Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18265
commit 4d6a746bff9c83d991cbac957c3d206752c27d57 Author: Patrick Georgi pgeorgi@chromium.org Date: Sat Jan 28 15:59:25 2017 +0100
ddr3 spd: move accessor code into lib/spd_bin.c
It's an attempt to consolidate the access code, even if there are still multiple implementations in the code.
Change-Id: I4b2b9cbc24a445f8fa4e0148f52fd15950535240 Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- src/device/Kconfig | 4 -- src/device/dram/Makefile.inc | 2 +- src/device/dram/spd_cache.c | 70 ----------------------------- src/include/spd_bin.h | 3 ++ src/include/spd_cache.h | 26 ----------- src/lib/Makefile.inc | 2 +- src/lib/spd_bin.c | 49 ++++++++++++++++++++ src/mainboard/amd/db-ft3b-lc/Kconfig | 1 - src/mainboard/bap/ode_e20XX/BiosCallOuts.c | 2 +- src/mainboard/bap/ode_e20XX/Kconfig | 1 - src/mainboard/bap/ode_e21XX/BiosCallOuts.c | 2 +- src/mainboard/bap/ode_e21XX/Kconfig | 1 - src/mainboard/gizmosphere/gizmo/Kconfig | 1 - src/mainboard/gizmosphere/gizmo2/Kconfig | 1 - src/mainboard/pcengines/apu1/BiosCallOuts.c | 2 +- src/mainboard/pcengines/apu1/Kconfig | 1 - src/mainboard/pcengines/apu2/BiosCallOuts.c | 2 +- src/mainboard/pcengines/apu2/Kconfig | 1 - src/northbridge/amd/agesa/def_callouts.c | 2 +- src/northbridge/amd/pi/def_callouts.c | 2 +- 20 files changed, 60 insertions(+), 115 deletions(-)
diff --git a/src/device/Kconfig b/src/device/Kconfig index d1f5694..4036a3d 100644 --- a/src/device/Kconfig +++ b/src/device/Kconfig @@ -210,10 +210,6 @@ config SMBUS_HAS_AUX_CHANNELS bool default n
-config SPD_CACHE - bool - default n - config PCI bool default n diff --git a/src/device/dram/Makefile.inc b/src/device/dram/Makefile.inc index 05f440b..b1a6755 100644 --- a/src/device/dram/Makefile.inc +++ b/src/device/dram/Makefile.inc @@ -1 +1 @@ -romstage-$(CONFIG_SPD_CACHE) += spd_cache.c ddr3.c +romstage-y += ddr3.c diff --git a/src/device/dram/spd_cache.c b/src/device/dram/spd_cache.c deleted file mode 100644 index 69cfc24..0000000 --- a/src/device/dram/spd_cache.c +++ /dev/null @@ -1,70 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2013 Advanced Micro Devices, Inc. - * Copyright (C) 2013 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <cbfs.h> -#include <console/console.h> -#include <device/dram/ddr3.h> -#include <spd_cache.h> -#include <stdint.h> -#include <string.h> - -int read_ddr3_spd_from_cbfs(u8 *buf, int idx) -{ - const int SPD_CRC_HI = 127; - const int SPD_CRC_LO = 126; - - const char *spd_file; - size_t spd_file_len = 0; - size_t min_len = (idx + 1) * CONFIG_DIMM_SPD_SIZE; - - if (CONFIG_DIMM_SPD_SIZE != 128) { - printk(BIOS_EMERG, - "SPD size configured to 0x%x (!= 128) bytes\n", - CONFIG_DIMM_SPD_SIZE); - return -1; - } - - spd_file = cbfs_boot_map_with_leak("spd.bin", CBFS_TYPE_SPD, - &spd_file_len); - if (!spd_file) - printk(BIOS_EMERG, "file [spd.bin] not found in CBFS"); - if (spd_file_len < min_len) - printk(BIOS_EMERG, "Missing SPD data."); - if (!spd_file || spd_file_len < min_len) - return -1; - - memcpy(buf, spd_file + (idx * CONFIG_DIMM_SPD_SIZE), CONFIG_DIMM_SPD_SIZE); - - u16 crc = spd_ddr3_calc_crc(buf, CONFIG_DIMM_SPD_SIZE); - - if (((buf[SPD_CRC_LO] == 0) && (buf[SPD_CRC_HI] == 0)) - || (buf[SPD_CRC_LO] != (crc & 0xff)) - || (buf[SPD_CRC_HI] != (crc >> 8))) { - printk(BIOS_WARNING, "SPD CRC %02x%02x is invalid, should be %04x\n", - buf[SPD_CRC_HI], buf[SPD_CRC_LO], crc); - buf[SPD_CRC_LO] = crc & 0xff; - buf[SPD_CRC_HI] = crc >> 8; - u16 i; - printk(BIOS_WARNING, "\nDisplay the SPD"); - for (i = 0; i < CONFIG_DIMM_SPD_SIZE; i++) { - if((i % 16) == 0x00) - printk(BIOS_WARNING, "\n%02x: ", i); - printk(BIOS_WARNING, "%02x ", buf[i]); - } - printk(BIOS_WARNING, "\n"); - } - return 0; -} diff --git a/src/include/spd_bin.h b/src/include/spd_bin.h index a0c1bbd..60be868 100644 --- a/src/include/spd_bin.h +++ b/src/include/spd_bin.h @@ -54,4 +54,7 @@ int get_spd_cbfs_rdev(struct region_device *spd_rdev, u8 spd_index); void dump_spd_info(struct spd_block *blk); void get_spd_smbus(struct spd_block *blk);
+/* expects SPD size to be 128 bytes, reads from "spd.bin" in CBFS and + verifies the checksum. */ +int read_ddr3_spd_from_cbfs(u8 *buf, int idx); #endif diff --git a/src/include/spd_cache.h b/src/include/spd_cache.h deleted file mode 100644 index 912aa64..0000000 --- a/src/include/spd_cache.h +++ /dev/null @@ -1,26 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef _SPD_CACHE_H_ -#define _SPD_CACHE_H_ - -#include <stdint.h> - -#if IS_ENABLED(CONFIG_SPD_CACHE) -int read_ddr3_spd_from_cbfs(u8 *buf, int idx); -#else -static inline int read_ddr3_spd_from_cbfs(u8 *buf, int idx) { return -1; } -#endif - -#endif diff --git a/src/lib/Makefile.inc b/src/lib/Makefile.inc index 9a9ddc8..37aa706 100644 --- a/src/lib/Makefile.inc +++ b/src/lib/Makefile.inc @@ -287,7 +287,7 @@ ramstage-$(CONFIG_HAVE_MONOTONIC_TIMER) += hw-time-timer.adb
endif # CONFIG_RAMSTAGE_LIBHWBASE
-romstage-$(CONFIG_GENERIC_SPD_BIN) += spd_bin.c +romstage-y += spd_bin.c
LIB_SPD_BIN = $(obj)/spd.bin
diff --git a/src/lib/spd_bin.c b/src/lib/spd_bin.c index 4108839..1d6c5ae 100644 --- a/src/lib/spd_bin.c +++ b/src/lib/spd_bin.c @@ -19,6 +19,7 @@ #include <spd_bin.h> #include <string.h> #include <device/early_smbus.h> +#include <device/dram/ddr3.h>
static u8 spd_data[CONFIG_DIMM_MAX * CONFIG_DIMM_SPD_SIZE] CAR_GLOBAL;
@@ -164,3 +165,51 @@ void get_spd_smbus(struct spd_block *blk)
update_spd_len(blk); } + +int read_ddr3_spd_from_cbfs(u8 *buf, int idx) +{ + const int SPD_CRC_HI = 127; + const int SPD_CRC_LO = 126; + + const char *spd_file; + size_t spd_file_len = 0; + size_t min_len = (idx + 1) * CONFIG_DIMM_SPD_SIZE; + + if (CONFIG_DIMM_SPD_SIZE != 128) { + printk(BIOS_EMERG, + "SPD size configured to 0x%x (!= 128) bytes\n", + CONFIG_DIMM_SPD_SIZE); + return -1; + } + + spd_file = cbfs_boot_map_with_leak("spd.bin", CBFS_TYPE_SPD, + &spd_file_len); + if (!spd_file) + printk(BIOS_EMERG, "file [spd.bin] not found in CBFS"); + if (spd_file_len < min_len) + printk(BIOS_EMERG, "Missing SPD data."); + if (!spd_file || spd_file_len < min_len) + return -1; + + memcpy(buf, spd_file + (idx * CONFIG_DIMM_SPD_SIZE), CONFIG_DIMM_SPD_SIZE); + + u16 crc = spd_ddr3_calc_crc(buf, CONFIG_DIMM_SPD_SIZE); + + if (((buf[SPD_CRC_LO] == 0) && (buf[SPD_CRC_HI] == 0)) + || (buf[SPD_CRC_LO] != (crc & 0xff)) + || (buf[SPD_CRC_HI] != (crc >> 8))) { + printk(BIOS_WARNING, "SPD CRC %02x%02x is invalid, should be %04x\n", + buf[SPD_CRC_HI], buf[SPD_CRC_LO], crc); + buf[SPD_CRC_LO] = crc & 0xff; + buf[SPD_CRC_HI] = crc >> 8; + u16 i; + printk(BIOS_WARNING, "\nDisplay the SPD"); + for (i = 0; i < CONFIG_DIMM_SPD_SIZE; i++) { + if((i % 16) == 0x00) + printk(BIOS_WARNING, "\n%02x: ", i); + printk(BIOS_WARNING, "%02x ", buf[i]); + } + printk(BIOS_WARNING, "\n"); + } + return 0; +} diff --git a/src/mainboard/amd/db-ft3b-lc/Kconfig b/src/mainboard/amd/db-ft3b-lc/Kconfig index 7bf3c86..3999039 100644 --- a/src/mainboard/amd/db-ft3b-lc/Kconfig +++ b/src/mainboard/amd/db-ft3b-lc/Kconfig @@ -27,7 +27,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_ACPI_TABLES select BOARD_ROMSIZE_KB_8192 select GFXUMA - select SPD_CACHE
config MAINBOARD_DIR string diff --git a/src/mainboard/bap/ode_e20XX/BiosCallOuts.c b/src/mainboard/bap/ode_e20XX/BiosCallOuts.c index 2ceb5c8..e6773b8 100644 --- a/src/mainboard/bap/ode_e20XX/BiosCallOuts.c +++ b/src/mainboard/bap/ode_e20XX/BiosCallOuts.c @@ -24,7 +24,7 @@ #include "imc.h" #endif #include <stdlib.h> -#include <spd_cache.h> +#include <spd_bin.h>
static AGESA_STATUS Fch_Oem_config(UINT32 Func, UINTN FchData, VOID *ConfigPtr); static AGESA_STATUS board_ReadSpd_from_cbfs(UINT32 Func, UINTN Data, VOID *ConfigPtr); diff --git a/src/mainboard/bap/ode_e20XX/Kconfig b/src/mainboard/bap/ode_e20XX/Kconfig index ee26772..6631ac8 100644 --- a/src/mainboard/bap/ode_e20XX/Kconfig +++ b/src/mainboard/bap/ode_e20XX/Kconfig @@ -28,7 +28,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select BOARD_ROMSIZE_KB_4096 select GFXUMA select SUPERIO_FINTEK_F81866D - select SPD_CACHE
config MAINBOARD_DIR string diff --git a/src/mainboard/bap/ode_e21XX/BiosCallOuts.c b/src/mainboard/bap/ode_e21XX/BiosCallOuts.c index 10ec422..9b241fc 100644 --- a/src/mainboard/bap/ode_e21XX/BiosCallOuts.c +++ b/src/mainboard/bap/ode_e21XX/BiosCallOuts.c @@ -25,7 +25,7 @@ #endif #include "hudson.h" #include <stdlib.h> -#include <spd_cache.h> +#include <spd_bin.h>
static AGESA_STATUS Fch_Oem_config(UINT32 Func, UINT32 FchData, VOID *ConfigPtr); static AGESA_STATUS board_ReadSpd_from_cbfs(UINT32 Func, UINTN Data, VOID *ConfigPtr); diff --git a/src/mainboard/bap/ode_e21XX/Kconfig b/src/mainboard/bap/ode_e21XX/Kconfig index 60a59ac..c8472c4 100644 --- a/src/mainboard/bap/ode_e21XX/Kconfig +++ b/src/mainboard/bap/ode_e21XX/Kconfig @@ -27,7 +27,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select BOARD_ROMSIZE_KB_8192 select GFXUMA select SUPERIO_FINTEK_F81866D - select SPD_CACHE
config MAINBOARD_DIR string diff --git a/src/mainboard/gizmosphere/gizmo/Kconfig b/src/mainboard/gizmosphere/gizmo/Kconfig index 8109019..4177b1d 100644 --- a/src/mainboard/gizmosphere/gizmo/Kconfig +++ b/src/mainboard/gizmosphere/gizmo/Kconfig @@ -28,7 +28,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_ACPI_TABLES select BOARD_ROMSIZE_KB_2048 select GFXUMA - select SPD_CACHE
config MAINBOARD_DIR string diff --git a/src/mainboard/gizmosphere/gizmo2/Kconfig b/src/mainboard/gizmosphere/gizmo2/Kconfig index 349f827..f5509f6 100644 --- a/src/mainboard/gizmosphere/gizmo2/Kconfig +++ b/src/mainboard/gizmosphere/gizmo2/Kconfig @@ -27,7 +27,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_ACPI_TABLES select BOARD_ROMSIZE_KB_4096 select GFXUMA - select SPD_CACHE
config MAINBOARD_DIR string diff --git a/src/mainboard/pcengines/apu1/BiosCallOuts.c b/src/mainboard/pcengines/apu1/BiosCallOuts.c index f35cbd2..7604277 100644 --- a/src/mainboard/pcengines/apu1/BiosCallOuts.c +++ b/src/mainboard/pcengines/apu1/BiosCallOuts.c @@ -15,7 +15,7 @@
#include "AGESA.h" #include "amdlib.h" -#include <spd_cache.h> +#include <spd_bin.h> #include <northbridge/amd/agesa/BiosCallOuts.h> #include "heapManager.h" #include "SB800.h" diff --git a/src/mainboard/pcengines/apu1/Kconfig b/src/mainboard/pcengines/apu1/Kconfig index f882b78..5e927cc 100644 --- a/src/mainboard/pcengines/apu1/Kconfig +++ b/src/mainboard/pcengines/apu1/Kconfig @@ -29,7 +29,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_OPTION_TABLE select HAVE_CMOS_DEFAULT select BOARD_ROMSIZE_KB_2048 - select SPD_CACHE
config MAINBOARD_DIR string diff --git a/src/mainboard/pcengines/apu2/BiosCallOuts.c b/src/mainboard/pcengines/apu2/BiosCallOuts.c index 221b315..ab9d521 100644 --- a/src/mainboard/pcengines/apu2/BiosCallOuts.c +++ b/src/mainboard/pcengines/apu2/BiosCallOuts.c @@ -15,7 +15,7 @@
#include "AGESA.h" #include "amdlib.h" -#include <spd_cache.h> +#include <spd_bin.h> #include <northbridge/amd/pi/BiosCallOuts.h> #include "Ids.h" #include "OptionsIds.h" diff --git a/src/mainboard/pcengines/apu2/Kconfig b/src/mainboard/pcengines/apu2/Kconfig index de42721..4303b84 100644 --- a/src/mainboard/pcengines/apu2/Kconfig +++ b/src/mainboard/pcengines/apu2/Kconfig @@ -26,7 +26,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select HAVE_MP_TABLE select HAVE_ACPI_TABLES select BOARD_ROMSIZE_KB_8192 - select SPD_CACHE select HUDSON_DISABLE_IMC select USE_BLOBS
diff --git a/src/northbridge/amd/agesa/def_callouts.c b/src/northbridge/amd/agesa/def_callouts.c index 953774a..0805c02 100644 --- a/src/northbridge/amd/agesa/def_callouts.c +++ b/src/northbridge/amd/agesa/def_callouts.c @@ -15,7 +15,7 @@ */
#include <cbfs.h> -#include <spd_cache.h> +#include <spd_bin.h>
#include "AGESA.h" #include "amdlib.h" diff --git a/src/northbridge/amd/pi/def_callouts.c b/src/northbridge/amd/pi/def_callouts.c index e38d807..6b8aaee 100644 --- a/src/northbridge/amd/pi/def_callouts.c +++ b/src/northbridge/amd/pi/def_callouts.c @@ -15,7 +15,7 @@ */
