Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84741?usp=email )
2 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: soc/intel/xeon_sp: Allow Memory POR independent of RMT ......................................................................
TEST=Build & boot in IBM SBP1 system. Verified the settings are effective in FSP logs.
Change-Id: I4341ead89a2683f64c834a6981ba316fcfef4f9a Signed-off-by: Naresh Solanki naresh.solanki@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84741 Reviewed-by: Shuo Liu shuo.liu@intel.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/soc/intel/xeon_sp/spr/Kconfig M src/soc/intel/xeon_sp/spr/romstage.c 2 files changed, 3 insertions(+), 4 deletions(-)
Approvals: Shuo Liu: Looks good to me, approved build bot (Jenkins): Verified Angel Pons: Looks good to me, but someone else must approve
diff --git a/src/soc/intel/xeon_sp/spr/Kconfig b/src/soc/intel/xeon_sp/spr/Kconfig index b84a8ff..6fad812 100644 --- a/src/soc/intel/xeon_sp/spr/Kconfig +++ b/src/soc/intel/xeon_sp/spr/Kconfig @@ -174,10 +174,9 @@ Enable Rank Margining Tool. This option is intended for debugging and validation and should normally be disabled.
-config RMT_MEM_POR_FREQ +config MEM_POR_FREQ bool "Enforce Plan Of Record restrictions for DDR5 frequency and voltage" default n - depends on ENABLE_RMT help When RMT is enabled. Select this option to enforce Intel Plan Of Record(POR) restriction on DDR5 frequency & voltage settings. diff --git a/src/soc/intel/xeon_sp/spr/romstage.c b/src/soc/intel/xeon_sp/spr/romstage.c index b05c7e7..4d95a33 100644 --- a/src/soc/intel/xeon_sp/spr/romstage.c +++ b/src/soc/intel/xeon_sp/spr/romstage.c @@ -241,9 +241,9 @@ mupd->FspmConfig.serialDebugMsgLvl = 0x3; mupd->FspmConfig.AllowedSocketsInParallel = 0x1; mupd->FspmConfig.EnforcePopulationPor = 0x1; - if (CONFIG(RMT_MEM_POR_FREQ)) - mupd->FspmConfig.EnforceDdrMemoryFreqPor = 0x0; } + if (CONFIG(MEM_POR_FREQ)) + mupd->FspmConfig.EnforceDdrMemoryFreqPor = 0x0;
/* SPR-FSP has no UPD to disable HDA, so do it manually here... */ if (!is_devfn_enabled(PCH_DEVFN_HDA))
