Hello Felix Singer, build bot (Jenkins), Nico Huber, Furquan Shaikh, Tim Wawrzynczak, Paul Menzel, Subrata Banik, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/48003
Change subject: soc/intel/skl: correct OC pin skip value for disabled usb ports ......................................................................
Commit 056d552 introduced a bug where 0xFF gets set as OC pin value to supposedly skip programming an OC pin for a disabled USB port. While the value is correct for the other platforms, Skylake uses 0x08 for this purpose. Correct this by using the enum value OC_SKIP (0x08) instead.
Change-Id: I41a8df3dce3712b4ab27c4e6e10160b2207406d1 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/skylake/chip.c 1 file changed, 6 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/48003/3
