Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/57925 )
Change subject: drivers/intel/dptf: Add support for PCH methods ......................................................................
Add various methods support for pch device under dptf driver. This provides support of different control knobs for FIVR.
BUG=b:198582766 BRANCH=None TEST=Build FW and test on brya0 board
Change-Id: I2d40fff98cb4eb9144d55fd5383d9946e4cb0558 Signed-off-by: Sumeet Pawnikar sumeet.r.pawnikar@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/57925 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/drivers/intel/dptf/dptf.c M src/drivers/intel/dptf/dptf.h M src/soc/intel/alderlake/dptf.c 3 files changed, 162 insertions(+), 20 deletions(-)
diff --git a/src/drivers/intel/dptf/dptf.c b/src/drivers/intel/dptf/dptf.c index a202a27..4a65127 100644 --- a/src/drivers/intel/dptf/dptf.c +++ b/src/drivers/intel/dptf/dptf.c @@ -5,16 +5,21 @@ #include <console/console.h> #include <device/device.h> #include <intelblocks/pmc_ipc.h> +#include <soc/pci_devs.h> #include "chip.h" #include "dptf.h"
/* Generic DPTF participants have a PTYP field to distinguish them */ enum dptf_generic_participant_type { DPTF_GENERIC_PARTICIPANT_TYPE_TSR = 0x3, + DPTF_GENERIC_PARTICIPANT_TYPE_TPCH = 0x5, DPTF_GENERIC_PARTICIPANT_TYPE_CHARGER = 0xB, };
#define DEFAULT_CHARGER_STR "Battery Charger" +#define DEFAULT_TPCH_STR "Intel PCH FIVR Participant" + +#define PMC_IPC_COMMAND_FIVR_SIZE 0x8
/* * Helper method to determine if a device is "used" (called out anywhere as a source or a target @@ -195,19 +200,31 @@ } }
-/* _SB.DPTF.TPCH.RFC methods */ -static void write_tpch_rfc_methods(const char *tpch_rfc_method_name, +static const char *get_pmc_ipcs_method(void) +{ + const char *method = acpi_device_path_join( + pcidev_path_on_root(PCH_DEVFN_PMC), "IPCS"); + if (!method) { + printk(BIOS_ERR, "%s: Unable to find PMC device IPCS method\n", __func__); + return NULL; + } + return method; +} + +static void write_tpch_write_method(const char *tpch_write_method_name, unsigned int ipc_subcmd_ctrl_value) { - acpigen_write_method_serialized(tpch_rfc_method_name, 1); - acpigen_emit_namestring("IPCS"); + /* Get IPCS method from the PMC device */ + const char *ipcs = get_pmc_ipcs_method(); + acpigen_write_method_serialized(tpch_write_method_name, 1); + acpigen_emit_namestring(ipcs); acpigen_write_integer(PMC_IPC_CMD_COMMAND_FIVR); acpigen_write_integer(PMC_IPC_CMD_CMD_ID_FIVR_WRITE); - acpigen_write_integer(0x8); + acpigen_write_integer(PMC_IPC_COMMAND_FIVR_SIZE); acpigen_write_integer(ipc_subcmd_ctrl_value); acpigen_emit_byte(ARG0_OP); - acpigen_write_dword(0); - acpigen_write_dword(0); + acpigen_write_zero(); + acpigen_write_zero(); /* The reason for returning a value here is a W/A for the ESIF shell */ acpigen_emit_byte(RETURN_OP); acpigen_write_package(0); @@ -215,12 +232,78 @@ acpigen_write_method_end(); }
+static void write_ppkg_package(const uint8_t i) +{ + acpigen_write_store(); + acpigen_emit_byte(DEREF_OP); + acpigen_emit_byte(INDEX_OP); + acpigen_emit_byte(ARG0_OP); + acpigen_write_integer(i); + acpigen_emit_byte(ZERO_OP); + acpigen_emit_byte(INDEX_OP); + acpigen_emit_namestring("PPKG"); + acpigen_write_integer(i); + acpigen_emit_byte(ZERO_OP); +} + +/* + * Truncate Package received from IPC + * Arguments: + * Arg0: Package returned from the IPCS read call from the Pmc + * Return Value: + * Return Package with just the Status and ReadBuf0 + * Status returns 0 for success and 2 for device error + */ +static void write_pkgc_method(void) +{ + acpigen_write_method_serialized("PKGC", 1); + acpigen_write_name("PPKG"); + acpigen_write_package(2); + acpigen_write_zero(); + acpigen_write_zero(); + acpigen_write_package_end(); + + write_ppkg_package(0); + write_ppkg_package(1); + + acpigen_write_return_namestr("PPKG"); + acpigen_write_method_end(); +} + +static void write_tpch_read_method(const char *tpch_read_method_name, + unsigned int ipc_subcmd_ctrl_value) +{ + /* Get IPCS method from the PMC device */ + const char *ipcs = get_pmc_ipcs_method(); + acpigen_write_method_serialized(tpch_read_method_name, 0); + acpigen_write_store(); + acpigen_emit_namestring(ipcs); + acpigen_write_integer(PMC_IPC_CMD_COMMAND_FIVR); + acpigen_write_integer(PMC_IPC_CMD_CMD_ID_FIVR_READ); + acpigen_write_integer(PMC_IPC_COMMAND_FIVR_SIZE); + acpigen_write_integer(ipc_subcmd_ctrl_value); + acpigen_write_zero(); + acpigen_write_zero(); + acpigen_write_zero(); + acpigen_emit_byte(LOCAL0_OP); + + acpigen_write_store(); + acpigen_emit_namestring("PKGC"); + acpigen_emit_byte(LOCAL0_OP); + acpigen_emit_byte(LOCAL1_OP); + + acpigen_emit_byte(RETURN_OP); + acpigen_emit_byte(LOCAL1_OP); + acpigen_write_method_end(); +} + static void write_create_tpch(const struct dptf_platform_info *platform_info) { acpigen_write_device("TPCH"); acpigen_write_name("_HID"); dptf_write_hid(platform_info->use_eisa_hids, platform_info->tpch_device_hid); - acpigen_write_name_integer("_UID", 0); + acpigen_write_name_string("_STR", DEFAULT_TPCH_STR); + acpigen_write_name_integer("PTYP", DPTF_GENERIC_PARTICIPANT_TYPE_TPCH); acpigen_write_STA(ACPI_STATUS_DEVICE_ALL_ON); }
@@ -228,12 +311,58 @@ { write_create_tpch(platform_info);
- /* Create RFC0 method */ - write_tpch_rfc_methods(platform_info->tpch_rfc0_method, - PMC_IPC_SUBCMD_RFI_CTRL0_LOGIC); - /* Create RFC1 method */ - write_tpch_rfc_methods(platform_info->tpch_rfc1_method, - PMC_IPC_SUBCMD_RFI_CTRL4_LOGIC); + const struct { + enum { READ, WRITE } type; + const char *method_name; + unsigned int subcommand; + } tpch_methods[] = { + { .type = WRITE, + .method_name = + platform_info->tpch_method_names.set_fivr_low_clock_method, + .subcommand = PMC_IPC_SUBCMD_RFI_CTRL0_LOGIC + }, + { .type = WRITE, + .method_name = + platform_info->tpch_method_names.set_fivr_high_clock_method, + .subcommand = PMC_IPC_SUBCMD_RFI_CTRL4_LOGIC + }, + { .type = READ, + .method_name = + platform_info->tpch_method_names.get_fivr_low_clock_method, + .subcommand = PMC_IPC_SUBCMD_RFI_CTRL0_LOGIC + }, + { .type = READ, + .method_name = + platform_info->tpch_method_names.get_fivr_high_clock_method, + .subcommand = PMC_IPC_SUBCMD_RFI_CTRL4_LOGIC + }, + { .type = READ, + .method_name = + platform_info->tpch_method_names.get_fivr_ssc_method, + .subcommand = PMC_IPC_SUBCMD_EMI_CTRL0_LOGIC + }, + { .type = READ, + .method_name = + platform_info->tpch_method_names.get_fivr_switching_fault_status, + .subcommand = PMC_IPC_SUBCMD_FFFC_FAULT_STATUS + }, + { .type = READ, + .method_name = + platform_info->tpch_method_names.get_fivr_switching_freq_mhz, + .subcommand = PMC_IPC_SUBCMD_FFFC_RFI_STATUS + }, + }; + + write_pkgc_method(); + for (size_t i = 0; i < ARRAY_SIZE(tpch_methods); i++) { + if (tpch_methods[i].type == READ) { + write_tpch_read_method(tpch_methods[i].method_name, + tpch_methods[i].subcommand); + } else if (tpch_methods[i].type == WRITE) { + write_tpch_write_method(tpch_methods[i].method_name, + tpch_methods[i].subcommand); + } + }
acpigen_write_device_end(); /* TPCH Device */ } diff --git a/src/drivers/intel/dptf/dptf.h b/src/drivers/intel/dptf/dptf.h index f23ae25..877aad9 100644 --- a/src/drivers/intel/dptf/dptf.h +++ b/src/drivers/intel/dptf/dptf.h @@ -15,8 +15,15 @@ const char *generic_hid; const char *fan_hid; const char *tpch_device_hid; - const char *tpch_rfc0_method; - const char *tpch_rfc1_method; + struct { + const char *set_fivr_low_clock_method; + const char *set_fivr_high_clock_method; + const char *get_fivr_low_clock_method; + const char *get_fivr_high_clock_method; + const char *get_fivr_ssc_method; + const char *get_fivr_switching_fault_status; + const char *get_fivr_switching_freq_mhz; + } tpch_method_names; };
const struct dptf_platform_info *get_dptf_platform_info(void); diff --git a/src/soc/intel/alderlake/dptf.c b/src/soc/intel/alderlake/dptf.c index ba604ca..37754db 100644 --- a/src/soc/intel/alderlake/dptf.c +++ b/src/soc/intel/alderlake/dptf.c @@ -12,10 +12,16 @@ .fan_hid = "INTC1048", /* _HID for the toplevel TPCH device, typically _SB.TPCH */ .tpch_device_hid = "INTC1049", - /* RFC0 method name */ - .tpch_rfc0_method = "RFC0", - /* RFC1 method name */ - .tpch_rfc1_method = "RFC1", + + .tpch_method_names = { + .set_fivr_low_clock_method = "RFC0", + .set_fivr_high_clock_method = "RFC1", + .get_fivr_low_clock_method = "GFC0", + .get_fivr_high_clock_method = "GFC1", + .get_fivr_ssc_method = "GEMI", + .get_fivr_switching_fault_status = "GFFS", + .get_fivr_switching_freq_mhz = "GFCS", + }, };
