Naresh Solanki (naresh.solanki@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17434
commit d839617b0ede2a23301240f70768a589f6cb9cea Author: Naresh G Solanki naresh.solanki@intel.com Date: Wed Oct 26 19:43:14 2016 +0530
lib: Add library to handle SPD data in CBFS or DIMM
Add library to: 1. add spd.bin in cbfs, generated from mainboard/spd/*.spd.hex files. 2. runtime get spd data with spd index as input. 3. fetch spd over smbus using early smbus functions.
Change-Id: I44fe1cdb883dd1037484d4bb5c87d2d4f9862bf8 Signed-off-by: Naresh G Solanki naresh.solanki@intel.com --- src/Kconfig | 25 ++++++++ src/include/spd_bin.h | 57 +++++++++++++++++ src/lib/Makefile.inc | 18 ++++++ src/lib/spd_bin.c | 168 ++++++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 268 insertions(+)
diff --git a/src/Kconfig b/src/Kconfig index be38af1..92817a0 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -316,6 +316,31 @@ config GENERIC_GPIO_LIB implies configurability usually found on SoCs, particularly the ability to control internal pull resistors.
+config GENERIC_SPD_BIN + bool + default n + help + If enabled, add support for adding spd.hex files in cbfs as spd.bin + and locating it runtime to load SPD. Additionally provide provision to + fetch SPD over SMBus. + +config DIMM_MAX + int + default 2 + depends on GENERIC_SPD_BIN + help + Total number of memory DIMM slots available on motherboard. + It is multiplication of number of channel to number of DIMMs per + channel + +config DIMM_SPD_SIZE + int + default 256 + depends on GENERIC_SPD_BIN + help + Total SPD size that will be used for DIMM. + Ex: DDR3 256, DDR4 512. + config BOARD_ID_AUTO bool default n diff --git a/src/include/spd_bin.h b/src/include/spd_bin.h new file mode 100644 index 0000000..a0c1bbd --- /dev/null +++ b/src/include/spd_bin.h @@ -0,0 +1,57 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef SPD_BIN_H +#define SPD_BIN_H + +#include <arch/early_variables.h> +#include <stdint.h> +#include <commonlib/region.h> + +#define SPD_PAGE_LEN 256 +#define SPD_PAGE_LEN_DDR4 512 +#define SPD_PAGE_0 (0x6C >> 1) +#define SPD_PAGE_1 (0x6E >> 1) +#define SPD_DRAM_TYPE 2 +#define SPD_DRAM_DDR3 0x0B +#define SPD_DRAM_LPDDR3_INTEL 0xF1 +#define SPD_DRAM_LPDDR3_JEDEC 0x0F +#define SPD_DRAM_DDR4 0x0C +#define SPD_DENSITY_BANKS 4 +#define SPD_ADDRESSING 5 +#define SPD_ORGANIZATION 7 +#define SPD_BUS_DEV_WIDTH 8 +#define DDR3_SPD_PART_OFF 128 +#define DDR3_SPD_PART_LEN 18 +#define LPDDR3_SPD_PART_OFF 128 +#define LPDDR3_SPD_PART_LEN 18 +#define DDR4_SPD_PART_OFF 329 +#define DDR4_SPD_PART_LEN 20 +#define LPDDR4_SPD_PART_OFF 329 +#define LPDDR4_SPD_PART_LEN 20 + +struct spd_block { + u8 *spd_array[CONFIG_DIMM_MAX]; + /* Length of each dimm */ + u16 len; +}; + +void print_spd_info(uint8_t spd[]); +/* Return 0 on success & -1 on failure */ +int get_spd_cbfs_rdev(struct region_device *spd_rdev, u8 spd_index); +void dump_spd_info(struct spd_block *blk); +void get_spd_smbus(struct spd_block *blk); + +#endif diff --git a/src/lib/Makefile.inc b/src/lib/Makefile.inc index 36591ad..2fb63d0 100644 --- a/src/lib/Makefile.inc +++ b/src/lib/Makefile.inc @@ -269,3 +269,21 @@ $(objcbfs)/%.debug.rmod: $(objcbfs)/%.debug | $(RMODTOOL)
$(obj)/%.elf.rmod: $(obj)/%.elf | $(RMODTOOL) $(RMODTOOL) -i $< -o $@ + +romstage-$(CONFIG_GENERIC_SPD_BIN) += spd_bin.c + +LIB_SPD_BIN = $(obj)/spd.bin + +LIB_SPD_DEPS = $(foreach f, $(SPD_SOURCES), src/mainboard/$(MAINBOARDDIR)/spd/$(f).spd.hex) + +# Include spd ROM data +$(LIB_SPD_BIN): $(LIB_SPD_DEPS) + for f in $(LIB_SPD_DEPS); \ + do for c in $$(cat $$f | grep -v ^#); \ + do printf $$(printf '%o' 0x$$c); \ + done; \ + done > $@ + +cbfs-files-$(CONFIG_GENERIC_SPD_BIN) += spd.bin +spd.bin-file := $(LIB_SPD_BIN) +spd.bin-type := spd diff --git a/src/lib/spd_bin.c b/src/lib/spd_bin.c new file mode 100644 index 0000000..343d48a --- /dev/null +++ b/src/lib/spd_bin.c @@ -0,0 +1,168 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <arch/byteorder.h> +#include <cbfs.h> +#include <console/console.h> +#include <spd_bin.h> +#include <string.h> +#include <device/early_smbus.h> + +static u8 spd_data[CONFIG_DIMM_MAX * CONFIG_DIMM_SPD_SIZE] CAR_GLOBAL; + +void dump_spd_info(struct spd_block *blk) +{ + u8 i; + + for (i = 0; i < CONFIG_DIMM_MAX; i++) + if (blk->spd_array[i] != NULL && blk->spd_array[i][0] != 0) { + printk(BIOS_DEBUG, "SPD @ 0x%02X\n", 0xA0|(i << 1)); + print_spd_info(blk->spd_array[i]); + } +} + +void print_spd_info(uint8_t spd[]) +{ + const int spd_banks[8] = { 8, 16, 32, 64, -1, -1, -1, -1 }; + const int spd_capmb[8] = { 1, 2, 4, 8, 16, 32, 64, 128 }; + const int spd_rows[8] = {12, 13, 14, 15, 16, 17, -1, -1 }; + const int spd_cols[8] = { 9, 10, 11, 12, -1, -1, -1, -1 }; + const int spd_ranks[8] = { 1, 2, 3, 4, -1, -1, -1, -1 }; + const int spd_devw[8] = { 4, 8, 16, 32, -1, -1, -1, -1 }; + const int spd_busw[8] = { 8, 16, 32, 64, -1, -1, -1, -1 }; + char spd_name[DDR4_SPD_PART_LEN+1] = { 0 }; + + int banks = spd_banks[(spd[SPD_DENSITY_BANKS] >> 4) & 7]; + int capmb = spd_capmb[spd[SPD_DENSITY_BANKS] & 7] * 256; + int rows = spd_rows[(spd[SPD_ADDRESSING] >> 3) & 7]; + int cols = spd_cols[spd[SPD_ADDRESSING] & 7]; + int ranks = spd_ranks[(spd[SPD_ORGANIZATION] >> 3) & 7]; + int devw = spd_devw[spd[SPD_ORGANIZATION] & 7]; + int busw = spd_busw[spd[SPD_BUS_DEV_WIDTH] & 7]; + + /* Module type */ + printk(BIOS_INFO, "SPD: module type is "); + switch (spd[SPD_DRAM_TYPE]) { + case SPD_DRAM_DDR3: + printk(BIOS_INFO, "DDR3\n"); + /* Module Part Number */ + memcpy(spd_name, &spd[DDR3_SPD_PART_OFF], DDR3_SPD_PART_LEN); + spd_name[DDR3_SPD_PART_LEN] = 0; + break; + case SPD_DRAM_LPDDR3_INTEL: + case SPD_DRAM_LPDDR3_JEDEC: + printk(BIOS_INFO, "LPDDR3\n"); + /* Module Part Number */ + memcpy(spd_name, &spd[LPDDR3_SPD_PART_OFF], + LPDDR3_SPD_PART_LEN); + spd_name[LPDDR3_SPD_PART_LEN] = 0; + break; + case SPD_DRAM_DDR4: + printk(BIOS_INFO, "DDR4\n"); + memcpy(spd_name, &spd[DDR4_SPD_PART_OFF], DDR4_SPD_PART_LEN); + spd_name[DDR4_SPD_PART_LEN] = 0; + ranks = (spd[SPD_ORGANIZATION] >> 3) & 7; + devw = spd_devw[spd[12] & 7]; + busw = spd_busw[spd[13] & 7]; + break; + default: + printk(BIOS_INFO, "Unknown (%02x)\n", spd[SPD_DRAM_TYPE]); + break; + } + + printk(BIOS_INFO, "SPD: module part is %s\n", spd_name); + + printk(BIOS_INFO, + "SPD: banks %d, ranks %d, rows %d, columns %d, density %d Mb\n", + banks, ranks, rows, cols, capmb); + printk(BIOS_INFO, "SPD: device width %d bits, bus width %d bits\n", + devw, busw); + + if (capmb > 0 && busw > 0 && devw > 0 && ranks > 0) { + /* SIZE = DENSITY / 8 * BUS_WIDTH / SDRAM_WIDTH * RANKS */ + printk(BIOS_INFO, "SPD: module size is %u MB (per channel)\n", + capmb / 8 * busw / devw * ranks); + } +} + +static void update_spd_len(struct spd_block *blk) +{ + u8 i, j = 0; + for (i = 0 ; i < CONFIG_DIMM_MAX; i++) + if (blk->spd_array[i] != NULL) + j |= blk->spd_array[i][SPD_DRAM_TYPE]; + + /* If spd used is DDR4, then its length is 512 byte. */ + if (j == SPD_DRAM_DDR4) + blk->len = SPD_PAGE_LEN_DDR4; + else + blk->len = SPD_PAGE_LEN; +} + +int get_spd_cbfs_rdev(struct region_device *spd_rdev, u8 spd_index) +{ + struct cbfsf fh; + + uint32_t cbfs_type = CBFS_TYPE_SPD; + + cbfs_boot_locate(&fh, "spd.bin", &cbfs_type); + cbfs_file_data(spd_rdev, &fh); + return rdev_chain(spd_rdev, spd_rdev, spd_index * CONFIG_DIMM_SPD_SIZE, + CONFIG_DIMM_SPD_SIZE); +} + +static void get_spd(u8 *spd, u8 addr) +{ + u16 i; + /* Assuming addr is 8 bit address, make it 7 bit */ + addr = addr >> 1; + if (smbus_read_byte(0, addr, 0) == 0xff) { + printk(BIOS_INFO, "No memory dimm at address %02X\n", + addr << 1); + /* Make sure spd is zeroed if dimm doesn't exist. */ + memset(spd, 0, CONFIG_DIMM_SPD_SIZE); + return; + } + + for (i = 0; i < SPD_PAGE_LEN; i++) + spd[i] = smbus_read_byte(0, addr, i); + /* Check if module is DDR4, DDR4 spd is 512 byte. */ + if (spd[SPD_DRAM_TYPE] == SPD_DRAM_DDR4 && + CONFIG_DIMM_SPD_SIZE >= SPD_DRAM_DDR4) { + /* Switch to page 1 */ + smbus_write_byte(0, SPD_PAGE_1, 0, 0); + for (i = 0; i < SPD_PAGE_LEN; i++) + spd[i+SPD_PAGE_LEN] = smbus_read_byte(0, addr, i); + /* Restore to page 0 */ + smbus_write_byte(0, SPD_PAGE_0, 0, 0); + } +} + +void get_spd_smbus(struct spd_block *blk) +{ + u8 i, j; + unsigned char *spd_data_ptr = car_get_var_ptr(&spd_data); + + for (i = 0 ; i < CONFIG_DIMM_MAX; i++) { + get_spd(spd_data_ptr + i * CONFIG_DIMM_SPD_SIZE, + 0xA0 + (i << 1)); + blk->spd_array[i] = spd_data_ptr + i * CONFIG_DIMM_SPD_SIZE; + } + + for (j = i; j < CONFIG_DIMM_MAX; j++) + blk->spd_array[j] = NULL; + + update_spd_len(blk); +}
