HAOUAS Elyes (ehaouas@noos.fr) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16414
commit f44577a1f7c8d1d634c1b86900fe58453498eedc Author: Elyes HAOUAS ehaouas@noos.fr Date: Fri Sep 2 19:22:00 2016 +0200
src/northbridge: Improve code formatting
Change-Id: Iffa058d9eb1e96a4d1587dc3f8a1740907ffbb32 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/northbridge/amd/agesa/family10/northbridge.c | 12 +- src/northbridge/amd/agesa/family12/northbridge.c | 316 ++++++++++----------- src/northbridge/amd/agesa/family15/northbridge.c | 4 +- src/northbridge/amd/agesa/family15rl/northbridge.c | 4 +- src/northbridge/amd/agesa/family15tn/northbridge.c | 4 +- src/northbridge/amd/agesa/family16kb/northbridge.c | 4 +- src/northbridge/amd/amdfam10/chip.h | 2 +- src/northbridge/amd/amdht/comlib.c | 48 ++-- src/northbridge/amd/amdht/ht_wrapper.c | 4 +- src/northbridge/amd/amdk8/amdk8.h | 4 +- src/northbridge/amd/amdmct/mct_ddr3/mct_d.c | 4 +- src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c | 2 +- src/northbridge/amd/amdmct/wrappers/mcti_d.c | 31 +- src/northbridge/amd/cimx/rd890/early.c | 2 +- src/northbridge/amd/pi/00630F01/northbridge.c | 2 +- src/northbridge/amd/pi/00660F01/northbridge.c | 2 +- src/northbridge/amd/pi/00730F01/northbridge.c | 2 +- src/northbridge/intel/e7501/debug.c | 89 +++--- src/northbridge/intel/e7501/northbridge.c | 40 +-- src/northbridge/intel/e7505/debug.c | 86 +++--- src/northbridge/intel/e7505/northbridge.c | 44 +-- src/northbridge/intel/haswell/northbridge.c | 24 +- src/northbridge/intel/i3100/northbridge.c | 14 +- src/northbridge/intel/i3100/raminit_ep80579.c | 2 +- src/northbridge/intel/i5000/raminit.c | 4 +- src/northbridge/intel/i855/debug.c | 40 +-- src/northbridge/intel/i855/northbridge.c | 66 ++--- src/northbridge/intel/i855/raminit.c | 34 +-- src/northbridge/intel/i945/debug.c | 34 +-- src/northbridge/intel/pineview/gma.c | 30 +- src/northbridge/intel/x4x/x4x.h | 46 +-- src/northbridge/via/cn700/vga.c | 2 +- src/northbridge/via/cx700/vga.c | 2 +- src/northbridge/via/vx800/detection.c | 12 +- src/northbridge/via/vx800/vga.c | 2 +- 35 files changed, 504 insertions(+), 514 deletions(-)
diff --git a/src/northbridge/amd/agesa/family10/northbridge.c b/src/northbridge/amd/agesa/family10/northbridge.c index 1c8f904..53ddc0e 100644 --- a/src/northbridge/amd/agesa/family10/northbridge.c +++ b/src/northbridge/amd/agesa/family10/northbridge.c @@ -41,8 +41,8 @@ extern uint32_t agesawrapper_amdinitmid(void);
typedef struct amdfam10_sysconf_t sys_info_conf_t; typedef struct dram_base_mask { - u32 base; //[47:27] at [28:8] - u32 mask; //[47:27] at [28:8] and enable at bit 0 + u32 base; //[47:27] at [28:8] + u32 mask; //[47:27] at [28:8] and enable at bit 0 } dram_base_mask_t;
@@ -162,7 +162,6 @@ static void store_conf_mmio_addr(u32 nodeid, u32 linkn, u32 reg, u32 index, static void set_io_addr_reg(device_t dev, u32 nodeid, u32 linkn, u32 reg, u32 io_min, u32 io_max) { - u32 i; u32 tempreg;
@@ -189,7 +188,6 @@ static void set_io_addr_reg(device_t dev, u32 nodeid, u32 linkn, u32 reg,
static void set_mmio_addr_reg(u32 nodeid, u32 linkn, u32 reg, u32 index, u32 mmio_min, u32 mmio_max, u32 nodes) { - u32 i; u32 tempreg;
@@ -218,9 +216,9 @@ static device_t get_node_pci(u32 nodeid, u32 fn)
static unsigned int read_nb_cfg_54(void) { - msr_t msr; - msr = rdmsr(NB_CFG_MSR); - return (( msr.hi >> (54-32)) & 1); + msr_t msr; + msr = rdmsr(NB_CFG_MSR); + return (( msr.hi >> (54-32)) & 1); }
static void get_fx_devs(void) diff --git a/src/northbridge/amd/agesa/family12/northbridge.c b/src/northbridge/amd/agesa/family12/northbridge.c index df6b3e4..1526972 100644 --- a/src/northbridge/amd/agesa/family12/northbridge.c +++ b/src/northbridge/amd/agesa/family12/northbridge.c @@ -269,47 +269,47 @@ struct hw_mem_hole_info {
static struct hw_mem_hole_info get_hw_mem_hole_info(void) { - struct hw_mem_hole_info mem_hole; - - mem_hole.hole_startk = CONFIG_HW_MEM_HOLE_SIZEK; - mem_hole.node_id = -1; - - struct dram_base_mask_t d; - u32 hole; - d = get_dram_base_mask(0); - if (d.mask & 1) { - hole = pci_read_config32(__f1_dev[0], 0xf0); - if (hole & 1) { // we find the hole - mem_hole.hole_startk = (hole & (0xff<<24)) >> 10; - mem_hole.node_id = 0; // record the node No with hole - } - } + struct hw_mem_hole_info mem_hole; + + mem_hole.hole_startk = CONFIG_HW_MEM_HOLE_SIZEK; + mem_hole.node_id = -1; + + struct dram_base_mask_t d; + u32 hole; + d = get_dram_base_mask(0); + if (d.mask & 1) { + hole = pci_read_config32(__f1_dev[0], 0xf0); + if (hole & 1) { // we find the hole + mem_hole.hole_startk = (hole & (0xff<<24)) >> 10; + mem_hole.node_id = 0; // record the node No with hole + } + }
#if 0 /* We need to double check if there is special set on base reg and limit reg * are not continuous instead of hole, it will find out its hole_startk. */ - if (mem_hole.node_id==-1) { - resource_t limitk_pri = 0; - struct dram_base_mask_t d; - resource_t base_k, limit_k; - d = get_dram_base_mask(0); - if (d.base & 1) { - base_k = ((resource_t)(d.base & 0x1fffff00)) <<9; - if (base_k <= 4 *1024 * 1024) { - if (limitk_pri != base_k) { // we find the hole - mem_hole.hole_startk = (unsigned)limitk_pri; // must be below 4G - mem_hole.node_id = 0; - } - } - - limit_k = ((resource_t)((d.mask + 0x00000100) & 0x1fffff00)) << 9; - limitk_pri = limit_k; - } - } + if (mem_hole.node_id==-1) { + resource_t limitk_pri = 0; + struct dram_base_mask_t d; + resource_t base_k, limit_k; + d = get_dram_base_mask(0); + if (d.base & 1) { + base_k = ((resource_t)(d.base & 0x1fffff00)) <<9; + if (base_k <= 4 *1024 * 1024) { + if (limitk_pri != base_k) { // we find the hole + mem_hole.hole_startk = (unsigned)limitk_pri; // must be below 4G + mem_hole.node_id = 0; + } + } + + limit_k = ((resource_t)((d.mask + 0x00000100) & 0x1fffff00)) << 9; + limitk_pri = limit_k; + } + } #endif
- return mem_hole; + return mem_hole; } #endif
@@ -471,44 +471,44 @@ static void setup_uma_memory(void)
static void domain_read_resources(device_t dev) { - unsigned reg; - - printk(BIOS_DEBUG, "\nFam12h - northbridge.c - %s - Start.\n",__func__); - - /* Find the already assigned resource pairs */ - get_fx_devs(); - for (reg = 0x80; reg <= 0xc0; reg+= 0x08) { - u32 base, limit; - base = f1_read_config32(reg); - limit = f1_read_config32(reg + 0x04); - /* Is this register allocated? */ - if ((base & 3) != 0) { - unsigned nodeid, reg_link; - device_t reg_dev; - if (reg<0xc0) { // mmio - nodeid = (limit & 0xf) + (base&0x30); - } else { // io - nodeid = (limit & 0xf) + ((base>>4)&0x30); - } - reg_link = (limit >> 4) & 7; - reg_dev = __f0_dev[nodeid]; - if (reg_dev) { - /* Reserve the resource */ - struct resource *res; - res = new_resource(reg_dev, IOINDEX(0x1000 + reg, reg_link)); - if (res) { - res->flags = 1; - } - } - } - } - /* FIXME: do we need to check extend conf space? - I don't believe that much preset value */ - - struct resource *resource; - /* Initialize the system-wide I/O space constraints. */ + unsigned reg; + + printk(BIOS_DEBUG, "\nFam12h - northbridge.c - %s - Start.\n",__func__); + + /* Find the already assigned resource pairs */ + get_fx_devs(); + for (reg = 0x80; reg <= 0xc0; reg+= 0x08) { + u32 base, limit; + base = f1_read_config32(reg); + limit = f1_read_config32(reg + 0x04); + /* Is this register allocated? */ + if ((base & 3) != 0) { + unsigned nodeid, reg_link; + device_t reg_dev; + if (reg<0xc0) { // mmio + nodeid = (limit & 0xf) + (base&0x30); + } else { // io + nodeid = (limit & 0xf) + ((base>>4)&0x30); + } + reg_link = (limit >> 4) & 7; + reg_dev = __f0_dev[nodeid]; + if (reg_dev) { + /* Reserve the resource */ + struct resource *res; + res = new_resource(reg_dev, IOINDEX(0x1000 + reg, reg_link)); + if (res) { + res->flags = 1; + } + } + } + } + /* FIXME: do we need to check extend conf space? + I don't believe that much preset value */ + + struct resource *resource; + /* Initialize the system-wide I/O space constraints. */ resource = new_resource(dev, IOINDEX_SUBTRACTIVE(0, 0)); - resource->base = 0x1000; + resource->base = 0x1000; resource->limit = 0xffffUL; resource->flags = IORESOURCE_IO | IORESOURCE_SUBTRACTIVE | IORESOURCE_ASSIGNED; @@ -520,40 +520,40 @@ static void domain_read_resources(device_t dev) resource->flags = IORESOURCE_MEM | IORESOURCE_SUBTRACTIVE | IORESOURCE_ASSIGNED;
- printk(BIOS_DEBUG, "Fam12h - northbridge.c - %s - End.\n",__func__); + printk(BIOS_DEBUG, "Fam12h - northbridge.c - %s - End.\n",__func__); }
static void domain_set_resources(device_t dev) { - printk(BIOS_DEBUG, "\nFam12h - northbridge.c - %s - Start.\n",__func__); - printk(BIOS_DEBUG, " amsr - incoming dev = %p\n", dev); - - unsigned long mmio_basek; - u32 pci_tolm; - u64 ramtop = 0; - int idx; - struct bus *link; + printk(BIOS_DEBUG, "\nFam12h - northbridge.c - %s - Start.\n",__func__); + printk(BIOS_DEBUG, " amsr - incoming dev = %p\n", dev); + + unsigned long mmio_basek; + u32 pci_tolm; + u64 ramtop = 0; + int idx; + struct bus *link; #if CONFIG_HW_MEM_HOLE_SIZEK != 0 - struct hw_mem_hole_info mem_hole; - u32 reset_memhole = 1; + struct hw_mem_hole_info mem_hole; + u32 reset_memhole = 1; #endif
- pci_tolm = 0xffffffffUL; - for (link = dev->link_list; link; link = link->next) { - pci_tolm = my_find_pci_tolm(link, pci_tolm); - } + pci_tolm = 0xffffffffUL; + for (link = dev->link_list; link; link = link->next) { + pci_tolm = my_find_pci_tolm(link, pci_tolm); + }
- // FIXME handle interleaved nodes. If you fix this here, please fix - // amdk8, too. - mmio_basek = pci_tolm >> 10; - /* Round mmio_basek to something the processor can support */ - mmio_basek &= ~((1 << 6) -1); + // FIXME handle interleaved nodes. If you fix this here, please fix + // amdk8, too. + mmio_basek = pci_tolm >> 10; + /* Round mmio_basek to something the processor can support */ + mmio_basek &= ~((1 << 6) -1);
- // FIXME improve mtrr.c so we don't use up all of the mtrrs with a 64M - // MMIO hole. If you fix this here, please fix amdk8, too. - /* Round the mmio hole to 64M */ - mmio_basek &= ~((64*1024) - 1); + // FIXME improve mtrr.c so we don't use up all of the mtrrs with a 64M + // MMIO hole. If you fix this here, please fix amdk8, too. + /* Round the mmio hole to 64M */ + mmio_basek &= ~((64*1024) - 1);
#if CONFIG_HW_MEM_HOLE_SIZEK != 0 /* if the hw mem hole is already set in raminit stage, here we will compare @@ -562,77 +562,76 @@ static void domain_set_resources(device_t dev) * otherwise We reset the hole to the mmio_basek */
- mem_hole = get_hw_mem_hole_info(); + mem_hole = get_hw_mem_hole_info();
- // Use hole_basek as mmio_basek, and we don't need to reset hole anymore - if ((mem_hole.node_id != -1) && (mmio_basek > mem_hole.hole_startk)) { - mmio_basek = mem_hole.hole_startk; - reset_memhole = 0; - } + // Use hole_basek as mmio_basek, and we don't need to reset hole anymore + if ((mem_hole.node_id != -1) && (mmio_basek > mem_hole.hole_startk)) { + mmio_basek = mem_hole.hole_startk; + reset_memhole = 0; + } #endif
- idx = 0x10; + idx = 0x10;
- struct dram_base_mask_t d; - resource_t basek, limitk, sizek; // 4 1T + struct dram_base_mask_t d; + resource_t basek, limitk, sizek; // 4 1T
- d = get_dram_base_mask(0); + d = get_dram_base_mask(0);
- if (d.mask & 1) { - basek = ((resource_t)(d.base)) << 8; - limitk = (resource_t)((d.mask << 8) | 0xFFFFFF); -printk(BIOS_DEBUG, "adsr: (before) basek = %llx, limitk = %llx.\n",basek,limitk); + if (d.mask & 1) { + basek = ((resource_t)(d.base)) << 8; + limitk = (resource_t)((d.mask << 8) | 0xFFFFFF); + printk(BIOS_DEBUG, "adsr: (before) basek = %llx, limitk = %llx.\n",basek,limitk);
- /* Convert these values to multiples of 1K for ease of math. */ - basek >>= 10; - limitk >>= 10; - sizek = limitk - basek + 1; + /* Convert these values to multiples of 1K for ease of math. */ + basek >>= 10; + limitk >>= 10; + sizek = limitk - basek + 1;
-printk(BIOS_DEBUG, "adsr: (after) basek = %llx, limitk = %llx, sizek = %llx.\n",basek,limitk,sizek); + printk(BIOS_DEBUG, "adsr: (after) basek = %llx, limitk = %llx, sizek = %llx.\n",basek,limitk,sizek);
- /* see if we need a hole from 0xa0000 to 0xbffff */ - if ((basek < 640) && (sizek > 768)) { -printk(BIOS_DEBUG, "adsr - 0xa0000 to 0xbffff resource.\n"); - ram_resource(dev, (idx | 0), basek, 640 - basek); - idx += 0x10; - basek = 768; - sizek = limitk - 768; - } + /* see if we need a hole from 0xa0000 to 0xbffff */ + if ((basek < 640) && (sizek > 768)) { + printk(BIOS_DEBUG, "adsr - 0xa0000 to 0xbffff resource.\n"); + ram_resource(dev, (idx | 0), basek, 640 - basek); + idx += 0x10; + basek = 768; + sizek = limitk - 768; + }
printk(BIOS_DEBUG, "adsr: mmio_basek=%08lx, basek=%08llx, limitk=%08llx\n", mmio_basek, basek, limitk);
- /* split the region to accommodate pci memory space */ - if ( (basek < 4*1024*1024 ) && (limitk > mmio_basek) ) { - if (basek <= mmio_basek) { - unsigned pre_sizek; - pre_sizek = mmio_basek - basek; - if (pre_sizek>0) { - ram_resource(dev, idx, basek, pre_sizek); - idx += 0x10; - sizek -= pre_sizek; - if (!ramtop) - ramtop = mmio_basek * 1024; - } - basek = mmio_basek; - } - if ((basek + sizek) <= 4*1024*1024) { - sizek = 0; - } - else { - basek = 4*1024*1024; - sizek -= (4*1024*1024 - mmio_basek); - } - } - - ram_resource(dev, (idx | 0), basek, sizek); - idx += 0x10; - printk(BIOS_DEBUG, "%d: mmio_basek=%08lx, basek=%08llx, limitk=%08llx\n", - 0, mmio_basek, basek, limitk); - if (!ramtop) - ramtop = limitk * 1024; - } + /* split the region to accommodate pci memory space */ + if ( (basek < 4*1024*1024 ) && (limitk > mmio_basek) ) { + if (basek <= mmio_basek) { + unsigned pre_sizek; + pre_sizek = mmio_basek - basek; + if (pre_sizek>0) { + ram_resource(dev, idx, basek, pre_sizek); + idx += 0x10; + sizek -= pre_sizek; + if (!ramtop) + ramtop = mmio_basek * 1024; + } + basek = mmio_basek; + } + if ((basek + sizek) <= 4*1024*1024) { + sizek = 0; + } else { + basek = 4*1024*1024; + sizek -= (4*1024*1024 - mmio_basek); + } + } + + ram_resource(dev, (idx | 0), basek, sizek); + idx += 0x10; + printk(BIOS_DEBUG, "%d: mmio_basek=%08lx, basek=%08llx, limitk=%08llx\n", + 0, mmio_basek, basek, limitk); + if (!ramtop) + ramtop = limitk * 1024; + } printk(BIOS_DEBUG, " adsr - mmio_basek = %lx.\n", mmio_basek);
#if CONFIG_GFXUMA @@ -642,13 +641,12 @@ printk(BIOS_DEBUG, "adsr - 0xa0000 to 0xbffff resource.\n"); set_top_of_ram(ramtop); #endif
- for (link = dev->link_list; link; link = link->next) { - if (link->children) { - assign_resources(link); - } - } -printk(BIOS_DEBUG, " adsr - leaving this lovely routine.\n"); - printk(BIOS_DEBUG, "Fam12h - northbridge.c - %s - End.\n",__func__); + for (link = dev->link_list; link; link = link->next) { + if (link->children) + assign_resources(link); + } + printk(BIOS_DEBUG, " adsr - leaving this lovely routine.\n"); + printk(BIOS_DEBUG, "Fam12h - northbridge.c - %s - End.\n",__func__); }
diff --git a/src/northbridge/amd/agesa/family15/northbridge.c b/src/northbridge/amd/agesa/family15/northbridge.c index f347b63..0c14bdd 100644 --- a/src/northbridge/amd/agesa/family15/northbridge.c +++ b/src/northbridge/amd/agesa/family15/northbridge.c @@ -1080,9 +1080,9 @@ static void cpu_bus_scan(device_t dev) * * This is needed because many IO-APIC devices only have 4 bits * for their APIC id and therefore must reside at 0..15 - */ + */
- u8 plat_num_io_apics = 3; /* FIXME */ + u8 plat_num_io_apics = 3; /* FIXME */
if ((node_nums * core_max) + plat_num_io_apics >= 0x10) { lapicid_start = (plat_num_io_apics - 1) / core_max; diff --git a/src/northbridge/amd/agesa/family15rl/northbridge.c b/src/northbridge/amd/agesa/family15rl/northbridge.c index ccb256b..d1560b7 100644 --- a/src/northbridge/amd/agesa/family15rl/northbridge.c +++ b/src/northbridge/amd/agesa/family15rl/northbridge.c @@ -1070,9 +1070,9 @@ static void cpu_bus_scan(device_t dev) * * This is needed because many IO-APIC devices only have 4 bits * for their APIC id and therefore must reside at 0..15 - */ + */
if ((node_nums * core_max) + plat_num_io_apics >= 0x10) { lapicid_start = (plat_num_io_apics - 1) / core_max; diff --git a/src/northbridge/amd/agesa/family15tn/northbridge.c b/src/northbridge/amd/agesa/family15tn/northbridge.c index 63ca2af..7b57cc3 100644 --- a/src/northbridge/amd/agesa/family15tn/northbridge.c +++ b/src/northbridge/amd/agesa/family15tn/northbridge.c @@ -1069,9 +1069,9 @@ static void cpu_bus_scan(device_t dev) * * This is needed because many IO-APIC devices only have 4 bits * for their APIC id and therefore must reside at 0..15 - */ + */
if ((node_nums * core_max) + plat_num_io_apics >= 0x10) { lapicid_start = (plat_num_io_apics - 1) / core_max; diff --git a/src/northbridge/amd/agesa/family16kb/northbridge.c b/src/northbridge/amd/agesa/family16kb/northbridge.c index c0769e7..28302ef 100644 --- a/src/northbridge/amd/agesa/family16kb/northbridge.c +++ b/src/northbridge/amd/agesa/family16kb/northbridge.c @@ -1086,9 +1086,9 @@ static void cpu_bus_scan(device_t dev) * * This is needed because many IO-APIC devices only have 4 bits * for their APIC id and therefore must reside at 0..15 - */ + */
if ((node_nums * core_max) + plat_num_io_apics >= 0x10) { lapicid_start = (plat_num_io_apics - 1) / core_max; diff --git a/src/northbridge/amd/amdfam10/chip.h b/src/northbridge/amd/amdfam10/chip.h index 60dc00f..daf429d 100644 --- a/src/northbridge/amd/amdfam10/chip.h +++ b/src/northbridge/amd/amdfam10/chip.h @@ -19,7 +19,7 @@ #include <stdint.h>
struct northbridge_amd_amdfam10_config { - uint64_t maximum_memory_capacity; + uint64_t maximum_memory_capacity; };
#endif /* _AMD_FAM10_CHIP_H_ */ diff --git a/src/northbridge/amd/amdht/comlib.c b/src/northbridge/amd/amdht/comlib.c index e2d158f..64092ff 100644 --- a/src/northbridge/amd/amdht/comlib.c +++ b/src/northbridge/amd/amdht/comlib.c @@ -249,38 +249,38 @@ void ErrorStop(u32 value) ; ; For use with SimNow the unrotated error code is also written to port 84h ErrorStop PROC FAR PASCAL PUBLIC Value:DWORD - pushad - mov eax, Value - mov bx, 0DEADh - out 84h, eax + pushad + mov eax, Value + mov bx, 0DEADh + out 84h, eax
ErrorStopTop: - out 80h, eax + out 80h, eax
- mov cx, 4 ; Rotate the display by one nibble + mov cx, 4 ; Rotate the display by one nibble @@: - bt bx, 15 - rcl eax, 1 - rcl bx, 1 - loop @B + bt bx, 15 + rcl eax, 1 + rcl bx, 1 + loop @B
- push eax ; Delay a few hundred milliseconds - push ebx - mov ecx, 10h ; TSC - db 00Fh, 032h ; RDMSR - mov ebx, eax + push eax ; Delay a few hundred milliseconds + push ebx + mov ecx, 10h ; TSC + db 00Fh, 032h ; RDMSR + mov ebx, eax @@: - db 00Fh, 032h ; RDMSR - sub eax, ebx - cmp eax, 500000000 - jb @B - pop ebx - pop eax + db 00Fh, 032h ; RDMSR + sub eax, ebx + cmp eax, 500000000 + jb @B + pop ebx + pop eax
- jmp ErrorStopTop + jmp ErrorStopTop
- popad - ret + popad + ret ErrorStop ENDP */ diff --git a/src/northbridge/amd/amdht/ht_wrapper.c b/src/northbridge/amd/amdht/ht_wrapper.c index f31fcd2..0dfc6ab 100644 --- a/src/northbridge/amd/amdht/ht_wrapper.c +++ b/src/northbridge/amd/amdht/ht_wrapper.c @@ -29,9 +29,9 @@ /* Single CPU system? */ #if (CONFIG_MAX_PHYSICAL_CPUS == 1) /* FIXME - * This #define is used by other #included .c files + * This #define is used by other #included .c files * When set, multiprocessor support is completely disabled - */ + */ #define HT_BUILD_NC_ONLY 1 #endif
diff --git a/src/northbridge/amd/amdk8/amdk8.h b/src/northbridge/amd/amdk8/amdk8.h index 05117f7..2cde166 100644 --- a/src/northbridge/amd/amdk8/amdk8.h +++ b/src/northbridge/amd/amdk8/amdk8.h @@ -6,9 +6,9 @@
#define K8_REV_F_SUPPORT_F0_F1_WORKAROUND 0
- #include "f.h" + #include "f.h" #else - #include "pre_f.h" + #include "pre_f.h" #endif
#ifdef __PRE_RAM__ diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c index 0c37366..08d8d43 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c @@ -2398,10 +2398,10 @@ static void precise_ndelay_fam15(struct MCTStatStruc *pMCTstat, uint32_t nanosec
tsc_msr = rdmsr(0x00000010); start_timestamp = (((uint64_t)tsc_msr.hi) << 32) | tsc_msr.lo; - do { + do { tsc_msr = rdmsr(0x00000010); current_timestamp = (((uint64_t)tsc_msr.hi) << 32) | tsc_msr.lo; - } while ((current_timestamp - start_timestamp) < cycle_count); + } while ((current_timestamp - start_timestamp) < cycle_count); }
static void precise_memclk_delay_fam15(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *pDCTstat, uint8_t dct, uint32_t clocks) { diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c b/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c index 324e35e..8024179 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mctsrc.c @@ -930,7 +930,7 @@ static void dqsTrainRcvrEn_SW_Fam10(struct MCTStatStruc *pMCTstat, */ for (lane = 0; lane < 8; lane++) { if (trained[lane]) { - pDCTstat->CH_D_B_RCVRDLY[Channel][Receiver >> 1][lane] = current_total_delay[lane]; + pDCTstat->CH_D_B_RCVRDLY[Channel][Receiver >> 1][lane] = current_total_delay[lane]; } else { printk(BIOS_WARNING, "TrainRcvrEn: WARNING: Lane %d of receiver %d on channel %d failed training!\n", lane, Receiver, Channel);
diff --git a/src/northbridge/amd/amdmct/wrappers/mcti_d.c b/src/northbridge/amd/amdmct/wrappers/mcti_d.c index 0ba2d33..143468a 100644 --- a/src/northbridge/amd/amdmct/wrappers/mcti_d.c +++ b/src/northbridge/amd/amdmct/wrappers/mcti_d.c @@ -476,34 +476,31 @@ static void mctHookAfterDramInit(void) #if (CONFIG_DIMM_SUPPORT & 0x000F)==0x0005 /* AMD_FAM10_DDR3 */ static void vErratum372(struct DCTStatStruc *pDCTstat) { - msr_t msr = rdmsr(NB_CFG_MSR); + msr_t msr = rdmsr(NB_CFG_MSR);
int nbPstate1supported = !(msr.hi & (1 << (NB_GfxNbPstateDis -32)));
- // is this the right way to check for NB pstate 1 or DDR3-1333 ? - if (((pDCTstat->PresetmaxFreq==1333)||(nbPstate1supported)) - &&(!pDCTstat->GangedMode)) { - /* DisableCf8ExtCfg */ - msr.hi &= ~(3 << (51 - 32)); - wrmsr(NB_CFG_MSR, msr); - } + // is this the right way to check for NB pstate 1 or DDR3-1333 ? + if (((pDCTstat->PresetmaxFreq==1333)||(nbPstate1supported)) + &&(!pDCTstat->GangedMode)) { + /* DisableCf8ExtCfg */ + msr.hi &= ~(3 << (51 - 32)); + wrmsr(NB_CFG_MSR, msr); + } }
static void vErratum414(struct DCTStatStruc *pDCTstat) { - int dct=0; - for (; dct < 2 ; dct++) - { - int dRAMConfigHi = Get_NB32(pDCTstat->dev_dct,0x94 + (0x100 * dct)); + int dct=0; + for (; dct < 2 ; dct++) { + int dRAMConfigHi = Get_NB32(pDCTstat->dev_dct,0x94 + (0x100 * dct)); int powerDown = dRAMConfigHi & (1 << PowerDownEn ); int ddr3 = dRAMConfigHi & (1 << Ddr3Mode ); - int dRAMMRS = Get_NB32(pDCTstat->dev_dct,0x84 + (0x100 * dct)); + int dRAMMRS = Get_NB32(pDCTstat->dev_dct,0x84 + (0x100 * dct)); int pchgPDModeSel = dRAMMRS & (1 << PchgPDModeSel); - if (powerDown && ddr3 && pchgPDModeSel ) - { - Set_NB32(pDCTstat->dev_dct,0x84 + (0x100 * dct), dRAMMRS & ~(1 << PchgPDModeSel) ); + if (powerDown && ddr3 && pchgPDModeSel ) + Set_NB32(pDCTstat->dev_dct,0x84 + (0x100 * dct), dRAMMRS & ~(1 << PchgPDModeSel) ); } - } } #endif
diff --git a/src/northbridge/amd/cimx/rd890/early.c b/src/northbridge/amd/cimx/rd890/early.c index 5852aa3..4904e52 100644 --- a/src/northbridge/amd/cimx/rd890/early.c +++ b/src/northbridge/amd/cimx/rd890/early.c @@ -34,7 +34,7 @@ void sr56x0_rd890_disable_pcie_bridge(void) AMD_NB_CONFIG_BLOCK *cfg_ptr = &cfg_block; AMD_NB_CONFIG *nb_cfg = &(cfg_block.Northbridges[0]);
- nb_cfg->ConfigPtr = &cfg_ptr; + nb_cfg->ConfigPtr = &cfg_ptr; nb_dev = MAKE_SBDFO(0, 0x0, 0x0, 0x0, 0x0); val = (1 << 2) | (1 << 3); /*GPP1*/ val |= (1 << 4) | (1 << 5) | (1 << 6) | (1 << 7) | (1 << 16) | (1 << 17); /*GPP3a*/ diff --git a/src/northbridge/amd/pi/00630F01/northbridge.c b/src/northbridge/amd/pi/00630F01/northbridge.c index c55cefb..0f9e5f5 100644 --- a/src/northbridge/amd/pi/00630F01/northbridge.c +++ b/src/northbridge/amd/pi/00630F01/northbridge.c @@ -1077,7 +1077,7 @@ static void cpu_bus_scan(device_t dev) * * This is needed because many IO-APIC devices only have 4 bits * for their APIC id and therefore must reside at 0..15 - */ + */ if ((node_nums * core_max) + ioapic_count >= 0x10) { lapicid_start = (ioapic_count - 1) / core_max; lapicid_start = (lapicid_start + 1) * core_max; diff --git a/src/northbridge/amd/pi/00660F01/northbridge.c b/src/northbridge/amd/pi/00660F01/northbridge.c index 1caecf9..efee0a4 100644 --- a/src/northbridge/amd/pi/00660F01/northbridge.c +++ b/src/northbridge/amd/pi/00660F01/northbridge.c @@ -1077,7 +1077,7 @@ static void cpu_bus_scan(device_t dev) * * This is needed because many IO-APIC devices only have 4 bits * for their APIC id and therefore must reside at 0..15 - */ + */ if ((node_nums * core_max) + ioapic_count >= 0x10) { lapicid_start = (ioapic_count - 1) / core_max; lapicid_start = (lapicid_start + 1) * core_max; diff --git a/src/northbridge/amd/pi/00730F01/northbridge.c b/src/northbridge/amd/pi/00730F01/northbridge.c index 6f7f993..6d5418a 100644 --- a/src/northbridge/amd/pi/00730F01/northbridge.c +++ b/src/northbridge/amd/pi/00730F01/northbridge.c @@ -1108,7 +1108,7 @@ static void cpu_bus_scan(device_t dev) * * This is needed because many IO-APIC devices only have 4 bits * for their APIC id and therefore must reside at 0..15 - */ + */ if ((node_nums * core_max) + ioapic_count >= 0x10) { lapicid_start = (ioapic_count - 1) / core_max; lapicid_start = (lapicid_start + 1) * core_max; diff --git a/src/northbridge/intel/e7501/debug.c b/src/northbridge/intel/e7501/debug.c index af9a8bf..d48a089 100644 --- a/src/northbridge/intel/e7501/debug.c +++ b/src/northbridge/intel/e7501/debug.c @@ -35,7 +35,7 @@ static void dump_pci_device(unsigned dev) for (i = 0; i < 256; i++) { unsigned char val; if ((i & 0x0f) == 0) - printk(BIOS_DEBUG, "\n%02x:",i); + printk(BIOS_DEBUG, "\n%02x:",i); val = pci_read_config8(dev, i); printk(BIOS_DEBUG, " %02x", val); } @@ -61,19 +61,19 @@ static inline void dump_pci_devices(void)
static inline void dump_pci_devices_on_bus(unsigned busn) { - device_t dev; - for (dev = PCI_DEV(busn, 0, 0); - dev <= PCI_DEV(busn, 0x1f, 0x7); - dev += PCI_DEV(0,0,1)) { - uint32_t id; - id = pci_read_config32(dev, PCI_VENDOR_ID); - if (((id & 0xffff) == 0x0000) || ((id & 0xffff) == 0xffff) || - (((id >> 16) & 0xffff) == 0xffff) || - (((id >> 16) & 0xffff) == 0x0000)) { - continue; - } - dump_pci_device(dev); - } + device_t dev; + for (dev = PCI_DEV(busn, 0, 0); + dev <= PCI_DEV(busn, 0x1f, 0x7); + dev += PCI_DEV(0,0,1)) { + uint32_t id; + id = pci_read_config32(dev, PCI_VENDOR_ID); + if (((id & 0xffff) == 0x0000) || ((id & 0xffff) == 0xffff) || + (((id >> 16) & 0xffff) == 0xffff) || + (((id >> 16) & 0xffff) == 0x0000)) { + continue; + } + dump_pci_device(dev); + } }
static inline void dump_spd_registers(const struct mem_controller *ctrl) @@ -103,18 +103,18 @@ static inline void dump_spd_registers(const struct mem_controller *ctrl) device = ctrl->channel1[i]; if (device) { int j; - printk(BIOS_DEBUG, "dimm: %02x.1: %02x", i, device); + printk(BIOS_DEBUG, "dimm: %02x.1: %02x", i, device); for (j = 0; j < 128; j++) { int status; unsigned char byte; if ((j & 0xf) == 0) - printk(BIOS_DEBUG, "\n%02x: ", j); + printk(BIOS_DEBUG, "\n%02x: ", j); status = smbus_read_byte(device, j); if (status < 0) { break; } byte = status & 0xff; - printk(BIOS_DEBUG, "%02x ", byte); + printk(BIOS_DEBUG, "%02x ", byte); } printk(BIOS_DEBUG, "\n"); } @@ -123,54 +123,53 @@ static inline void dump_spd_registers(const struct mem_controller *ctrl) static inline void dump_smbus_registers(void) { unsigned device; - printk(BIOS_DEBUG, "\n"); - for (device = 1; device < 0x80; device++) { - int j; + printk(BIOS_DEBUG, "\n"); + for (device = 1; device < 0x80; device++) { + int j; if ( smbus_read_byte(device, 0) < 0 ) continue; printk(BIOS_DEBUG, "smbus: %02x", device); - for (j = 0; j < 256; j++) { - int status; - unsigned char byte; - status = smbus_read_byte(device, j); - if (status < 0) { + for (j = 0; j < 256; j++) { + int status; + unsigned char byte; + status = smbus_read_byte(device, j); + if (status < 0) { break; - } - if ((j & 0xf) == 0) + } + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ",j); - byte = status & 0xff; - printk(BIOS_DEBUG, "%02x ", byte); - } - printk(BIOS_DEBUG, "\n"); + byte = status & 0xff; + printk(BIOS_DEBUG, "%02x ", byte); + } + printk(BIOS_DEBUG, "\n"); } }
static inline void dump_io_resources(unsigned port) { - int i; printk(BIOS_DEBUG, "%04x:\n", port); - for (i=0;i<256;i++) { - uint8_t val; - if ((i & 0x0f) == 0) + for (i=0;i<256;i++) { + uint8_t val; + if ((i & 0x0f) == 0) printk(BIOS_DEBUG, "%02x:", i); - val = inb(port); + val = inb(port); printk(BIOS_DEBUG, " %02x",val); - if ((i & 0x0f) == 0x0f) { - printk(BIOS_DEBUG, "\n"); - } + if ((i & 0x0f) == 0x0f) { + printk(BIOS_DEBUG, "\n"); + } port++; - } + } }
static inline void dump_mem(unsigned start, unsigned end) { - unsigned i; + unsigned i; printk(BIOS_DEBUG, "dump_mem:"); - for (i=start;i<end;i++) { + for (i=start;i<end;i++) { if ((i & 0xf)==0) printk(BIOS_DEBUG, "\n%08x:", i); printk(BIOS_DEBUG, " %02x", (unsigned char)*((unsigned char *)i)); - } - printk(BIOS_DEBUG, "\n"); - } + } + printk(BIOS_DEBUG, "\n"); +} #endif diff --git a/src/northbridge/intel/e7501/northbridge.c b/src/northbridge/intel/e7501/northbridge.c index 5296bdb..d4f77ae 100644 --- a/src/northbridge/intel/e7501/northbridge.c +++ b/src/northbridge/intel/e7501/northbridge.c @@ -23,9 +23,9 @@ unsigned long acpi_fill_mcfg(unsigned long current) static void pci_domain_set_resources(device_t dev) { device_t mc_dev; - uint32_t pci_tolm; + uint32_t pci_tolm;
- pci_tolm = find_pci_tolm(dev->link_list); + pci_tolm = find_pci_tolm(dev->link_list); mc_dev = dev->link_list->children; if (mc_dev) { /* Figure out which areas are/should be occupied by RAM. @@ -102,36 +102,36 @@ static void pci_domain_set_resources(device_t dev) }
static struct device_operations pci_domain_ops = { - .read_resources = pci_domain_read_resources, - .set_resources = pci_domain_set_resources, - .enable_resources = NULL, - .init = NULL, - .scan_bus = pci_domain_scan_bus, + .read_resources = pci_domain_read_resources, + .set_resources = pci_domain_set_resources, + .enable_resources = NULL, + .init = NULL, + .scan_bus = pci_domain_scan_bus, .ops_pci_bus = pci_bus_default_ops, };
static void cpu_bus_init(device_t dev) { - initialize_cpus(dev->link_list); + initialize_cpus(dev->link_list); }
static struct device_operations cpu_bus_ops = { - .read_resources = DEVICE_NOOP, - .set_resources = DEVICE_NOOP, - .enable_resources = DEVICE_NOOP, - .init = cpu_bus_init, - .scan_bus = 0, + .read_resources = DEVICE_NOOP, + .set_resources = DEVICE_NOOP, + .enable_resources = DEVICE_NOOP, + .init = cpu_bus_init, + .scan_bus = 0, };
static void enable_dev(struct device *dev) { - /* Set the operations if it is a special bus type */ - if (dev->path.type == DEVICE_PATH_DOMAIN) { - dev->ops = &pci_domain_ops; - } - else if (dev->path.type == DEVICE_PATH_CPU_CLUSTER) { - dev->ops = &cpu_bus_ops; - } + /* Set the operations if it is a special bus type */ + if (dev->path.type == DEVICE_PATH_DOMAIN) { + dev->ops = &pci_domain_ops; + } + else if (dev->path.type == DEVICE_PATH_CPU_CLUSTER) { + dev->ops = &cpu_bus_ops; + } }
struct chip_operations northbridge_intel_e7501_ops = { diff --git a/src/northbridge/intel/e7505/debug.c b/src/northbridge/intel/e7505/debug.c index 33f1ed1..e20d676 100644 --- a/src/northbridge/intel/e7505/debug.c +++ b/src/northbridge/intel/e7505/debug.c @@ -45,7 +45,7 @@ void dump_pci_device(unsigned dev) for (i = 0; i < 256; i++) { unsigned char val; if ((i & 0x0f) == 0) - printk(BIOS_DEBUG, "\n%02x:",i); + printk(BIOS_DEBUG, "\n%02x:",i); val = pci_read_config8(dev, i); printk(BIOS_DEBUG, " %02x", val); } @@ -71,19 +71,19 @@ void dump_pci_devices(void)
void dump_spd_registers(const struct mem_controller *ctrl) @@ -113,18 +113,18 @@ void dump_spd_registers(const struct mem_controller *ctrl) device = ctrl->channel1[i]; if (device) { int j; - printk(BIOS_DEBUG, "dimm: %02x.1: %02x", i, device); + printk(BIOS_DEBUG, "dimm: %02x.1: %02x", i, device); for (j = 0; j < 128; j++) { int status; unsigned char byte; if ((j & 0xf) == 0) - printk(BIOS_DEBUG, "\n%02x: ", j); + printk(BIOS_DEBUG, "\n%02x: ", j); status = spd_read_byte(device, j); if (status < 0) { break; } byte = status & 0xff; - printk(BIOS_DEBUG, "%02x ", byte); + printk(BIOS_DEBUG, "%02x ", byte); } printk(BIOS_DEBUG, "\n"); } @@ -133,24 +133,24 @@ void dump_spd_registers(const struct mem_controller *ctrl) void dump_smbus_registers(void) { unsigned device; - printk(BIOS_DEBUG, "\n"); - for (device = 1; device < 0x80; device++) { - int j; + printk(BIOS_DEBUG, "\n"); + for (device = 1; device < 0x80; device++) { + int j; if ( spd_read_byte(device, 0) < 0 ) continue; printk(BIOS_DEBUG, "smbus: %02x", device); - for (j = 0; j < 256; j++) { - int status; - unsigned char byte; - status = spd_read_byte(device, j); - if (status < 0) { + for (j = 0; j < 256; j++) { + int status; + unsigned char byte; + status = spd_read_byte(device, j); + if (status < 0) { break; - } - if ((j & 0xf) == 0) + } + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ",j); - byte = status & 0xff; - printk(BIOS_DEBUG, "%02x ", byte); - } - printk(BIOS_DEBUG, "\n"); + byte = status & 0xff; + printk(BIOS_DEBUG, "%02x ", byte); + } + printk(BIOS_DEBUG, "\n"); } }
@@ -159,27 +159,27 @@ void dump_io_resources(unsigned port)
void dump_mem(unsigned start, unsigned end) { - unsigned i; + unsigned i; printk(BIOS_DEBUG, "dump_mem:"); - for (i=start;i<end;i++) { + for (i=start;i<end;i++) { if ((i & 0xf)==0) printk(BIOS_DEBUG, "\n%08x:", i); printk(BIOS_DEBUG, " %02x", (unsigned char)*((unsigned char *)i)); - } - printk(BIOS_DEBUG, "\n"); + } + printk(BIOS_DEBUG, "\n"); } diff --git a/src/northbridge/intel/e7505/northbridge.c b/src/northbridge/intel/e7505/northbridge.c index 4a3e993..71b19f6 100644 --- a/src/northbridge/intel/e7505/northbridge.c +++ b/src/northbridge/intel/e7505/northbridge.c @@ -12,16 +12,16 @@
unsigned long acpi_fill_mcfg(unsigned long current) { - /* Just a dummy */ - return current; + /* Just a dummy */ + return current; }
- pci_tolm = find_pci_tolm(dev->link_list); + pci_tolm = find_pci_tolm(dev->link_list); mc_dev = dev->link_list->children; if (mc_dev) { /* Figure out which areas are/should be occupied by RAM. @@ -108,37 +108,37 @@ static struct pci_operations intel_pci_ops = { };
static struct device_operations pci_domain_ops = { - .read_resources = pci_domain_read_resources, - .set_resources = pci_domain_set_resources, - .enable_resources = NULL, - .init = NULL, - .scan_bus = pci_domain_scan_bus, + .read_resources = pci_domain_read_resources, + .set_resources = pci_domain_set_resources, + .enable_resources = NULL, + .init = NULL, + .scan_bus = pci_domain_scan_bus, .ops_pci = &intel_pci_ops, .ops_pci_bus = pci_bus_default_ops, };
struct chip_operations northbridge_intel_e7505_ops = { diff --git a/src/northbridge/intel/haswell/northbridge.c b/src/northbridge/intel/haswell/northbridge.c index 4af6e11..d4b6e90 100644 --- a/src/northbridge/intel/haswell/northbridge.c +++ b/src/northbridge/intel/haswell/northbridge.c @@ -101,8 +101,7 @@ static int get_bar(device_t dev, unsigned int index, u32 *base, u32 *len) /* There are special BARs that actually are programmed in the MCHBAR. These * Intel special features, but they do consume resources that need to be * accounted for. */ -static int get_bar_in_mchbar(device_t dev, unsigned int index, u32 *base, - u32 *len) +static int get_bar_in_mchbar(device_t dev, unsigned int index, u32 *base, u32 *len) { u32 bar;
@@ -122,7 +121,7 @@ struct fixed_mmio_descriptor { unsigned int index; u32 size; int (*get_resource)(device_t dev, unsigned int index, - u32 *base, u32 *size); + u32 *base, u32 *size); const char *description; };
@@ -154,13 +153,13 @@ static void mc_add_fixed_mmio_resources(device_t dev) size = mc_fixed_resources[i].size; index = mc_fixed_resources[i].index; if (!mc_fixed_resources[i].get_resource(dev, index, - &base, &size)) + &base, &size)) continue;
resource = new_resource(dev, mc_fixed_resources[i].index); resource->flags = IORESOURCE_MEM | IORESOURCE_FIXED | - IORESOURCE_STORED | IORESOURCE_RESERVE | - IORESOURCE_ASSIGNED; + IORESOURCE_STORED | IORESOURCE_RESERVE | + IORESOURCE_ASSIGNED; resource->base = base; resource->size = size; printk(BIOS_DEBUG, "%s: Adding %s @ %x 0x%08lx-0x%08lx.\n", @@ -198,8 +197,7 @@ struct map_entry { const char *description; };
-static void read_map_entry(device_t dev, struct map_entry *entry, - uint64_t *result) +static void read_map_entry(device_t dev, struct map_entry *entry, uint64_t *result) { uint64_t value; uint64_t mask; @@ -345,16 +343,16 @@ static void mc_add_dram_resources(device_t dev) resource->base = mc_values[TSEG_REG]; resource->size = mc_values[BGSM_REG] - resource->base; resource->flags = IORESOURCE_MEM | IORESOURCE_FIXED | - IORESOURCE_STORED | IORESOURCE_RESERVE | - IORESOURCE_ASSIGNED | IORESOURCE_CACHEABLE; + IORESOURCE_STORED | IORESOURCE_RESERVE | + IORESOURCE_ASSIGNED | IORESOURCE_CACHEABLE;
/* BGSM -> TOLUD */ resource = new_resource(dev, index++); resource->base = mc_values[BGSM_REG]; resource->size = mc_values[TOLUD_REG] - resource->base; resource->flags = IORESOURCE_MEM | IORESOURCE_FIXED | - IORESOURCE_STORED | IORESOURCE_RESERVE | - IORESOURCE_ASSIGNED; + IORESOURCE_STORED | IORESOURCE_RESERVE | + IORESOURCE_ASSIGNED;
/* 4GiB -> TOUUD */ base_k = 4096 * 1024; /* 4GiB */ @@ -370,7 +368,7 @@ static void mc_add_dram_resources(device_t dev) */ mmio_resource(dev, index++, (0xa0000 >> 10), (0xc0000 - 0xa0000) >> 10); reserved_ram_resource(dev, index++, (0xc0000 >> 10), - (0x100000 - 0xc0000) >> 10); + (0x100000 - 0xc0000) >> 10); #if CONFIG_CHROMEOS_RAMOOPS reserved_ram_resource(dev, index++, CONFIG_CHROMEOS_RAMOOPS_RAM_START >> 10, diff --git a/src/northbridge/intel/i3100/northbridge.c b/src/northbridge/intel/i3100/northbridge.c index c8e3221..a48d8fe 100644 --- a/src/northbridge/intel/i3100/northbridge.c +++ b/src/northbridge/intel/i3100/northbridge.c @@ -40,7 +40,7 @@ static void pci_domain_set_resources(device_t dev) device_t mc_dev; u32 pci_tolm;
#if 1 printk(BIOS_DEBUG, "PCI mem marker = %x\n", pci_tolm); @@ -211,15 +211,15 @@ static const struct pci_driver mc_driver __pci_driver = {
diff --git a/src/northbridge/intel/i3100/raminit_ep80579.c b/src/northbridge/intel/i3100/raminit_ep80579.c index 497339c..001ec0d 100644 --- a/src/northbridge/intel/i3100/raminit_ep80579.c +++ b/src/northbridge/intel/i3100/raminit_ep80579.c @@ -618,7 +618,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) write32(BAR+DCALCSR, (0x80000003 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); while (data32 & 0x80000000); - } + }
udelay(16); /* No command */ diff --git a/src/northbridge/intel/i5000/raminit.c b/src/northbridge/intel/i5000/raminit.c index ef49380..ed3f0b4 100644 --- a/src/northbridge/intel/i5000/raminit.c +++ b/src/northbridge/intel/i5000/raminit.c @@ -599,7 +599,7 @@ static int i5000_ddr_init(struct i5000_fbdimm *d)
val = (d->setup->t_al << 19) | ((odt & 1) << 18) | - ((odt & 2) << 21) | 1; + ((odt & 2) << 21) | 1;
printk(BIOS_DEBUG, "EMRS(1): 0x%08x\n", val);
@@ -1268,7 +1268,7 @@ static void i5000_setup_interleave(struct i5000_fbd_setup *setup) mir0 = (size0 << 1) | 3; mir1 = (size0 << 1); mir2 = (size0 << 1); - } else if (!size0) { + } else if (!size0) { mir0 = size1 | 1; mir1 = size1; mir2 = size1; diff --git a/src/northbridge/intel/i855/debug.c b/src/northbridge/intel/i855/debug.c index 05e934d..2a9e407 100644 --- a/src/northbridge/intel/i855/debug.c +++ b/src/northbridge/intel/i855/debug.c @@ -104,26 +104,26 @@ static inline void dump_spd_registers(void)
static inline void dump_smbus_registers(void) { - int i; - printk(BIOS_DEBUG, "\n"); - for (i = 1; i < 0x80; i++) { - unsigned device; - device = i; - int j; - printk(BIOS_DEBUG, "smbus: %02x", device); - for (j = 0; j < 256; j++) { - int status; - unsigned char byte; - if ((j & 0xf) == 0) - printk(BIOS_DEBUG, "\n%02x: ", j); - status = smbus_read_byte(device, j); - if (status < 0) { - printk(BIOS_DEBUG, "bad device\n"); - break; - } - byte = status & 0xff; + int i; + printk(BIOS_DEBUG, "\n"); + for (i = 1; i < 0x80; i++) { + unsigned device; + device = i; + int j; + printk(BIOS_DEBUG, "smbus: %02x", device); + for (j = 0; j < 256; j++) { + int status; + unsigned char byte; + if ((j & 0xf) == 0) + printk(BIOS_DEBUG, "\n%02x: ", j); + status = smbus_read_byte(device, j); + if (status < 0) { + printk(BIOS_DEBUG, "bad device\n"); + break; + } + byte = status & 0xff; printk(BIOS_DEBUG, "%02x ", byte); - } - printk(BIOS_DEBUG, "\n"); + } + printk(BIOS_DEBUG, "\n"); } } diff --git a/src/northbridge/intel/i855/northbridge.c b/src/northbridge/intel/i855/northbridge.c index e9b1cac..bc497a8 100644 --- a/src/northbridge/intel/i855/northbridge.c +++ b/src/northbridge/intel/i855/northbridge.c @@ -30,33 +30,33 @@
static void northbridge_init(device_t dev) { - printk(BIOS_SPEW, "Northbridge init\n"); + printk(BIOS_SPEW, "Northbridge init\n"); }
static struct device_operations northbridge_operations = { - .read_resources = pci_dev_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = northbridge_init, - .enable = 0, - .ops_pci = 0, + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = northbridge_init, + .enable = 0, + .ops_pci = 0, };
static const struct pci_driver northbridge_driver __pci_driver = { - .ops = &northbridge_operations, - .vendor = PCI_VENDOR_ID_INTEL, - .device = 0x3580, + .ops = &northbridge_operations, + .vendor = PCI_VENDOR_ID_INTEL, + .device = 0x3580, };
- printk(BIOS_DEBUG, "Entered with dev vid = %x\n", dev->vendor); + printk(BIOS_DEBUG, "Entered with dev vid = %x\n", dev->vendor); printk(BIOS_DEBUG, "Entered with dev did = %x\n", dev->device);
- pci_tolm = find_pci_tolm(dev->link_list); + pci_tolm = find_pci_tolm(dev->link_list); mc_dev = dev->link_list->children->sibling; printk(BIOS_DEBUG, "MC dev vendor = %x\n", mc_dev->vendor); printk(BIOS_DEBUG, "MC dev device = %x\n", mc_dev->device); @@ -107,39 +107,39 @@ static void pci_domain_set_resources(device_t dev) }
static struct device_operations pci_domain_ops = { - .read_resources = pci_domain_read_resources, - .set_resources = pci_domain_set_resources, - .enable_resources = NULL, - .init = NULL, - .scan_bus = pci_domain_scan_bus, - .ops_pci_bus = pci_bus_default_ops, + .read_resources = pci_domain_read_resources, + .set_resources = pci_domain_set_resources, + .enable_resources = NULL, + .init = NULL, + .scan_bus = pci_domain_scan_bus, + .ops_pci_bus = pci_bus_default_ops, };
struct chip_operations northbridge_intel_i855_ops = { - CHIP_NAME("Intel 855 Northbridge") + CHIP_NAME("Intel 855 Northbridge") .enable_dev = enable_dev, }; diff --git a/src/northbridge/intel/i855/raminit.c b/src/northbridge/intel/i855/raminit.c index fe6059d..43400ab 100644 --- a/src/northbridge/intel/i855/raminit.c +++ b/src/northbridge/intel/i855/raminit.c @@ -369,32 +369,32 @@ static void do_ram_command(uint8_t command, uint16_t jedec_mode_bits) PRINTK_DEBUG(" Sending RAM command 0x%08x\n", reg32); pci_write_config32(NORTHBRIDGE_MMC, DRC, reg32);
- // RAM_COMMAND_NORMAL is an exception. - // It affects only the memory controller and does not need to be "sent" to the DIMMs. + // RAM_COMMAND_NORMAL is an exception. + // It affects only the memory controller and does not need to be "sent" to the DIMMs.
- if (command != RAM_COMMAND_NORMAL) { + if (command != RAM_COMMAND_NORMAL) {
- // Send the command to all DIMMs by accessing a memory location within each - // NOTE: for mode select commands, some of the location address bits - // are part of the command + // Send the command to all DIMMs by accessing a memory location within each + // NOTE: for mode select commands, some of the location address bits + // are part of the command
- // Map JEDEC mode bits to i855 - if (command == RAM_COMMAND_MRS || command == RAM_COMMAND_EMRS) { + // Map JEDEC mode bits to i855 + if (command == RAM_COMMAND_MRS || command == RAM_COMMAND_EMRS) { /* Host address lines [13:3] map to DIMM address lines [11, 9:0] */ i855_mode_bits = ((jedec_mode_bits & 0x800) << (13 - 11)) | ((jedec_mode_bits & 0x3ff) << (12 - 9)); - } + }
- for (i = 0; i < (DIMM_SOCKETS * 2); ++i) { - uint8_t dimm_end_32M_multiple = pci_read_config8(NORTHBRIDGE_MMC, DRB + i); - if (dimm_end_32M_multiple > dimm_start_32M_multiple) { + for (i = 0; i < (DIMM_SOCKETS * 2); ++i) { + uint8_t dimm_end_32M_multiple = pci_read_config8(NORTHBRIDGE_MMC, DRB + i); + if (dimm_end_32M_multiple > dimm_start_32M_multiple) {
- uint32_t dimm_start_address = dimm_start_32M_multiple << 25; + uint32_t dimm_start_address = dimm_start_32M_multiple << 25; PRINTK_DEBUG(" Sending RAM command to 0x%08x\n", dimm_start_address + i855_mode_bits); - read32((void *)(dimm_start_address + i855_mode_bits)); + read32((void *)(dimm_start_address + i855_mode_bits));
- // Set the start of the next DIMM - dimm_start_32M_multiple = dimm_end_32M_multiple; - } + // Set the start of the next DIMM + dimm_start_32M_multiple = dimm_end_32M_multiple; + } } } } diff --git a/src/northbridge/intel/i945/debug.c b/src/northbridge/intel/i945/debug.c index 5b6c87a..d3be886 100644 --- a/src/northbridge/intel/i945/debug.c +++ b/src/northbridge/intel/i945/debug.c @@ -78,21 +78,21 @@ void dump_pci_devices(void)
void dump_spd_registers(void) { - unsigned device; - device = DIMM0; - while (device <= DIMM3) { - int status = 0; - int i; - printk(BIOS_DEBUG, "\ndimm %02x", device); + unsigned device; + device = DIMM0; + while (device <= DIMM3) { + int status = 0; + int i; + printk(BIOS_DEBUG, "\ndimm %02x", device);
- for (i = 0; (i < 256) ; i++) { - if ((i % 16) == 0) { + for (i = 0; (i < 256) ; i++) { + if ((i % 16) == 0) { printk(BIOS_DEBUG, "\n%02x: ", i); - } + } status = smbus_read_byte(device, i); - if (status < 0) { - printk(BIOS_DEBUG, "bad device: %02x\n", -status); - break; + if (status < 0) { + printk(BIOS_DEBUG, "bad device: %02x\n", -status); + break; } printk(BIOS_DEBUG, "%02x ", status); } @@ -103,13 +103,13 @@ void dump_spd_registers(void)
void dump_mem(unsigned start, unsigned end) { - unsigned i; + unsigned i; printk(BIOS_DEBUG, "dump_mem:"); - for (i=start;i<end;i++) { + for (i=start;i<end;i++) { if ((i & 0xf)==0) { printk(BIOS_DEBUG, "\n%08x:", i); } printk(BIOS_DEBUG, " %02x", (unsigned char)*((unsigned char *)i)); - } - printk(BIOS_DEBUG, "\n"); - } + } + printk(BIOS_DEBUG, "\n"); +} diff --git a/src/northbridge/intel/pineview/gma.c b/src/northbridge/intel/pineview/gma.c index 989f5ef..335e38a 100644 --- a/src/northbridge/intel/pineview/gma.c +++ b/src/northbridge/intel/pineview/gma.c @@ -46,31 +46,31 @@ #define PGETBL_ENABLED 0x1
#define ADPA_HOTPLUG_BITS (ADPA_CRT_HOTPLUG_PERIOD_128 | \ - ADPA_CRT_HOTPLUG_WARMUP_10MS | \ - ADPA_CRT_HOTPLUG_MONITOR_COLOR| \ - ADPA_CRT_HOTPLUG_SAMPLE_4S | \ - ADPA_CRT_HOTPLUG_VOLTAGE_50 | \ - ADPA_CRT_HOTPLUG_VOLREF_325MV | \ - ADPA_CRT_HOTPLUG_ENABLE) + ADPA_CRT_HOTPLUG_WARMUP_10MS | \ + ADPA_CRT_HOTPLUG_MONITOR_COLOR| \ + ADPA_CRT_HOTPLUG_SAMPLE_4S | \ + ADPA_CRT_HOTPLUG_VOLTAGE_50 | \ + ADPA_CRT_HOTPLUG_VOLREF_325MV | \ + ADPA_CRT_HOTPLUG_ENABLE)
static struct resource *gtt_res = NULL; static struct resource *mmio_res = NULL;
static int gtt_setup(u8 *mmiobase) { - u32 gttbase; - device_t dev = dev_find_slot(0, PCI_DEVFN(0,0)); + u32 gttbase; + device_t dev = dev_find_slot(0, PCI_DEVFN(0,0));
- gttbase = pci_read_config32(dev, BGSM); - printk(BIOS_DEBUG, "gttbase = %08x\n", gttbase); + gttbase = pci_read_config32(dev, BGSM); + printk(BIOS_DEBUG, "gttbase = %08x\n", gttbase);
- write32(mmiobase + PGETBL_CTL, gttbase | PGETBL_512KB); - udelay(50); - write32(mmiobase + PGETBL_CTL, gttbase | PGETBL_512KB); + write32(mmiobase + PGETBL_CTL, gttbase | PGETBL_512KB); + udelay(50); + write32(mmiobase + PGETBL_CTL, gttbase | PGETBL_512KB);
- write32(mmiobase + GFX_FLSH_CNTL, 0); + write32(mmiobase + GFX_FLSH_CNTL, 0);
- return 0; + return 0; }
static void intel_gma_init(const struct northbridge_intel_pineview_config *info, diff --git a/src/northbridge/intel/x4x/x4x.h b/src/northbridge/intel/x4x/x4x.h index e02ee02..4c61e1c 100644 --- a/src/northbridge/intel/x4x/x4x.h +++ b/src/northbridge/intel/x4x/x4x.h @@ -289,29 +289,29 @@ struct sysinfo { };
enum ddr2_signals { - CLKSET0 = 0, - CTRL0, - CLKSET1, - CMD, - CTRL1, - CTRL2, - CTRL3, - DQS1, - DQS2, - DQS3, - DQS4, - DQS5, - DQS6, - DQS7, - DQS8, - DQ1, - DQ2, - DQ3, - DQ4, - DQ5, - DQ6, - DQ7, - DQ8 + CLKSET0 = 0, + CTRL0, + CLKSET1, + CMD, + CTRL1, + CTRL2, + CTRL3, + DQS1, + DQS2, + DQS3, + DQS4, + DQS5, + DQS6, + DQS7, + DQS8, + DQ1, + DQ2, + DQ3, + DQ4, + DQ5, + DQ6, + DQ7, + DQ8 };
#ifndef __BOOTBLOCK__ diff --git a/src/northbridge/via/cn700/vga.c b/src/northbridge/via/cn700/vga.c index 2e453dc..10b7f65 100644 --- a/src/northbridge/via/cn700/vga.c +++ b/src/northbridge/via/cn700/vga.c @@ -64,7 +64,7 @@ static int via_cn700_int15_handler(void) case 0x5f0f: X86_EAX=0x860f; break; - default: + default: printk(BIOS_DEBUG, "Unknown INT15 function %04x!\n", X86_EAX & 0xffff); break; diff --git a/src/northbridge/via/cx700/vga.c b/src/northbridge/via/cx700/vga.c index 7f9d286..16f0ea0 100644 --- a/src/northbridge/via/cx700/vga.c +++ b/src/northbridge/via/cx700/vga.c @@ -116,7 +116,7 @@ static int via_cx700_int15_handler(void) res=1; break;
- default: + default: printk(BIOS_DEBUG, "Unknown INT15 function %04x!\n", X86_EAX & 0xffff); break; diff --git a/src/northbridge/via/vx800/detection.c b/src/northbridge/via/vx800/detection.c index c2397c8..ce643a0 100644 --- a/src/northbridge/via/vx800/detection.c +++ b/src/northbridge/via/vx800/detection.c @@ -146,16 +146,16 @@ CB_STATUS GetInfoFromSPD(DRAM_SYS_ATTR *DramAttr) LoadNum = (u8) (ModuleDataWidth / ChipWidth);
/* Set the RANK map. */ - /* Get bit0,1, the most number of supported RANK is 2. */ + /* Get bit0,1, the most number of supported RANK is 2. */ RankNum = (u8) (pSPDDataBuf[SPD_SDRAM_DIMM_RANKS] & 0x3); if (RAMTYPE_SDRAMDDR2 == DramAttr->DramType) - /* - * For DDR bit[0,1]: 01->1 RANK, 10->2 RANK - * For DDR2 bit[0,1]: 00->1 RANK, 01->2 RANK - */ + /* + * For DDR bit[0,1]: 01->1 RANK, 10->2 RANK + * For DDR2 bit[0,1]: 00->1 RANK, 01->2 RANK + */ RankNum++;
- /* Every DIMM have 1 or 2 ranks. */ + /* Every DIMM have 1 or 2 ranks. */ if (RankNum != 2 && RankNum != 1) { Status = CB_DEVICE_ERROR; PRINT_DEBUG_MEM("Memory Device ERROR: Number " diff --git a/src/northbridge/via/vx800/vga.c b/src/northbridge/via/vx800/vga.c index f02236d..61d4563 100644 --- a/src/northbridge/via/vx800/vga.c +++ b/src/northbridge/via/vx800/vga.c @@ -114,7 +114,7 @@ static int via_vx800_int15_handler(void) X86_EAX = 0x005f; res = 1; break; - default: + default: printk(BIOS_DEBUG, "Unknown INT15 function %04x!\n", X86_EAX & 0xffff); X86_EAX = 0;
