Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/21495
Change subject: amd/stoneyridge: Remove multi-node support ......................................................................
The Stoney Ridge APU can never be used in a multi-node system. Reduce the feature set to a single node.
Remove the static variables for each D18Fn device and replace the routines with coreboot config read and write functions.
Strip down domain_set_resources() to consider only a single node. A follow-on patch will further simplify this.
Change-Id: I1982b3fbf8dbb44ca75112c57afa59a2b4e4cf5a --- M src/soc/amd/stoneyridge/northbridge.c 1 file changed, 36 insertions(+), 88 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/21495/1
diff --git a/src/soc/amd/stoneyridge/northbridge.c b/src/soc/amd/stoneyridge/northbridge.c index 8e3c13c..2ed3156 100644 --- a/src/soc/amd/stoneyridge/northbridge.c +++ b/src/soc/amd/stoneyridge/northbridge.c @@ -31,6 +31,7 @@ #include <agesawrapper.h> #include <agesawrapper_call.h> #include <soc/northbridge.h> +#include <soc/pci_devs.h> #include <stdint.h> #include <stdlib.h> #include <string.h> @@ -46,8 +47,6 @@ #include <Porting.h> #include <Topology.h>
-#define MAX_NODE_NUMS (MAX_NODES * MAX_DIES) - #if IS_ENABLED(CONFIG_EXT_CONF_SUPPORT) #error CONFIG_EXT_CONF_SUPPORT == 1 not support anymore! #endif @@ -57,33 +56,26 @@ u32 mask; /* [47:27] at [28:8] and enable at bit 0 */ } dram_base_mask_t;
-static unsigned int node_nums; -static device_t __f0_dev; -static device_t __f1_dev; -static device_t __f2_dev; -static device_t __f4_dev; -static unsigned int fx_dev = 0; - -static dram_base_mask_t get_dram_base_mask(u32 nodeid) +static dram_base_mask_t get_dram_base_mask(void) { - device_t dev = __f1_dev; + device_t dev = dev_find_slot(0, ADDR_DEVFN); dram_base_mask_t d; u32 temp;
/* [39:24] at [31:16] */ - temp = pci_read_config32(dev, 0x44 + (nodeid << 3)); + temp = pci_read_config32(dev, 0x44);
/* mask out DramMask [26:24] too */ d.mask = ((temp & 0xfff80000) >> (8 + 3));
/* [47:40] at [7:0] */ - temp = pci_read_config32(dev, 0x144 + (nodeid << 3)) & 0xff; + temp = pci_read_config32(dev, 0x144) & 0xff; d.mask |= temp << 21;
- temp = pci_read_config32(dev, 0x40 + (nodeid << 3)); + temp = pci_read_config32(dev, 0x40); d.mask |= (temp & 1); /* enable bit */ d.base = ((temp & 0xfff80000) >> (8 + 3)); - temp = pci_read_config32(dev, 0x140 + (nodeid << 3)) & 0xff; + temp = pci_read_config32(dev, 0x140) & 0xff; d.base |= temp << 21; return d; } @@ -92,54 +84,27 @@ u32 io_min, u32 io_max) { u32 tempreg; + device_t addr_map = dev_find_slot(0, ADDR_DEVFN); + /* io range allocation. Limit */ tempreg = (nodeid & 0xf) | ((nodeid & 0x30) << (8 - 4)) | (linkn << 4) | ((io_max & 0xf0) << (12 - 4)); - pci_write_config32(__f1_dev, reg + 4, tempreg); + pci_write_config32(addr_map, reg + 4, tempreg); tempreg = 3 | ((io_min & 0xf0) << (12 - 4)); /* base: ISA and VGA ? */ - pci_write_config32(__f1_dev, reg, tempreg); + pci_write_config32(addr_map, reg, tempreg); }
static void set_mmio_addr_reg(u32 nodeid, u32 linkn, u32 reg, u32 index, u32 mmio_min, u32 mmio_max) { u32 tempreg; + device_t addr_map = dev_find_slot(0, ADDR_DEVFN); + /* io range allocation. Limit */ tempreg = (nodeid & 0xf) | (linkn << 4) | (mmio_max & 0xffffff00); - pci_write_config32(__f1_dev, reg + 4, tempreg); + pci_write_config32(addr_map, reg + 4, tempreg); tempreg = 3 | (nodeid & 0x30) | (mmio_min & 0xffffff00); - pci_write_config32(__f1_dev, reg, tempreg); -} - -static device_t get_node_pci(u32 fn) -{ - return dev_find_slot(CONFIG_CBB, PCI_DEVFN(CONFIG_CDB, fn)); -} - -static void get_fx_dev(void) -{ - __f0_dev = get_node_pci(0); - __f1_dev = get_node_pci(1); - __f2_dev = get_node_pci(2); - __f4_dev = get_node_pci(4); - fx_dev = 1; - - if (__f1_dev == NULL || __f0_dev == NULL || fx_dev == 0) - die("Cannot find 0:0x18.[0|1]\n"); -} - -static u32 f1_read_config32(unsigned int reg) -{ - if (fx_dev == 0) - get_fx_dev(); - return pci_read_config32(__f1_dev, reg); -} - -static void f1_write_config32(unsigned int reg, u32 value) -{ - if (fx_dev == 0) - get_fx_dev(); - pci_write_config32(__f1_dev, reg, value); + pci_write_config32(addr_map, reg, tempreg); }
static void read_resources(device_t dev) @@ -216,7 +181,8 @@ return;
printk(BIOS_DEBUG, "VGA: %s has VGA device\n", dev_path(dev)); - f1_write_config32(0xf4, 1); /* Route A0000-BFFFF, IO 3B0-3BB 3C0-3DF */ + /* Route A0000-BFFFF, IO 3B0-3BB 3C0-3DF */ + pci_write_config32(dev_find_slot(0, ADDR_DEVFN), 0xf4, 1); }
static void set_resources(device_t dev) @@ -403,24 +369,23 @@ void domain_read_resources(device_t dev) { unsigned int reg; + device_t addr_map = dev_find_slot(0, ADDR_DEVFN);
/* Find the already assigned resource pairs */ - get_fx_dev(); for (reg = 0x80 ; reg <= 0xd8 ; reg += 0x08) { u32 base, limit; - base = f1_read_config32(reg); - limit = f1_read_config32(reg + 0x04); + base = pci_read_config32(addr_map, reg); + limit = pci_read_config32(addr_map, reg + 4); /* Is this register allocated? */ if ((base & 3) != 0) { unsigned int nodeid, reg_link; - device_t reg_dev; + device_t reg_dev = dev_find_slot(0, HT_DEVFN); if (reg < 0xc0) /* mmio */ nodeid = (limit & 0xf) + (base & 0x30); else /* io */ nodeid = (limit & 0xf) + ((base >> 4) & 0x30);
reg_link = (limit >> 4) & 7; - reg_dev = __f0_dev; if (reg_dev) { /* Reserve the resource */ struct resource *res; @@ -463,8 +428,8 @@ mem_hole.node_id = -1; dram_base_mask_t d; u32 hole; - d = get_dram_base_mask(0); - hole = pci_read_config32(__f1_dev, 0xf0); + d = get_dram_base_mask(); + hole = pci_read_config32(dev_find_slot(0, ADDR_DEVFN), 0xf0); if (hole & 2) { /* We found the hole */ mem_hole.hole_startk = (hole & (0xff << 24)) >> 10; @@ -479,7 +444,7 @@ { unsigned long mmio_basek; u32 pci_tolm; - int i, idx; + int idx; struct bus *link; #if CONFIG_HW_MEM_HOLE_SIZEK != 0 struct hw_mem_hole_info mem_hole; @@ -517,14 +482,12 @@ #endif
idx = 0x10; - for (i = 0 ; i < node_nums ; i++) { - dram_base_mask_t d; - resource_t basek, limitk, sizek; /* 4 1T */ + dram_base_mask_t d; + resource_t basek, limitk, sizek; /* 4 1T */
- d = get_dram_base_mask(i); + d = get_dram_base_mask();
- if (!(d.mask & 1)) - continue; + if ((d.mask & 1)) { /* if enabled... */ /* could overflow, we may lose 6 bit here */ basek = ((resource_t)(d.base & 0x1fffff00)) << 9; limitk = ((resource_t)(((d.mask & ~1) + 0x000ff) @@ -535,7 +498,7 @@ /* see if we need a hole from 0xa0000 to 0xbffff */ if ((basek < ((8 * 64) + (8 * 16))) && (sizek > ((8 * 64) + (16 * 16)))) { - ram_resource(dev, (idx | i), basek, + ram_resource(dev, idx, basek, ((8 * 64) + (8 * 16)) - basek); idx += 0x10; basek = (8 * 64) + (16 * 16); @@ -549,7 +512,7 @@ unsigned int pre_sizek; pre_sizek = mmio_basek - basek; if (pre_sizek > 0) { - ram_resource(dev, (idx | i), basek, + ram_resource(dev, idx, basek, pre_sizek); idx += 0x10; sizek -= pre_sizek; @@ -565,11 +528,9 @@ } }
- ram_resource(dev, (idx | i), basek, sizek); - idx += 0x10; - printk(BIOS_DEBUG, "node %d: mmio_basek=%08lx, basek=%08llx," - " limitk=%08llx\n", i, mmio_basek, basek, - limitk); + ram_resource(dev, idx, basek, sizek); + printk(BIOS_DEBUG, "node 0: mmio_basek=%08lx, basek=%08llx," + " limitk=%08llx\n", mmio_basek, basek, limitk); }
add_uma_resource_below_tolm(dev, 7); @@ -586,13 +547,6 @@ */ mmio_resource(dev, 0xa0000, 0xa0000 / KiB, 0x20000 / KiB); reserved_ram_resource(dev, 0xc0000, 0xc0000 / KiB, 0x40000 / KiB); -} - -/* first node */ -static void sysconf_init(device_t dev) -{ - /* NodeCnt[2:0] */ - node_nums = ((pci_read_config32(dev, 0x60) >> 4) & 7) + 1; }
void cpu_bus_scan(device_t dev) @@ -618,11 +572,6 @@ CONFIG_CDB); die(""); } - sysconf_init(dev_mc); /* sets global node_nums */ - - if (node_nums != 1) - die("node_nums != 1. This is an SOC." - " Something is terribly wrong.");
/* Get max and actual number of cores */ pccount = cpuid_ecx(AMD_CPUID_ASIZE_PCCOUNT); @@ -665,13 +614,12 @@
for (j = 0 ; j <= siblings ; j++) { apic_id = lapicid_start + j; - printk(BIOS_SPEW, "lapicid_start 0x%x, node 0x%x, core 0x%x," - " apicid=0x%x\n", lapicid_start, node_nums, - j, apic_id); + printk(BIOS_SPEW, "lapicid_start 0x%x, core 0x%x," + " apicid=0x%x\n", lapicid_start, j, apic_id);
cpu = add_cpu_device(cpu_bus, apic_id, enable_node); if (cpu) - amd_cpu_topology(cpu, node_nums, j); + amd_cpu_topology(cpu, 1, j); } }
