Dave Frodin (dave.frodin@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5963
commit af9cf7f4511f202a8ac753b52e0962948b0a7b8e Author: Dave Frodin dave.frodin@se-eng.com Date: Mon Jun 9 12:33:24 2014 -0600
superio/nuvoton: Adds a function to route pins 41-48 to UARTD
Pins 41-48 default to being GPIs. This switches the internal mux to connect them to UARTD.
Change-Id: I61393b8c35cbc664f6520f60eed09ba4bbede0dc Signed-off-by: Dave Frodin dave.frodin@se-eng.com --- src/superio/nuvoton/Makefile.inc | 1 + src/superio/nuvoton/nct5104d/early_serial.c | 77 +++++++++++++++++++++++++++++ src/superio/nuvoton/nct5104d/nct5104d.h | 8 +-- 3 files changed, 83 insertions(+), 3 deletions(-)
diff --git a/src/superio/nuvoton/Makefile.inc b/src/superio/nuvoton/Makefile.inc index 1ce6963..6fd1266 100644 --- a/src/superio/nuvoton/Makefile.inc +++ b/src/superio/nuvoton/Makefile.inc @@ -19,6 +19,7 @@
## include generic nuvoton pre-ram stage driver romstage-$(CONFIG_SUPERIO_NUVOTON_COMMON_ROMSTAGE) += common/early_serial.c +romstage-$(CONFIG_SUPERIO_NUVOTON_NCT5104D) += nct5104d/early_serial.c
subdirs-$(CONFIG_SUPERIO_NUVOTON_WPCM450) += wpcm450 subdirs-$(CONFIG_SUPERIO_NUVOTON_NCT5104D) += nct5104d diff --git a/src/superio/nuvoton/nct5104d/early_serial.c b/src/superio/nuvoton/nct5104d/early_serial.c new file mode 100644 index 0000000..2d63268 --- /dev/null +++ b/src/superio/nuvoton/nct5104d/early_serial.c @@ -0,0 +1,77 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2011 Advanced Micro Devices, Inc. + * Copyright (C) 2014 Edward O'Callaghan eocallaghan@alterapraxis.com + * Copyright (C) 2014 Felix Held felix-coreboot@felixheld.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* + * A generic romstage (pre-ram) driver for Nuvoton variant Super I/O chips. + * + * The following is derived directly from the vendor Nuvoton's data-sheets: + * + * To toggle between `configuration mode` and `normal operation mode` as to + * manipulate the various LDN's in Nuvoton Super I/O's we are required to + * pass magic numbers `passwords keys`. + * + * NUVOTON_ENTRY_KEY := enable configuration : 0x87 + * NUVOTON_EXIT_KEY := disable configuration : 0xAA + * + * To modify a LDN's configuration register, we use the index port to select + * the index of the LDN and then write to the data port to alter the + * parameters. A default index, data port pair is 0x4E, 0x4F respectively, a + * user modified pair is 0x2E, 0x2F respectively. + * + */ + +#include <arch/io.h> +#include <device/pnp.h> +#include <stdint.h> +#include "nct5104d.h" + +#define NUVOTON_ENTRY_KEY 0x87 +#define NUVOTON_EXIT_KEY 0xAA + +/* Enable configuration: pass entry key '0x87' into index port dev + * two times. */ +static void pnp_enter_conf_state(device_t dev) +{ + u16 port = dev >> 8; + outb(NUVOTON_ENTRY_KEY, port); + outb(NUVOTON_ENTRY_KEY, port); +} + +/* Disable configuration: pass exit key '0xAA' into index port dev. */ +static void pnp_exit_conf_state(device_t dev) +{ + u16 port = dev >> 8; + outb(NUVOTON_EXIT_KEY, port); +} + +/* Route UARTD to pins 41-48 */ +void nuvoton_enable_uartd(device_t dev) +{ + u8 tmp; + u16 port = dev >> 8; + pnp_enter_conf_state(dev); + outb(0x1c, port); + tmp = inb(port + 1); + tmp |= 0x04; + outb(tmp, port + 1); + pnp_exit_conf_state(dev); +} diff --git a/src/superio/nuvoton/nct5104d/nct5104d.h b/src/superio/nuvoton/nct5104d/nct5104d.h index b72dda0..f6a0387 100644 --- a/src/superio/nuvoton/nct5104d/nct5104d.h +++ b/src/superio/nuvoton/nct5104d/nct5104d.h @@ -19,8 +19,8 @@ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
-#ifndef SUPERIO_NUVOTON_NCT5104D_NCT5104D_H -#define SUPERIO_NUVOTON_NCT5104D_NCT5104D_H +#ifndef SUPERIO_NUVOTON_NCT5104D_H +#define SUPERIO_NUVOTON_NCT5104D_H
/* Logical Device Numbers (LDN). */ #define NCT5104D_FDC 0x00 /* FDC - not pinned out */ @@ -42,4 +42,6 @@ #define NCT5104D_GPIO1 ((1 << 8) | NCT5104D_GPIO_V) #define NCT5104D_GPIO6 ((6 << 8) | NCT5104D_GPIO_V)
-#endif /* SUPERIO_NUVOTON_NCT5104D_NCT5104D_H */ +void nuvoton_enable_uartd(device_t dev); + +#endif /* SUPERIO_NUVOTON_NCT5104D_H */
