Attention is currently required from: Benjamin Doron, Dinesh Gehlot, Kane Chen, Kapil Porwal, Karthik Ramasubramanian, Nick Vaccaro, Paul Menzel, Sowmya Aralguppe, Subrata Banik.
Angel Pons has posted comments on this change by Sowmya Aralguppe. ( https://review.coreboot.org/c/coreboot/+/82136?usp=email )
Change subject: mb/google/brox: Fix CPU crashlog device MMIO memory access ......................................................................
Patch Set 10:
(3 comments)
File src/soc/intel/alderlake/crashlog.c:
https://review.coreboot.org/c/coreboot/+/82136/comment/ac0df1e4_414ad3de?usp... : PS10, Line 205: &
I am reading the value in the CRASHLOG_HEADER and CRASHLOG_CAPABILITY_STATUS registers and populatin […]
Ah, it's two separate registers... Later stored as a single 64-bit value for reasons I cannot comprehend. Oh, well.
In that case, can we *not* name these variables `dw0` and `dw1`, please? `cl_header` and `cl_cap_status` would make the code substantially easier to follow.
https://review.coreboot.org/c/coreboot/+/82136/comment/1aa5aef0_b317da92?usp... : PS10, Line 215: : for (int i = 0; i < cpu_cl_disc_tab.header.fields.count; i++) { : cur_offset = 16 + 8*i; : cpu_cl_disc_tab.buffers[i].data = ((u64)read32((u32 *)(disc_tab_addr + : cur_offset)) + ((u64)read32((u32 *) : (disc_tab_addr + cur_offset + 4)) << 32)); This code makes little sense. Why is it using arrays of 64-bit values to store stuff that gets read as 32-bit values?
```suggestion for (int i = 0; i < cpu_cl_disc_tab.header.fields.count; i++) { const uintptr_t cur_addr = (uintptr_t)disc_tab_addr + 16 + 8 * i; cpu_cl_disc_tab.buffers[i].data = (u64)read32p(cur_addr) | (u64)read32p(cur_addr + 4) << 32); ```
https://review.coreboot.org/c/coreboot/+/82136/comment/4635d739_eaed2bd2?usp... : PS10, Line 248: if (cpu_cl_devsc_cap.discovery_data.fields.t_bir_q == TEL_DVSEC_TBIR_BAR0) { : pci_write_config32(SA_DEV_TMT, PCI_BASE_ADDRESS_0, cpu_bar_addr); : } else if (cpu_cl_devsc_cap.discovery_data.fields.t_bir_q == TEL_DVSEC_TBIR_BAR1) { : pci_write_config32(SA_DEV_TMT, PCI_BASE_ADDRESS_1, cpu_bar_addr); : } else { : printk(BIOS_DEBUG, "invalid discovery data t_bir_q: 0x%x\n", : cpu_cl_devsc_cap.discovery_data.fields.t_bir_q); : return false; : }
The intention here is to write the temp address (cpu_bar_addr) in both PCI_BASE_ADDRESS_0 and PCI_BA […]
If you assign the same base address to both BARs, don't you end up with a resource conflict?
