Maximilian Brune has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80139?usp=email )
Change subject: util/crossgcc/buildgcc: Compile RISC-V GCC with medany ......................................................................
currently the HiFive Unmatched mainboard produces the following error: util/crossgcc/xgcc/lib/gcc/riscv64-elf/13.2.0/rv64imafdc/lp64d/libgcc.a(_clzsi2.o): in function `__clzdi2': util/crossgcc/build-riscv64-elf-GCC/riscv64-elf/rv64imafdc/lp64d/libgcc/../../../../../gcc-13.2.0/libgcc/libgcc2.c:690:(.text+0x1e): relocation truncated to fit: R_RISCV_HI20 against symbol `__clz_tab' defined in .rodata section in /home/max/coreboot/coreboot-alderlake-p/util/crossgcc/xgcc/lib/gcc/riscv64-elf/13.2.0/rv64imafdc/lp64d/libgcc.a(_clz.o)
This is due to the fact that the libgcc.a library is compiled with the medlow code model but the mainboards are compiled with the medany code model.
Changing the code model of the GCC libraries to the medany code model fixes the issue.
Signed-off-by: Maximilian Brune maximilian.brune@9elements.com Change-Id: If5f07ce034686dd7fec160ea76838507c0ba7fa0 --- M util/crossgcc/buildgcc 1 file changed, 6 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/39/80139/1
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index 23a5caf..d200378 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -774,6 +774,11 @@ [ -n "$CXX" ] && $CXX --version | grep clang >/dev/null 2>&1 && \ CLANGCXXFLAGS="-fbracket-depth=1024"
+ # standard code model is medlow but all mainboards are compiled with medany code model + if [ "${TARGETARCH}" = "riscv64-elf" ]; then + CFLAGS_FOR_TARGET_EXTRA="-mcmodel=medany" + fi + # GCC does not honor HOSTCFLAGS at all. CFLAGS are used for # both target and host object files. # There's a work-around called CFLAGS_FOR_BUILD and CFLAGS_FOR_TARGET @@ -783,7 +788,7 @@ # using C++. # shellcheck disable=SC2086 CC="$(hostcc target)" CXX="$(hostcxx target)" \ - CFLAGS_FOR_TARGET="-O2 -Dinhibit_libc" \ + CFLAGS_FOR_TARGET="${CFLAGS_FOR_TARGET_EXTRA} -O2 -Dinhibit_libc" \ CFLAGS="$HOSTCFLAGS $CLANGFLAGS" \ CFLAGS_FOR_BUILD="$HOSTCFLAGS $CLANGFLAGS" \ CXXFLAGS="$HOSTCFLAGS $CLANGCXXFLAGS" \
