Kenneth Chan has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/58313 )
Change subject: mb/google/guybrush/dewatt: update DRAM table ......................................................................
K4U6E3S4AB-MGCL H54G46CYRBX267 MT53E1G32D2NP-046 WT:B MT53E512M32D1NP-046 WT:B
BUG=b:203014978 BRANCH=guybrush TEST=emerge-guybrush coreboot chromeos-bootimage
Signed-off-by: Kenneth Chan kenneth.chan@quanta.corp-partner.google.com Change-Id: I31ec5b84b5ad2e8d0aedf41ceb56f9e5f7fa538a --- M src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc M src/mainboard/google/guybrush/variants/dewatt/memory/dram_id.generated.txt M src/mainboard/google/guybrush/variants/dewatt/memory/mem_parts_used.txt 3 files changed, 20 insertions(+), 15 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/58313/1
diff --git a/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc b/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc index 6751a42..069b2eb 100644 --- a/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc +++ b/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc @@ -1,5 +1,8 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Generated by: +# util/spd_tools/bin/part_id_gen CZN lp4x src/mainboard/google/guybrush/variants/dewatt/memory src/mainboard/google/guybrush/variants/dewatt/memory/mem_parts_used.txt
-SPD_SOURCES = placeholder +SPD_SOURCES = +SPD_SOURCES += spd/lp4x/set-1/spd-1.hex # ID = 0(0b0000) Parts = K4U6E3S4AB-MGCL, H54G46CYRBX267, MT53E512M32D1NP-046 WT:B +SPD_SOURCES += spd/lp4x/set-1/spd-3.hex # ID = 1(0b0001) Parts = MT53E1G32D2NP-046 WT:B diff --git a/src/mainboard/google/guybrush/variants/dewatt/memory/dram_id.generated.txt b/src/mainboard/google/guybrush/variants/dewatt/memory/dram_id.generated.txt index fa24790..5ce9e79 100644 --- a/src/mainboard/google/guybrush/variants/dewatt/memory/dram_id.generated.txt +++ b/src/mainboard/google/guybrush/variants/dewatt/memory/dram_id.generated.txt @@ -1 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Generated by: +# util/spd_tools/bin/part_id_gen CZN lp4x src/mainboard/google/guybrush/variants/dewatt/memory src/mainboard/google/guybrush/variants/dewatt/memory/mem_parts_used.txt + DRAM Part Name ID to assign +K4U6E3S4AB-MGCL 0 (0000) +H54G46CYRBX267 0 (0000) +MT53E1G32D2NP-046 WT:B 1 (0001) +MT53E512M32D1NP-046 WT:B 0 (0000) diff --git a/src/mainboard/google/guybrush/variants/dewatt/memory/mem_parts_used.txt b/src/mainboard/google/guybrush/variants/dewatt/memory/mem_parts_used.txt index 416b512..4b6ba22 100644 --- a/src/mainboard/google/guybrush/variants/dewatt/memory/mem_parts_used.txt +++ b/src/mainboard/google/guybrush/variants/dewatt/memory/mem_parts_used.txt @@ -1,11 +1,4 @@ -# This is a CSV file containing a list of memory parts used by this variant. -# One part per line with an optional fixed ID in column 2. -# Only include a fixed ID if it is required for legacy reasons! -# Generated IDs are dependent on the order of parts in this file, -# so new parts must always be added at the end of the file! -# -# Generate an updated Makefile.inc and dram_id.generated.txt by running the -# part_id_gen tool from util/spd_tools. -# See util/spd_tools/README.md for more details and instructions. - -# Part Name, Fixed ID (optional) +K4U6E3S4AB-MGCL +H54G46CYRBX267 +MT53E1G32D2NP-046 WT:B +MT53E512M32D1NP-046 WT:B
