Attention is currently required from: Jonathan Zhang.
Shuming Chu (Shuming) has uploaded a new patch set (#3) to the change originally created by Jonathan Zhang. ( https://review.coreboot.org/c/coreboot/+/68878 )
Change subject: soc/intel/cmn/block/acpi: enable BERT table without crashlog ......................................................................
Besides crashlog, there's also other errors such as MCA error, which should be recorded in BERT table. With current code, BERT table is not generated if crashlog is not enabled. Add if statement for SOC_INTEL_CRASHLOG so that MCA error can be recorded in BERT table when crashlog is not supported. For some server mainboard, crashlog is supported through BMC instead of host firmware.
Also check if BERT region is generated when crashlog is not enabled.
Change-Id: I323ca889eef2b246fc4e062582d2d11b4213316f Signed-off-by: Tim Chu Tim.Chu@quantatw.com Signed-off-by: Jonathan Zhang jonzhang@meta.com --- M src/soc/intel/common/block/acpi/acpi_bert.c 1 file changed, 39 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/78/68878/3
