Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/81630?usp=email )
Change subject: drivers/intel/fsp2_0: Introduce fsp print helper macros ......................................................................
This patch introduces fsp print helper macros to print `efi_return_status_t' with the appropriate format. These macros are now used for fsp debug prints with return status
efi_return_status_t is defined as UINT64 or UNIT32 based on the selected architecture
BUG=b:329034258 TEST=Verified on Meteor Lake board (Rex)
Change-Id: If6342c4d40c76b702351070e424797c21138a4a9 Signed-off-by: Appukuttan V K appukuttan.vk@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/81630 Reviewed-by: Subrata Banik subratabanik@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/drivers/intel/fsp2_0/debug.c M src/drivers/intel/fsp2_0/include/fsp/debug.h M src/drivers/intel/fsp2_0/include/fsp/util.h M src/drivers/intel/fsp2_0/memory_init.c M src/drivers/intel/fsp2_0/silicon_init.c M src/drivers/intel/fsp2_0/util.c M src/include/efi/efi_datatype.h M src/soc/amd/common/fsp/fsp_reset.c M src/soc/intel/common/fsp_reset.c 9 files changed, 48 insertions(+), 36 deletions(-)
Approvals: build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved
diff --git a/src/drivers/intel/fsp2_0/debug.c b/src/drivers/intel/fsp2_0/debug.c index 4cd309e..9dc964d 100644 --- a/src/drivers/intel/fsp2_0/debug.c +++ b/src/drivers/intel/fsp2_0/debug.c @@ -85,10 +85,10 @@ printk(BIOS_SPEW, "\t%p: &hob_list_ptr\n", fsp_get_hob_list_ptr()); }
-void fsp_debug_after_memory_init(uint32_t status) +void fsp_debug_after_memory_init(efi_return_status_t status) { if (CONFIG(DISPLAY_FSP_CALLS_AND_STATUS)) - printk(BIOS_SPEW, "FspMemoryInit returned 0x%08x\n", status); + fsp_printk(status, BIOS_SPEW, "FspMemoryInit");
if (status != FSP_SUCCESS) return; @@ -130,13 +130,13 @@ printk(BIOS_SPEW, "\t%p: upd\n", fsps_new_upd); }
-void fsp_debug_after_silicon_init(uint32_t status) +void fsp_debug_after_silicon_init(efi_return_status_t status) { if (CONFIG(CHECK_GPIO_CONFIG_CHANGES)) fsp_gpio_config_check(AFTER_FSP_CALL, "FSP Silicon Init");
if (CONFIG(DISPLAY_FSP_CALLS_AND_STATUS)) - printk(BIOS_SPEW, "FspSiliconInit returned 0x%08x\n", status); + fsp_printk(status, BIOS_SPEW, "FspSiliconInit");
/* Display the HOBs */ if (CONFIG(DISPLAY_HOBS)) @@ -164,13 +164,13 @@ printk(BIOS_SPEW, "\t%p: notify_params\n", notify_params); }
-void fsp_debug_after_notify(uint32_t status) +void fsp_debug_after_notify(efi_return_status_t status) { if (CONFIG(CHECK_GPIO_CONFIG_CHANGES)) fsp_gpio_config_check(AFTER_FSP_CALL, "FSP Notify");
if (CONFIG(DISPLAY_FSP_CALLS_AND_STATUS)) - printk(BIOS_SPEW, "FspNotify returned 0x%08x\n", status); + fsp_printk(status, BIOS_SPEW, "FspNotify");
/* Display the HOBs */ if (CONFIG(DISPLAY_HOBS)) diff --git a/src/drivers/intel/fsp2_0/include/fsp/debug.h b/src/drivers/intel/fsp2_0/include/fsp/debug.h index dc5557e..e7f9f25 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/debug.h +++ b/src/drivers/intel/fsp2_0/include/fsp/debug.h @@ -19,14 +19,14 @@ void fsp_debug_before_memory_init(fsp_memory_init_fn memory_init, const FSPM_UPD *fspm_old_upd, const FSPM_UPD *fspm_new_upd); -void fsp_debug_after_memory_init(uint32_t status); +void fsp_debug_after_memory_init(efi_return_status_t status); void fsp_debug_before_silicon_init(fsp_silicon_init_fn silicon_init, const FSPS_UPD *fsps_old_upd, const FSPS_UPD *fsps_new_upd); -void fsp_debug_after_silicon_init(uint32_t status); +void fsp_debug_after_silicon_init(efi_return_status_t status); void fsp_before_debug_notify(fsp_notify_fn notify, const struct fsp_notify_params *notify_params); -void fsp_debug_after_notify(uint32_t status); +void fsp_debug_after_notify(efi_return_status_t status); void fspm_display_upd_values(const FSPM_UPD *old, const FSPM_UPD *new); void fsp_display_hobs(void); diff --git a/src/drivers/intel/fsp2_0/include/fsp/util.h b/src/drivers/intel/fsp2_0/include/fsp/util.h index bed4fcb..e89b7f8 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/util.h +++ b/src/drivers/intel/fsp2_0/include/fsp/util.h @@ -31,6 +31,17 @@ memcpy(dst, src, sizeof(src)); \ } while (0)
+/* Helper function to print a message concatenated with the a FSP return status. */ +#if CONFIG(PLATFORM_USES_FSP2_X86_32) +#define FSP_STATUS_FMT "0x%08x" +#else +#define FSP_STATUS_FMT "0x%016llx" +#endif +#define fsp_printk(status, msg_level, fmt, ...) \ + printk(msg_level, fmt ", status=" FSP_STATUS_FMT "\n", ##__VA_ARGS__, status) +#define fsp_die_with_post_code(status, postcode, fmt, ...) \ + die_with_post_code(postcode, fmt ", status=" FSP_STATUS_FMT "\n", ##__VA_ARGS__, status) + struct hob_header { uint16_t type; uint16_t length; @@ -187,10 +198,10 @@ * SoC. If the requested status is not a reboot status or unhandled, this * function does nothing. */ -void fsp_handle_reset(uint32_t status); +void fsp_handle_reset(efi_return_status_t status);
/* SoC/chipset must provide this to handle platform-specific reset codes */ -void chipset_handle_reset(uint32_t status); +void chipset_handle_reset(efi_return_status_t status);
#if CONFIG(PLATFORM_USES_SECOND_FSP) /* The SoC must implement these to choose the appropriate FSP-M/FSP-S binary. */ diff --git a/src/drivers/intel/fsp2_0/memory_init.c b/src/drivers/intel/fsp2_0/memory_init.c index dc725c3..31ae213 100644 --- a/src/drivers/intel/fsp2_0/memory_init.c +++ b/src/drivers/intel/fsp2_0/memory_init.c @@ -274,22 +274,22 @@ return ver; }
-static void fspm_return_value_handler(const char *context, uint32_t status, bool die_on_error) +static void fspm_return_value_handler(const char *context, efi_return_status_t status, + bool die_on_error) { if (status == FSP_SUCCESS) return;
fsp_handle_reset(status); if (die_on_error) - die_with_post_code(POSTCODE_RAM_FAILURE, "%s returned with error 0x%zx!\n", - context, (size_t)status); + fsp_die_with_post_code(status, POSTCODE_RAM_FAILURE, "%s error", context);
- printk(BIOS_SPEW, "%s returned 0x%zx\n", context, (size_t)status); + fsp_printk(status, BIOS_SPEW, "%s", context); }
static void fspm_multi_phase_init(const struct fsp_header *hdr) { - uint32_t status; + efi_return_status_t status; fsp_multi_phase_init_fn fsp_multi_phase_init; struct fsp_multi_phase_params multi_phase_params; struct fsp_multi_phase_get_number_of_phases_params multi_phase_get_number; @@ -332,7 +332,7 @@
static void do_fsp_memory_init(const struct fspm_context *context, bool s3wake) { - uint32_t status; + efi_return_status_t status; fsp_memory_init_fn fsp_raminit; FSPM_UPD fspm_upd, *upd; FSPM_ARCHx_UPD *arch_upd; diff --git a/src/drivers/intel/fsp2_0/silicon_init.c b/src/drivers/intel/fsp2_0/silicon_init.c index 08258d3..52d714d 100644 --- a/src/drivers/intel/fsp2_0/silicon_init.c +++ b/src/drivers/intel/fsp2_0/silicon_init.c @@ -36,7 +36,8 @@ FSP_MULTI_PHASE_SI_INIT_EXECUTE_PHASE_API };
-static void fsps_return_value_handler(enum fsp_silicon_init_phases phases, uint32_t status) +static void fsps_return_value_handler(enum fsp_silicon_init_phases phases, + efi_return_status_t status) { uint8_t postcode;
@@ -54,16 +55,13 @@
switch (phases) { case FSP_SILICON_INIT_API: - die_with_post_code(postcode, "FspSiliconInit returned with error 0x%08x\n", - status); + fsp_die_with_post_code(status, postcode, "FspSiliconInit error"); break; case FSP_MULTI_PHASE_SI_INIT_GET_NUMBER_OF_PHASES_API: - printk(BIOS_SPEW, "FspMultiPhaseSiInit NumberOfPhases returned 0x%08x\n", - status); + fsp_printk(status, BIOS_SPEW, "FspMultiPhaseSiInit NumberOfPhases"); break; case FSP_MULTI_PHASE_SI_INIT_EXECUTE_PHASE_API: - printk(BIOS_SPEW, "FspMultiPhaseSiInit ExecutePhase returned 0x%08x\n", - status); + fsp_printk(status, BIOS_SPEW, "FspMultiPhaseSiInit ExecutePhase"); break; default: break; @@ -88,7 +86,7 @@ { FSPS_UPD *upd, *supd; fsp_silicon_init_fn silicon_init; - uint32_t status; + efi_return_status_t status; fsp_multi_phase_init_fn multi_phase_si_init; struct fsp_multi_phase_params multi_phase_params; struct fsp_multi_phase_get_number_of_phases_params multi_phase_get_number; @@ -139,7 +137,7 @@ status = silicon_init(upd); null_breakpoint_init();
- printk(BIOS_INFO, "FSPS returned %x\n", status); + fsp_printk(status, BIOS_INFO, "FSPS");
timestamp_add_now(TS_FSP_SILICON_INIT_END); post_code(POSTCODE_FSP_SILICON_EXIT); diff --git a/src/drivers/intel/fsp2_0/util.c b/src/drivers/intel/fsp2_0/util.c index f912d9a..47dc3e8 100644 --- a/src/drivers/intel/fsp2_0/util.c +++ b/src/drivers/intel/fsp2_0/util.c @@ -83,18 +83,18 @@ return CB_SUCCESS; }
-static bool fsp_reset_requested(uint32_t status) +static bool fsp_reset_requested(efi_return_status_t status) { return (status >= FSP_STATUS_RESET_REQUIRED_COLD && status <= FSP_STATUS_RESET_REQUIRED_8); }
-void fsp_handle_reset(uint32_t status) +void fsp_handle_reset(efi_return_status_t status) { if (!fsp_reset_requested(status)) return;
- printk(BIOS_SPEW, "FSP: handling reset type %x\n", status); + fsp_printk(status, BIOS_SPEW, "FSP: handling reset type");
switch (status) { case FSP_STATUS_RESET_REQUIRED_COLD: diff --git a/src/include/efi/efi_datatype.h b/src/include/efi/efi_datatype.h index 31612b8..8a1a124 100644 --- a/src/include/efi/efi_datatype.h +++ b/src/include/efi/efi_datatype.h @@ -65,7 +65,11 @@ /* Signed value of native width. */ typedef INTN efi_intn_t; /* Status codes common to all execution phases */ -typedef EFI_STATUS efi_return_status_t; +#if CONFIG(PLATFORM_USES_FSP2_X86_32) +typedef UINT32 efi_return_status_t; +#else +typedef UINT64 efi_return_status_t; +#endif /* Data structure for EFI_PHYSICAL_ADDRESS */ typedef EFI_PHYSICAL_ADDRESS efi_physical_address; /* 128-bit buffer containing a unique identifier value */ diff --git a/src/soc/amd/common/fsp/fsp_reset.c b/src/soc/amd/common/fsp/fsp_reset.c index 0a89dc7..761ba2b 100644 --- a/src/soc/amd/common/fsp/fsp_reset.c +++ b/src/soc/amd/common/fsp/fsp_reset.c @@ -6,10 +6,9 @@ #include <fsp/util.h> #include <stdint.h>
-void chipset_handle_reset(uint32_t status) +void chipset_handle_reset(efi_return_status_t status) { - printk(BIOS_ERR, "unexpected call to %s(0x%08x). Doing cold reset.\n", - __func__, status); + fsp_printk(status, BIOS_ERR, "Doing cold reset due to unexpected call to %s", __func__); BUG(); do_cold_reset(); } diff --git a/src/soc/intel/common/fsp_reset.c b/src/soc/intel/common/fsp_reset.c index 2bb39bd..2626c39 100644 --- a/src/soc/intel/common/fsp_reset.c +++ b/src/soc/intel/common/fsp_reset.c @@ -30,20 +30,20 @@ struct pch_reset_data reset_data; };
-void chipset_handle_reset(uint32_t status) +void chipset_handle_reset(efi_return_status_t status) { if (status == CONFIG_FSP_STATUS_GLOBAL_RESET) { printk(BIOS_DEBUG, "GLOBAL RESET!\n"); global_reset(); }
- printk(BIOS_ERR, "unhandled reset type %x\n", status); + fsp_printk(status, BIOS_ERR, "unhandled reset type"); die("unknown reset type"); }
static uint32_t fsp_reset_type_to_status(EFI_RESET_TYPE reset_type) { - uint32_t status; + efi_return_status_t status;
switch (reset_type) { case EfiResetCold:
