Stefan Reinauer has submitted this change. ( https://review.coreboot.org/c/coreboot/+/14225 )
Change subject: util/release: add gerrit stats script ......................................................................
This tool downloads, caches and analyzes commits pushed to gerrit for a specified range of commits. Currently it only works over SSH.
Data that is printed about the range of commits: CSV Data about each individual commit: - Commit ID - Commit Date - Author - Commiter - Submitter - Lines added - Lines removed - Title - Reviewers
It then prints the analysis it did on the data: - Total Commits - Total lines added - Total lines removed - Total difference - Authors - Number of commits - Total Authors - Authors - Lines added - Authors - Lines removed - Reviewers - Number of patches reviewed - Submitters - Number of patches submitted
The script relies on a number of perl modules which must be installed separately.
Change-Id: I74896a97b5fe370c0b08562ac85d29435e438a31 Signed-off-by: Martin Roth martinroth@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/14225 Reviewed-by: Stefan Reinauer stefan.reinauer@coreboot.org Tested-by: Stefan Reinauer stefan.reinauer@coreboot.org --- A util/release/gerrit_stats.pl 1 file changed, 470 insertions(+), 0 deletions(-)
Approvals: Stefan Reinauer: Verified; Looks good to me, approved
diff --git a/util/release/gerrit_stats.pl b/util/release/gerrit_stats.pl new file mode 100755 index 0000000..acd5622 --- /dev/null +++ b/util/release/gerrit_stats.pl @@ -0,0 +1,470 @@ +#!/usr/bin/perl + +# +# This file is part of the coreboot project. +# +# Copyright (C) 2015 Google, Inc. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +package gerrit_stats; + +# To install any needed modules install the cpanm app, and use it to install the required modules: +# sudo cpan App::cpanminus +# sudo /usr/local/bin/cpanm JSON::Util Net::OpenSSH DateTime Devel::Size + +use strict; +use warnings; +use English qw( -no_match_vars ); +use File::Find; +use File::Path; +use Getopt::Long; +use Getopt::Std; +use JSON::Util; +use Net::OpenSSH; +use Data::Dumper qw(Dumper); +use DateTime; +use Devel::Size qw(size total_size); + +my $old_version; +my $new_version; +my $infodir="$ENV{'HOME'}/.commit_info/" . `git config -l | grep remote.origin.url | sed 's|.*@||' | sed 's|:.*||'`; +chomp($infodir); +my $URL_WITH_USER; +my $SKIP_GERRIT_CHECK; +my $print_commit_list = 1; + +#disable print buffering +$OUTPUT_AUTOFLUSH = 1; +binmode STDOUT, ":utf8"; + +Main(); + +#------------------------------------------------------------------------------- +# Main +#------------------------------------------------------------------------------- +sub Main { + check_arguments(); + + my %submitters = (); + my %authors = (); + my %owners = (); + my %reviewers = (); + my %author_added = (); + my %author_removed = (); + my $total_added = 0; + my $total_removed = 0; + my $number_of_commits = 0; + my $number_of_submitters = 0; + my $submit_epoch = ""; + my $first_submit_epoch = ""; + if (!$URL_WITH_USER) { + get_user() + } + + # make sure the versions exist + check_versions(); + + #fetch patches if needed. Get ids of first and last commits + my @commits = `git log --pretty=%h "$old_version..$new_version" 2>/dev/null`; + get_commits(@commits); + my $last_commit_id = $commits[0]; + my $first_commit_id = $commits[@commits - 1]; + chomp $last_commit_id; + chomp $first_commit_id; + + print "Statistics from commit $first_commit_id to commit $last_commit_id\n"; + print "Patch, Date, Owner, Author, Submitter, Inserted lines, Deleted lines, Subject, Reviewers\n"; + + #loop through all commits + for my $commit_id (@commits) { + $commit_id =~ s/^\s+|\s+$//g; + + my $submitter = ""; + my %patch_reviewers = (); + my $info; + my $owner; + my $author; + my $author_email; + my $inserted_lines = 0; + my $deleted_lines = 0; + my $subject; + + $number_of_commits++; + print ""$commit_id", "; + + #read the data file for the current commit + if (-f "$infodir/$commit_id" && -s "$infodir/$commit_id" > 20) { + open( my $HANDLE, "<", "$infodir/$commit_id" ) or die "Error: could not open file '$infodir/$commit_id'\n"; + $info = <$HANDLE>; + close $HANDLE; + + my $commit_info = JSON::Util->decode($info); + + #get the easy data + $owner = $commit_info->{'owner'}{'name'}; + if (! $owner) { + $owner = $commit_info->{'owner'}{'username'}; + } + if (! $owner) { + $owner = ""; + } + $author = $commit_info->{'currentPatchSet'}{'author'}{'name'}; + $author_email = $commit_info->{'currentPatchSet'}{'author'}{'email'}; + if (! $author) { + $author = $commit_info->{'currentPatchSet'}{'author'}{'username'}; + } + + $inserted_lines = $commit_info->{'currentPatchSet'}{'sizeInsertions'}; + $deleted_lines = $commit_info->{'currentPatchSet'}{'sizeDeletions'}; + $subject = $commit_info->{'subject'}; + + #get the patch's submitter + my $approvals = $commit_info->{'currentPatchSet'}{'approvals'}; + for my $approval (@$approvals) { + if ($approval->{'type'} eq "SUBM") { + $submit_epoch = $approval->{'grantedOn'}; + $submitter = $approval->{'by'}{'name'}; + } + } + + #get all the reviewers for all patch revisions + my $patchsets = $commit_info->{'patchSets'}; + for my $patch (@$patchsets) { + if (! $author) { + $author = $patch->{'author'}{'name'}; + } + my $approvals = $patch->{'approvals'}; + for my $approval (@$approvals) { + + if ( (! $submitter) && ($approval->{'type'} eq "SUBM")) { + $submit_epoch = $approval->{'grantedOn'}; + $submitter = $approval->{'by'}{'name'}; + } + + if ($approval->{'type'} eq "Code-Review") { + my $patch_reviewer = $approval->{'by'}{'name'}; + if ($patch_reviewer) { + if (exists $patch_reviewers{$patch_reviewer}) { + $patch_reviewers{$patch_reviewer}++; + } else { + $patch_reviewers{$patch_reviewer} = 1; + } + } + } + } + } + + } else { + # get the info from git + my $logline = `git log --pretty="%ct@@@%s@@@%an@@@%aE@@@%cn" $commit_id^..$commit_id --`; + $logline =~ m/^(.*)@@@(.*)@@@(.*)@@@(.*)@@@(.*)\n/; + ($submit_epoch, $subject, $author, $author_email, $submitter) = ($1, $2, $3, $4, $5); + $owner = $author; + $logline = `git log --pretty= --shortstat $commit_id^..$commit_id --`; + if ($logline =~ m/\s+(\d+)\s+insertion/) { + $inserted_lines = $1; + } + if ($logline =~ m/\s+(\d+)\s+deletion/) { + $deleted_lines = $1 * -1; + } + my @loglines = `git log $commit_id^..$commit_id -- | grep '\sReviewed-by:'`; + for my $line (@loglines){ + if ($line =~ m/.*:\s+(.*)\s</) { + my $patch_reviewer = $1; + if ($patch_reviewer) { + if (exists $patch_reviewers{$patch_reviewer}) { + $patch_reviewers{$patch_reviewer}++; + } else { + $patch_reviewers{$patch_reviewer} = 1; + } + } + } + } + + } + + # Not entirely certain why this is needed, but for a number of patches have been submitted + # the submit time in gerrit is set to April 9, 2015. + if ($submit_epoch == 1428586219){ + my $logline = `git log --pretty="%ct" $commit_id^..$commit_id --`; + $logline =~ m/^(.*)\n/; + $submit_epoch = $1; + } + + #add the count and owner to the submitter hash + if (exists $submitters{$submitter}) { + $submitters{$submitter}++; + } else { + $submitters{$submitter} = 1; + $number_of_submitters++; + } + + #create a readable date + my $dt = DateTime->from_epoch(epoch => $submit_epoch); + $dt->set_time_zone( 'Europe/Paris' ); + my $submit_time = $dt->strftime('%Y/%m/%d %H:%M:%S'); + if (!$first_submit_epoch) { + $first_submit_epoch = $submit_epoch; + } + + #create the list of reviewers to print + my $reviewerlist = ""; + foreach my $reviewer (keys %patch_reviewers) { + if ($reviewerlist eq "") { + $reviewerlist = $reviewer; + } else { + $reviewerlist .= ", $reviewer"; + } + + if (exists $reviewers{$reviewer}) { + $reviewers{$reviewer}++; + } else { + $reviewers{$reviewer} = 1; + } + } + if (! $reviewerlist) { + $reviewerlist = "-" + } + + if ($print_commit_list) { + print "$submit_time, $owner, $author, $submitter, $inserted_lines, $deleted_lines, "$subject", "$reviewerlist"\n"; + } else { + print "$number_of_commits\n"; + } + $total_added += $inserted_lines; + $total_removed += $deleted_lines; + if (exists $owners{$owner}) { + $owners{$owner}++; + } else { + $owners{$owner} = 1; + } + + if (exists $authors{$author}{"num"}) { + $authors{$author}{"num"}++; + $author_added{$author} += $inserted_lines; + $author_removed{$author} += $deleted_lines; + $authors{$author}{"earliest_commit"}=$submit_time; + } else { + $authors{$author}{"num"} = 1; + $authors{$author}{"latest_commit"}=$submit_time; + $authors{$author}{"earliest_commit"}=$submit_time; + $author_added{$author} = $inserted_lines; + $author_removed{$author} = $deleted_lines; + } + if (! exists $authors{$author}{email} && $author_email) { + $authors{$author}{email} = "$author_email"; + } + } + my $Days = ($first_submit_epoch - $submit_epoch) / 86400; + if (($first_submit_epoch - $submit_epoch) % 86400) { + $Days += 1; + } + + print "- Total Commits: $number_of_commits\n"; + printf "- Average Commits per day: %.2f\n", $number_of_commits / $Days; + print "- Total lines added: $total_added\n"; + print "- Total lines removed: $total_removed\n"; + print "- Total difference: " . ($total_added + $total_removed) . "\n\n"; + + print "=== Authors - Number of commits ===\n"; + my $number_of_authors = 0; + foreach my $author (sort { $authors{$b}{num} <=> $authors{$a}{num} } (keys %authors) ) { + if (! exists $authors{$author}{"email"}) { + $authors{$author}{"email"} = "-"; + } + printf "%-25s %5d %-40s (%2.2f%%) {%s / %s}\n",$author, $authors{$author}{"num"}, $authors{$author}{"email"}, $authors{$author}{"num"} / $number_of_commits * 100, $authors{$author}{"latest_commit"}, $authors{$author}{"earliest_commit"}; + $number_of_authors++; + } + print "Total Authors: $number_of_authors\n\n"; + + print "=== Authors - Lines added ===\n"; + foreach my $author (sort { $author_added{$b} <=> $author_added{$a} } (keys %author_added) ) { + if ($author_added{$author}) { + printf "%-25s %5d (%2.3f%%)\n",$author, $author_added{$author}, $author_added{$author} / $total_added * 100; + } + } + print "\n"; + + print "=== Authors - Lines removed ===\n"; + foreach my $author (sort { $author_removed{$a} <=> $author_removed{$b} } (keys %author_removed) ) { + if ($author_removed{$author}) { + printf "%-25s %5d (%2.3f%%)\n",$author,$author_removed{$author} * -1, $author_removed{$author} / $total_removed * 100; + } + } + print "\n"; + + print "=== Reviewers - Number of patches reviewed ===\n"; + my $number_of_reviewers = 0; + foreach my $reviewer (sort { $reviewers{$b} <=> $reviewers{$a} } (keys %reviewers) ) { + printf "%-25s %5d (%2.3f%%)\n",$reviewer, $reviewers{$reviewer}, $reviewers{$reviewer} / $number_of_commits * 100; + $number_of_reviewers++; + } + print "Total Reviewers: $number_of_reviewers\n\n"; + + print "=== Submitters - Number of patches submitted ===\n"; + foreach my $submitter (sort { $submitters{$b} <=> $submitters{$a} } (keys %submitters) ) { + printf "%-25s %5d (%2.3f%%)\n",$submitter, $submitters{$submitter}, $submitters{$submitter} / $number_of_commits * 100; + } + print "Total Submitters: $number_of_submitters\n\n"; + + print "Commits, Ave, Added, Removed, Diff, Authors, Reviewers, Submitters\n"; + printf "$number_of_commits, %.2f, $total_added, $total_removed, " . ($total_added + $total_removed) . ", $number_of_authors, $number_of_reviewers, $number_of_submitters\n", $number_of_commits / $Days; +} + +#------------------------------------------------------------------------------- +#------------------------------------------------------------------------------- +sub check_versions { + `git cat-file -e $old_version^{commit} 2>/dev/null`; + if (${^CHILD_ERROR_NATIVE}){ + print "Error: Old version ($old_version) does not exist.\n"; + exit 1; + } + + `git cat-file -e $new_version^{commit} 2>/dev/null`; + if (${^CHILD_ERROR_NATIVE}){ + print "Error: New version ($new_version) does not exist.\n"; + exit 1; + } +} + +#------------------------------------------------------------------------------- +#------------------------------------------------------------------------------- +sub get_user { + my $url=`git config -l | grep remote.origin.url`; + + if ($url =~ /.*url=ssh://(\w+@[a-zA-Z][a-zA-Z0-9.]+:\d+)/) + { + $URL_WITH_USER = $1; + } else { + print "Error: Could not get a ssh url with a username from gitconfig.\n"; + print " use the -u option to set a url.\n"; + exit 1; + } +} + +#------------------------------------------------------------------------------- +#------------------------------------------------------------------------------- +sub get_commits { + my @commits = @_; + my $submit_time = ""; + if (defined $SKIP_GERRIT_CHECK) { + return; + } + my $ssh = Net::OpenSSH->new("$URL_WITH_USER", ); + $ssh->error and die "Couldn't establish SSH connection to $URL_WITH_USER:". $ssh->error; + + print "Using URL: ssh://$URL_WITH_USER\n"; + + if (! -d $infodir) { + mkpath($infodir) + } + + for my $commit_id (@commits) { + $commit_id =~ s/^\s+|\s+$//g; + $submit_time = ""; + my $gerrit_review; + + # Quit if we've reeached the last coreboot commit supporting these queries + if ($commit_id =~ /^7309709/) { + last; + } + + if (-f "$infodir/$commit_id") { + $gerrit_review = 1; + } else { + $gerrit_review = `git log $commit_id^..$commit_id | grep '\sReviewed-on:\s'`; + } + + if ($gerrit_review && $commit_id && (! -f "$infodir/$commit_id") ) { + print "Downloading $commit_id"; + my @info = $ssh->capture("gerrit query --format=JSON --comments --files --current-patch-set --all-approvals --submit-records --dependencies commit:$commit_id"); + $ssh->error and die "remote ls command failed: " . $ssh->error; + + my $commit_info = JSON::Util->decode($info[0]); + my $rowcount = $commit_info->{'rowCount'}; + if (defined $rowcount && ($rowcount eq "0")) { + print " - no gerrit commit for that id.\n"; + open( my $HANDLE, ">", "$infodir/$commit_id" ) or die "Error: could not open file '$infodir/$commit_id'\n"; + print $HANDLE "No gerrit commit"; + close $HANDLE; + next; + } + my $approvals = $commit_info->{'currentPatchSet'}{'approvals'}; + + for my $approval (@$approvals) { + if ($approval->{'type'} eq "SUBM") { + $submit_time = $approval->{'grantedOn'} + } + } + my $dt=""; + if ($submit_time) { + $dt = DateTime->from_epoch(epoch => $submit_time); + } else { + print " - no submit time for that id.\n"; + open( my $HANDLE, ">", "$infodir/$commit_id" ) or die "Error: could not open file '$infodir/$commit_id'\n"; + print $HANDLE "No submit time"; + close $HANDLE; + + next; + } + + open( my $HANDLE, ">", "$infodir/$commit_id" ) or die "Error: could not open file '$infodir/$commit_id'\n"; + print $HANDLE $info[0]; + close $HANDLE; + + $dt->set_time_zone( 'Europe/Paris' ); + print " - submit time: " . $dt->strftime('%Y/%m/%d %H:%M:%S') . "\n"; + } elsif ($commit_id && (! -f "$infodir/$commit_id")) { + print "No gerrit commit for $commit_id\n"; + open( my $HANDLE, ">", "$infodir/$commit_id" ) or die "Error: could not open file '$infodir/$commit_id'\n"; + print $HANDLE "No gerrit commit"; + close $HANDLE; + } + } + print "\n"; +} + +#------------------------------------------------------------------------------- +# check_arguments parse the command line arguments +#------------------------------------------------------------------------------- +sub check_arguments { + my $show_usage = 0; + GetOptions( + 'help|?' => sub { usage() }, + 'url|u=s' => $URL_WITH_USER, + 'skip|s' => $SKIP_GERRIT_CHECK, + ); + # strip ssh:// from url if passed in. + if (defined $URL_WITH_USER) { + $URL_WITH_USER =~ s|ssh://||; + } + if (@ARGV) { + ($old_version, $new_version) = @ARGV; + } else { + usage(); + } +} + +#------------------------------------------------------------------------------- +# usage - Print the arguments for the user +#------------------------------------------------------------------------------- +sub usage { + print "gerrit_stats <options> [Old version] [New version]\n"; + print "Old version should be a tag (4.1), a branch (origin/4.1), or a commit id\n"; + print "New version can be 'HEAD' a branch (origin/master) a tag (4.2), or a commit id\n"; + print " Options:\n"; + print " u | url [url] url with username.\n"; + print "Example: "$0 -u Gaumless@review.coreboot.org:29418 origin/4.1 4.2"\n"; + exit(0); +} + +1;
