Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5229
commit 10a838775cbce316019883123317d8f8d8b2899e Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Sat Feb 15 10:21:59 2014 +0200
uart: Add single function for divisor calculation
Divisor is a function of requested baudrate and platform-specific clock used for UART reference. Combine this with the capability to read baudrate from option_table.
When building without option_table or when there is no entry for baud_rate, CONFIG_TTYS0_BAUD is used.
FIXME: Field for baudrate in lb_tables is still incorrect.
Change-Id: I68539738469af780fadd3392263dd9b3d5964d2d Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/arch/x86/lib/romcc_console.c | 2 ++ src/console/Makefile.inc | 6 ++-- src/console/uart8250_console.c | 1 - src/console/uart8250mem_console.c | 1 - src/console/util.c | 54 ++++++++++++++++++++++++++++++++ src/drivers/oxford/oxpcie/oxpcie_early.c | 8 ++++- src/include/console/uart.h | 26 +++++++++++++++ src/include/uart8250.h | 2 ++ src/lib/uart8250.c | 27 +--------------- src/lib/uart8250mem.c | 24 +------------- 10 files changed, 96 insertions(+), 55 deletions(-)
diff --git a/src/arch/x86/lib/romcc_console.c b/src/arch/x86/lib/romcc_console.c index db84f9e..e517428 100644 --- a/src/arch/x86/lib/romcc_console.c +++ b/src/arch/x86/lib/romcc_console.c @@ -31,6 +31,8 @@ #include <uart8250.h> #endif
+#include <console/util.c> + #if CONFIG_CONSOLE_SERIAL8250 #include "lib/uart8250.c" #endif diff --git a/src/console/Makefile.inc b/src/console/Makefile.inc index 54d59cd..8760012 100644 --- a/src/console/Makefile.inc +++ b/src/console/Makefile.inc @@ -1,5 +1,5 @@ ramstage-y += printk.c -ramstage-y += console.c +ramstage-y += util.c console.c ramstage-y += vtxprintf.c ramstage-y += vsprintf.c ramstage-y += post.c @@ -9,12 +9,12 @@ smm-$(CONFIG_DEBUG_SMI) += vtxprintf.c printk.c smm-$(CONFIG_SMM_TSEG) += die.c
romstage-$(CONFIG_EARLY_CONSOLE) += vtxprintf.c -romstage-y += console.c +romstage-y += util.c console.c romstage-y += post.c romstage-y += die.c
bootblock-$(CONFIG_BOOTBLOCK_CONSOLE) += vtxprintf.c -bootblock-y += console.c +bootblock-y += util.c console.c bootblock-y += die.c
ramstage-$(CONFIG_CONSOLE_SERIAL8250) += uart8250_console.c diff --git a/src/console/uart8250_console.c b/src/console/uart8250_console.c index 330ed68..196412c 100644 --- a/src/console/uart8250_console.c +++ b/src/console/uart8250_console.c @@ -19,7 +19,6 @@
#include <console/console.h> #include <uart8250.h> -#include <pc80/mc146818rtc.h>
static void ttyS0_init(void) { diff --git a/src/console/uart8250mem_console.c b/src/console/uart8250mem_console.c index ed77237..3833e47 100644 --- a/src/console/uart8250mem_console.c +++ b/src/console/uart8250mem_console.c @@ -19,7 +19,6 @@
static u32 uart_bar = 0;
diff --git a/src/console/util.c b/src/console/util.c new file mode 100644 index 0000000..a7651fb --- /dev/null +++ b/src/console/util.c @@ -0,0 +1,54 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <uart8250.h> +#if CONFIG_USE_OPTION_TABLE +#include <pc80/mc146818rtc.h> +#include "option_table.h" +#endif + +#if CONFIG_CONSOLE_SERIAL +/* Treat the default base frequency 115200 as a special case + * to avoid runtime division. Might help ROMCC builds. + */ +unsigned uart_divisor(unsigned basefreq) +{ + unsigned div = (basefreq / CONFIG_TTYS0_BAUD); + +#if !defined(__SMM__) && CONFIG_USE_OPTION_TABLE + static const unsigned char divisor[8] = { 1, 2, 3, 6, 12, 24, 48, 96 }; + static const unsigned baud[8] = + { 115200, 57600, 38400, 19200, 9600, 4800, 2400, 1200 }; + unsigned b_index = 0; +#if defined(__PRE_RAM__) + b_index = read_option(baud_rate, 0xff); +#else + if (get_option(&b_index, "baud_rate") != CB_SUCCESS) + b_index = 0xff; +#endif + if (b_index < 8) { + if (basefreq == 115200) + div = divisor[b_index]; + else + div = (basefreq / baud[b_index]); + } +#endif + return div; +} + +#endif diff --git a/src/drivers/oxford/oxpcie/oxpcie_early.c b/src/drivers/oxford/oxpcie/oxpcie_early.c index d04e9d4..693c1e9 100644 --- a/src/drivers/oxford/oxpcie/oxpcie_early.c +++ b/src/drivers/oxford/oxpcie/oxpcie_early.c @@ -116,7 +116,13 @@ void oxford_init(void) /* Now the UART initialization */ u32 uart0_base = CONFIG_OXFORD_OXPCIE_BASE_ADDRESS + 0x1000;
- uart8250_mem_init(uart0_base, (4000000 / CONFIG_TTYS0_BAUD)); + unsigned div = uart_platform_divisor(); + uart8250_mem_init(uart0_base, div); }
#endif + +unsigned uart_platform_divisor(void) +{ + return uart_divisor(4000000); +} diff --git a/src/include/console/uart.h b/src/include/console/uart.h new file mode 100644 index 0000000..c4079b3 --- /dev/null +++ b/src/include/console/uart.h @@ -0,0 +1,26 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 The ChromiumOS Authors. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef CONSOLE_UART_H +#define CONSOLE_UART_H + +unsigned uart_divisor(unsigned basefreq); +unsigned uart_platform_divisor(void); + +#endif /* CONSOLE_UART_H */ diff --git a/src/include/uart8250.h b/src/include/uart8250.h index bec3637..996a854 100644 --- a/src/include/uart8250.h +++ b/src/include/uart8250.h @@ -143,4 +143,6 @@ void oxford_init(void);
#endif /* CONFIG_CONSOLE_SERIAL8250 || CONFIG_CONSOLE_SERIAL8250MEM */
+#include <console/uart.h> + #endif /* UART8250_H */ diff --git a/src/lib/uart8250.c b/src/lib/uart8250.c index aa18d2a..bcb137a 100644 --- a/src/lib/uart8250.c +++ b/src/lib/uart8250.c @@ -20,13 +20,8 @@
#include <arch/io.h> #include <uart8250.h> -#include <pc80/mc146818rtc.h> #include <trace.h>
-#if CONFIG_USE_OPTION_TABLE -#include "option_table.h" -#endif - /* Should support 8250, 16450, 16550, 16550A type UARTs */
/* Expected character delay at 1200bps is 9ms for a working UART @@ -107,26 +102,6 @@ void uart8250_init(unsigned base_port, unsigned divisor)
void uart_init(void) { - /* TODO the divisor calculation is hard coded to standard UARTs. Some - * UARTs won't work with these values. This should be a property of the - * UART used, worst case a Kconfig variable. For now live with hard - * codes as the only devices that might be different are the iWave - * iRainbowG6 and the OXPCIe952 card (and the latter is memory mapped) - */ - unsigned int div = (115200 / CONFIG_TTYS0_BAUD); - -#if !defined(__SMM__) && CONFIG_USE_OPTION_TABLE - static const unsigned char divisor[8] = { 1, 2, 3, 6, 12, 24, 48, 96 }; - unsigned b_index = 0; -#if defined(__PRE_RAM__) - b_index = read_option(baud_rate, 0); - b_index &= 7; - div = divisor[b_index]; -#else - if (get_option(&b_index, "baud_rate") == CB_SUCCESS) - div = divisor[b_index]; -#endif -#endif - + unsigned int div = uart_divisor(115200); uart8250_init(CONFIG_TTYS0_BASE, div); } diff --git a/src/lib/uart8250mem.c b/src/lib/uart8250mem.c index 1482142..26c83fa 100644 --- a/src/lib/uart8250mem.c +++ b/src/lib/uart8250mem.c @@ -20,10 +20,6 @@
#include <arch/io.h> #include <uart8250.h> -#include <pc80/mc146818rtc.h> -#if CONFIG_USE_OPTION_TABLE -#include "option_table.h" -#endif #include <device/device.h> #include <delay.h>
@@ -105,27 +101,11 @@ void uart8250_mem_init(unsigned base_port, unsigned divisor)
u32 uart_mem_init(void) { - unsigned uart_baud = CONFIG_TTYS0_BAUD; u32 uart_bar = 0; - unsigned div; - - /* find out the correct baud rate */ -#if !defined(__SMM__) && CONFIG_USE_OPTION_TABLE - static const unsigned baud[8] = { 115200, 57600, 38400, 19200, 9600, 4800, 2400, 1200 }; - unsigned b_index = 0; -#if defined(__PRE_RAM__) - b_index = read_option(baud_rate, 0); - b_index &= 7; - uart_baud = baud[b_index]; -#else - if (get_option(&b_index, "baud_rate") == CB_SUCCESS) - uart_baud = baud[b_index]; -#endif -#endif + unsigned div = uart_platform_divisor();
/* Now find the UART base address and calculate the divisor */ #if CONFIG_DRIVERS_OXFORD_OXPCIE - #if defined(MORE_TESTING) && !defined(__SIMPLE_DEVICE__) device_t dev = dev_find_device(0x1415, 0xc158, NULL); if (!dev) @@ -144,8 +124,6 @@ u32 uart_mem_init(void) #endif uart_bar = CONFIG_OXFORD_OXPCIE_BASE_ADDRESS + 0x1000; // 1st UART // uart_bar = CONFIG_OXFORD_OXPCIE_BASE_ADDRESS + 0x2000; // 2nd UART - - div = 4000000 / uart_baud; #endif
if (uart_bar)
