Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/68908 )
Change subject: mb/siemens/mc_ehl: Remove spd.bin from CBFS ......................................................................
The SPD data for DRAM init has moved into the hwinfo data structure and is therefore not used from spd.bin anymore. spd.bin will not receive any updates, changes will only be done in hwinfo. There is no reason to keep spd.bin around so remove it for both variants.
Change-Id: Ie6091b655ba7ff2e01b684266ce34b85593b8623 Signed-off-by: Werner Zeh werner.zeh@siemens.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/68908 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz --- M src/mainboard/siemens/mc_ehl/Kconfig M src/mainboard/siemens/mc_ehl/romstage_fsp_params.c M src/mainboard/siemens/mc_ehl/variants/mc_ehl1/Makefile.inc D src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/empty.spd.hex D src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/mc_ehl1.spd.hex D src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/spd.h M src/mainboard/siemens/mc_ehl/variants/mc_ehl2/Makefile.inc D src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/empty.spd.hex D src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/mc_ehl2.spd.hex D src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/spd.h 10 files changed, 19 insertions(+), 172 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/mainboard/siemens/mc_ehl/Kconfig b/src/mainboard/siemens/mc_ehl/Kconfig index 3236464..d3fb8d6 100644 --- a/src/mainboard/siemens/mc_ehl/Kconfig +++ b/src/mainboard/siemens/mc_ehl/Kconfig @@ -3,7 +3,6 @@ select SOC_INTEL_ELKHARTLAKE select BOARD_ROMSIZE_KB_16384 select DRIVERS_I2C_GENERIC - select HAVE_SPD_IN_CBFS select HAVE_ACPI_TABLES select DRIVER_SIEMENS_NC_FPGA select NC_FPGA_NOTIFY_CB_READY diff --git a/src/mainboard/siemens/mc_ehl/romstage_fsp_params.c b/src/mainboard/siemens/mc_ehl/romstage_fsp_params.c index 21b33bd..7befa4a 100644 --- a/src/mainboard/siemens/mc_ehl/romstage_fsp_params.c +++ b/src/mainboard/siemens/mc_ehl/romstage_fsp_params.c @@ -27,9 +27,7 @@ spd_info.spd_spec.spd_data_ptr_info.spd_data_len = CONFIG_DIMM_SPD_SIZE; spd_info.read_type = READ_SPD_MEMPTR; } else { - printk(BIOS_WARNING, "SPD in HW-Info not valid, fall back to spd.bin!\n"); - spd_info.read_type = READ_SPD_CBFS; - spd_info.spd_spec.spd_index = 0x00; + die("SPD in HW-Info not valid!\n"); } /* Initialize variant specific configurations */ memcfg_init(&memupd->FspmConfig, board_cfg, &spd_info, false); diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/Makefile.inc b/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/Makefile.inc index 3036363..2b78a7a 100644 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/Makefile.inc +++ b/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/Makefile.inc @@ -5,7 +5,3 @@ ramstage-y += gpio.c
all-$(CONFIG_NC_FPGA_POST_CODE) += post.c - -SPD_SOURCES = mc_ehl1 # 0b000 -LIB_SPD_DEPS := $(foreach f, $(SPD_SOURCES), \ - src/mainboard/$(MAINBOARDDIR)/variants/$(VARIANT_DIR)/spd/$(f).spd.hex) diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/empty.spd.hex b/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/empty.spd.hex deleted file mode 100644 index 67b46cd..0000000 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/empty.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/mc_ehl1.spd.hex b/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/mc_ehl1.spd.hex deleted file mode 100644 index 71e5456..0000000 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/mc_ehl1.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 11 11 0E 15 21 90 08 00 40 00 00 02 22 00 00 -00 00 04 0F 92 54 05 00 87 00 90 A8 90 C0 08 60 -04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 E1 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 20 00 00 00 20 20 20 20 20 20 20 -20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/spd.h b/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/spd.h deleted file mode 100644 index f667e74..0000000 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl1/spd/spd.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -#ifndef MAINBOARD_SPD_H -#define MAINBOARD_SPD_H - -#include <stdint.h> - -#define RCOMP_TARGET_PARAMS 0x5 - -void mainboard_fill_dq_map_ch0(u8 *dq_map_ptr); -void mainboard_fill_dq_map_ch1(u8 *dq_map_ptr); -void mainboard_fill_dqs_map_ch0(u8 *dqs_map_ptr); -void mainboard_fill_dqs_map_ch1(u8 *dqs_map_ptr); -void mainboard_fill_rcomp_res_data(u16 *rcomp_ptr); -void mainboard_fill_rcomp_strength_data(u16 *rcomp_strength_ptr); -#endif diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/Makefile.inc b/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/Makefile.inc index 2903dd1..6e87f9f 100644 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/Makefile.inc +++ b/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/Makefile.inc @@ -4,7 +4,3 @@ romstage-y += memory.c ramstage-y += gpio.c ramstage-y += mainboard.c - -SPD_SOURCES = mc_ehl2 # 0b000 -LIB_SPD_DEPS := $(foreach f, $(SPD_SOURCES), \ - src/mainboard/$(MAINBOARDDIR)/variants/$(VARIANT_DIR)/spd/$(f).spd.hex) diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/empty.spd.hex b/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/empty.spd.hex deleted file mode 100644 index 67b46cd..0000000 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/empty.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/mc_ehl2.spd.hex b/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/mc_ehl2.spd.hex deleted file mode 100644 index eff68b3..0000000 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/mc_ehl2.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 11 11 0E 14 19 90 08 00 40 00 00 02 22 00 00 -00 00 04 0F 92 54 05 00 87 00 90 A8 90 10 04 E0 -01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 E1 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 20 00 00 00 20 20 20 20 20 20 20 -20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/spd.h b/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/spd.h deleted file mode 100644 index f667e74..0000000 --- a/src/mainboard/siemens/mc_ehl/variants/mc_ehl2/spd/spd.h +++ /dev/null @@ -1,16 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -#ifndef MAINBOARD_SPD_H -#define MAINBOARD_SPD_H - -#include <stdint.h> - -#define RCOMP_TARGET_PARAMS 0x5 - -void mainboard_fill_dq_map_ch0(u8 *dq_map_ptr); -void mainboard_fill_dq_map_ch1(u8 *dq_map_ptr); -void mainboard_fill_dqs_map_ch0(u8 *dqs_map_ptr); -void mainboard_fill_dqs_map_ch1(u8 *dqs_map_ptr); -void mainboard_fill_rcomp_res_data(u16 *rcomp_ptr); -void mainboard_fill_rcomp_strength_data(u16 *rcomp_strength_ptr); -#endif
