Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17890
commit 579b13006c88133f8268dccb6ddc2c5897efffe3 Author: Martin Roth martinroth@google.com Date: Wed Dec 14 10:16:26 2016 -0700
util/abuild: Print list of failed boards at the end of the abuild
When running abuild outside of jenkins, because all of the builds are printed intermixed, it's easy to miss when a board has failed the build by looking at the output. This saves a list of failed builds and prints the list at the end of the run.
- Add a command line option to mark when abuild is being called recursively. - Add all failed builds to a list. - Print the list when a non-recursive abuild run exits.
Change-Id: Icb40ed8083a57bbcde49297d2b0814f98dcbb6c8 Signed-off-by: Martin Roth martinroth@google.com --- util/abuild/abuild | 29 ++++++++++++++++++++++++++--- 1 file changed, 26 insertions(+), 3 deletions(-)
diff --git a/util/abuild/abuild b/util/abuild/abuild index 7c4e29f..93ceac5 100755 --- a/util/abuild/abuild +++ b/util/abuild/abuild @@ -79,6 +79,9 @@ quiet=false # clang mode enabled by -sb option. scanbuild=false
+# Mark whether abuild was called recursively +recursive=false + trap interrupt INT
function interrupt @@ -359,6 +362,7 @@ function compile_target printf "failed\n" > compile.status printf "%s build FAILED after %ss!\nLog excerpt:\n" "$BUILD_NAME" "${duration}" tail -n $CONTEXT make.log 2> /dev/null || tail -$CONTEXT make.log + echo "$BUILD_NAME" >> "$FAILED_BOARDS" failed=1 fi cd "$CURR" || return $? @@ -424,6 +428,7 @@ function build_config tail -n $CONTEXT "$build_dir/config.log" 2> /dev/null || tail -$CONTEXT "$build_dir/config.log"
junit "</testcase>" + echo "$BUILD_NAME" >> "$FAILED_BOARDS" return fi
@@ -585,12 +590,12 @@ getoptbrand="$(getopt -V)" # shellcheck disable=SC2086 if [ "${getoptbrand:0:6}" == "getopt" ]; then # Detected GNU getopt that supports long options. - args=$(getopt -l version,verbose,quiet,help,all,target:,payloads:,cpus:,silent,junit,config,loglevel:,remove,prefix:,update,scan-build,ccache,blobs,clang,clean,outdir:,chromeos,xmlfile:,kconfig:,dir:,root: -o Vvqhat:p:c:sJCl:rP:uyBLzo:xX:K:d:R: -- "$@") || exit 1 + args=$(getopt -l version,verbose,quiet,help,all,target:,payloads:,cpus:,silent,junit,config,loglevel:,remove,prefix:,update,scan-build,ccache,blobs,clang,clean,outdir:,chromeos,xmlfile:,kconfig:,dir:,root:,recursive -o Vvqhat:p:c:sJCl:rP:uyBLzo:xX:K:d:R:I -- "$@") || exit 1 eval set -- $args retval=$? else # Detected non-GNU getopt - args=$(getopt Vvqhat:p:c:sJCl:rP:uyBLzo:xX:K:d:R: "$@") + args=$(getopt Vvqhat:p:c:sJCl:rP:uyBLzo:xX:K:d:R:I "$@") set -- $args retval=$? fi @@ -671,6 +676,7 @@ while true ; do configoptions="${configoptions}CONFIG_CHROMEOS=y\n" ;; -X|--xmlfile) shift; XMLFILE=$1; REAL_XMLFILE=$1; shift;; + -I|--recursive) shift; recursive=true;; -K|--kconfig) shift testclass="$(basename "$1" | tr '.' '_' )" customizing="${customizing}, $1 config" @@ -695,6 +701,12 @@ if [ "$customizing" = "" ]; then customizing="default configuration" fi
+FAILED_BOARDS="$TOP/$TARGET/failed_boards" + +if [ "$recursive" = "false" ]; then + rm -f "$FAILED_BOARDS" +fi + USE_XARGS=0 if [ "$cpus" != "1" ]; then # Limit to 32 parallel builds for now. @@ -770,7 +782,7 @@ build_targets() fi rm -rf "$TARGET/temp" "$TMPCFG" # shellcheck disable=SC2086 - echo $targets | xargs -P ${cpus:-0} -n 1 "$0" $cmdline -t + echo $targets | xargs -P ${cpus:-0} -n 1 "$0" $cmdline -I -t } fi
@@ -814,4 +826,15 @@ else fi junit '</testsuite>'
+if [ "$recursive" = "false" ]; then + + # Print the list of failed boards + if [ -f "$FAILED_BOARDS" ]; then + printf "%s build(s) failed:\n" "$( wc -l < "$FAILED_BOARDS" )" + cat "$FAILED_BOARDS" + else + echo "All tested boards passed." + fi +fi + exit $failed
