Christian Gmeiner (christian.gmeiner@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3308
commit ed29feff89c79024e6d999d7df4c3da3d6b57eb8 Author: Christian Gmeiner christian.gmeiner@gmail.com Date: Mon May 27 08:54:25 2013 +0200
cpu/amd/geode_lx/Kconfig: Select TSC_MONOTONIC_TIMER
The following is an excerpt from serial log of the Bachmann OT200.
$ grep usec coreboot_log clocks_per_usec: 500 Root Device init 48034 usecs CPU_CLUSTER: 0 init 133251 usecs PCI: 00:01.0 init 33376 usecs PCI: 00:01.1 init 9930 usecs PCI: 00:01.2 init 9929 usecs PCI: 00:04.0 init 9929 usecs PCI: 00:0f.0 init 185788 usecs PCI: 00:0f.2 init 21473 usecs PCI: 00:0f.3 init 9930 usecs PCI: 00:0f.4 init 9930 usecs PCI: 00:0f.5 init 9930 usecs PCI: 00:0f.6 init 9930 usecs PCI: 00:0f.7 init 9929 usecs
Change-Id: I4d0805c4cf8fcb25ec107615787fc6da0c945a30 Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- src/cpu/amd/geode_lx/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/src/cpu/amd/geode_lx/Kconfig b/src/cpu/amd/geode_lx/Kconfig index 7deb100..ac59c3f 100644 --- a/src/cpu/amd/geode_lx/Kconfig +++ b/src/cpu/amd/geode_lx/Kconfig @@ -6,6 +6,7 @@ if CPU_AMD_GEODE_LX config CPU_SPECIFIC_OPTIONS def_bool y select CACHE_AS_RAM + select TSC_MONOTONIC_TIMER
config DCACHE_RAM_BASE hex
