Iru Cai (mytbk920423@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18241
commit 735e4e817025c11fb11b46de16b87731bdb01ad6 Author: Iru Cai mytbk920423@gmail.com Date: Thu Jan 26 14:51:47 2017 +0800
New port: HP Elitebook 2760p
The code is generated by autoport.
The flash chip is socketed beside the WLAN slot. The EHCI debug port is on right side of the laptop beside the RJ11 connector.
Things that works: - memory: 0+8G (the DIMM under the keyboard) - Linux - native graphics init + SeaBIOS payload with SeaVGABIOS - all 3 USB ports - WLAN - S3 suspend and resume
Things that doesn't work: - keyboard (use a USB keyboard instead) - AC and battery status - wacom digitizer - fan control (fan always runs on full speed)
Things that is not tested: - WWAN - SD card reader - smart card reader - expresscard - cable modem
(EC) blobs:
This laptop uses SMSC KBC1126-NU as EC. It may need some blobs in the flash chip.
- There may be some data needed by EC at 0x7ff700-0x7fff07, which needs to be copied from the factory firmware
- The padding before 0x7a0000 in the original UEFI firmware (can be seen with UEFITool) may contain EC firmware (it has strings like `8051 Reset'), so now I set the CBFS size to 0x60000
Change-Id: I3ffdb9f9c71f6c9a84e896abc3c424c8dd4bed0e Signed-off-by: Iru Cai mytbk920423@gmail.com --- src/mainboard/hp/2760p/Kconfig | 65 +++++ src/mainboard/hp/2760p/Kconfig.name | 2 + src/mainboard/hp/2760p/Makefile.inc | 3 + src/mainboard/hp/2760p/acpi/ec.asl | 7 + src/mainboard/hp/2760p/acpi/platform.asl | 10 + src/mainboard/hp/2760p/acpi/superio.asl | 1 + src/mainboard/hp/2760p/acpi_tables.c | 1 + src/mainboard/hp/2760p/board_info.txt | 6 + src/mainboard/hp/2760p/devicetree.cb | 111 ++++++++ src/mainboard/hp/2760p/dsdt.asl | 30 ++ src/mainboard/hp/2760p/early_southbridge.c | 69 +++++ src/mainboard/hp/2760p/gnvs.c | 19 ++ src/mainboard/hp/2760p/gpio.c | 433 +++++++++++++++++++++++++++++ src/mainboard/hp/2760p/hda_verb.c | 65 +++++ src/mainboard/hp/2760p/mainboard.c | 55 ++++ src/mainboard/hp/2760p/romstage.c | 1 + 16 files changed, 878 insertions(+)
diff --git a/src/mainboard/hp/2760p/Kconfig b/src/mainboard/hp/2760p/Kconfig new file mode 100644 index 0000000..440c1f6 --- /dev/null +++ b/src/mainboard/hp/2760p/Kconfig @@ -0,0 +1,65 @@ +if BOARD_HP_2760P + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select BOARD_ROMSIZE_KB_8192 + select CPU_INTEL_SOCKET_RPGA989 + select EC_ACPI + select HAVE_ACPI_RESUME + select HAVE_ACPI_TABLES + select INTEL_INT15 + select NORTHBRIDGE_INTEL_SANDYBRIDGE + select SANDYBRIDGE_IVYBRIDGE_LVDS + select SERIRQ_CONTINUOUS_MODE + select SOUTHBRIDGE_INTEL_BD82X6X + select SYSTEM_TYPE_LAPTOP + select USE_NATIVE_RAMINIT + +config HAVE_IFD_BIN + bool + default n + +config HAVE_ME_BIN + bool + default n + +config MAINBOARD_DIR + string + default hp/2760p + +config MAINBOARD_PART_NUMBER + string + default "HP EliteBook 2760p" + +config VGA_BIOS_FILE + string + default "pci8086,0116.rom" + +config VGA_BIOS_ID + string + default "8086,0116" + +config MAINBOARD_PCI_SUBSYSTEM_DEVICE_ID + hex + default 0x162a + +config MAINBOARD_PCI_SUBSYSTEM_VENDOR_ID + hex + default 0x103c + +config MMCONF_BASE_ADDRESS + hex + default 0xf0000000 + +config DRAM_RESET_GATE_GPIO # FIXME: check this + int + default 60 + +config MAX_CPUS + int + default 8 + +config USBDEBUG_HCD_INDEX + int + default 1 +endif diff --git a/src/mainboard/hp/2760p/Kconfig.name b/src/mainboard/hp/2760p/Kconfig.name new file mode 100644 index 0000000..4a6a8e5 --- /dev/null +++ b/src/mainboard/hp/2760p/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_HP_2760P + bool "HP EliteBook 2760p" diff --git a/src/mainboard/hp/2760p/Makefile.inc b/src/mainboard/hp/2760p/Makefile.inc new file mode 100644 index 0000000..6064cea --- /dev/null +++ b/src/mainboard/hp/2760p/Makefile.inc @@ -0,0 +1,3 @@ +romstage-y += early_southbridge.c +romstage-y += gpio.c +ramstage-y += gnvs.c diff --git a/src/mainboard/hp/2760p/acpi/ec.asl b/src/mainboard/hp/2760p/acpi/ec.asl new file mode 100644 index 0000000..aea3c58 --- /dev/null +++ b/src/mainboard/hp/2760p/acpi/ec.asl @@ -0,0 +1,7 @@ +Device(EC) +{ + Name (_HID, EISAID("PNP0C09")) + Name (_UID, 0) + Name (_GPE, 22) +/* FIXME: EC support */ +} diff --git a/src/mainboard/hp/2760p/acpi/platform.asl b/src/mainboard/hp/2760p/acpi/platform.asl new file mode 100644 index 0000000..c2862c9 --- /dev/null +++ b/src/mainboard/hp/2760p/acpi/platform.asl @@ -0,0 +1,10 @@ +Method(_WAK,1) +{ + /* FIXME: EC support */ + Return(Package(){0,0}) +} + +Method(_PTS,1) +{ + /* FIXME: EC support */ +} diff --git a/src/mainboard/hp/2760p/acpi/superio.asl b/src/mainboard/hp/2760p/acpi/superio.asl new file mode 100644 index 0000000..f2b35ba --- /dev/null +++ b/src/mainboard/hp/2760p/acpi/superio.asl @@ -0,0 +1 @@ +#include <drivers/pc80/pc/ps2_controller.asl> diff --git a/src/mainboard/hp/2760p/acpi_tables.c b/src/mainboard/hp/2760p/acpi_tables.c new file mode 100644 index 0000000..2997587 --- /dev/null +++ b/src/mainboard/hp/2760p/acpi_tables.c @@ -0,0 +1 @@ +/* dummy */ diff --git a/src/mainboard/hp/2760p/board_info.txt b/src/mainboard/hp/2760p/board_info.txt new file mode 100644 index 0000000..ae1ca3b --- /dev/null +++ b/src/mainboard/hp/2760p/board_info.txt @@ -0,0 +1,6 @@ +Category: laptop +ROM protocol: SPI +ROM package: SOIC-8 +ROM socketed: yes +Flashrom support: n +Release year: 2011 diff --git a/src/mainboard/hp/2760p/devicetree.cb b/src/mainboard/hp/2760p/devicetree.cb new file mode 100644 index 0000000..34acfaf --- /dev/null +++ b/src/mainboard/hp/2760p/devicetree.cb @@ -0,0 +1,111 @@ +chip northbridge/intel/sandybridge # FIXME: check gfx.ndid and gfx.did + register "gfx.did" = "{ 0x80000100, 0x80000240, 0x80000410, 0x80000410, 0x00000005 }" + register "gfx.link_frequency_270_mhz" = "1" + register "gfx.ndid" = "3" + register "gfx.use_spread_spectrum_clock" = "1" + register "gpu_cpu_backlight" = "0x00000129" + register "gpu_dp_b_hotplug" = "4" + register "gpu_dp_c_hotplug" = "4" + register "gpu_dp_d_hotplug" = "4" + register "gpu_panel_port_select" = "0" + register "gpu_panel_power_backlight_off_delay" = "2000" + register "gpu_panel_power_backlight_on_delay" = "2000" + register "gpu_panel_power_cycle_delay" = "5" + register "gpu_panel_power_down_delay" = "230" + register "gpu_panel_power_up_delay" = "300" + register "gpu_pch_backlight" = "0x02880288" + device cpu_cluster 0x0 on + chip cpu/intel/socket_rPGA989 + device lapic 0x0 on + end + end + chip cpu/intel/model_206ax # FIXME: check all registers + register "c1_acpower" = "1" + register "c1_battery" = "1" + register "c2_acpower" = "3" + register "c2_battery" = "3" + register "c3_acpower" = "5" + register "c3_battery" = "5" + device lapic 0xacac off + end + end + end + device domain 0x0 on + chip southbridge/intel/bd82x6x # Intel Series 6 Cougar Point PCH + register "c2_latency" = "0x0065" + register "docking_supported" = "0" + register "gen1_dec" = "0x007c0201" + register "gen2_dec" = "0x000c0101" + register "gen3_dec" = "0x00fcfe01" + register "gen4_dec" = "0x007c0281" + register "gpi6_routing" = "2" + register "p_cnt_throttling_supported" = "1" + register "pcie_hotplug_map" = "{ 0, 0, 1, 0, 0, 0, 0, 0 }" + register "pcie_port_coalesce" = "1" + register "sata_interface_speed_support" = "0x3" + register "sata_port_map" = "0x21" + device pci 16.0 on # Management Engine Interface 1 + subsystemid 0x103c 0x162a + end + device pci 16.1 off # Management Engine Interface 2 + end + device pci 16.2 off # Management Engine IDE-R + end + device pci 16.3 off # Management Engine KT + end + device pci 19.0 on # Intel Gigabit Ethernet + subsystemid 0x103c 0x162a + end + device pci 1a.0 on # USB2 EHCI #2 + subsystemid 0x103c 0x162a + end + device pci 1b.0 on # High Definition Audio Audio controller + subsystemid 0x103c 0x162a + end + device pci 1c.0 on # PCIe Port #1 + subsystemid 0x103c 0x162a + end + device pci 1c.1 on # PCIe Port #2 + subsystemid 0x103c 0x162a + end + device pci 1c.2 on # PCIe Port #3 + subsystemid 0x103c 0x162a + end + device pci 1c.3 on # WLAN + end + device pci 1c.4 off # PCIe Port #5 + end + device pci 1c.5 off # PCIe Port #6 + end + device pci 1c.6 off # PCIe Port #7 + end + device pci 1c.7 off # PCIe Port #8 + end + device pci 1d.0 on # USB2 EHCI #1 + subsystemid 0x103c 0x162a + end + device pci 1e.0 off # PCI bridge + end + device pci 1f.0 on # LPC bridge PCI-LPC bridge + subsystemid 0x103c 0x162a + end + device pci 1f.2 on # SATA Controller 1 + subsystemid 0x103c 0x162a + end + device pci 1f.3 off # SMBus + end + device pci 1f.5 off # SATA Controller 2 + end + device pci 1f.6 off # Thermal + end + end + device pci 00.0 on # Host bridge Host bridge + subsystemid 0x103c 0x162a + end + device pci 01.0 off # PCIe Bridge for discrete graphics + end + device pci 02.0 on # Internal graphics VGA controller + subsystemid 0x103c 0x162a + end + end +end diff --git a/src/mainboard/hp/2760p/dsdt.asl b/src/mainboard/hp/2760p/dsdt.asl new file mode 100644 index 0000000..3b7fb7e --- /dev/null +++ b/src/mainboard/hp/2760p/dsdt.asl @@ -0,0 +1,30 @@ +#define BRIGHTNESS_UP _SB.PCI0.GFX0.INCB +#define BRIGHTNESS_DOWN _SB.PCI0.GFX0.DECB +#define ACPI_VIDEO_DEVICE _SB.PCI0.GFX0 +DefinitionBlock( + "dsdt.aml", + "DSDT", + 0x03, // DSDT revision: ACPI v3.0 + "COREv4", // OEM id + "COREBOOT", // OEM table id + 0x20141018 // OEM revision +) +{ + // Some generic macros + #include "acpi/platform.asl" + #include <cpu/intel/model_206ax/acpi/cpu.asl> + #include <southbridge/intel/bd82x6x/acpi/platform.asl> + /* global NVS and variables. */ + #include <southbridge/intel/bd82x6x/acpi/globalnvs.asl> + #include <southbridge/intel/bd82x6x/acpi/sleepstates.asl> + + Scope (_SB) { + Device (PCI0) + { + #include <northbridge/intel/sandybridge/acpi/sandybridge.asl> + #include <drivers/intel/gma/acpi/default_brightness_levels.asl> + #include <southbridge/intel/bd82x6x/acpi/pch.asl> + #include <southbridge/intel/bd82x6x/acpi/default_irq_route.asl> + } + } +} diff --git a/src/mainboard/hp/2760p/early_southbridge.c b/src/mainboard/hp/2760p/early_southbridge.c new file mode 100644 index 0000000..f2178b3 --- /dev/null +++ b/src/mainboard/hp/2760p/early_southbridge.c @@ -0,0 +1,69 @@ +#include <stdint.h> +#include <string.h> +#include <lib.h> +#include <timestamp.h> +#include <arch/byteorder.h> +#include <arch/io.h> +#include <device/pci_def.h> +#include <device/pnp_def.h> +#include <cpu/x86/lapic.h> +#include <arch/acpi.h> +#include <console/console.h> +#include "northbridge/intel/sandybridge/sandybridge.h" +#include "northbridge/intel/sandybridge/raminit_native.h" +#include "southbridge/intel/bd82x6x/pch.h" +#include <southbridge/intel/common/gpio.h> +#include <arch/cpu.h> +#include <cpu/x86/msr.h> + +void pch_enable_lpc(void) +{ + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x82, 0x3f0f); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x84, 0x007c0201); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x88, 0x000c0101); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x8c, 0x00fcfe01); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x90, 0x007c0281); + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x80, 0x0010); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0xac, 0x82000000); +} + +void rcba_config(void) +{ + /* Disable devices. */ + RCBA32(0x3414) = 0x00000000; + RCBA32(0x3418) = 0x1ff01feb; + +} +const struct southbridge_usb_port mainboard_usb_ports[] = { + { 1, 1, 0 }, + { 1, 1, 0 }, + { 1, 1, 1 }, + { 1, 1, 1 }, + { 1, 0, 2 }, + { 1, 1, 2 }, + { 0, 0, 3 }, + { 1, 0, 3 }, + { 1, 1, 4 }, + { 0, 0, 4 }, + { 0, 0, 5 }, + { 1, 1, 5 }, + { 0, 0, 6 }, + { 1, 1, 6 }, +}; + +void mainboard_early_init(int s3resume) +{ +} + +void mainboard_config_superio(void) +{ +} + +/* FIXME: Put proper SPD map here. */ +void mainboard_get_spd(spd_raw_data *spd, bool id_only) +{ + read_spd(&spd[0], 0x50, id_only); + read_spd(&spd[1], 0x51, id_only); + read_spd(&spd[2], 0x52, id_only); + read_spd(&spd[3], 0x53, id_only); +} diff --git a/src/mainboard/hp/2760p/gnvs.c b/src/mainboard/hp/2760p/gnvs.c new file mode 100644 index 0000000..37cd5c9 --- /dev/null +++ b/src/mainboard/hp/2760p/gnvs.c @@ -0,0 +1,19 @@ +#include <southbridge/intel/bd82x6x/nvs.h> + +/* FIXME: check this function. */ +void acpi_create_gnvs(global_nvs_t *gnvs) +{ + /* Disable USB ports in S3 by default */ + gnvs->s3u0 = 0; + gnvs->s3u1 = 0; + + /* Disable USB ports in S5 by default */ + gnvs->s5u0 = 0; + gnvs->s5u1 = 0; + + // the lid is open by default. + gnvs->lids = 1; + + gnvs->tcrt = 100; + gnvs->tpsv = 90; +} diff --git a/src/mainboard/hp/2760p/gpio.c b/src/mainboard/hp/2760p/gpio.c new file mode 100644 index 0000000..65bff4e --- /dev/null +++ b/src/mainboard/hp/2760p/gpio.c @@ -0,0 +1,433 @@ +#include <southbridge/intel/common/gpio.h> +const struct pch_gpio_set1 pch_gpio_set1_mode = { + .gpio0 = GPIO_MODE_GPIO, + .gpio1 = GPIO_MODE_GPIO, + .gpio2 = GPIO_MODE_GPIO, + .gpio3 = GPIO_MODE_GPIO, + .gpio4 = GPIO_MODE_GPIO, + .gpio5 = GPIO_MODE_NATIVE, + .gpio6 = GPIO_MODE_GPIO, + .gpio7 = GPIO_MODE_GPIO, + .gpio8 = GPIO_MODE_GPIO, + .gpio9 = GPIO_MODE_NATIVE, + .gpio10 = GPIO_MODE_GPIO, + .gpio11 = GPIO_MODE_GPIO, + .gpio12 = GPIO_MODE_NATIVE, + .gpio13 = GPIO_MODE_GPIO, + .gpio14 = GPIO_MODE_GPIO, + .gpio15 = GPIO_MODE_GPIO, + .gpio16 = GPIO_MODE_GPIO, + .gpio17 = GPIO_MODE_GPIO, + .gpio18 = GPIO_MODE_NATIVE, + .gpio19 = GPIO_MODE_NATIVE, + .gpio20 = GPIO_MODE_NATIVE, + .gpio21 = GPIO_MODE_GPIO, + .gpio22 = GPIO_MODE_GPIO, + .gpio23 = GPIO_MODE_GPIO, + .gpio24 = GPIO_MODE_GPIO, + .gpio25 = GPIO_MODE_NATIVE, + .gpio26 = GPIO_MODE_NATIVE, + .gpio27 = GPIO_MODE_GPIO, + .gpio28 = GPIO_MODE_GPIO, + .gpio29 = GPIO_MODE_GPIO, + .gpio30 = GPIO_MODE_NATIVE, + .gpio31 = GPIO_MODE_NATIVE, +}; + +const struct pch_gpio_set1 pch_gpio_set1_direction = { + .gpio0 = GPIO_DIR_OUTPUT, + .gpio1 = GPIO_DIR_INPUT, + .gpio2 = GPIO_DIR_INPUT, + .gpio3 = GPIO_DIR_INPUT, + .gpio4 = GPIO_DIR_INPUT, + .gpio5 = GPIO_DIR_OUTPUT, + .gpio6 = GPIO_DIR_INPUT, + .gpio7 = GPIO_DIR_INPUT, + .gpio8 = GPIO_DIR_INPUT, + .gpio9 = GPIO_DIR_INPUT, + .gpio10 = GPIO_DIR_INPUT, + .gpio11 = GPIO_DIR_OUTPUT, + .gpio12 = GPIO_DIR_OUTPUT, + .gpio13 = GPIO_DIR_INPUT, + .gpio14 = GPIO_DIR_INPUT, + .gpio15 = GPIO_DIR_INPUT, + .gpio16 = GPIO_DIR_INPUT, + .gpio17 = GPIO_DIR_OUTPUT, + .gpio18 = GPIO_DIR_INPUT, + .gpio19 = GPIO_DIR_INPUT, + .gpio20 = GPIO_DIR_INPUT, + .gpio21 = GPIO_DIR_INPUT, + .gpio22 = GPIO_DIR_OUTPUT, + .gpio23 = GPIO_DIR_INPUT, + .gpio24 = GPIO_DIR_OUTPUT, + .gpio25 = GPIO_DIR_INPUT, + .gpio26 = GPIO_DIR_INPUT, + .gpio27 = GPIO_DIR_OUTPUT, + .gpio28 = GPIO_DIR_OUTPUT, + .gpio29 = GPIO_DIR_OUTPUT, + .gpio30 = GPIO_DIR_OUTPUT, + .gpio31 = GPIO_DIR_INPUT, +}; + +const struct pch_gpio_set1 pch_gpio_set1_level = { + .gpio0 = GPIO_LEVEL_LOW, + .gpio1 = GPIO_LEVEL_HIGH, + .gpio2 = GPIO_LEVEL_HIGH, + .gpio3 = GPIO_LEVEL_HIGH, + .gpio4 = GPIO_LEVEL_HIGH, + .gpio5 = GPIO_LEVEL_LOW, + .gpio6 = GPIO_LEVEL_HIGH, + .gpio7 = GPIO_LEVEL_HIGH, + .gpio8 = GPIO_LEVEL_HIGH, + .gpio9 = GPIO_LEVEL_HIGH, + .gpio10 = GPIO_LEVEL_HIGH, + .gpio11 = GPIO_LEVEL_LOW, + .gpio12 = GPIO_LEVEL_HIGH, + .gpio13 = GPIO_LEVEL_HIGH, + .gpio14 = GPIO_LEVEL_HIGH, + .gpio15 = GPIO_LEVEL_HIGH, + .gpio16 = GPIO_LEVEL_HIGH, + .gpio17 = GPIO_LEVEL_HIGH, + .gpio18 = GPIO_LEVEL_HIGH, + .gpio19 = GPIO_LEVEL_HIGH, + .gpio20 = GPIO_LEVEL_HIGH, + .gpio21 = GPIO_LEVEL_HIGH, + .gpio22 = GPIO_LEVEL_HIGH, + .gpio23 = GPIO_LEVEL_HIGH, + .gpio24 = GPIO_LEVEL_HIGH, + .gpio25 = GPIO_LEVEL_LOW, + .gpio26 = GPIO_LEVEL_HIGH, + .gpio27 = GPIO_LEVEL_LOW, + .gpio28 = GPIO_LEVEL_LOW, + .gpio29 = GPIO_LEVEL_HIGH, + .gpio30 = GPIO_LEVEL_HIGH, + .gpio31 = GPIO_LEVEL_LOW, +}; + +const struct pch_gpio_set1 pch_gpio_set1_reset = { + .gpio0 = GPIO_RESET_PWROK, + .gpio1 = GPIO_RESET_PWROK, + .gpio2 = GPIO_RESET_PWROK, + .gpio3 = GPIO_RESET_PWROK, + .gpio4 = GPIO_RESET_PWROK, + .gpio5 = GPIO_RESET_PWROK, + .gpio6 = GPIO_RESET_PWROK, + .gpio7 = GPIO_RESET_PWROK, + .gpio8 = GPIO_RESET_PWROK, + .gpio9 = GPIO_RESET_PWROK, + .gpio10 = GPIO_RESET_PWROK, + .gpio11 = GPIO_RESET_PWROK, + .gpio12 = GPIO_RESET_PWROK, + .gpio13 = GPIO_RESET_PWROK, + .gpio14 = GPIO_RESET_PWROK, + .gpio15 = GPIO_RESET_PWROK, + .gpio16 = GPIO_RESET_PWROK, + .gpio17 = GPIO_RESET_PWROK, + .gpio18 = GPIO_RESET_PWROK, + .gpio19 = GPIO_RESET_PWROK, + .gpio20 = GPIO_RESET_PWROK, + .gpio21 = GPIO_RESET_PWROK, + .gpio22 = GPIO_RESET_PWROK, + .gpio23 = GPIO_RESET_PWROK, + .gpio24 = GPIO_RESET_RSMRST, + .gpio25 = GPIO_RESET_PWROK, + .gpio26 = GPIO_RESET_PWROK, + .gpio27 = GPIO_RESET_PWROK, + .gpio28 = GPIO_RESET_PWROK, + .gpio29 = GPIO_RESET_PWROK, + .gpio30 = GPIO_RESET_RSMRST, + .gpio31 = GPIO_RESET_PWROK, +}; + +const struct pch_gpio_set1 pch_gpio_set1_invert = { + .gpio0 = GPIO_NO_INVERT, + .gpio1 = GPIO_INVERT, + .gpio2 = GPIO_NO_INVERT, + .gpio3 = GPIO_INVERT, + .gpio4 = GPIO_NO_INVERT, + .gpio5 = GPIO_NO_INVERT, + .gpio6 = GPIO_INVERT, + .gpio7 = GPIO_INVERT, + .gpio8 = GPIO_NO_INVERT, + .gpio9 = GPIO_NO_INVERT, + .gpio10 = GPIO_INVERT, + .gpio11 = GPIO_INVERT, + .gpio12 = GPIO_NO_INVERT, + .gpio13 = GPIO_INVERT, + .gpio14 = GPIO_INVERT, + .gpio15 = GPIO_NO_INVERT, + .gpio16 = GPIO_NO_INVERT, + .gpio17 = GPIO_NO_INVERT, + .gpio18 = GPIO_NO_INVERT, + .gpio19 = GPIO_NO_INVERT, + .gpio20 = GPIO_NO_INVERT, + .gpio21 = GPIO_NO_INVERT, + .gpio22 = GPIO_NO_INVERT, + .gpio23 = GPIO_NO_INVERT, + .gpio24 = GPIO_NO_INVERT, + .gpio25 = GPIO_NO_INVERT, + .gpio26 = GPIO_NO_INVERT, + .gpio27 = GPIO_NO_INVERT, + .gpio28 = GPIO_NO_INVERT, + .gpio29 = GPIO_NO_INVERT, + .gpio30 = GPIO_NO_INVERT, + .gpio31 = GPIO_NO_INVERT, +}; + +const struct pch_gpio_set1 pch_gpio_set1_blink = { + .gpio0 = GPIO_NO_BLINK, + .gpio1 = GPIO_NO_BLINK, + .gpio2 = GPIO_NO_BLINK, + .gpio3 = GPIO_NO_BLINK, + .gpio4 = GPIO_NO_BLINK, + .gpio5 = GPIO_NO_BLINK, + .gpio6 = GPIO_NO_BLINK, + .gpio7 = GPIO_NO_BLINK, + .gpio8 = GPIO_NO_BLINK, + .gpio9 = GPIO_NO_BLINK, + .gpio10 = GPIO_NO_BLINK, + .gpio11 = GPIO_NO_BLINK, + .gpio12 = GPIO_NO_BLINK, + .gpio13 = GPIO_NO_BLINK, + .gpio14 = GPIO_NO_BLINK, + .gpio15 = GPIO_NO_BLINK, + .gpio16 = GPIO_NO_BLINK, + .gpio17 = GPIO_NO_BLINK, + .gpio18 = GPIO_NO_BLINK, + .gpio19 = GPIO_NO_BLINK, + .gpio20 = GPIO_NO_BLINK, + .gpio21 = GPIO_NO_BLINK, + .gpio22 = GPIO_NO_BLINK, + .gpio23 = GPIO_NO_BLINK, + .gpio24 = GPIO_NO_BLINK, + .gpio25 = GPIO_NO_BLINK, + .gpio26 = GPIO_NO_BLINK, + .gpio27 = GPIO_NO_BLINK, + .gpio28 = GPIO_NO_BLINK, + .gpio29 = GPIO_NO_BLINK, + .gpio30 = GPIO_NO_BLINK, + .gpio31 = GPIO_NO_BLINK, +}; + +const struct pch_gpio_set2 pch_gpio_set2_mode = { + .gpio32 = GPIO_MODE_NATIVE, + .gpio33 = GPIO_MODE_GPIO, + .gpio34 = GPIO_MODE_GPIO, + .gpio35 = GPIO_MODE_GPIO, + .gpio36 = GPIO_MODE_GPIO, + .gpio37 = GPIO_MODE_GPIO, + .gpio38 = GPIO_MODE_GPIO, + .gpio39 = GPIO_MODE_GPIO, + .gpio40 = GPIO_MODE_NATIVE, + .gpio41 = GPIO_MODE_NATIVE, + .gpio42 = GPIO_MODE_NATIVE, + .gpio43 = GPIO_MODE_NATIVE, + .gpio44 = GPIO_MODE_GPIO, + .gpio45 = GPIO_MODE_NATIVE, + .gpio46 = GPIO_MODE_GPIO, + .gpio47 = GPIO_MODE_NATIVE, + .gpio48 = GPIO_MODE_GPIO, + .gpio49 = GPIO_MODE_GPIO, + .gpio50 = GPIO_MODE_GPIO, + .gpio51 = GPIO_MODE_GPIO, + .gpio52 = GPIO_MODE_GPIO, + .gpio53 = GPIO_MODE_GPIO, + .gpio54 = GPIO_MODE_GPIO, + .gpio55 = GPIO_MODE_GPIO, + .gpio56 = GPIO_MODE_NATIVE, + .gpio57 = GPIO_MODE_GPIO, + .gpio58 = GPIO_MODE_NATIVE, + .gpio59 = GPIO_MODE_NATIVE, + .gpio60 = GPIO_MODE_GPIO, + .gpio61 = GPIO_MODE_GPIO, + .gpio62 = GPIO_MODE_NATIVE, + .gpio63 = GPIO_MODE_NATIVE, +}; + +const struct pch_gpio_set2 pch_gpio_set2_direction = { + .gpio32 = GPIO_DIR_OUTPUT, + .gpio33 = GPIO_DIR_OUTPUT, + .gpio34 = GPIO_DIR_INPUT, + .gpio35 = GPIO_DIR_OUTPUT, + .gpio36 = GPIO_DIR_OUTPUT, + .gpio37 = GPIO_DIR_OUTPUT, + .gpio38 = GPIO_DIR_INPUT, + .gpio39 = GPIO_DIR_INPUT, + .gpio40 = GPIO_DIR_INPUT, + .gpio41 = GPIO_DIR_INPUT, + .gpio42 = GPIO_DIR_INPUT, + .gpio43 = GPIO_DIR_INPUT, + .gpio44 = GPIO_DIR_INPUT, + .gpio45 = GPIO_DIR_INPUT, + .gpio46 = GPIO_DIR_INPUT, + .gpio47 = GPIO_DIR_INPUT, + .gpio48 = GPIO_DIR_INPUT, + .gpio49 = GPIO_DIR_OUTPUT, + .gpio50 = GPIO_DIR_INPUT, + .gpio51 = GPIO_DIR_INPUT, + .gpio52 = GPIO_DIR_INPUT, + .gpio53 = GPIO_DIR_OUTPUT, + .gpio54 = GPIO_DIR_OUTPUT, + .gpio55 = GPIO_DIR_OUTPUT, + .gpio56 = GPIO_DIR_INPUT, + .gpio57 = GPIO_DIR_OUTPUT, + .gpio58 = GPIO_DIR_INPUT, + .gpio59 = GPIO_DIR_INPUT, + .gpio60 = GPIO_DIR_OUTPUT, + .gpio61 = GPIO_DIR_OUTPUT, + .gpio62 = GPIO_DIR_OUTPUT, + .gpio63 = GPIO_DIR_OUTPUT, +}; + +const struct pch_gpio_set2 pch_gpio_set2_level = { + .gpio32 = GPIO_LEVEL_LOW, + .gpio33 = GPIO_LEVEL_LOW, + .gpio34 = GPIO_LEVEL_HIGH, + .gpio35 = GPIO_LEVEL_LOW, + .gpio36 = GPIO_LEVEL_LOW, + .gpio37 = GPIO_LEVEL_LOW, + .gpio38 = GPIO_LEVEL_HIGH, + .gpio39 = GPIO_LEVEL_HIGH, + .gpio40 = GPIO_LEVEL_HIGH, + .gpio41 = GPIO_LEVEL_HIGH, + .gpio42 = GPIO_LEVEL_HIGH, + .gpio43 = GPIO_LEVEL_HIGH, + .gpio44 = GPIO_LEVEL_LOW, + .gpio45 = GPIO_LEVEL_HIGH, + .gpio46 = GPIO_LEVEL_HIGH, + .gpio47 = GPIO_LEVEL_HIGH, + .gpio48 = GPIO_LEVEL_LOW, + .gpio49 = GPIO_LEVEL_LOW, + .gpio50 = GPIO_LEVEL_HIGH, + .gpio51 = GPIO_LEVEL_HIGH, + .gpio52 = GPIO_LEVEL_HIGH, + .gpio53 = GPIO_LEVEL_HIGH, + .gpio54 = GPIO_LEVEL_HIGH, + .gpio55 = GPIO_LEVEL_LOW, + .gpio56 = GPIO_LEVEL_HIGH, + .gpio57 = GPIO_LEVEL_HIGH, + .gpio58 = GPIO_LEVEL_HIGH, + .gpio59 = GPIO_LEVEL_HIGH, + .gpio60 = GPIO_LEVEL_HIGH, + .gpio61 = GPIO_LEVEL_HIGH, + .gpio62 = GPIO_LEVEL_HIGH, + .gpio63 = GPIO_LEVEL_HIGH, +}; + +const struct pch_gpio_set2 pch_gpio_set2_reset = { + .gpio32 = GPIO_RESET_PWROK, + .gpio33 = GPIO_RESET_PWROK, + .gpio34 = GPIO_RESET_PWROK, + .gpio35 = GPIO_RESET_PWROK, + .gpio36 = GPIO_RESET_PWROK, + .gpio37 = GPIO_RESET_PWROK, + .gpio38 = GPIO_RESET_PWROK, + .gpio39 = GPIO_RESET_PWROK, + .gpio40 = GPIO_RESET_PWROK, + .gpio41 = GPIO_RESET_PWROK, + .gpio42 = GPIO_RESET_PWROK, + .gpio43 = GPIO_RESET_PWROK, + .gpio44 = GPIO_RESET_PWROK, + .gpio45 = GPIO_RESET_PWROK, + .gpio46 = GPIO_RESET_PWROK, + .gpio47 = GPIO_RESET_PWROK, + .gpio48 = GPIO_RESET_PWROK, + .gpio49 = GPIO_RESET_PWROK, + .gpio50 = GPIO_RESET_PWROK, + .gpio51 = GPIO_RESET_PWROK, + .gpio52 = GPIO_RESET_PWROK, + .gpio53 = GPIO_RESET_PWROK, + .gpio54 = GPIO_RESET_PWROK, + .gpio55 = GPIO_RESET_PWROK, + .gpio56 = GPIO_RESET_PWROK, + .gpio57 = GPIO_RESET_PWROK, + .gpio58 = GPIO_RESET_PWROK, + .gpio59 = GPIO_RESET_PWROK, + .gpio60 = GPIO_RESET_PWROK, + .gpio61 = GPIO_RESET_PWROK, + .gpio62 = GPIO_RESET_PWROK, + .gpio63 = GPIO_RESET_PWROK, +}; + +const struct pch_gpio_set3 pch_gpio_set3_mode = { + .gpio64 = GPIO_MODE_NATIVE, + .gpio65 = GPIO_MODE_NATIVE, + .gpio66 = GPIO_MODE_NATIVE, + .gpio67 = GPIO_MODE_NATIVE, + .gpio68 = GPIO_MODE_GPIO, + .gpio69 = GPIO_MODE_GPIO, + .gpio70 = GPIO_MODE_GPIO, + .gpio71 = GPIO_MODE_NATIVE, + .gpio72 = GPIO_MODE_GPIO, + .gpio73 = GPIO_MODE_GPIO, + .gpio74 = GPIO_MODE_GPIO, + .gpio75 = GPIO_MODE_NATIVE, +}; + +const struct pch_gpio_set3 pch_gpio_set3_direction = { + .gpio64 = GPIO_DIR_OUTPUT, + .gpio65 = GPIO_DIR_OUTPUT, + .gpio66 = GPIO_DIR_OUTPUT, + .gpio67 = GPIO_DIR_OUTPUT, + .gpio68 = GPIO_DIR_OUTPUT, + .gpio69 = GPIO_DIR_INPUT, + .gpio70 = GPIO_DIR_OUTPUT, + .gpio71 = GPIO_DIR_INPUT, + .gpio72 = GPIO_DIR_OUTPUT, + .gpio73 = GPIO_DIR_OUTPUT, + .gpio74 = GPIO_DIR_OUTPUT, + .gpio75 = GPIO_DIR_INPUT, +}; + +const struct pch_gpio_set3 pch_gpio_set3_level = { + .gpio64 = GPIO_LEVEL_HIGH, + .gpio65 = GPIO_LEVEL_HIGH, + .gpio66 = GPIO_LEVEL_HIGH, + .gpio67 = GPIO_LEVEL_HIGH, + .gpio68 = GPIO_LEVEL_HIGH, + .gpio69 = GPIO_LEVEL_LOW, + .gpio70 = GPIO_LEVEL_HIGH, + .gpio71 = GPIO_LEVEL_HIGH, + .gpio72 = GPIO_LEVEL_HIGH, + .gpio73 = GPIO_LEVEL_HIGH, + .gpio74 = GPIO_LEVEL_HIGH, + .gpio75 = GPIO_LEVEL_HIGH, +}; + +const struct pch_gpio_set3 pch_gpio_set3_reset = { + .gpio64 = GPIO_RESET_PWROK, + .gpio65 = GPIO_RESET_PWROK, + .gpio66 = GPIO_RESET_PWROK, + .gpio67 = GPIO_RESET_PWROK, + .gpio68 = GPIO_RESET_PWROK, + .gpio69 = GPIO_RESET_PWROK, + .gpio70 = GPIO_RESET_PWROK, + .gpio71 = GPIO_RESET_PWROK, + .gpio72 = GPIO_RESET_PWROK, + .gpio73 = GPIO_RESET_PWROK, + .gpio74 = GPIO_RESET_PWROK, + .gpio75 = GPIO_RESET_PWROK, +}; + +const struct pch_gpio_map mainboard_gpio_map = { + .set1 = { + .mode = &pch_gpio_set1_mode, + .direction = &pch_gpio_set1_direction, + .level = &pch_gpio_set1_level, + .blink = &pch_gpio_set1_blink, + .invert = &pch_gpio_set1_invert, + .reset = &pch_gpio_set1_reset, + }, + .set2 = { + .mode = &pch_gpio_set2_mode, + .direction = &pch_gpio_set2_direction, + .level = &pch_gpio_set2_level, + .reset = &pch_gpio_set2_reset, + }, + .set3 = { + .mode = &pch_gpio_set3_mode, + .direction = &pch_gpio_set3_direction, + .level = &pch_gpio_set3_level, + .reset = &pch_gpio_set3_reset, + }, +}; diff --git a/src/mainboard/hp/2760p/hda_verb.c b/src/mainboard/hp/2760p/hda_verb.c new file mode 100644 index 0000000..c60846e --- /dev/null +++ b/src/mainboard/hp/2760p/hda_verb.c @@ -0,0 +1,65 @@ +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + 0x111d7605, /* Codec Vendor / Device ID: IDT */ + 0x103c162a, /* Subsystem ID */ + + 0x0000000b, /* Number of 4 dword sets */ + /* NID 0x01: Subsystem ID. */ + AZALIA_SUBVENDOR(0x0, 0x103c162a), + + /* NID 0x0a. */ + AZALIA_PIN_CFG(0x0, 0x0a, 0x40f000f0), + + /* NID 0x0b. */ + AZALIA_PIN_CFG(0x0, 0x0b, 0x0421401f), + + /* NID 0x0c. */ + AZALIA_PIN_CFG(0x0, 0x0c, 0x04a11020), + + /* NID 0x0d. */ + AZALIA_PIN_CFG(0x0, 0x0d, 0x90170110), + + /* NID 0x0e. */ + AZALIA_PIN_CFG(0x0, 0x0e, 0x90a70130), + + /* NID 0x0f. */ + AZALIA_PIN_CFG(0x0, 0x0f, 0x40f000f0), + + /* NID 0x10. */ + AZALIA_PIN_CFG(0x0, 0x10, 0x40f000f0), + + /* NID 0x11. */ + AZALIA_PIN_CFG(0x0, 0x11, 0x40f000f0), + + /* NID 0x1f. */ + AZALIA_PIN_CFG(0x0, 0x1f, 0x40f000f0), + + /* NID 0x20. */ + AZALIA_PIN_CFG(0x0, 0x20, 0x40f000f0), + 0x11c11040, /* Codec Vendor / Device ID: LSI */ + 0x103c3066, /* Subsystem ID */ + + 0x00000001, /* Number of 4 dword sets */ + /* NID 0x01: Subsystem ID. */ + AZALIA_SUBVENDOR(0x1, 0x103c3066), + 0x80862805, /* Codec Vendor / Device ID: Intel */ + 0x80860101, /* Subsystem ID */ + + 0x00000004, /* Number of 4 dword sets */ + /* NID 0x01: Subsystem ID. */ + AZALIA_SUBVENDOR(0x3, 0x80860101), + + /* NID 0x05. */ + AZALIA_PIN_CFG(0x3, 0x05, 0x18560010), + + /* NID 0x06. */ + AZALIA_PIN_CFG(0x3, 0x06, 0x58560020), + + /* NID 0x07. */ + AZALIA_PIN_CFG(0x3, 0x07, 0x58560030), +}; + +const u32 pc_beep_verbs[0] = {}; + +AZALIA_ARRAY_SIZES; diff --git a/src/mainboard/hp/2760p/mainboard.c b/src/mainboard/hp/2760p/mainboard.c new file mode 100644 index 0000000..5cf9f60 --- /dev/null +++ b/src/mainboard/hp/2760p/mainboard.c @@ -0,0 +1,55 @@ +#include <device/device.h> +#include <drivers/intel/gma/int15.h> +#include <southbridge/intel/bd82x6x/pch.h> +#include <ec/acpi/ec.h> +#include <console/console.h> +#include <pc80/keyboard.h> + +static void mainboard_init(device_t dev) +{ + RCBA32(0x38c8) = 0x00002005; + RCBA32(0x38c4) = 0x00800000; + RCBA32(0x38c0) = 0x00000007; +#if 0 + /* FIXME: trim this down or remove if necessary */ + { + int i; + const u8 dmp[256] = { + /* 00 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 10 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 20 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 30 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 40 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 50 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 60 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 70 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 80 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 90 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* a0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* b0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* c0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* d0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* e0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* f0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + }; + + printk(BIOS_DEBUG, "Replaying EC dump ..."); + for (i = 0; i < 256; i++) + ec_write (i, dmp[i]); + printk(BIOS_DEBUG, "done\n"); + } +#endif + pc_keyboard_init(NO_AUX_DEVICE); +} + +static void mainboard_enable(device_t dev) +{ + dev->ops->init = mainboard_init; + + /* FIXME: fix those values*/ + install_intel_vga_int15_handler(GMA_INT15_ACTIVE_LFP_INT_LVDS, GMA_INT15_PANEL_FIT_DEFAULT, GMA_INT15_BOOT_DISPLAY_DEFAULT, 0); +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/hp/2760p/romstage.c b/src/mainboard/hp/2760p/romstage.c new file mode 100644 index 0000000..f1839f0 --- /dev/null +++ b/src/mainboard/hp/2760p/romstage.c @@ -0,0 +1 @@ +/* dummy file */
