Julia has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/83968?usp=email )
Change subject: q45t-am ......................................................................
q45t-am
Change-Id: Ic2654ca4b198bfea409992be14e89702cf67ea50 Signed-off-by: Julia Kittlinger launchpad.vineyard395@passinbox.com --- M src/mainboard/acer/g43t-am3/Kconfig M src/mainboard/acer/g43t-am3/Kconfig.name A src/mainboard/acer/g43t-am3/variants/q45t-am/data.vbt A src/mainboard/acer/g43t-am3/variants/q45t-am/early_init.c A src/mainboard/acer/g43t-am3/variants/q45t-am/gpio.c A src/mainboard/acer/g43t-am3/variants/q45t-am/include/acpi/superio.asl A src/mainboard/acer/g43t-am3/variants/q45t-am/overridetree.cb 7 files changed, 239 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/83968/1
diff --git a/src/mainboard/acer/g43t-am3/Kconfig b/src/mainboard/acer/g43t-am3/Kconfig index 34d191f..77ce9d4 100644 --- a/src/mainboard/acer/g43t-am3/Kconfig +++ b/src/mainboard/acer/g43t-am3/Kconfig @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0-only
-if BOARD_ACER_G43T_AM3 +if BOARD_ACER_G43T_AM3 || BOARD_ACER_Q45T_AM
config BOARD_SPECIFIC_OPTIONS def_bool y @@ -10,6 +10,7 @@ select SUPERIO_ITE_IT8720F select HAVE_ACPI_TABLES select BOARD_ROMSIZE_KB_2048 if BOARD_ACER_G43T_AM3 + select BOARD_ROMSIZE_KB_4096 if BOARD_ACER_Q45T_AM select PCIEXP_ASPM select PCIEXP_CLK_PM select HAVE_OPTION_TABLE @@ -23,18 +24,21 @@ config VGA_BIOS_ID string default "8086,2e22" if BOARD_ACER_G43T_AM3 + default "8086,2e12" if BOARD_ACER_Q45T_AM
config MAINBOARD_DIR default "acer/g43t-am3"
config VARIANT_DIR default "g43t-am3" if BOARD_ACER_G43T_AM3 + default "q45t-am" if BOARD_ACER_Q45T_AM
config MAINBOARD_PART_NUMBER default "G43T-AM3" if BOARD_ACER_G43T_AM3 + default "Q45T-AM" if BOARD_ACER_Q45T_AM
config OVERRIDE_DEVICETREE string default "variants/$(CONFIG_VARIANT_DIR)/overridetree.cb"
-endif # BOARD_ACER_G43T_AM3 +endif # BOARD_ACER_G43T_AM3 || BOARD_ACER_Q45T_AM diff --git a/src/mainboard/acer/g43t-am3/Kconfig.name b/src/mainboard/acer/g43t-am3/Kconfig.name index 39c5158..5b4447d 100644 --- a/src/mainboard/acer/g43t-am3/Kconfig.name +++ b/src/mainboard/acer/g43t-am3/Kconfig.name @@ -2,3 +2,6 @@
config BOARD_ACER_G43T_AM3 bool "G43T-AM3" + +config BOARD_ACER_Q45T_AM + bool "Q45T-AM" diff --git a/src/mainboard/acer/g43t-am3/variants/q45t-am/data.vbt b/src/mainboard/acer/g43t-am3/variants/q45t-am/data.vbt new file mode 100644 index 0000000..0b264c3 --- /dev/null +++ b/src/mainboard/acer/g43t-am3/variants/q45t-am/data.vbt Binary files differ diff --git a/src/mainboard/acer/g43t-am3/variants/q45t-am/early_init.c b/src/mainboard/acer/g43t-am3/variants/q45t-am/early_init.c new file mode 100644 index 0000000..560e343 --- /dev/null +++ b/src/mainboard/acer/g43t-am3/variants/q45t-am/early_init.c @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <bootblock_common.h> +#include <southbridge/intel/i82801jx/i82801jx.h> +#include <northbridge/intel/x4x/x4x.h> +#include <superio/ite/common/ite.h> +#include <superio/ite/it8720f/it8720f.h> + +#define GPIO_DEV PNP_DEV(0x2e, IT8720F_GPIO) +#define SERIAL_DEV PNP_DEV(0x2e, IT8720F_SP1) + +void bootblock_mainboard_early_init(void) +{ + /* Set up GPIOs on Super I/O. */ + ite_reg_write(GPIO_DEV, 0x25, 0x00); // GPIO set 1 + ite_reg_write(GPIO_DEV, 0x26, 0x0c); // GPIO set 2 + ite_reg_write(GPIO_DEV, 0x27, 0x00); // GPIO set 3 + ite_reg_write(GPIO_DEV, 0x28, 0x40); // GPIO set 4 + ite_reg_write(GPIO_DEV, 0x29, 0x20); // GPIO set 5 + + /* Enable 3VSB during Suspend-to-RAM */ + ite_enable_3vsbsw(GPIO_DEV); + + /* Delay PWROK2 after 3VSBSW# during resume from Suspend-to-RAM */ + ite_delay_pwrgd3(GPIO_DEV); + + ite_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); +} + +void mb_get_spd_map(u8 spd_map[4]) +{ + spd_map[0] = 0x50; + spd_map[1] = 0x51; + spd_map[2] = 0x52; + spd_map[3] = 0x53; +} diff --git a/src/mainboard/acer/g43t-am3/variants/q45t-am/gpio.c b/src/mainboard/acer/g43t-am3/variants/q45t-am/gpio.c new file mode 100644 index 0000000..e344fab --- /dev/null +++ b/src/mainboard/acer/g43t-am3/variants/q45t-am/gpio.c @@ -0,0 +1,112 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <southbridge/intel/common/gpio.h> + +static const struct pch_gpio_set1 pch_gpio_set1_mode = { + .gpio0 = GPIO_MODE_GPIO, + .gpio1 = GPIO_MODE_GPIO, + .gpio6 = GPIO_MODE_GPIO, + .gpio7 = GPIO_MODE_GPIO, + .gpio9 = GPIO_MODE_GPIO, + .gpio13 = GPIO_MODE_GPIO, + .gpio14 = GPIO_MODE_GPIO, + .gpio17 = GPIO_MODE_GPIO, + .gpio18 = GPIO_MODE_GPIO, + .gpio20 = GPIO_MODE_GPIO, + .gpio27 = GPIO_MODE_GPIO, + .gpio28 = GPIO_MODE_GPIO, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_direction = { + .gpio0 = GPIO_DIR_INPUT, + .gpio1 = GPIO_DIR_INPUT, + .gpio6 = GPIO_DIR_INPUT, + .gpio7 = GPIO_DIR_INPUT, + .gpio9 = GPIO_DIR_OUTPUT, + .gpio13 = GPIO_DIR_INPUT, + .gpio14 = GPIO_DIR_INPUT, + .gpio17 = GPIO_DIR_INPUT, + .gpio18 = GPIO_DIR_OUTPUT, + .gpio20 = GPIO_DIR_OUTPUT, + .gpio27 = GPIO_DIR_OUTPUT, + .gpio28 = GPIO_DIR_OUTPUT, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_level = { + .gpio9 = GPIO_LEVEL_HIGH, + .gpio18 = GPIO_LEVEL_HIGH, + .gpio20 = GPIO_LEVEL_LOW, + .gpio27 = GPIO_LEVEL_LOW, + .gpio28 = GPIO_LEVEL_HIGH, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_invert = { + .gpio6 = GPIO_INVERT, + .gpio13 = GPIO_INVERT, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_blink = { + .gpio18 = GPIO_BLINK, + +}; + +static const struct pch_gpio_set2 pch_gpio_set2_mode = { + .gpio32 = GPIO_MODE_GPIO, + .gpio33 = GPIO_MODE_GPIO, + .gpio34 = GPIO_MODE_GPIO, + .gpio35 = GPIO_MODE_NATIVE, + .gpio36 = GPIO_MODE_NATIVE, + .gpio37 = GPIO_MODE_NATIVE, + .gpio38 = GPIO_MODE_NATIVE, + .gpio39 = GPIO_MODE_NATIVE, + .gpio48 = GPIO_MODE_NATIVE, + .gpio49 = GPIO_MODE_GPIO, + .gpio56 = GPIO_MODE_GPIO, + .gpio57 = GPIO_MODE_GPIO, + .gpio58 = GPIO_MODE_NATIVE, + .gpio60 = GPIO_MODE_GPIO, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_direction = { + .gpio32 = GPIO_DIR_OUTPUT, + .gpio33 = GPIO_DIR_INPUT, + .gpio34 = GPIO_DIR_INPUT, + .gpio49 = GPIO_DIR_OUTPUT, + .gpio56 = GPIO_DIR_INPUT, + .gpio57 = GPIO_DIR_INPUT, + .gpio60 = GPIO_DIR_OUTPUT, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_level = { + .gpio32 = GPIO_LEVEL_HIGH, + .gpio49 = GPIO_LEVEL_HIGH, + .gpio60 = GPIO_LEVEL_LOW, +}; + +static const struct pch_gpio_set3 pch_gpio_set3_mode = { + .gpio72 = GPIO_MODE_GPIO, +}; + +static const struct pch_gpio_set3 pch_gpio_set3_direction = { + .gpio72 = GPIO_DIR_INPUT, +}; + +const struct pch_gpio_map mainboard_gpio_map = { + .set1 = { + .mode = &pch_gpio_set1_mode, + .direction = &pch_gpio_set1_direction, + .level = &pch_gpio_set1_level, + .blink = &pch_gpio_set1_blink, + .invert = &pch_gpio_set1_invert, + }, + .set2 = { + .mode = &pch_gpio_set2_mode, + .direction = &pch_gpio_set2_direction, + .level = &pch_gpio_set2_level, + }, + .set3 = { + .mode = &pch_gpio_set3_mode, + .direction = &pch_gpio_set3_direction, + }, + +}; diff --git a/src/mainboard/acer/g43t-am3/variants/q45t-am/include/acpi/superio.asl b/src/mainboard/acer/g43t-am3/variants/q45t-am/include/acpi/superio.asl new file mode 100644 index 0000000..04fc150 --- /dev/null +++ b/src/mainboard/acer/g43t-am3/variants/q45t-am/include/acpi/superio.asl @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#undef SUPERIO_DEV +#undef SUPERIO_PNP_BASE +#undef IT8720F_SHOW_SP1 +#undef IT8720F_SHOW_SP2 +#undef IT8720F_SHOW_EC +#undef IT8720F_SHOW_KBCK +#undef IT8720F_SHOW_KBCM +#undef IT8720F_SHOW_GPIO +#undef IT8720F_SHOW_CIR +#define SUPERIO_DEV SIO0 +#define SUPERIO_PNP_BASE 0x2e +#define IT8720F_SHOW_SP1 1 +#define IT8720F_SHOW_SP2 1 +#define IT8720F_SHOW_EC 1 +#define IT8720F_SHOW_KBCK 1 +#define IT8720F_SHOW_KBCM 1 +#define IT8720F_SHOW_GPIO 1 +#define IT8720F_SHOW_CIR 1 +#include <superio/ite/it8720f/acpi/superio.asl> diff --git a/src/mainboard/acer/g43t-am3/variants/q45t-am/overridetree.cb b/src/mainboard/acer/g43t-am3/variants/q45t-am/overridetree.cb new file mode 100644 index 0000000..126c1ab --- /dev/null +++ b/src/mainboard/acer/g43t-am3/variants/q45t-am/overridetree.cb @@ -0,0 +1,61 @@ +# SPDX-License-Identifier: GPL-2.0-or-later + +chip northbridge/intel/x4x # Northbridge + device domain 0 on # PCI domain + chip southbridge/intel/i82801jx # Southbridge + device pci 1c.1 off end # PCIe 2 + device pci 1f.0 on # LPC bridge + chip superio/ite/it8720f # Super I/O + device pnp 2e.0 on end # Floppy + device pnp 2e.1 on end # COM 1 + device pnp 2e.2 on end # COM 2 + device pnp 2e.3 on end # Parallel port + device pnp 2e.7 on # GPIO + io 0x60 = 0x000 + io 0x62 = 0xa20 + io 0x64 = 0xa30 + irq 0xc0 = 0x01 # Simple IO Set 1 + irq 0xc1 = 0x0c # Simple IO Set 2 + irq 0xc2 = 0x00 # Simple IO Set 3 + irq 0xc3 = 0x00 # Simple IO Set 4 + irq 0xc4 = 0x20 # Simple IO Set 5 + irq 0xc8 = 0x01 # Simple IO Set 1 Output + irq 0xc9 = 0x0c # Simple IO Set 2 Output + irq 0xca = 0x00 # Simple IO Set 3 Output + irq 0xcb = 0x00 # Simple IO Set 4 Output + irq 0xcc = 0x20 # Simple IO Set 5 Output + irq 0xf0 = 0x00 + irq 0xf1 = 0x00 + irq 0xf2 = 0x00 + irq 0xf3 = 0x00 + irq 0xf4 = 0x00 + irq 0xf5 = 0x00 + irq 0xf6 = 0x00 + irq 0xf7 = 0x00 + irq 0xf8 = 0x12 + irq 0xf9 = 0x02 + irq 0xfa = 0x13 + irq 0xfb = 0x02 + #irq 0xfc = 0xef # VID Input + irq 0xfd = 0x00 + irq 0xfe = 0x00 + end + device pnp 2e.a on end # CIR + end + end + device pci 1f.3 on # SMBus + chip drivers/i2c/ck505 # IDT CV194 + register "mask" = "{ 0xff, 0xff, 0xff, 0x00, + 0xff, 0x00, 0x00, 0x00, + 0x00, 0xff, 0xff, 0xff, + 0x00, 0xff }" + register "regs" = "{ 0x57, 0xd9, 0xfe, 0xff, + 0xff, 0x00, 0x00, 0x00, + 0x00, 0x25, 0x7d, 0x96, + 0x00, 0xbf }" + device i2c 69 on end + end + end + end + end +end
