100644 index 0000000..0d9e772 --- /dev/null +++ b/src/soc/nvidia/tegra124/memlayout.ld @@ -0,0 +1,48 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> +#include <vendorcode/google/chromeos/memlayout.h> + +#include <arch/header.ld> + +/* + * Note: The BootROM uses the address range [0x4000_0000:0x4000_E000) itself, + * so the bootblock loading address must be placed after that. After the + * handoff that area may be reclaimed for other uses, e.g. CBFS cache. + */ + +SECTIONS +{ + SRAM_START(0x40000000) + TTB(0x40000000, 16K + 32) + PRERAM_CBMEM_CONSOLE(0x40004020, 8K - 32) + PRERAM_CBFS_CACHE(0x40006000, 16K) + VBOOT2_WORK(0x4000A000, 16K) + STACK(0x4000E000, 8K) + BOOTBLOCK(0x40010000, 24K) + VERSTAGE(0x40016000, 72K) + ROMSTAGE(0x40028000, 96K) + SRAM_END(0x40040000) + + DRAM_START(0x80000000) + POSTRAM_CBFS_CACHE(0x80100000, 1M) + RAMSTAGE(0x80200000, 128K) + DMA_COHERENT(0x90000000, 2M) +} diff --git a/src/soc/nvidia/tegra124/sdram.c b/src/soc/nvidia/tegra124/sdram.c index f0797db..82219b1 100644 --- a/src/soc/nvidia/tegra124/sdram.c +++ b/src/soc/nvidia/tegra124/sdram.c @@ -23,6 +23,7 @@ #include <soc/addressmap.h> #include <soc/clock.h> #include <stdlib.h> +#include <symbols.h>
#include "emc.h" #include "mc.h" @@ -643,5 +644,5 @@ int sdram_size_mb(void)
uintptr_t sdram_max_addressable_mb(void) { - return MIN((CONFIG_SYS_SDRAM_BASE/MiB) + sdram_size_mb(), 4096); + return MIN(((uintptr_t)_dram/MiB) + sdram_size_mb(), 4096); } diff --git a/src/soc/nvidia/tegra124/soc.c b/src/soc/nvidia/tegra124/soc.c index 48e50bd..5da41a9 100644 --- a/src/soc/nvidia/tegra124/soc.c +++ b/src/soc/nvidia/tegra124/soc.c @@ -26,6 +26,7 @@ #include <soc/nvidia/tegra124/sdram.h> #include "chip.h" #include <soc/display.h> +#include <symbols.h> #include <vendorcode/google/chromeos/chromeos.h>
/* this sucks, but for now, fb size/location are hardcoded. @@ -37,12 +38,12 @@ static void soc_enable(device_t dev) u32 lcdbase = fb_base_mb(); unsigned long fb_size = FB_SIZE_MB;
- ram_resource(dev, 0, CONFIG_SYS_SDRAM_BASE/KiB, + ram_resource(dev, 0, (uintptr_t)_dram/KiB, (sdram_max_addressable_mb() - fb_size)*KiB - - CONFIG_SYS_SDRAM_BASE/KiB); + (uintptr_t)_dram/KiB); mmio_resource(dev, 1, lcdbase*KiB, fb_size*KiB);
- u32 sdram_end_mb = sdram_size_mb() + CONFIG_SYS_SDRAM_BASE/MiB; + u32 sdram_end_mb = sdram_size_mb() + (uintptr_t)_dram/MiB;
if (sdram_end_mb > sdram_max_addressable_mb()) ram_resource(dev, 2, sdram_max_addressable_mb()*KiB, diff --git a/src/soc/nvidia/tegra124/verstage.c b/src/soc/nvidia/tegra124/verstage.c index 60361a2..2e5ddf2 100644 --- a/src/soc/nvidia/tegra124/verstage.c +++ b/src/soc/nvidia/tegra124/verstage.c @@ -22,6 +22,8 @@ #include <console/console.h> #include <soc/nvidia/tegra124/cache.h> #include <soc/nvidia/tegra124/early_configs.h> +#include <stdlib.h> +#include <symbols.h> #include <vendorcode/google/chromeos/chromeos.h>
static void enable_cache(void) @@ -29,8 +31,9 @@ static void enable_cache(void) mmu_init(); /* Whole space is uncached. */ mmu_config_range(0, 4096, DCACHE_OFF); - /* SRAM is cached. Round the size up to 2MB, the LPAE page size. */ - mmu_config_range(0x40000000 >> 20, 1, DCACHE_WRITEBACK); + /* SRAM is cached. MMU code will round size up to page size. */ + mmu_config_range((uintptr_t)_sram/MiB, div_round_up(_sram_size, MiB), + DCACHE_WRITEBACK); mmu_disable_range(0, 1); dcache_mmu_enable(); } diff --git a/src/soc/nvidia/tegra132/Kconfig b/src/soc/nvidia/tegra132/Kconfig index 24bf864..c87698a 100644 --- a/src/soc/nvidia/tegra132/Kconfig +++ b/src/soc/nvidia/tegra132/Kconfig @@ -43,50 +43,6 @@ config CBFS_ROM_OFFSET hex "offset of CBFS data in ROM" default 0x40080
-config BOOTBLOCK_BASE - hex - default 0x40020000 - -config ROMSTAGE_BASE - hex - default 0x40025000 - -config SYS_SDRAM_BASE - hex - default 0x80000000 - -config RAMSTAGE_BASE - hex - default 0x80200000 - -config BOOTBLOCK_STACK_TOP - hex - default 0x40020000 - -config BOOTBLOCK_STACK_BOTTOM - hex - default 0x4001c000 - -config ROMSTAGE_STACK_TOP - hex - default 0x40020000 - -config ROMSTAGE_STACK_BOTTOM - hex - default 0x4001c000 - -config CBFS_CACHE_ADDRESS - hex "memory address to put CBFS cache data" - default 0x40006000 - -config CBFS_CACHE_SIZE - hex "size of CBFS cache data" - default 0x00016000 - -config CONSOLE_PRERAM_BUFFER_BASE - hex "memory address of the CBMEM console buffer" - default 0x40004020 - config MTS_DIRECTORY string "Directory where MTS microcode files are located" default "3rdparty/cpu/nvidia/tegra132/current/prod" diff --git a/src/soc/nvidia/tegra132/Makefile.inc b/src/soc/nvidia/tegra132/Makefile.inc index 10d4d4e..81d08f5 100644 --- a/src/soc/nvidia/tegra132/Makefile.inc +++ b/src/soc/nvidia/tegra132/Makefile.inc @@ -114,7 +114,7 @@ $(objcbfs)/bootblock.bin: $(objcbfs)/bootblock.raw.bin $(BCT_BIN) $(CBOOTIMAGE) echo "Bctcopy = 1;" >> $(BCT_WRAPPER) echo "Bctfile = $(BCT_BIN);" >> $(BCT_WRAPPER) echo "MtsPreboot = $(PREBOOT_MTS_FILE),0x4000f000,0x4000f000,Complete;" >> $(BCT_WRAPPER) - echo "BootLoader = $<,$(CONFIG_BOOTBLOCK_BASE),$(CONFIG_BOOTBLOCK_BASE),Complete;" >> $(BCT_WRAPPER) + echo "BootLoader = $<,$(call loadaddr,bootblock),$(call loadaddr,bootblock),Complete;" >> $(BCT_WRAPPER) @printf " CBOOTIMAGE $(subst $(obj)/,,$(@))\n" $(CBOOTIMAGE) $(CBOOTIMAGE_OPTS) $(BCT_WRAPPER) $@
diff --git a/src/soc/nvidia/tegra132/addressmap.c b/src/soc/nvidia/tegra132/addressmap.c index d7ade2f..8b5a069 100644 --- a/src/soc/nvidia/tegra132/addressmap.c +++ b/src/soc/nvidia/tegra132/addressmap.c @@ -24,6 +24,7 @@ #include <soc/addressmap.h> #include <soc/display.h> #include <soc/id.h> +#include <symbols.h> #include "mc.h" #include "sdram.h"
@@ -106,7 +107,7 @@ static void memory_in_range(uintptr_t *base_mib, uintptr_t *end_mib, uintptr_t end; int i;
- base = CONFIG_SYS_SDRAM_BASE / MiB; + base = (uintptr_t)_dram / MiB; end = base + sdram_size_mb();
/* Requested limits out of range. */ diff --git a/src/soc/nvidia/tegra132/bootblock_asm.S b/src/soc/nvidia/tegra132/bootblock_asm.S index 1b2fbb7..bf63c02 100644 --- a/src/soc/nvidia/tegra132/bootblock_asm.S +++ b/src/soc/nvidia/tegra132/bootblock_asm.S @@ -42,17 +42,5 @@ ENTRY(_start) */ msr cpsr_cxf, #0xdf
- stack_init stack=.Stack size=.Stack_size seed=1 func=main + stack_init stack_top=_estack stack_bottom=_stack seed=1 func=main ENDPROC(_start) - -/* we do it this way because it's a 32-bit constant and - * in some cases too far away to be loaded as just an offset - * from IP - */ -.align 2 -.Stack: - .word CONFIG_BOOTBLOCK_STACK_TOP -.align 2 -/* create this size the same way we do in ramstage.ld: top-bottom */ -.Stack_size: - .word CONFIG_BOOTBLOCK_STACK_TOP - CONFIG_BOOTBLOCK_STACK_BOTTOM diff --git a/src/soc/nvidia/tegra132/cbfs.c b/src/soc/nvidia/tegra132/cbfs.c index 7b75f7c..648d136 100644 --- a/src/soc/nvidia/tegra132/cbfs.c +++ b/src/soc/nvidia/tegra132/cbfs.c @@ -19,12 +19,12 @@
#include "spi.h"
int init_default_cbfs_media(struct cbfs_media *media) { return initialize_tegra_spi_cbfs_media(media, - (void*)CONFIG_CBFS_CACHE_ADDRESS, - CONFIG_CBFS_CACHE_SIZE); + _cbfs_cache, _cbfs_cache_size); } diff --git a/src/soc/nvidia/tegra132/memlayout.ld b/src/soc/nvidia/tegra132/memlayout.ld new file mode 100644 index 0000000..63cf4f0 --- /dev/null +++ b/src/soc/nvidia/tegra132/memlayout.ld @@ -0,0 +1,44 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> + +#include <arch/header.ld> + +/* + * Note: The BootROM uses the address range [0x4000_0000:0x4000_E000) itself, + * so the bootblock loading address must be placed after that. After the + * handoff that area may be reclaimed for other uses, e.g. CBFS cache. + * TODO: Did this change on Tegra132? What's the new valid range? + */ + +SECTIONS +{ + SRAM_START(0x40000000) + /* 16K hole */ + PRERAM_CBMEM_CONSOLE(0x40004000, 8K) + CBFS_CACHE(0x40006000, 88K) + STACK(0x4001C000, 16K) + BOOTBLOCK(0x40020000, 20K) + ROMSTAGE(0x40025000, 108K) + SRAM_END(0x40040000) + + DRAM_START(0x80000000) + RAMSTAGE(0x80200000, 192K) +} diff --git a/src/soc/nvidia/tegra132/romstage_asm.S b/src/soc/nvidia/tegra132/romstage_asm.S index ac3c93e..d0b036c 100644 --- a/src/soc/nvidia/tegra132/romstage_asm.S +++ b/src/soc/nvidia/tegra132/romstage_asm.S @@ -23,17 +23,5 @@ .section ".text", "ax", %progbits
ENTRY(main) - stack_init stack=.Stack size=.Stack_size seed=0 func=romstage + stack_init stack_top=_estack stack_bottom=_stack seed=0 func=romstage ENDPROC(main) - -/* we do it this way because it's a 32-bit constant and - * in some cases too far away to be loaded as just an offset - * from IP - */ -.align 2 -.Stack: - .word CONFIG_ROMSTAGE_STACK_TOP -.align 2 -.Stack_size: - .word CONFIG_ROMSTAGE_STACK_TOP - CONFIG_ROMSTAGE_STACK_BOTTOM - diff --git a/src/soc/nvidia/tegra132/stack.S b/src/soc/nvidia/tegra132/stack.S index 6d3cd4e..3b877e4 100644 --- a/src/soc/nvidia/tegra132/stack.S +++ b/src/soc/nvidia/tegra132/stack.S @@ -19,21 +19,19 @@
/* Macro to initialize stack, perform seeding if required and finally call the * function provided - * @stack : Stack address - * @size : Stack size - * @seed : Stack seeding required (1=yes/otherwise=no) - * @func : Function to call after initializing stack + * @stack_top : First address above the stack + * @stack_bottom : Lowest address on the stack + * @seed : Stack seeding required (1=yes/otherwise=no) + * @func : Function to call after initializing stack */ -.macro stack_init stack, size, seed, func +.macro stack_init stack_top, stack_bottom, seed, func /* Check if stack seeding is required */ mov r0, #\seed cmp r0, #1 bne call_func /* Stack seeding */ - ldr r0, \stack - ldr r1, \size - sub r0, r0, r1 - ldr r1, \stack + ldr r0, =\stack_bottom + ldr r1, =\stack_top ldr r2, =0xdeadbeef init_stack_loop: str r2, [r0] @@ -42,6 +40,6 @@ init_stack_loop: bne init_stack_loop
call_func: - ldr sp, \stack /* Set up stack pointer */ + ldr sp, =\stack_top /* Set up stack pointer */ bl \func .endm diff --git a/src/soc/qualcomm/ipq806x/Kconfig b/src/soc/qualcomm/ipq806x/Kconfig index 013d86c..092951d 100644 --- a/src/soc/qualcomm/ipq806x/Kconfig +++ b/src/soc/qualcomm/ipq806x/Kconfig @@ -39,44 +39,4 @@ config SBL_BLOB ipq806x early initialization code, as supplied by the vendor.
-config BOOTBLOCK_BASE - hex "256K bytes left for TZBSP" - default 0x40600000 - -config ROMSTAGE_BASE - hex - default 0x40620000 - -config RAMSTAGE_BASE - hex - default 0x40640000 - -config SYS_SDRAM_BASE - hex - default 0x40000000 - -config CBMEM_CONSOLE_PRERAM_BASE - hex "memory address of the pre-RAM CBMEM console buffer" - default 0x40618000 - -config STACK_TOP - hex - default 0x40600000 - -config STACK_BOTTOM - hex - default 0x405fc000 - -config CBFS_CACHE_ADDRESS - hex "memory address to put CBFS cache data" - default 0x405cc000 - -config CBFS_CACHE_SIZE - hex "size of CBFS cache data" - default 0x00030000 - -config TTB_BUFFER - hex "memory address for page tables" - default 0x2a05c000 - endif diff --git a/src/soc/qualcomm/ipq806x/Makefile.inc b/src/soc/qualcomm/ipq806x/Makefile.inc index a7dabc6..5dfca4d 100644 --- a/src/soc/qualcomm/ipq806x/Makefile.inc +++ b/src/soc/qualcomm/ipq806x/Makefile.inc @@ -51,7 +51,7 @@ $(objcbfs)/bootblock.raw: $(objcbfs)/bootblock.elf # Add MBN header to allow SBL3 to start coreboot bootblock $(objcbfs)/bootblock.mbn: $(objcbfs)/bootblock.raw @printf " ADD MBN $(subst $(obj)/,,$(@))\n" - ./util/ipqheader/ipqheader.py $(CONFIG_BOOTBLOCK_BASE) $< $@.tmp + ./util/ipqheader/ipqheader.py $(call loadaddr,bootblock) $< $@.tmp @mv $@.tmp $@
# Create a complete bootblock which will start up the system diff --git a/src/soc/qualcomm/ipq806x/cbmem.c b/src/soc/qualcomm/ipq806x/cbmem.c index ecb02e4..fdf2605 100644 --- a/src/soc/qualcomm/ipq806x/cbmem.c +++ b/src/soc/qualcomm/ipq806x/cbmem.c @@ -19,9 +19,9 @@
#include <cbmem.h> #include <stddef.h> +#include <symbols.h>
void *cbmem_top(void) { - return (void *)((uintptr_t)CONFIG_SYS_SDRAM_BASE + - (CONFIG_DRAM_SIZE_MB << 20)); + return (void *)((uintptr_t)_dram + CONFIG_DRAM_SIZE_MB*MiB); } diff --git a/src/soc/qualcomm/ipq806x/memlayout.ld b/src/soc/qualcomm/ipq806x/memlayout.ld new file mode 100644 index 0000000..9158c17 --- /dev/null +++ b/src/soc/qualcomm/ipq806x/memlayout.ld @@ -0,0 +1,40 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> + +#include <arch/header.ld> + +/* TODO: This should be revised by someone who understands the SoC better. */ + +SECTIONS +{ + /* TODO: add SRAM_START(), SRAM_END() and REGION(reserved_sbl) */ + TTB(0x2A05C000, 16K) + + DRAM_START(0x40000000) + CBFS_CACHE(0x405CC000, 192K) + STACK(0x405FC000, 16K) + /* TODO: "256K bytes left for TZBSP"... what does that mean? */ + BOOTBLOCK(0x40600000, 32K) + PRERAM_CBMEM_CONSOLE(0x40618000, 8K) + ROMSTAGE(0x40620000, 128K) + RAMSTAGE(0x40640000, 128K) + DMA_COHERENT(0x5A000000, 2M) +} diff --git a/src/soc/qualcomm/ipq806x/soc.c b/src/soc/qualcomm/ipq806x/soc.c index 6421ccd..1d63cac 100644 --- a/src/soc/qualcomm/ipq806x/soc.c +++ b/src/soc/qualcomm/ipq806x/soc.c @@ -21,16 +21,15 @@
#include <console/console.h> #include <device/device.h> - +#include <symbols.h>
#define RESERVED_SIZE_KB (0x01500000 / KiB)
static void soc_read_resources(device_t dev) { /* Reserve bottom 0x150_0000 bytes for NSS, SMEM, etc. */ - reserved_ram_resource(dev, 0, - CONFIG_SYS_SDRAM_BASE/KiB, RESERVED_SIZE_KB); - ram_resource(dev, 0, CONFIG_SYS_SDRAM_BASE/KiB + RESERVED_SIZE_KB, + reserved_ram_resource(dev, 0, (uintptr_t)_dram / KiB, RESERVED_SIZE_KB); + ram_resource(dev, 0, (uintptr_t)_dram / KiB + RESERVED_SIZE_KB, (CONFIG_DRAM_SIZE_MB * KiB) - RESERVED_SIZE_KB); }
diff --git a/src/soc/rockchip/rk3288/Kconfig b/src/soc/rockchip/rk3288/Kconfig index 359ce2f..e61e5a3 100644 --- a/src/soc/rockchip/rk3288/Kconfig +++ b/src/soc/rockchip/rk3288/Kconfig @@ -42,45 +42,6 @@ config BOOTBLOCK_CPU_INIT # 0x00000 Combined bootblock and ID Block # 0x08000 Master CBFS header. # 0x18000 Free for CBFS data. -# -# iRAM (96k) layout. -# (Note: The BootROM will jump to 0xff704004 after loading bootblock, -# so the bootblock loading address must be at 0xff704004.) -# -# 0xFF70_0000 TTB (16KB). -# 0xFF70_4004 Bootblock (max 16KB-4B). -# 0xFF70_8000 ROM stage (max 40KB). -# 0xFF71_2000 STACK (4KB). -# 0xFF71_3000 CBFS mapping cache (20K) -# 0xFF71_7FFF End of iRAM. - -config SYS_SRAM_BASE - hex "SRAM base address" - default 0xFF700000 - -config SYS_SDRAM_BASE - hex "SDRAM base address" - default 0x00000000 - -config STACK_TOP - hex "STACK TOP" - default 0xff713000 - -config STACK_BOTTOM - hex "STACK BOTTOM" - default 0xff712000 - -config BOOTBLOCK_BASE - hex - default 0xff704004 - -config ROMSTAGE_BASE - hex "ROM STAGE BASE" - default 0xff708000 - -config RAMSTAGE_BASE - hex "RAMSTAGE BASE" - default 0x00200000
config BOOTBLOCK_ROM_OFFSET hex @@ -94,26 +55,6 @@ config CBFS_ROM_OFFSET hex default 0x0018000
-config CBFS_SRAM_CACHE_ADDRESS - hex "sram memory address to put CBFS cache data" - default 0xff713000 - -config CBFS_SRAM_CACHE_SIZE - hex "size of CBFS cache data" - default 0x00005000 - -config CBFS_DRAM_CACHE_ADDRESS - hex "dram memory address to put CBFS cache data" - default 0x01000000 - -config CBFS_DRAM_CACHE_SIZE - hex "size of CBFS cache data" - default 0x00100000 - -config TTB_BUFFER - hex "memory address of the TTB buffer" - default 0xff700000 - config CONSOLE_SERIAL_UART_ADDRESS hex depends on CONSOLE_SERIAL_UART diff --git a/src/soc/rockchip/rk3288/media.c b/src/soc/rockchip/rk3288/media.c index 1389eb2..f2471f9 100644 --- a/src/soc/rockchip/rk3288/media.c +++ b/src/soc/rockchip/rk3288/media.c @@ -18,19 +18,12 @@ */
#include <cbfs.h> -#include <string.h> -#include <console/console.h> -#include "soc/rockchip/rk3288/spi.h" +#include <symbols.h> + +#include "spi.h"
int init_default_cbfs_media(struct cbfs_media *media) { -#if defined(__BOOT_BLOCK__) - return initialize_rockchip_spi_cbfs_media(media, - (void *)CONFIG_CBFS_SRAM_CACHE_ADDRESS, - CONFIG_CBFS_SRAM_CACHE_SIZE); -#else return initialize_rockchip_spi_cbfs_media(media, - (void *)CONFIG_CBFS_DRAM_CACHE_ADDRESS, - CONFIG_CBFS_DRAM_CACHE_SIZE); -#endif + _cbfs_cache, _cbfs_cache_size); } diff --git a/src/soc/rockchip/rk3288/memlayout.ld b/src/soc/rockchip/rk3288/memlayout.ld new file mode 100644 index 0000000..6faec63 --- /dev/null +++ b/src/soc/rockchip/rk3288/memlayout.ld @@ -0,0 +1,48 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> +#include <vendorcode/google/chromeos/memlayout.h> + +#include <arch/header.ld> + +/* Note: The BootROM will jump to 0xFF704004 after loading bootblock, + * so the bootblock loading address must be at 0xFF704004. + */ +SECTIONS +{ + DRAM_START(0x00000000) + RAMSTAGE(0x00200000, 128K) + POSTRAM_CBFS_CACHE(0x01000000, 1M) + DMA_COHERENT(0x10000000, 2M) + + SRAM_START(0xFF700000) + TTB(0xFF700000, 16K) + BOOTBLOCK(0xFF704004, 16K - 4) + VBOOT2_WORK(0xFF708000, 16K) + OVERLAP_VERSTAGE_ROMSTAGE(0xFF70C000, 40K) + PRERAM_CBFS_CACHE(0xFF716000, 4K) + STACK(0xFF717000, 4K) + SRAM_END(0xFF718000) + + /* 4K of special SRAM in PMU power domain. Careful: only supports 32-bit + * wide write accesses! Only use with MMU and writeback mapping. */ + SYMBOL(pmu_sram, 0xFF720000) + SYMBOL(epmu_sram, 0xFF721000) +} diff --git a/src/soc/samsung/exynos5250/Kconfig b/src/soc/samsung/exynos5250/Kconfig index 3c7d6c4..4126ec1 100644 --- a/src/soc/samsung/exynos5250/Kconfig +++ b/src/soc/samsung/exynos5250/Kconfig @@ -32,59 +32,4 @@ config CBFS_ROM_OFFSET hex "offset of CBFS data in ROM" default 0x0A080
-config SYS_SDRAM_BASE - hex - default 0x40000000 - -# Example SRAM/iRAM map for Exynos5250 platform: -# -# 0x0202_0000: vendor-provided BL1 -# 0x0202_3400: bootblock, assume up to 32KB in size -# 0x0203_0000: romstage, assume up to 128KB in size. -# 0x0207_8000: stack pointer - -config BOOTBLOCK_BASE - hex - default 0x02023400 - -config ROMSTAGE_BASE - hex - default 0x02030000 - -config RAMSTAGE_BASE - hex - default SYS_SDRAM_BASE - -# Stack may reside in either IRAM or DRAM. We will define it to live -# at the top of IRAM for now. -# -# Stack grows downward, push operation stores register contents in -# consecutive memory locations ending just below SP -config STACK_TOP - hex - default 0x02078000 - -config STACK_BOTTOM - hex - default 0x02074000 - -config STACK_SIZE - hex - default 0x4000 - -# TODO We may probably move this to board-specific implementation files instead -# of KConfig values. -config CBFS_CACHE_ADDRESS - hex "memory address to put CBFS cache data" - default 0x0205c000 - -config CBFS_CACHE_SIZE - hex "size of CBFS cache data" - default 0x00018000 - -# TTB needs to be aligned to 16KB. -config TTB_BUFFER - hex "memory address of the TTB buffer" - default 0x02058000 - endif diff --git a/src/soc/samsung/exynos5250/alternate_cbfs.c b/src/soc/samsung/exynos5250/alternate_cbfs.c index 10b33f0..e46221c 100644 --- a/src/soc/samsung/exynos5250/alternate_cbfs.c +++ b/src/soc/samsung/exynos5250/alternate_cbfs.c @@ -22,6 +22,7 @@ #include <cbfs.h> /* This driver serves as a CBFS media source. */ #include <stdlib.h> #include <string.h> +#include <symbols.h> #include <console/console.h> #include "alternate_cbfs.h" #include "power.h" @@ -33,14 +34,14 @@ * by the IROM / BL1, so this code has nothing to do with them. * * The third transfer is a valid CBFS image that contains only the romstage, - * and must be small enough to fit into alternate_cbfs_size[__BOOT_BLOCK__] in + * and must be small enough to fit into the PRE_RAM CBFS cache in * IRAM. It is loaded when this function gets called in the boot block, and * the normal CBFS code extracts the romstage from it. * * The fourth transfer is also a CBFS image, but can be of arbitrary size and * should contain all available stages/payloads/etc. It is loaded when this * function is called a second time at the end of the romstage, and copied to - * alternate_cbfs_buffer[!__BOOT_BLOCK__] in DRAM. It will reside there for the + * the romstage/ramstage CBFS cache in DRAM. It will reside there for the * rest of the firmware's lifetime and all subsequent stages (which will not * have __PRE_RAM__ defined) can just directly reference it there. */ @@ -60,12 +61,12 @@ static int usb_cbfs_open(struct cbfs_media *media)
/* * We need to trust the host/irom to copy the image to our - * alternate_cbfs_buffer address... there is no way to control or even + * _cbfs_cache address... there is no way to control or even * check the transfer size or target address from our side. */
printk(BIOS_DEBUG, "USB A-A transfer successful, CBFS image should now" - " be at %p\n", alternate_cbfs_buffer); + " be at %p\n", _cbfs_cache); first_run = 0; #endif return 0; @@ -86,11 +87,11 @@ static int sdmmc_cbfs_open(struct cbfs_media *media) * In the bootblock, we just copy the small part that fits in the buffer * and hope that it's enough (since the romstage is currently always the * first component in the image, this should work out). In the romstage, - * we copy until our buffer is full (currently 12M) to avoid the pain of + * we copy until our cache is full (currently 12M) to avoid the pain of * figuring out the true image size from in here. Since this is mainly a * developer/debug boot mode, those shortcomings should be bearable. */ - const u32 count = alternate_cbfs_size / 512; + const u32 count = _cbfs_cache_size / 512; static int first_run = 1; int (*irom_load_sdmmc)(u32 start, u32 count, void *dst) = *irom_sdmmc_read_blocks_ptr; @@ -98,13 +99,13 @@ static int sdmmc_cbfs_open(struct cbfs_media *media) if (!first_run) return 0;
- if (!irom_load_sdmmc(1, count, alternate_cbfs_buffer)) { + if (!irom_load_sdmmc(1, count, _cbfs_cache)) { printk(BIOS_EMERG, "Unable to load CBFS image from SDMMC!\n"); return -1; }
printk(BIOS_DEBUG, "SDMMC read successful, CBFS image should now be" - " at %p\n", alternate_cbfs_buffer); + " at %p\n", _cbfs_cache); first_run = 0; #endif return 0; @@ -115,16 +116,16 @@ static int alternate_cbfs_close(struct cbfs_media *media) { return 0; } static size_t alternate_cbfs_read(struct cbfs_media *media, void *dest, size_t offset, size_t count) { - ASSERT(offset + count < alternate_cbfs_size); - memcpy(dest, alternate_cbfs_buffer + offset, count); + ASSERT(offset + count < _cbfs_cache_size); + memcpy(dest, _cbfs_cache + offset, count); return count; }
static void *alternate_cbfs_map(struct cbfs_media *media, size_t offset, size_t count) { - ASSERT(offset + count < alternate_cbfs_size); - return alternate_cbfs_buffer + offset; + ASSERT(offset + count < _cbfs_cache_size); + return _cbfs_cache + offset; }
static void *alternate_cbfs_unmap(struct cbfs_media *media, @@ -166,8 +167,7 @@ int init_default_cbfs_media(struct cbfs_media *media) return initialize_exynos_sdmmc_cbfs_media(media); case OM_STAT_SPI: return initialize_exynos_spi_cbfs_media(media, - (void*)CONFIG_CBFS_CACHE_ADDRESS, - CONFIG_CBFS_CACHE_SIZE); + _cbfs_cache, _cbfs_cache_size); default: printk(BIOS_EMERG, "Exynos OM_STAT value 0x%x not supported!\n", exynos_power->om_stat); diff --git a/src/soc/samsung/exynos5250/alternate_cbfs.h b/src/soc/samsung/exynos5250/alternate_cbfs.h index 72a30ac..fe1af46 100644 --- a/src/soc/samsung/exynos5250/alternate_cbfs.h +++ b/src/soc/samsung/exynos5250/alternate_cbfs.h @@ -36,16 +36,4 @@ static u32 * const iram_secondary_base = (u32 *)0x02020018; #define OM_STAT_SPI 0x14 #define OM_STAT_MASK 0x7f
-#if defined(__BOOT_BLOCK__) - /* A small space in IRAM to hold the romstage-only image */ - static void * const alternate_cbfs_buffer = - (void *)CONFIG_CBFS_CACHE_ADDRESS; - static size_t const alternate_cbfs_size = CONFIG_CBFS_CACHE_SIZE; -#else - /* Just put this anywhere in RAM that's far enough from anything else */ - /* TODO: Find a better way to "reserve" this region? */ - static void * const alternate_cbfs_buffer = (void *)0x77400000; - static size_t const alternate_cbfs_size = 0xc00000; -#endif - #endif diff --git a/src/soc/samsung/exynos5250/cpu.h b/src/soc/samsung/exynos5250/cpu.h index 10f9ef4..c9c5832 100644 --- a/src/soc/samsung/exynos5250/cpu.h +++ b/src/soc/samsung/exynos5250/cpu.h @@ -21,6 +21,7 @@ #define CPU_SAMSUNG_EXYNOS5250_CPU_H
#include <arch/io.h> +#include <symbols.h>
/* Base address registers */ #define EXYNOS5_GPIO_PART6_BASE 0x03860000 /* Z<6:0> */ @@ -76,7 +77,7 @@ extern struct tmu_info exynos5250_tmu_info;
/* TODO clean up defines. */ #define FB_SIZE_KB 4096 -#define RAM_BASE_KB (CONFIG_SYS_SDRAM_BASE >> 10) +#define RAM_BASE_KB ((uintptr_t)_dram/KiB) #define RAM_SIZE_KB (CONFIG_DRAM_SIZE_MB << 10UL)
static inline u32 get_fb_base_kb(void) diff --git a/src/soc/samsung/exynos5250/memlayout.ld b/src/soc/samsung/exynos5250/memlayout.ld new file mode 100644 index 0000000..010bb7b --- /dev/null +++ b/src/soc/samsung/exynos5250/memlayout.ld @@ -0,0 +1,46 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> + +#include <arch/header.ld> + +/* + * Note: The BootROM loads the 8K BL1 at [0x2020000:0x2022000), so the bootblock + * must be placed after that. After the handoff, the space can be reclaimed. + */ + +SECTIONS +{ + SRAM_START(0x2020000) + /* 13K hole, includes BL1 */ + BOOTBLOCK(0x2023400, 32K) + /* 19K hole */ + ROMSTAGE(0x2030000, 128K) + /* 32K hole */ + TTB(0x2058000, 16K) + PRERAM_CBFS_CACHE(0x205C000, 96K) + STACK(0x2074000, 16K) + SRAM_END(0x2078000) + + DRAM_START(0x40000000) + RAMSTAGE(0x40000000, 128K) + POSTRAM_CBFS_CACHE(0x41000000, 8M) + DMA_COHERENT(0x77300000, 1M) +} diff --git a/src/soc/samsung/exynos5420/Kconfig b/src/soc/samsung/exynos5420/Kconfig index bd2bf13..ed9d2f8 100644 --- a/src/soc/samsung/exynos5420/Kconfig +++ b/src/soc/samsung/exynos5420/Kconfig @@ -33,78 +33,4 @@ config CBFS_ROM_OFFSET hex "offset of CBFS data in ROM" default 0x0A000
-config SYS_SDRAM_BASE - hex - default 0x20000000 - -# Example SRAM/iRAM map for Exynos5420 platform: -# -# 0x0202_0000: vendor-provided BL1 -# 0x0202_4400: variable length bootblock checksum header. -# 0x0202_4410: bootblock, assume up to 32KB in size -# 0x0203_0000: romstage, assume up to 128KB in size. -# 0x0205_8000: TTB buffer. -# 0x0205_c000: cache for CBFS data. -# 0x0206_f000: stack bottom -# 0x0207_3000: stack pointer -# 0x0207_3000: shared (with kernel) page for cpu & secondary core states. -# the shared data is currently only <0x50 bytes so we can share -# this page with stack. - -config BOOTBLOCK_BASE - hex - default 0x02024410 - -config ROMSTAGE_BASE - hex - default 0x02030000 - -config RAMSTAGE_BASE - hex - default SYS_SDRAM_BASE - -# Stack may reside in either IRAM or DRAM. We will define it to live -# at the top of IRAM for now. -# -# Stack grows downward, push operation stores register contents in -# consecutive memory locations ending just below SP. -# The setup in the exynos 5420 is a new one for coreboot. We have got -# the bootblock, romstage, and ramstage sharing the same stack space. -# The SRAM is always there and having a known-good stack memory -# makes for a more reliable setup. -# Thus, in this case: -# STACK_TOP: highest stack address in SRAM -# STACK_BOTTOM: lowest stack address in SRAM -# STACK_SIZE: as in standard coreboot usage, size of thread stacks in ramstage -# ROMSTAGE_STACK_SIZE: size of the single stack in romstage - -config STACK_TOP - hex - default 0x02073000 - -config STACK_BOTTOM - hex - default 0x0206f000 - -# STACK_SIZE is for the ramstage core and thread stacks. -# It must be a power of 2, to make the cpu_info computation work, -# and cpu_info needs to work to make SMP startup and threads work. -config STACK_SIZE - hex - default 0x0800 - -# TODO We may probably move this to board-specific implementation files instead -# of KConfig values. -config CBFS_CACHE_ADDRESS - hex "memory address to put CBFS cache data" - default 0x0205c000 - -config CBFS_CACHE_SIZE - hex "size of CBFS cache data" - default 0x00013000 - -config TTB_BUFFER - hex "memory address of the TTB buffer" - default 0x02058000 - endif diff --git a/src/soc/samsung/exynos5420/alternate_cbfs.c b/src/soc/samsung/exynos5420/alternate_cbfs.c index d19098b..7fc0e6d 100644 --- a/src/soc/samsung/exynos5420/alternate_cbfs.c +++ b/src/soc/samsung/exynos5420/alternate_cbfs.c @@ -22,6 +22,7 @@ #include <cbfs.h> /* This driver serves as a CBFS media source. */ #include <stdlib.h> #include <string.h> +#include <symbols.h> #include <arch/cache.h> #include <console/console.h> #include "alternate_cbfs.h" @@ -34,14 +35,14 @@ * by the IROM / BL1, so this code has nothing to do with them. * * The third transfer is a valid CBFS image that contains only the romstage, - * and must be small enough to fit into alternate_cbfs_size[__BOOT_BLOCK__] in + * and must be small enough to fit into the PRE_RAM CBFS cache in * IRAM. It is loaded when this function gets called in the boot block, and * the normal CBFS code extracts the romstage from it. * * The fourth transfer is also a CBFS image, but can be of arbitrary size and * should contain all available stages/payloads/etc. It is loaded when this * function is called a second time at the end of the romstage, and copied to - * alternate_cbfs_buffer[!__BOOT_BLOCK__] in DRAM. It will reside there for the + * the romstage/ramstage CBFS cache in DRAM. It will reside there for the * rest of the firmware's lifetime and all subsequent stages (which will not * have __PRE_RAM__ defined) can just directly reference it there. */ @@ -64,12 +65,12 @@ static int usb_cbfs_open(struct cbfs_media *media)
printk(BIOS_DEBUG, "USB A-A transfer successful, CBFS image should now" - " be at %p\n", alternate_cbfs_buffer); + " be at %p\n", _cbfs_cache); first_run = 0; #endif return 0; @@ -90,11 +91,11 @@ static int sdmmc_cbfs_open(struct cbfs_media *media) * In the bootblock, we just copy the small part that fits in the buffer * and hope that it's enough (since the romstage is currently always the * first component in the image, this should work out). In the romstage, - * we copy until our buffer is full (currently 12M) to avoid the pain of + * we copy until our cache is full (currently 12M) to avoid the pain of * figuring out the true image size from in here. Since this is mainly a * developer/debug boot mode, those shortcomings should be bearable. */ - const u32 count = alternate_cbfs_size / 512; + const u32 count = _cbfs_cache_size / 512; static int first_run = 1; int (*irom_load_sdmmc)(u32 start, u32 count, void *dst) = *irom_sdmmc_read_blocks_ptr; @@ -103,7 +104,7 @@ static int sdmmc_cbfs_open(struct cbfs_media *media) return 0;
dcache_mmu_disable(); - if (!irom_load_sdmmc(1, count, alternate_cbfs_buffer)) { + if (!irom_load_sdmmc(1, count, _cbfs_cache)) { dcache_mmu_enable(); printk(BIOS_EMERG, "Unable to load CBFS image from SDMMC!\n"); return -1; @@ -111,7 +112,7 @@ static int sdmmc_cbfs_open(struct cbfs_media *media) dcache_mmu_enable();
printk(BIOS_DEBUG, "SDMMC read successful, CBFS image should now be" - " at %p\n", alternate_cbfs_buffer); + " at %p\n", _cbfs_cache); first_run = 0; #endif return 0; @@ -122,16 +123,16 @@ static int alternate_cbfs_close(struct cbfs_media *media) { return 0; } static size_t alternate_cbfs_read(struct cbfs_media *media, void *dest, size_t offset, size_t count) { - ASSERT(offset + count < alternate_cbfs_size); - memcpy(dest, alternate_cbfs_buffer + offset, count); + ASSERT(offset + count < _cbfs_cache_size); + memcpy(dest, _cbfs_cache + offset, count); return count; }
static void *alternate_cbfs_unmap(struct cbfs_media *media, @@ -173,8 +174,7 @@ int init_default_cbfs_media(struct cbfs_media *media) return initialize_exynos_sdmmc_cbfs_media(media); case OM_STAT_SPI: return initialize_exynos_spi_cbfs_media(media, - (void*)CONFIG_CBFS_CACHE_ADDRESS, - CONFIG_CBFS_CACHE_SIZE); + _cbfs_cache, _cbfs_cache_size); default: printk(BIOS_EMERG, "Exynos OM_STAT value 0x%x not supported!\n", exynos_power->om_stat); diff --git a/src/soc/samsung/exynos5420/alternate_cbfs.h b/src/soc/samsung/exynos5420/alternate_cbfs.h index af7751d..4df61d5 100644 --- a/src/soc/samsung/exynos5420/alternate_cbfs.h +++ b/src/soc/samsung/exynos5420/alternate_cbfs.h @@ -36,16 +36,4 @@ static u32 * const iram_secondary_base = (u32 *)0x02020018; #define OM_STAT_SPI 0x14 #define OM_STAT_MASK 0x7f
-#if defined(__BOOT_BLOCK__) - /* A small space in IRAM to hold the romstage-only image */ - static void * const alternate_cbfs_buffer = - (void *)CONFIG_CBFS_CACHE_ADDRESS; - static size_t const alternate_cbfs_size = CONFIG_CBFS_CACHE_SIZE; -#else - /* Just put this anywhere in RAM that's far enough from anything else */ - /* TODO: Find a better way to "reserve" this region? */ - static void * const alternate_cbfs_buffer = (void *)0x77400000; - static size_t const alternate_cbfs_size = 0xc00000; -#endif - #endif /* CPU_SAMSUNG_EXYNOS5420_ALTERNATE_CBFS_H */ diff --git a/src/soc/samsung/exynos5420/cpu.h b/src/soc/samsung/exynos5420/cpu.h index 5b5c731..bea7f1e 100644 --- a/src/soc/samsung/exynos5420/cpu.h +++ b/src/soc/samsung/exynos5420/cpu.h @@ -21,6 +21,7 @@ #define CPU_SAMSUNG_EXYNOS5420_CPU_H
#define EXYNOS5_SRAM_BASE 0x02020000
@@ -84,7 +85,7 @@ extern struct tmu_info exynos5420_tmu_info;
static inline u32 get_fb_base_kb(void) diff --git a/src/soc/samsung/exynos5420/memlayout.ld b/src/soc/samsung/exynos5420/memlayout.ld new file mode 100644 index 0000000..3259ff9 --- /dev/null +++ b/src/soc/samsung/exynos5420/memlayout.ld @@ -0,0 +1,49 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <memlayout.h> + +#include <arch/header.ld> + +/* + * Note: The BootROM loads the 8K BL1 at [0x2020000:0x2022000), so the bootblock + * must be placed after that. After the handoff, the space can be reclaimed. + */ + +SECTIONS +{ + SRAM_START(0x2020000) + /* 17K hole, includes BL1 */ + /* Bootblock is preceeded by 16 byte variable length BL2 checksum. */ + BOOTBLOCK(0x2024410, 32K - 16) + /* 15K hole */ + ROMSTAGE(0x2030000, 128K) + /* 32K hole */ + TTB(0x2058000, 16K) + PRERAM_CBFS_CACHE(0x205C000, 76K) + STACK(0x206F000, 16K) + /* 1K hole for weird kernel-shared CPU/SMP state structure that doesn't + * seem to be implemented right now? */ + SRAM_END(0x2074000) + + DRAM_START(0x20000000) + RAMSTAGE(0x20000000, 128K) + POSTRAM_CBFS_CACHE(0x21000000, 8M) + DMA_COHERENT(0x77300000, 1M) +} diff --git a/src/vendorcode/google/chromeos/Makefile.inc b/src/vendorcode/google/chromeos/Makefile.inc index c445135..f43a87e 100644 --- a/src/vendorcode/google/chromeos/Makefile.inc +++ b/src/vendorcode/google/chromeos/Makefile.inc @@ -110,6 +110,8 @@ verstage-$(CONFIG_CHROMEOS_VBNV_EC) += vbnv_ec.c verstage-$(CONFIG_CHROMEOS_VBNV_FLASH) += vbnv_flash.c romstage-y += vboot_handoff.c
+verstage-y += verstage.ld + VB_FIRMWARE_ARCH := $(ARCHDIR-$(ARCH-VERSTAGE-y)) VB2_LIB = $(obj)/external/vboot_reference/vboot_fw2.a VBOOT_CFLAGS += $(patsubst -I%,-I$(top)/%,$(filter-out -include $(src)/include/kconfig.h, $(CFLAGS_verstage) $(CPPFLAGS_verstage))) diff --git a/src/vendorcode/google/chromeos/chromeos.c b/src/vendorcode/google/chromeos/chromeos.c index 3a499d5..2dacb55 100644 --- a/src/vendorcode/google/chromeos/chromeos.c +++ b/src/vendorcode/google/chromeos/chromeos.c @@ -22,6 +22,7 @@ #include "chromeos.h" #if CONFIG_VBOOT_VERIFY_FIRMWARE || CONFIG_VBOOT2_VERIFY_FIRMWARE #include "fmap.h" +#include "symbols.h" #include "vboot_handoff.h" #include <reset.h> #endif @@ -253,7 +254,7 @@ void *vboot_load_stage(int stage_index,
struct vb2_working_data * const vboot_get_working_data(void) { - return (struct vb2_working_data *)CONFIG_VBOOT_WORK_BUFFER_ADDRESS; + return (struct vb2_working_data *)_vboot2_work; }
void vboot_reboot(void) diff --git a/src/vendorcode/google/chromeos/memlayout.h b/src/vendorcode/google/chromeos/memlayout.h new file mode 100644 index 0000000..468f746 --- /dev/null +++ b/src/vendorcode/google/chromeos/memlayout.h @@ -0,0 +1,47 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file contains macro definitions for memlayout.ld linker scripts. */ + +#ifndef __CHROMEOS_MEMLAYOUT_H +#define __CHROMEOS_MEMLAYOUT_H + +#define VBOOT2_WORK(addr, size) \ + REGION(vboot2_work, addr, size, 4) \ + _ = ASSERT(size >= 16K, "vboot2 work buffer must be at least 16K!"); + +#ifdef __VERSTAGE__ + #define VERSTAGE(addr, sz) \ + SET_COUNTER(VERSTAGE, addr) \ + _ = ASSERT(_everstage - _verstage <= sz, \ + STR(Verstage exceeded its allotted size! (sz))); \ + INCLUDE "vendorcode/google/chromeos/verstage.verstage.ld" +#else + #define VERSTAGE(addr, sz) \ + SET_COUNTER(VERSTAGE, addr) \ + . += sz; +#endif + +#ifdef __VERSTAGE__ + #define OVERLAP_VERSTAGE_ROMSTAGE(addr, size) VERSTAGE(addr, size) +#else + #define OVERLAP_VERSTAGE_ROMSTAGE(addr, size) ROMSTAGE(addr, size) +#endif + +#endif /* __CHROMEOS_MEMLAYOUT_H */ diff --git a/src/vendorcode/google/chromeos/symbols.h b/src/vendorcode/google/chromeos/symbols.h new file mode 100644 index 0000000..21169f0 --- /dev/null +++ b/src/vendorcode/google/chromeos/symbols.h @@ -0,0 +1,32 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA, 02110-1301 USA + */ + +#ifndef __CHROMEOS_SYMBOLS_H +#define __CHROMEOS_SYMBOLS_H + +extern u8 _vboot2_work[]; +extern u8 _evboot2_work[]; +#define _vboot2_work_size (_evboot2_work - _vboot2_work) + +/* Careful: _e<stage> and _<stage>_size only defined for the current stage! */ +extern u8 _verstage[]; +extern u8 _everstage[]; +#define _verstage_size (_everstage - _verstage) + +#endif /* __CHROMEOS_SYMBOLS_H */ diff --git a/src/vendorcode/google/chromeos/verstage.ld b/src/vendorcode/google/chromeos/verstage.ld new file mode 100644 index 0000000..c7fd646 --- /dev/null +++ b/src/vendorcode/google/chromeos/verstage.ld @@ -0,0 +1,58 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* This file is included inside a SECTIONS block */ + +.text . : { + _program = .; + _verstage = .; + *(.text._start); + *(.text.stage_entry); + *(.text); + *(.text.*); +} : to_load + +.data . : { + *(.rodata); + *(.rodata.*); + *(.data); + *(.data.*); + . = ALIGN(8); +} + +.bss . : { + . = ALIGN(8); + _bss = .; + *(.bss) + *(.bss.*) + *(.sbss) + *(.sbss.*) + _ebss = .; + _everstage = .; + _eprogram = .; +} + +/* Discard the sections we don't need/want */ +/DISCARD/ : { + *(.comment) + *(.note) + *(.comment.*) + *(.note.*) + *(.eh_frame); +} diff --git a/src/vendorcode/google/chromeos/verstub.c b/src/vendorcode/google/chromeos/verstub.c index e295b25..eb91c22 100644 --- a/src/vendorcode/google/chromeos/verstub.c +++ b/src/vendorcode/google/chromeos/verstub.c @@ -22,17 +22,18 @@ #include <console/console.h> #include <string.h> #include "chromeos.h" +#include "symbols.h"
static struct vb2_working_data *init_vb2_working_data(void) { struct vb2_working_data *wd;
wd = vboot_get_working_data(); - memset(wd, 0, CONFIG_VBOOT_WORK_BUFFER_SIZE); + memset(wd, 0, _vboot2_work_size); /* 8-byte alignment for ARMv7 */ wd->buffer = ALIGN_UP((uintptr_t)&wd[1], 8); - wd->buffer_size = CONFIG_VBOOT_WORK_BUFFER_SIZE + (uintptr_t)wd - - (uintptr_t)wd->buffer; + wd->buffer_size = _vboot2_work_size + (uintptr_t)wd + - (uintptr_t)wd->buffer;
return wd; }
