Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16511
commit 09546d389511350d1b33b3c6bd9230de8bbbe317 Author: Arthur Heymans arthur@aheymans.xyz Date: Mon Sep 5 22:46:11 2016 +0200
i945/gma.c: add native VGA init
This reuses the intel pineview native graphic initialization to have output on the VGA connector of i945 devices.
The behavior is the same as with the vbios blob. It uses the external VGA display if it is connected.
Change-Id: I7eaee87d16df2e5c9ebeaaff01d36ec1aa4ea495 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/northbridge/intel/i945/gma.c | 196 ++++++++++++++++++++++++++++++++++++++- 1 file changed, 194 insertions(+), 2 deletions(-)
diff --git a/src/northbridge/intel/i945/gma.c b/src/northbridge/intel/i945/gma.c index d1d68d4..37674d7 100644 --- a/src/northbridge/intel/i945/gma.c +++ b/src/northbridge/intel/i945/gma.c @@ -78,7 +78,7 @@ static int gtt_setup(void *mmiobase) return 0; }
-static int intel_gma_init(struct northbridge_intel_i945_config *conf, +static int intel_gma_init_lvds(struct northbridge_intel_i945_config *conf, unsigned int pphysbase, unsigned int piobase, void *pmmio, unsigned int pgfx) { @@ -382,6 +382,194 @@ static int intel_gma_init(struct northbridge_intel_i945_config *conf, #endif return 0; } + +static int intel_gma_init_vga(struct northbridge_intel_i945_config *conf, + unsigned int pphysbase, unsigned int piobase, + void *pmmio, unsigned int pgfx) +{ + int i; + u32 hactive, vactive; + u16 reg16; + u32 uma_size; + + printk(BIOS_SPEW, "pmmio %x addrport %x physbase %x\n", + (u32)pmmio, piobase, pphysbase); + + gtt_setup(pmmio); + + /* Disable VGA. */ + write32(pmmio + VGACNTRL, VGA_DISP_DISABLE); + + /* Disable pipes. */ + write32(pmmio + PIPECONF(0), 0); + write32(pmmio + PIPECONF(1), 0); + + write32(pmmio + INSTPM, 0x800); + + vga_gr_write(0x18, 0); + + write32(pmmio + VGA0, 0x200074); + write32(pmmio + VGA1, 0x200074); + + write32(pmmio + DSPFW3, 0x7f3f00c1 & ~PINEVIEW_SELF_REFRESH_EN); + write32(pmmio + DSPCLK_GATE_D, 0); + write32(pmmio + FW_BLC, 0x03060106); + write32(pmmio + FW_BLC2, 0x00000306); + + write32(pmmio + ADPA, ADPA_DAC_ENABLE + | ADPA_PIPE_A_SELECT + | ADPA_USE_VGA_HVPOLARITY + | ADPA_VSYNC_CNTL_ENABLE + | ADPA_HSYNC_CNTL_ENABLE + | ADPA_DPMS_ON + ); + + write32(pmmio + 0x7041c, 0x0); + + write32(pmmio + DPLL_MD(0), 0x3); + write32(pmmio + DPLL_MD(1), 0x3); + write32(pmmio + DSPCNTR(1), 0x1000000); + write32(pmmio + PIPESRC(1), 0x027f01df); + + vga_misc_write(0x67); + const u8 cr[] = { 0x5f, 0x4f, 0x50, 0x82, 0x55, 0x81, 0xbf, 0x1f, + 0x00, 0x4f, 0x0d, 0x0e, 0x00, 0x00, 0x00, 0x00, + 0x9c, 0x8e, 0x8f, 0x28, 0x1f, 0x96, 0xb9, 0xa3, + 0xff + }; + vga_cr_write(0x11, 0); + + for (i = 0; i <= 0x18; i++) + vga_cr_write(i, cr[i]); + + // Disable screen memory to prevent garbage from appearing. + vga_sr_write(1, vga_sr_read(1) | 0x20); + hactive = 640; + vactive = 400; + + mdelay(1); + write32(pmmio + DPLL(0), + DPLL_VCO_ENABLE | DPLLB_MODE_DAC_SERIAL + | DPLL_VGA_MODE_DIS + | DPLL_DAC_SERIAL_P2_CLOCK_DIV_10 + | 0x400601 + ); + mdelay(1); + write32(pmmio + DPLL(0), + DPLL_VCO_ENABLE | DPLLB_MODE_DAC_SERIAL + | DPLL_VGA_MODE_DIS + | DPLL_DAC_SERIAL_P2_CLOCK_DIV_10 + | 0x400601 + ); + + write32(pmmio + ADPA, ADPA_DAC_ENABLE + | ADPA_PIPE_A_SELECT + | ADPA_USE_VGA_HVPOLARITY + | ADPA_VSYNC_CNTL_ENABLE + | ADPA_HSYNC_CNTL_ENABLE + | ADPA_DPMS_ON + ); + + write32(pmmio + HTOTAL(0), + ((hactive - 1) << 16) + | (hactive - 1)); + write32(pmmio + HBLANK(0), + ((hactive - 1) << 16) + | (hactive - 1)); + write32(pmmio + HSYNC(0), + ((hactive - 1) << 16) + | (hactive - 1)); + + write32(pmmio + VTOTAL(0), ((vactive - 1) << 16) + | (vactive - 1)); + write32(pmmio + VBLANK(0), ((vactive - 1) << 16) + | (vactive - 1)); + write32(pmmio + VSYNC(0), + ((vactive - 1) << 16) + | (vactive - 1)); + + write32(pmmio + PF_WIN_POS(0), 0); + + write32(pmmio + PIPESRC(0), (639 << 16) | 399); + write32(pmmio + PF_CTL(0),PF_ENABLE | PF_FILTER_MED_3x3); + write32(pmmio + PF_WIN_SZ(0), vactive | (hactive << 16)); + write32(pmmio + PFIT_CONTROL, 0x0); + + mdelay(1); + + write32(pmmio + FDI_RX_CTL(0), 0x00002040); + mdelay(1); + write32(pmmio + FDI_RX_CTL(0), 0x80002050); + write32(pmmio + FDI_TX_CTL(0), 0x00044000); + mdelay(1); + write32(pmmio + FDI_TX_CTL(0), 0x80044000); + write32(pmmio + PIPECONF(0), PIPECONF_ENABLE | PIPECONF_BPP_6 | PIPECONF_DITHER_EN); + + write32(pmmio + VGACNTRL, 0x0); + write32(pmmio + DSPCNTR(0), DISPLAY_PLANE_ENABLE | DISPPLANE_BGRX888); + mdelay(1); + + write32(pmmio + ADPA, ADPA_DAC_ENABLE + | ADPA_PIPE_A_SELECT + | ADPA_USE_VGA_HVPOLARITY + | ADPA_VSYNC_CNTL_ENABLE + | ADPA_HSYNC_CNTL_ENABLE + | ADPA_DPMS_ON + ); + + write32(pmmio + DSPFW3, 0x7f3f00c1); + write32(pmmio + MI_MODE, 0x200 | VS_TIMER_DISPATCH); + write32(pmmio + CACHE_MODE_0, (0x6820 | (1 << 9)) & ~(1 << 5)); + write32(pmmio + CACHE_MODE_1, 0x380 & ~(1 << 9)); + + /* Set up GTT. */ + + reg16 = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0, 0)), GGC); + uma_size = 0; + if (!(reg16 & 2)) { + uma_size = decode_igd_memory_size((reg16 >> 4) & 7); + printk(BIOS_DEBUG, "%dM UMA\n", uma_size >> 10); + } + + for (i = 0; i < (uma_size - 256) / 4; i++) + { + outl((i << 2) | 1, piobase); + outl(pphysbase + (i << 12) + 1, piobase + 4); + } + + /* Clear interrupts. */ + write32(pmmio + DEIIR, 0xffffffff); + write32(pmmio + SDEIIR, 0xffffffff); + write32(pmmio + IIR, 0xffffffff); + write32(pmmio + IMR, 0xffffffff); + write32(pmmio + EIR, 0xffffffff); + + vga_textmode_init(); + + /* Enable screen memory. */ + vga_sr_write(1, vga_sr_read(1) & ~0x20); + + return 0; + +} + +/* compare the header of the vga edid header */ +/* if vga is not connected it should have a correct header */ +static int vga_connected(u8 *pmmio) { + u8 vga_edid[128]; + u8 header[8] = {0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00}; + intel_gmbus_read_edid(pmmio + GMBUS0, 2, 0x50, vga_edid, 128); + intel_gmbus_stop(pmmio + GMBUS0); + for (int i = 0; i < 8; i++) { + if (vga_edid[i] != header[i]) { + printk(BIOS_DEBUG, "VGA not connected. Using LVDS display\n"); + return 0; + } + } + printk(BIOS_SPEW, "VGA display connected\n"); + return 1; +} + #endif
static void gma_func0_init(struct device *dev) @@ -423,7 +611,11 @@ static void gma_func0_init(struct device *dev) );
int err; - err = intel_gma_init(conf, pci_read_config32(dev, 0x5c) & ~0xf, + if (vga_connected(mmiobase)) + err = intel_gma_init_vga(conf, pci_read_config32(dev, 0x5c) & ~0xf, + iobase, mmiobase, graphics_base); + else + err = intel_gma_init_lvds(conf, pci_read_config32(dev, 0x5c) & ~0xf, iobase, mmiobase, graphics_base); if (err == 0) gfx_set_init_done(1);
