Attention is currently required from: Tim Wawrzynczak, Nick Vaccaro, Karthik Ramasubramanian. Hello build bot (Jenkins), Paul Menzel, Nick Vaccaro, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/60016
Change subject: drivers/generic/bayhub_lv2: Work around known errata ......................................................................
The Bayhub LV2 has a known errata wherein PCI config registers at offsets 0x234, 0x238, and 0x24C will only correctly accept writes when they are addressed via a DWORD (32-bit) wide write operation on the PCIe bus. Offset 0x234 is the LTR max snoop and max no-snoop latency register, therefore add a finalize callback to this driver which will program the LTR max-snoop/no-snoop register with a 32-bit write using the values from pciexp_get_ltr_max_latencies().
BUG=b:204343849 TEST=verified the PCI config space writes took effect on google/taeko
Change-Id: I1813f798faa534fb212cb1a074bc7bcadd17a517 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/drivers/generic/bayhub_lv2/lv2.c 1 file changed, 22 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/16/60016/3
