Tim Wawrzynczak has submitted this change. ( https://review.coreboot.org/c/coreboot/+/56802 )
Change subject: mb/google/brya/variant/taeko: Update devicetree settings ......................................................................
Based on schematic and gpio table of taeko, generate overridetree.cb settings for taeko.
BUG=b:195494281 TEST=FW_NAME=taeko emerge-brya coreboot chromeos-bootimage
Signed-off-by: Joey Peng joey.peng@lcfc.corp-partner.google.com Change-Id: I96aaf48284a226edc39115f870bf0f3dd83ab8b4 Reviewed-on: https://review.coreboot.org/c/coreboot/+/56802 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/brya/variants/taeko/overridetree.cb 1 file changed, 277 insertions(+), 2 deletions(-)
diff --git a/src/mainboard/google/brya/variants/taeko/overridetree.cb b/src/mainboard/google/brya/variants/taeko/overridetree.cb index 4f2c04a..a8a5e83 100644 --- a/src/mainboard/google/brya/variants/taeko/overridetree.cb +++ b/src/mainboard/google/brya/variants/taeko/overridetree.cb @@ -1,6 +1,281 @@ chip soc/intel/alderlake + register "usb2_ports[1]" = "USB2_PORT_EMPTY" # Disable Port 1 + register "usb2_ports[2]" = "USB2_PORT_TYPE_C(OC2)" # DB USB2_C1 + register "usb2_ports[3]" = "USB2_PORT_EMPTY" # Disable M.2 WWAN + register "usb3_ports[3]" = "USB3_PORT_EMPTY" # Disable M.2 WWAN
- device domain 0 on - end + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| chipset_lockdown | CHIPSET_LOCKDOWN_COREBOOT | + #| GSPI1 | Fingerprint MCU | + #| I2C0 | Audio | + #| I2C1 | Touchscreen | + #| I2C2 | HPS | + #| I2C3 | cr50 TPM. Early init is | + #| | required to set up a BAR | + #| | for TPM communication | + #| I2C5 | Trackpad | + #+-------------------+---------------------------+ + register "common_soc_config.chipset_lockdown" = "CHIPSET_LOCKDOWN_COREBOOT" + register "common_soc_config" = "{ + .i2c[0] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[2] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[3] = { + .early_init = 1, + .speed = I2C_SPEED_FAST, + }, + .i2c[5] = { + .speed = I2C_SPEED_FAST, + }, + }" + # I2C Port Config + register "SerialIoI2cMode" = "{ + [PchSerialIoIndexI2C0] = PchSerialIoPci, + [PchSerialIoIndexI2C1] = PchSerialIoPci, + [PchSerialIoIndexI2C2] = PchSerialIoPci, + [PchSerialIoIndexI2C3] = PchSerialIoPci, + [PchSerialIoIndexI2C4] = PchSerialIoDisabled, + [PchSerialIoIndexI2C5] = PchSerialIoPci, + }" + device domain 0 on + device ref tbt_pcie_rp0 off end + device ref tbt_pcie_rp1 off end + device ref tbt_pcie_rp2 off end + device ref i2c0 on + chip drivers/i2c/generic + register "hid" = ""10EC5682"" + register "name" = ""RT58"" + register "desc" = ""Headset Codec"" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_BOTH(GPP_A23)" + # Set the jd_src to RT5668_JD1 for jack detection + register "property_count" = "1" + register "property_list[0].type" = "ACPI_DP_TYPE_INTEGER" + register "property_list[0].name" = ""realtek,jd-src"" + register "property_list[0].integer" = "1" + device i2c 1a on + end + end + end + device ref i2c1 on + chip drivers/i2c/hid + register "generic.hid" = ""GDIX0000"" + register "generic.desc" = ""Goodix Touchscreen"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C7_IRQ)" + register "generic.probed" = "1" + register "generic.reset_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C1)" + # Parameter T5 >= 180ms + register "generic.reset_delay_ms" = "180" + # Parameter T2 >= 1ms + register "generic.reset_off_delay_ms" = "3" + register "generic.enable_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_C0)" + # Parameter T1 >= 20ms + register "generic.enable_delay_ms" = "20" + register "generic.stop_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_E3)" + # Parameter T4 >= 1ms + register "generic.stop_off_delay_ms" = "1" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + device i2c 5d on end + end + chip drivers/i2c/generic + register "hid" = ""ELAN0001"" + register "desc" = ""ELAN Touchscreen"" + register "irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C7_IRQ)" + register "probed" = "1" + register "reset_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C1)" + register "reset_delay_ms" = "20" + register "enable_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_C0)" + register "enable_delay_ms" = "1" + register "has_power_resource" = "1" + device i2c 10 on end + end + end + device ref i2c5 on + chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_F14_IRQ)" + register "wake" = "GPE0_DW2_15" + register "probed" = "1" + device i2c 15 on end + end + chip drivers/i2c/hid + register "generic.hid" = ""PNP0C50"" + register "generic.desc" = ""Synaptics Touchpad"" + register "generic.irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_F14_IRQ)" + register "generic.wake" = "GPE0_DW2_15" + register "generic.probed" = "1" + register "hid_desc_reg_offset" = "0x20" + device i2c 2c on end + end + end + device ref hda on + chip drivers/generic/max98357a + register "hid" = ""MX98357A"" + register "sdmode_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_A11)" + register "sdmode_delay" = "5" + device generic 0 on end + end
+ chip drivers/intel/soundwire + device generic 0 on + chip drivers/soundwire/alc5682 + # SoundWire Link 0 ID 1 + register "desc" = ""Headset Codec"" + device generic 0.1 on end + end + chip drivers/soundwire/max98373 + # SoundWire Link 2 ID 3 + register "desc" = ""Left Speaker Amp"" + device generic 2.3 on end + end + chip drivers/soundwire/max98373 + # SoundWire Link 2 ID 7 + register "desc" = ""Right Speaker Amp"" + device generic 2.7 on end + end + end + end + end + device ref pcie_rp5 on + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_B11)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H20)" + register "srcclk_pin" = "2" + device generic 0 on end + end + register "pch_pcie_rp[PCH_RP(5)]" = "{ + .clk_src = 2, + .clk_req = 2, + .flags = PCIE_RP_LTR | PCIE_RP_AER, + }" + end + device ref pcie_rp6 off end + device ref pcie_rp8 on + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_H13)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D18)" + register "srcclk_pin" = "3" + device generic 0 on end + end + end + device ref pcie_rp9 on + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_D11)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B4)" + register "srcclk_pin" = "1" + device generic 0 on end + end + end + device ref gspi1 on + chip drivers/spi/acpi + register "name" = ""CRFP"" + register "hid" = "ACPI_DT_NAMESPACE_HID" + register "uid" = "1" + register "compat_string" = ""google,cros-ec-spi"" + register "irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_F15_IRQ)" + register "wake" = "GPE0_DW2_15" + device spi 0 on end + end # FPMCU + end + device ref pch_espi on + chip ec/google/chromeec + use conn0 as mux_conn[0] + use conn1 as mux_conn[1] + device pnp 0c09.0 on end + end + end + device ref pmc hidden + chip drivers/intel/pmc_mux + device generic 0 on + chip drivers/intel/pmc_mux/conn + register "usb2_port_number" = "1" + register "usb3_port_number" = "1" + device generic 0 alias conn0 on end + end + chip drivers/intel/pmc_mux/conn + register "usb2_port_number" = "3" + register "usb3_port_number" = "3" + device generic 2 alias conn1 on end + end + end + end + end + device ref tcss_xhci on + chip drivers/usb/acpi + device ref tcss_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device ref tcss_usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C1 (DB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(3, 1)" + device ref tcss_usb3_port3 on end + end + end + end + end + device ref xhci on + chip drivers/usb/acpi + device ref xhci_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(1, 1)" + device ref usb2_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C1 (DB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "group" = "ACPI_PLD_GROUP(3, 1)" + device ref usb2_port3 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Camera"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb2_port6 on + end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port (MLB)"" + register "type" = "UPC_TYPE_A" + register "group" = "ACPI_PLD_GROUP(4, 1)" + device ref usb2_port9 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D4)" + device ref usb2_port10 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port (MLB)"" + register "type" = "UPC_TYPE_USB3_A" + register "group" = "ACPI_PLD_GROUP(4, 1)" + device ref usb3_port1 on end + end + end + end + end + end end
