Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/83614?usp=email )
Change subject: mb/google/nissa/var/riven: Add Fn key scancode ......................................................................
The Fn key on riven emits a scancode of 94 (0x5e).
BUG=b:345231373 TEST=Flash riven, boot to Linux kernel, and verify that KEY_FN is generated when pressed using `evtest`.
Change-Id: Iddedd08fc50e8e8e369ce3d73edf0f3077867e87 Signed-off-by: David Wu david_wu@quanta.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/83614 Reviewed-by: Subrata Banik subratabanik@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Paul Menzel paulepanter@mailbox.org Reviewed-by: Eric Lai ericllai@google.com --- M src/mainboard/google/brya/Kconfig 1 file changed, 1 insertion(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved Paul Menzel: Looks good to me, but someone else must approve Eric Lai: Looks good to me, approved
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index a5bae12..dfbd291 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -1,7 +1,7 @@ ## SPDX-License-Identifier: GPL-2.0-only
config ACPI_FNKEY_GEN_SCANCODE - default 94 if BOARD_GOOGLE_XOL + default 94 if (BOARD_GOOGLE_XOL || BOARD_GOOGLE_RIVEN)
config BOARD_GOOGLE_BRYA_COMMON def_bool n
