Bob Moragues has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/30094
Change subject: zoombini: remove support for deprecated zoombini board ......................................................................
Change-Id: Iab2737940f07afb4f5a29ff50e6cb2a22027c51b Signed-off-by: Bob Moragues moragues@chromium.org --- D src/mainboard/google/zoombini/Kconfig D src/mainboard/google/zoombini/Kconfig.name D src/mainboard/google/zoombini/Makefile.inc D src/mainboard/google/zoombini/acpi_tables.c D src/mainboard/google/zoombini/board_info.txt D src/mainboard/google/zoombini/bootblock.c D src/mainboard/google/zoombini/chromeos.c D src/mainboard/google/zoombini/chromeos.fmd D src/mainboard/google/zoombini/dsdt.asl D src/mainboard/google/zoombini/ec.c D src/mainboard/google/zoombini/mainboard.c D src/mainboard/google/zoombini/memory.c D src/mainboard/google/zoombini/ramstage.c D src/mainboard/google/zoombini/romstage.c D src/mainboard/google/zoombini/smihandler.c D src/mainboard/google/zoombini/spd/Hynix_H9HCNNN8KUMLHR_1GB.spd.hex D src/mainboard/google/zoombini/spd/Hynix_H9HCNNNCPUMLHR_4GB.spd.hex D src/mainboard/google/zoombini/spd/Makefile.inc D src/mainboard/google/zoombini/spd/Micron_MT53B1024M32D4_4GB.spd.hex D src/mainboard/google/zoombini/spd/Micron_MT53B512M32D2_2GB.spd.hex D src/mainboard/google/zoombini/spd/Samsung_K4F6E3S4HM_2GB.spd.hex D src/mainboard/google/zoombini/spd/Samsung_K4F8E304HB_1GB.spd.hex D src/mainboard/google/zoombini/variants/baseboard/Makefile.inc D src/mainboard/google/zoombini/variants/baseboard/devicetree.cb D src/mainboard/google/zoombini/variants/baseboard/gpio.c D src/mainboard/google/zoombini/variants/baseboard/include/baseboard/acpi/dptf.asl D src/mainboard/google/zoombini/variants/baseboard/include/baseboard/ec.h D src/mainboard/google/zoombini/variants/baseboard/include/baseboard/gpio.h D src/mainboard/google/zoombini/variants/baseboard/include/baseboard/variants.h D src/mainboard/google/zoombini/variants/baseboard/nhlt.c D src/mainboard/google/zoombini/variants/meowth/Makefile.inc D src/mainboard/google/zoombini/variants/meowth/devicetree.cb D src/mainboard/google/zoombini/variants/meowth/gpio.c D src/mainboard/google/zoombini/variants/meowth/include/variant/acpi/dptf.asl D src/mainboard/google/zoombini/variants/meowth/include/variant/ec.h D src/mainboard/google/zoombini/variants/meowth/include/variant/gpio.h D src/mainboard/google/zoombini/variants/meowth/memory.c D src/mainboard/google/zoombini/variants/zoombini/Makefile.inc D src/mainboard/google/zoombini/variants/zoombini/include/variant/acpi/dptf.asl D src/mainboard/google/zoombini/variants/zoombini/include/variant/ec.h D src/mainboard/google/zoombini/variants/zoombini/include/variant/gpio.h M util/release/genrelnotes 42 files changed, 0 insertions(+), 2,352 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/30094/1
diff --git a/src/mainboard/google/zoombini/Kconfig b/src/mainboard/google/zoombini/Kconfig deleted file mode 100644 index 249b028..0000000 --- a/src/mainboard/google/zoombini/Kconfig +++ /dev/null @@ -1,115 +0,0 @@ - -config BOARD_GOOGLE_BASEBOARD_ZOOMBINI - def_bool n - select BOARD_ROMSIZE_KB_16384 - select DRIVERS_I2C_GENERIC - select DRIVERS_I2C_HID - select DRIVERS_I2C_MAX98373 - select DRIVERS_SPI_ACPI - select EC_GOOGLE_CHROMEEC - select EC_GOOGLE_CHROMEEC_BOARDID - select EC_GOOGLE_CHROMEEC_LPC - select HAVE_ACPI_RESUME - select HAVE_ACPI_TABLES - select MAINBOARD_HAS_CHROMEOS - select SOC_INTEL_CANNONLAKE - select SOC_INTEL_CANNONLAKE_MEMCFG_INIT - -if BOARD_GOOGLE_BASEBOARD_ZOOMBINI - -config BASEBOARD_ZOOMBINI_LAPTOP - def_bool n - select SYSTEM_TYPE_LAPTOP - -config DEVICETREE - string - default "variants/meowth/devicetree.cb" if BOARD_GOOGLE_MEOWTH - default "variants/baseboard/devicetree.cb" - -config DIMM_SPD_SIZE - int - default 512 - -config DRIVER_TPM_I2C_BUS - depends on ZOOMBINI_USE_I2C_TPM - default 0x1 - -config DRIVER_TPM_I2C_ADDR - depends on ZOOMBINI_USE_I2C_TPM - default 0x50 - -config DRIVER_TPM_SPI_BUS - depends on ZOOMBINI_USE_SPI_TPM - default 0x1 - -config GBB_HWID - string - depends on CHROMEOS - default "MEOWTH TEST 5868" if BOARD_GOOGLE_MEOWTH - default "ZOOMBINI TEST 5722" if BOARD_GOOGLE_ZOOMBINI - -config MAINBOARD_DIR - string - default "google/zoombini" - -config MAINBOARD_FAMILY - string - default "Google_Meowth" if BOARD_GOOGLE_MEOWTH - default "Google_Zoombini" if BOARD_GOOGLE_ZOOMBINI - -config MAINBOARD_PART_NUMBER - string - default "Meowth" if BOARD_GOOGLE_MEOWTH - default "Zoombini" if BOARD_GOOGLE_ZOOMBINI - -config MAINBOARD_VENDOR - string - default "Google" - -config INCLUDE_SND_MAX98357_DA7219_NHLT - bool "Include blobs for audio with MAX98357_DA7219" - select NHLT_DMIC_4CH_16B - select NHLT_DMIC_2CH_16B - select NHLT_DA7219 - select NHLT_MAX98357 - -config INCLUDE_SND_MAX98373_NHLT - bool "Include blobs for audio with MAX98373" - select NHLT_DMIC_4CH_16B - select NHLT_DMIC_2CH_16B - select NHLT_MAX98373 - -config MAX_CPUS - int - default 4 - -config VARIANT_DIR - string - default "meowth" if BOARD_GOOGLE_MEOWTH - default "zoombini" if BOARD_GOOGLE_ZOOMBINI - -config VBOOT - select EC_GOOGLE_CHROMEEC_SWITCHES - select HAS_RECOVERY_MRC_CACHE - select MRC_CLEAR_NORMAL_CACHE_ON_RECOVERY_RETRAIN - select VBOOT_LID_SWITCH if BASEBOARD_ZOOMBINI_LAPTOP - -# Select this option to enable use of cr50 I2C TPM on zoombini. -config ZOOMBINI_USE_I2C_TPM - bool - default n - select MAINBOARD_HAS_I2C_TPM_CR50 - select MAINBOARD_HAS_TPM2 - -# Select this option to enable use of cr50 SPI TPM on zoombini. -config ZOOMBINI_USE_SPI_TPM - bool - default y - select MAINBOARD_HAS_SPI_TPM_CR50 - select MAINBOARD_HAS_TPM2 - -config TPM_TIS_ACPI_INTERRUPT - int - default 76 # GPE0_DW2_12 (GPP_C12) - -endif # BOARD_GOOGLE_BASEBOARD_ZOOMBINI diff --git a/src/mainboard/google/zoombini/Kconfig.name b/src/mainboard/google/zoombini/Kconfig.name deleted file mode 100644 index 6d4adcc..0000000 --- a/src/mainboard/google/zoombini/Kconfig.name +++ /dev/null @@ -1,11 +0,0 @@ -comment "Zoombini" - -config BOARD_GOOGLE_ZOOMBINI - bool "-> Zoombini" - select BOARD_GOOGLE_BASEBOARD_ZOOMBINI - select BASEBOARD_ZOOMBINI_LAPTOP - -config BOARD_GOOGLE_MEOWTH - bool "-> Meowth" - select BOARD_GOOGLE_BASEBOARD_ZOOMBINI - select BASEBOARD_ZOOMBINI_LAPTOP diff --git a/src/mainboard/google/zoombini/Makefile.inc b/src/mainboard/google/zoombini/Makefile.inc deleted file mode 100644 index d4e9fd4..0000000 --- a/src/mainboard/google/zoombini/Makefile.inc +++ /dev/null @@ -1,40 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright 2018 Google Inc. -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## - -bootblock-y += bootblock.c -bootblock-$(CONFIG_CHROMEOS) += chromeos.c -bootblock-$(CONFIG_EC_GOOGLE_CHROMEEC) += ec.c - -verstage-$(CONFIG_CHROMEOS) += chromeos.c - -romstage-$(CONFIG_CHROMEOS) += chromeos.c -romstage-y += memory.c -romstage-y += romstage.c - -ramstage-$(CONFIG_CHROMEOS) += chromeos.c -ramstage-$(CONFIG_EC_GOOGLE_CHROMEEC) += ec.c -ramstage-y += mainboard.c -ramstage-y += ramstage.c - -smm-$(CONFIG_HAVE_SMI_HANDLER) += smihandler.c - -subdirs-y += variants/baseboard -CPPFLAGS_common += -I$(src)/mainboard/$(MAINBOARDDIR)/variants/baseboard/include - -subdirs-y += variants/$(VARIANT_DIR) -CPPFLAGS_common += -I$(src)/mainboard/$(MAINBOARDDIR)/variants/$(VARIANT_DIR)/include -subdirs-y += variants/$(VARIANT_DIR)/spd - -subdirs-y += spd diff --git a/src/mainboard/google/zoombini/acpi_tables.c b/src/mainboard/google/zoombini/acpi_tables.c deleted file mode 100644 index e69de29..0000000 --- a/src/mainboard/google/zoombini/acpi_tables.c +++ /dev/null diff --git a/src/mainboard/google/zoombini/board_info.txt b/src/mainboard/google/zoombini/board_info.txt deleted file mode 100644 index 3ed5a7e..0000000 --- a/src/mainboard/google/zoombini/board_info.txt +++ /dev/null @@ -1,6 +0,0 @@ -Vendor name: Google -Board name: Zoombini Cannonlake Reference Board -Category: laptop -ROM protocol: SPI -ROM socketed: n -Flashrom support: y diff --git a/src/mainboard/google/zoombini/bootblock.c b/src/mainboard/google/zoombini/bootblock.c deleted file mode 100644 index 5f37206..0000000 --- a/src/mainboard/google/zoombini/bootblock.c +++ /dev/null @@ -1,33 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/gpio.h> -#include <baseboard/variants.h> -#include <bootblock_common.h> -#include <soc/gpio.h> - -static void early_config_gpio(void) -{ - const struct pad_config *early_gpio_table; - size_t num_gpios = 0; - - early_gpio_table = variant_early_gpio_table(&num_gpios); - gpio_configure_pads(early_gpio_table, num_gpios); -} - -void bootblock_mainboard_init(void) -{ - early_config_gpio(); -} diff --git a/src/mainboard/google/zoombini/chromeos.c b/src/mainboard/google/zoombini/chromeos.c deleted file mode 100644 index 730e2c4..0000000 --- a/src/mainboard/google/zoombini/chromeos.c +++ /dev/null @@ -1,52 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <arch/acpi.h> -#include <baseboard/gpio.h> -#include <boot/coreboot_tables.h> -#include <gpio.h> -#include <rules.h> -#include <soc/gpio.h> -#include <vendorcode/google/chromeos/chromeos.h> - -void fill_lb_gpios(struct lb_gpios *gpios) -{ - struct lb_gpio chromeos_gpios[] = { - {-1, ACTIVE_HIGH, get_write_protect_state(), "write protect"}, - {-1, ACTIVE_HIGH, get_recovery_mode_switch(), "recovery"}, - {-1, ACTIVE_HIGH, get_lid_switch(), "lid"}, - {-1, ACTIVE_HIGH, 0, "power"}, - {-1, ACTIVE_HIGH, gfx_get_init_done(), "oprom"}, - /* always report back 0 as temp workaround for b:74215817 */ - {GPIO_EC_IN_RW, ACTIVE_HIGH, 0, "EC in RW"}, - }; - lb_add_gpios(gpios, chromeos_gpios, ARRAY_SIZE(chromeos_gpios)); -} - -int get_write_protect_state(void) -{ - /* Read PCH_WP GPIO. */ - return gpio_get(GPIO_PCH_WP); -} - -static const struct cros_gpio cros_gpios[] = { - CROS_GPIO_REC_AL(CROS_GPIO_VIRTUAL, CROS_GPIO_DEVICE_NAME), - CROS_GPIO_WP_AH(GPIO_PCH_WP, CROS_GPIO_DEVICE_NAME), -}; - -void mainboard_chromeos_acpi_generate(void) -{ - chromeos_acpi_gpio_generate(cros_gpios, ARRAY_SIZE(cros_gpios)); -} diff --git a/src/mainboard/google/zoombini/chromeos.fmd b/src/mainboard/google/zoombini/chromeos.fmd deleted file mode 100644 index 7123a5f..0000000 --- a/src/mainboard/google/zoombini/chromeos.fmd +++ /dev/null @@ -1,44 +0,0 @@ -FLASH@0xff000000 0x1000000 { - SI_ALL@0x0 0x300000 { - SI_DESC@0x0 0x1000 - SI_ME@0x1000 0x2ff000 - } - SI_BIOS@0x300000 0xd00000 { - RW_SECTION_A@0x0 0x368000 { - VBLOCK_A@0x0 0x10000 - FW_MAIN_A(CBFS)@0x10000 0x357fc0 - RW_FWID_A@0x367fc0 0x40 - } - RW_SECTION_B@0x368000 0x368000 { - VBLOCK_B@0x0 0x10000 - FW_MAIN_B(CBFS)@0x10000 0x357fc0 - RW_FWID_B@0x367fc0 0x40 - } - RW_MISC@0x6d0000 0x30000 { - UNIFIED_MRC_CACHE@0x0 0x20000 { - RECOVERY_MRC_CACHE@0x0 0x10000 - RW_MRC_CACHE@0x10000 0x10000 - } - RW_ELOG@0x20000 0x4000 - RW_SHARED@0x24000 0x4000 { - SHARED_DATA@0x0 0x2000 - VBLOCK_DEV@0x2000 0x2000 - } - RW_VPD@0x28000 0x2000 - RW_NVRAM@0x2a000 0x6000 - } - SMMSTORE@0x700000 0x40000 - RW_LEGACY(CBFS)@0x740000 0x1c0000 - WP_RO@0x900000 0x400000 { - RO_VPD@0x0 0x4000 - RO_UNUSED@0x4000 0xc000 - RO_SECTION@0x10000 0x3f0000 { - FMAP@0x0 0x800 - RO_FRID@0x800 0x40 - RO_FRID_PAD@0x840 0x7c0 - GBB@0x1000 0xef000 - COREBOOT(CBFS)@0xf0000 0x300000 - } - } - } -} diff --git a/src/mainboard/google/zoombini/dsdt.asl b/src/mainboard/google/zoombini/dsdt.asl deleted file mode 100644 index e9988f0..0000000 --- a/src/mainboard/google/zoombini/dsdt.asl +++ /dev/null @@ -1,64 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * Copyright 2017 Google Inc. - * Copyright (C) 2017 Intel Corporation - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include "variant/ec.h" -#include "variant/gpio.h" - -#include <arch/acpi.h> -DefinitionBlock( - "dsdt.aml", - "DSDT", - 0x02, // DSDT revision: ACPI v2.0 and up - OEM_ID, - ACPI_TABLE_CREATOR, - 0x20110725 // OEM revision -) -{ - // Some generic macros - #include <soc/intel/cannonlake/acpi/platform.asl> - - // global NVS and variables - #include <soc/intel/cannonlake/acpi/globalnvs.asl> - - // CPU - #include <cpu/intel/common/acpi/cpu.asl> - - Scope (_SB) { - Device (PCI0) - { - #include <soc/intel/cannonlake/acpi/northbridge.asl> - #include <soc/intel/cannonlake/acpi/southbridge.asl> - } - } - - #if IS_ENABLED(CONFIG_CHROMEOS) - // Chrome OS specific - #include <vendorcode/google/chromeos/acpi/chromeos.asl> - #endif - - // Chipset specific sleep states - #include <soc/intel/cannonlake/acpi/sleepstates.asl> - - /* Chrome OS Embedded Controller */ - Scope (_SB.PCI0.LPCB) - { - /* ACPI code for EC SuperIO functions */ - #include <ec/google/chromeec/acpi/superio.asl> - /* ACPI code for EC functions */ - #include <ec/google/chromeec/acpi/ec.asl> - } -} diff --git a/src/mainboard/google/zoombini/ec.c b/src/mainboard/google/zoombini/ec.c deleted file mode 100644 index d756444..0000000 --- a/src/mainboard/google/zoombini/ec.c +++ /dev/null @@ -1,30 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <arch/acpi.h> -#include <ec/google/chromeec/ec.h> -#include <variant/ec.h> - -void mainboard_ec_init(void) -{ - const struct google_chromeec_event_info info = { - .log_events = MAINBOARD_EC_LOG_EVENTS, - .sci_events = MAINBOARD_EC_SCI_EVENTS, - .s3_wake_events = MAINBOARD_EC_S3_WAKE_EVENTS, - .s5_wake_events = MAINBOARD_EC_S5_WAKE_EVENTS, - }; - - google_chromeec_events_init(&info, acpi_is_wakeup_s3()); -} diff --git a/src/mainboard/google/zoombini/mainboard.c b/src/mainboard/google/zoombini/mainboard.c deleted file mode 100644 index 96e1ac0..0000000 --- a/src/mainboard/google/zoombini/mainboard.c +++ /dev/null @@ -1,61 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <device/device.h> -#include <ec/ec.h> -#include <vendorcode/google/chromeos/chromeos.h> -#include <nhlt.h> -#include <arch/acpi.h> -#include <baseboard/variants.h> - -static void mainboard_init(struct device *dev) -{ - mainboard_ec_init(); -} - -static unsigned long mainboard_write_acpi_tables(struct device *device, - unsigned long current, acpi_rsdp_t *rsdp) -{ - uintptr_t start_addr; - uintptr_t end_addr; - struct nhlt *nhlt; - - start_addr = current; - - nhlt = nhlt_init(); - - if (nhlt == NULL) - return start_addr; - - variant_nhlt_init(nhlt); - - end_addr = nhlt_soc_serialize(nhlt, start_addr); - - if (end_addr != start_addr) - acpi_add_table(rsdp, (void *)start_addr); - - return end_addr; -} - -static void mainboard_enable(struct device *dev) -{ - dev->ops->init = mainboard_init; - dev->ops->acpi_inject_dsdt_generator = chromeos_dsdt_generator; - dev->ops->write_acpi_tables = mainboard_write_acpi_tables; -} - -struct chip_operations mainboard_ops = { - .enable_dev = mainboard_enable, -}; diff --git a/src/mainboard/google/zoombini/memory.c b/src/mainboard/google/zoombini/memory.c deleted file mode 100644 index 60829b1..0000000 --- a/src/mainboard/google/zoombini/memory.c +++ /dev/null @@ -1,97 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/variants.h> -#include <baseboard/gpio.h> -#include <gpio.h> -#include <soc/cnl_memcfg_init.h> - -static const struct cnl_mb_cfg baseboard_lpddr4_cfg = { - .dq_map[DDR_CH0] = { - /* - * CLK0 goes to package 0 - Bytes[3:0], - * CLK1 goes to package 1 - Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* - * Cmd CAA goes to Bytes[3:0], - * Cmd CAB goes to Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* CTL (CS) goes to all bytes */ - { 0xFF, 0x00 }, - }, - - .dq_map[DDR_CH1] = { - /* - * CLK0 goes to package 0 - Bytes[3:0], - * CLK1 goes to package 1 - Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* - * Cmd CAA goes to Bytes[3:0], - * Cmd CAB goes to Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* CTL (CS) goes to all bytes */ - { 0xFF, 0x00 }, - }, - - /* - * The dqs_map arrays map the lpddr4 pins to the SoC pins - * for both channels. - * - * the index = pin number on lpddr4 part - * the value = pin number on SoC - */ - .dqs_map[DDR_CH0] = { 3, 1, 2, 0, 7, 5, 6, 4 }, - .dqs_map[DDR_CH1] = { 3, 2, 0, 1, 7, 5, 6, 4 }, - - /* Baseboard uses three 100 Ohm rcomp resistors */ - .rcomp_resistor = { 100, 100, 100 }, - - /* - * Baseboard Rcomp target values. - * Rcomp targets for baseboard should be - * { 80, 40, 40, 40, 30 }, but we need to - * nil out rcomp targets for now to avoid bug b:70896346 - */ - .rcomp_targets = { 0, 0, 0, 0, 0 }, - - /* Baseboard is a non-interleaved design */ - .dq_pins_interleaved = 0, - - /* Disable Early Command Training */ - .ect = 0, -}; - -const struct cnl_mb_cfg *__weak variant_lpddr4_config(void) -{ - return &baseboard_lpddr4_cfg; -} - -size_t __weak variant_memory_sku(void) -{ - const gpio_t pads[] = { - [3] = GPIO_MEM_CONFIG_3, [2] = GPIO_MEM_CONFIG_2, - [1] = GPIO_MEM_CONFIG_1, [0] = GPIO_MEM_CONFIG_0, - }; - - return gpio_base2_value(pads, ARRAY_SIZE(pads)); -} diff --git a/src/mainboard/google/zoombini/ramstage.c b/src/mainboard/google/zoombini/ramstage.c deleted file mode 100644 index 7c73357..0000000 --- a/src/mainboard/google/zoombini/ramstage.c +++ /dev/null @@ -1,27 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/variants.h> -#include <soc/ramstage.h> -#include <variant/gpio.h> - -void mainboard_silicon_init_params(FSP_S_CONFIG *params) -{ - size_t num; - const struct pad_config *gpio_table; - - gpio_table = variant_gpio_table(&num); - gpio_configure_pads(gpio_table, num); -} diff --git a/src/mainboard/google/zoombini/romstage.c b/src/mainboard/google/zoombini/romstage.c deleted file mode 100644 index 4bd0ede..0000000 --- a/src/mainboard/google/zoombini/romstage.c +++ /dev/null @@ -1,29 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/variants.h> -#include <soc/cnl_memcfg_init.h> -#include <soc/romstage.h> - -void mainboard_memory_init_params(FSPM_UPD *memupd) -{ - const struct spd_info spd = { - .spd_by_index = true, - .spd_spec.spd_index = variant_memory_sku(), - }; - - cannonlake_memcfg_init(&memupd->FspmConfig, - variant_lpddr4_config(), &spd); -} diff --git a/src/mainboard/google/zoombini/smihandler.c b/src/mainboard/google/zoombini/smihandler.c deleted file mode 100644 index c9d08a5..0000000 --- a/src/mainboard/google/zoombini/smihandler.c +++ /dev/null @@ -1,39 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <cpu/x86/smm.h> -#include <ec/google/chromeec/smm.h> -#include <gpio.h> -#include <soc/gpio.h> -#include <soc/smm.h> -#include <variant/ec.h> - -void mainboard_smi_espi_handler(void) -{ - chromeec_smi_process_events(); -} - -void mainboard_smi_sleep(u8 slp_typ) -{ - chromeec_smi_sleep(slp_typ, MAINBOARD_EC_S3_WAKE_EVENTS, - MAINBOARD_EC_S5_WAKE_EVENTS); -} - -int mainboard_smi_apmc(u8 apmc) -{ - chromeec_smi_apmc(apmc, MAINBOARD_EC_SCI_EVENTS, - MAINBOARD_EC_SMI_EVENTS); - return 0; -} diff --git a/src/mainboard/google/zoombini/spd/Hynix_H9HCNNN8KUMLHR_1GB.spd.hex b/src/mainboard/google/zoombini/spd/Hynix_H9HCNNN8KUMLHR_1GB.spd.hex deleted file mode 100644 index b5da9f3..0000000 --- a/src/mainboard/google/zoombini/spd/Hynix_H9HCNNN8KUMLHR_1GB.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 11 10 0E 15 19 05 08 00 40 00 00 02 22 00 00 -00 00 05 FF 92 55 00 00 8C 00 90 A8 90 A0 05 D0 -02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 9E 00 A7 ED 8A -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/zoombini/spd/Hynix_H9HCNNNCPUMLHR_4GB.spd.hex b/src/mainboard/google/zoombini/spd/Hynix_H9HCNNNCPUMLHR_4GB.spd.hex deleted file mode 100644 index 1a6d90bc..0000000 --- a/src/mainboard/google/zoombini/spd/Hynix_H9HCNNNCPUMLHR_4GB.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 11 10 0E 16 21 95 08 00 40 00 00 0A 22 00 00 -48 00 05 FF 92 55 00 00 A0 41 90 A8 90 A0 05 D0 -02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 7A 05 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/zoombini/spd/Makefile.inc b/src/mainboard/google/zoombini/spd/Makefile.inc deleted file mode 100644 index 0aec18d..0000000 --- a/src/mainboard/google/zoombini/spd/Makefile.inc +++ /dev/null @@ -1,34 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright 2018 Google Inc. -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## - -SPD_BIN = $(obj)/spd.bin - -ifeq ($(SPD_SOURCES),) - SPD_DEPS := $(error SPD_SOURCES is not set. Variant must provide this) -else - SPD_DEPS := $(foreach f, $(SPD_SOURCES), src/mainboard/$(MAINBOARDDIR)/spd/$(f).spd.hex) -endif - -# Include spd ROM data -$(SPD_BIN): $(SPD_DEPS) - for f in $+; \ - do for c in $$(cat $$f | grep -v ^#); \ - do printf $$(printf '%o' 0x$$c); \ - done; \ - done > $@ - -cbfs-files-y += spd.bin -spd.bin-file := $(SPD_BIN) -spd.bin-type := spd diff --git a/src/mainboard/google/zoombini/spd/Micron_MT53B1024M32D4_4GB.spd.hex b/src/mainboard/google/zoombini/spd/Micron_MT53B1024M32D4_4GB.spd.hex deleted file mode 100644 index 1e28d92..0000000 --- a/src/mainboard/google/zoombini/spd/Micron_MT53B1024M32D4_4GB.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 11 10 OE 15 21 B5 08 00 40 00 00 0A 63 00 00 -51 00 05 FF D2 5D 01 00 A0 41 90 A8 90 A0 05 D0 -02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 7A 05 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/zoombini/spd/Micron_MT53B512M32D2_2GB.spd.hex b/src/mainboard/google/zoombini/spd/Micron_MT53B512M32D2_2GB.spd.hex deleted file mode 100644 index 87d0420..0000000 --- a/src/mainboard/google/zoombini/spd/Micron_MT53B512M32D2_2GB.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 11 10 OE 15 19 95 08 00 40 00 00 0A 63 00 00 -09 00 04 00 D2 5D 05 00 89 41 90 A8 90 A0 05 D0 -02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 FB 00 23 17 9B -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/zoombini/spd/Samsung_K4F6E3S4HM_2GB.spd.hex b/src/mainboard/google/zoombini/spd/Samsung_K4F6E3S4HM_2GB.spd.hex deleted file mode 100644 index f4c330a..0000000 --- a/src/mainboard/google/zoombini/spd/Samsung_K4F6E3S4HM_2GB.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 10 10 0E 15 19 95 08 00 40 00 00 02 22 00 00 -48 00 05 FF 92 55 00 00 8C 00 90 A8 90 A0 05 D0 -02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 7F 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 55 00 00 00 20 20 20 20 20 20 20 -20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/zoombini/spd/Samsung_K4F8E304HB_1GB.spd.hex b/src/mainboard/google/zoombini/spd/Samsung_K4F8E304HB_1GB.spd.hex deleted file mode 100644 index bf5e261..0000000 --- a/src/mainboard/google/zoombini/spd/Samsung_K4F8E304HB_1GB.spd.hex +++ /dev/null @@ -1,32 +0,0 @@ -23 10 10 0E 15 19 04 08 00 00 00 00 02 22 00 00 -48 00 05 0f 92 54 01 00 8A 00 90 A8 90 A0 05 D0 -02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 92 00 A7 E3 B5 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 4B 34 46 38 45 33 30 -34 48 42 2D 4D 47 43 6A 00 00 00 00 00 00 80 CE -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/zoombini/variants/baseboard/Makefile.inc b/src/mainboard/google/zoombini/variants/baseboard/Makefile.inc deleted file mode 100644 index d81101a..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/Makefile.inc +++ /dev/null @@ -1,19 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright 2017 Google Inc. -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## - -bootblock-y += gpio.c - -ramstage-y += gpio.c -ramstage-y += nhlt.c diff --git a/src/mainboard/google/zoombini/variants/baseboard/devicetree.cb b/src/mainboard/google/zoombini/variants/baseboard/devicetree.cb deleted file mode 100644 index 36c6595..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/devicetree.cb +++ /dev/null @@ -1,129 +0,0 @@ -chip soc/intel/cannonlake - - # GPE configuration - # Note that GPE events called out in ASL code rely on this - # route. i.e. If this route changes then the affected GPE - # offset bits also need to be changed. - register "gpe0_dw0" = "PMC_GPP_A" - register "gpe0_dw1" = "PMC_GPP_B" - register "gpe0_dw2" = "PMC_GPP_C" - - # EC host command ranges are in 0x800-0x8ff & 0x200-0x20f - register "gen1_dec" = "0x00fc0801" - register "gen2_dec" = "0x000c0201" - # EC memory map range is 0x900-0x9ff - register "gen3_dec" = "0x00fc0901" - - device cpu_cluster 0 on - device lapic 0 on end - end - - # FSP configuration - register "SaGv" = "3" - register "ScsEmmcHs400Enabled" = "1" - - # Intel Common SoC Config - #+-------------------+---------------------------+ - #| Field | Value | - #+-------------------+---------------------------+ - #| GSPI0 | cr50 TPM. Early init is | - #| | required to set up a BAR | - #| | for TPM communication | - #| | before memory is up | - #+-------------------+---------------------------+ - register "common_soc_config" = "{ - .gspi[0] = { - .speed_mhz = 1, - .early_init = 1, - }, - }" - - register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC0)" - register "usb2_ports[1]" = "USB2_PORT_TYPE_C(OC1)" - register "usb2_ports[2]" = "USB2_PORT_TYPE_C(OC2)" - register "usb2_ports[3]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[4]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[5]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[6]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[7]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[8]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[9]" = "USB2_PORT_TYPE_C(OC_SKIP)" - - register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC0)" - register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" - register "usb3_ports[2]" = "USB3_PORT_DEFAULT(OC0)" - register "usb3_ports[3]" = "USB3_PORT_DEFAULT(OC0)" - register "usb3_ports[4]" = "USB3_PORT_DEFAULT(OC0)" - register "usb3_ports[5]" = "USB3_PORT_DEFAULT(OC0)" - - # Enable Root port 8 (PCIe port 9) for NVMe - register "PcieRpEnable[8]" = "1" - register "PcieClkSrcUsage[3]" = "8" - register "PcieClkSrcClkReq[3]" = "3" - - device domain 0 on - device pci 00.0 on end # Host Bridge - device pci 02.0 on end # Integrated Graphics Device - device pci 04.0 on end # SA Thermal device - device pci 12.0 on end # Thermal Subsystem - device pci 12.5 off end # UFS SCS - device pci 12.6 off end # GSPI #2 - device pci 14.0 on end # USB xHCI - device pci 14.1 off end # USB xDCI (OTG) - chip drivers/intel/wifi - register "wake" = "PME_B0_EN_BIT" - device pci 14.3 on end # CNVi wifi - end - device pci 14.5 on end # SDCard - device pci 15.0 on end # I2C #0 - device pci 15.1 on end # I2C #1 - device pci 15.2 on end # I2C #2 - device pci 15.3 on end # I2C #3 - device pci 16.0 on end # Management Engine Interface 1 - device pci 16.1 off end # Management Engine Interface 2 - device pci 16.2 off end # Management Engine IDE-R - device pci 16.3 off end # Management Engine KT Redirection - device pci 16.4 off end # Management Engine Interface 3 - device pci 16.5 off end # Management Engine Interface 4 - device pci 17.0 off end # SATA - device pci 19.0 on end # I2C #4 - device pci 19.1 on end # I2C #5 - device pci 19.2 off end # UART #2 - device pci 1a.0 on end # eMMC - device pci 1c.0 on end # PCI Express Port 1 x4 SLOT1 - device pci 1c.4 on end # PCI Express Port 5 x1 SLOT2/LAN - device pci 1c.5 off end # PCI Express Port 6 - device pci 1c.6 off end # PCI Express Port 7 - device pci 1c.7 off end # PCI Express Port 8 - device pci 1d.0 on end # PCI Express Port 9 - device pci 1d.1 off end # PCI Express Port 10 - device pci 1d.2 off end # PCI Express Port 11 - device pci 1d.3 off end # PCI Express Port 12 - device pci 1d.4 off end # PCI Express Port 13 - device pci 1d.5 off end # PCI Express Port 14 - device pci 1d.6 off end # PCI Express Port 15 - device pci 1d.7 off end # PCI Express Port 16 - device pci 1e.0 on end # UART #0 - device pci 1e.1 off end # UART #1 - device pci 1e.2 on - chip drivers/spi/acpi - register "hid" = "ACPI_DT_NAMESPACE_HID" - register "compat_string" = ""google,cr50"" - register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_C12_IRQ)" - device spi 0 on end - end - end # GSPI #0 - device pci 1e.3 on end # GSPI #1 - device pci 1f.0 on - chip ec/google/chromeec - device pnp 0c09.0 on end - end - end # LPC Interface - device pci 1f.1 on end # P2SB - device pci 1f.2 on end # Power Management Controller - device pci 1f.3 on end # Intel HDA - device pci 1f.4 on end # SMBus - device pci 1f.5 on end # PCH SPI - device pci 1f.6 off end # GbE - end -end diff --git a/src/mainboard/google/zoombini/variants/baseboard/gpio.c b/src/mainboard/google/zoombini/variants/baseboard/gpio.c deleted file mode 100644 index 5447405..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/gpio.c +++ /dev/null @@ -1,279 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the - * GNU General Public License for more details. - */ - -#include <baseboard/gpio.h> -#include <baseboard/variants.h> - -/* Pad configuration in ramstage */ -static const struct pad_config gpio_table[] = { -/* RCIN# */ PAD_CFG_GPI(GPP_A0, NONE, DEEP), /* PCH_CSI_GPIO1 */ -/* ESPI_IO0 */ -/* ESPI_IO1 */ -/* ESPI_IO2 */ -/* ESPI_IO3 */ -/* ESPI_CS# */ -/* SERIRQ */ PAD_CFG_GPI(GPP_A6, NONE, DEEP), /* PCH_CSI_GPIO2 */ -/* PIRQA# */ PAD_NC(GPP_A7, NONE), /* PCH_CSI_GPIO1 */ -/* CLKRUN# */ PAD_CFG_GPI(GPP_A8, NONE, DEEP), /* EC_IN_RW_OD */ -/* ESPI_CLK */ -/* CLKOUT_LPC1 */ PAD_CFG_GPO(GPP_A10, 0, DEEP), /* PEN_RESET_ODL */ -/* PME# */ PAD_NC(GPP_A11, NONE), -/* BM_BUSY# */ PAD_CFG_GPI(GPP_A12, UP_20K, DEEP), /* FPMCU_INT */ -/* SUSWARN# */ -/* ESPI_RESET# */ -/* SUSACK# */ -/* SD_1P8_SEL */ PAD_NC(GPP_A16, NONE), -/* SD_PWR_EN# */ -/* ISH_GP0 */ PAD_CFG_GPO(GPP_A18, 0, DEEP), - /* GNSS_DISABLE_1V8_ODL */ -/* ISH_GP1 */ PAD_CFG_GPO(GPP_A19, 0, DEEP), - /* WWAN_RADIO_DISABLE_1V8_ODL */ -/* ISH_GP2 */ PAD_CFG_GPI(GPP_A20, NONE, DEEP), /* GP_INT_ODL */ -/* ISH_GP3 */ PAD_CFG_GPI(GPP_A21, NONE, DEEP), /* FPMCU_PCH_BOOT0 */ -/* ISH_GP4 */ PAD_CFG_GPI(GPP_A22, UP_20K, DEEP), /* FPMCU_INT */ -/* ISH_GP5 */ PAD_CFG_GPO(GPP_A23, 0, DEEP), /* FPMCU_RST_ODL */ -/* CORE_VID0 */ PAD_NC(GPP_B0, NONE), -/* CORE_VID1 */ PAD_NC(GPP_B1, NONE), -/* VRALERT# */ PAD_NC(GPP_B2, NONE), -/* CPU_GP2 */ PAD_NC(GPP_B3, NONE), -/* CPU_GP3 */ PAD_NC(GPP_B4, NONE), -/* SRCCLKREQ0# */ PAD_NC(GPP_B5, NONE), -/* SRCCLKREQ1# */ -/* SRCCLKREQ2# */ -/* SRCCLKREQ3# */ -/* SRCCLKREQ4# */ PAD_NC(GPP_B9, NONE), -/* SRCCLKREQ5# */ PAD_NC(GPP_B10, NONE), -/* EXT_PWR_GATE# */ -/* SLP_S0# */ -/* PLTRST# */ -/* SPKR */ PAD_NC(GPP_B14, DN_20K), /* GPP_B14_STRAP */ -#if IS_ENABLED(CONFIG_ZOOMBINI_USE_SPI_TPM) -/* GSPI0_CS# */ /* H1_SLAVE_SPI_CS_L */ -/* GSPI0_CLK */ /* H1_SLAVE_SPI_CLK_R */ -/* GSPI0_MISO */ /* H1_SLAVE_SPI_MISO_R */ -/* GSPI0_MOSI */ /* H1_SLAVE_SPI_MOSI_R */ -#else -/* GSPI0_CS# */ PAD_NC(GPP_B15, NONE), -/* GSPI0_CLK */ PAD_NC(GPP_B16, NONE), -/* GSPI0_MISO */ PAD_NC(GPP_B17, NONE), -/* GSPI0_MOSI */ PAD_NC(GPP_B18, NONE), -#endif -/* GSPI1_CS# */ -/* GSPI1_CLK */ -/* GSPI1_MISO */ -/* GSPI1_MOSI */ -/* SML1ALERT# */ PAD_NC(GPP_B23, DN_20K), /* GPP_B23_STRAP */ -/* SMBCLK */ PAD_CFG_GPO(GPP_C0, 0, DEEP), /* SOC_EDP_CABC_EN */ -/* SMBDATA */ PAD_CFG_GPI(GPP_C1, NONE, DEEP), - /* PCIE_8_WLAN_WAKE_ODL */ -/* SMBALERT# */ PAD_NC(GPP_C2, DN_20K), /* GPP_C2_STRAP - 20K_PD */ -/* SML0CLK */ PAD_CFG_GPO(GPP_C3, 0, DEEP), - /* EN_PP3300_TRACKPAD */ -/* SML0DATA */ PAD_NC(GPP_C4, NONE), -/* SML0ALERT# */ PAD_NC(GPP_C5, DN_20K), /* GPP_C5_STRAP - 20K_PD */ -/* SM1CLK */ PAD_CFG_GPI(GPP_C6, NONE, DEEP), /* PEN_PDCT_ODL */ -/* SM1DATA */ PAD_CFG_GPI(GPP_C7, NONE, DEEP), /* PEN_INT_ODL */ -/* UART0_RXD */ -/* UART0_TXD */ -/* UART0_RTS# */ PAD_NC(GPP_C10, NONE), -/* UART0_CTS# */ PAD_NC(GPP_C11, NONE), -/* UART1_RXD */ PAD_CFG_GPI_APIC(GPP_C12, NONE, DEEP, EDGE_SINGLE, - INVERT), /* H1_PCH_INT_ODL */ -/* UART1_TXD */ PAD_CFG_GPI(GPP_C13, NONE, DEEP), /* TRACKPAD_INT_ODL */ -/* UART1_RTS# */ PAD_CFG_GPI(GPP_C14, NONE, DEEP), - /* TOUCHSCREEN_INT_ODL */ -/* UART1_CTS# */ PAD_CFG_GPI(GPP_C15, NONE, DEEP), /* TRACKPAD_INT_ODL */ -/* I2C0_SDA */ -/* I2C0_SCL */ -/* I2C1_SDA */ -/* I2C1_SCL */ -/* UART2_RXD */ PAD_NC(GPP_C20, NONE), -/* UART2_TXD */ PAD_NC(GPP_C21, NONE), -/* UART2_RTS# */ PAD_NC(GPP_C22, NONE), -/* UART2_CTS# */ PAD_NC(GPP_C23, NONE), -/* SPI1_CS# */ PAD_CFG_GPI(GPP_D0, NONE, DEEP), /* PCH_MEM_STRAP3 */ -/* SPI1_CLK */ PAD_NC(GPP_D1, NONE), -/* SPI1_MISO */ PAD_NC(GPP_D2, NONE), -/* SPI1_MOSI */ PAD_CFG_GPI(GPP_D3, NONE, DEEP), /* PCH_MEM_STRAP0 */ -/* FASHTRIG */ -/* ISH_I2C0_SDA */ PAD_CFG_NF(GPP_D5, NONE, DEEP, NF1), - /* EC_I2C_SENSOR_SDA */ -/* ISH_I2C0_SCL */ PAD_CFG_NF(GPP_D6, NONE, DEEP, NF1), - /* EC_I2C_SENSOR_SCL */ -/* ISH_I2C1_SDA */ PAD_CFG_GPI(GPP_D7, NONE, DEEP), /* WWAN_SAR_INT_ODL */ -/* ISH_I2C1_SCL */ PAD_NC(GPP_D8, NONE), -/* ISH_SPI_CS# */ PAD_CFG_GPO(GPP_D9, 0, DEEP), - /* EN_PP3300_TOUCHSCREEN */ -/* ISH_SPI_CLK */ PAD_CFG_GPO(GPP_D10, 0, DEEP), /* EN_PP3300_WLAN */ -/* ISH_SPI_MISO */ PAD_CFG_GPO(GPP_D11, 0, DEEP), /* EN_PP3300_WWAN */ -/* ISH_SPI_MOSI */ PAD_CFG_GPI(GPP_D12, NONE, DEEP), /* GPP_D12_STRAP */ -/* ISH_UART0_RXD */ PAD_NC(GPP_D13, NONE), /* ISH_UART_RX */ -/* ISH_UART0_TXD */ PAD_NC(GPP_D14, NONE), /* ISH_UART_TX */ -/* ISH_UART0_RTS# */ PAD_CFG_GPO(GPP_D15, 0, DEEP), - /* TOUCHSCREEN_RST_ODL */ -/* ISH_UART0_CTS# */ PAD_CFG_GPO(GPP_D16, 0, DEEP), /* SPK_PA_EN */ -/* DMIC_CLK1 */ PAD_CFG_NF(GPP_D17, NONE, DEEP, NF1), - /* BASE_CAM_DMIC_CLK */ -/* DMIC_DATA1 */ PAD_CFG_NF(GPP_D18, NONE, DEEP, NF1), - /* BASE_CAM_DMIC_DATA */ -/* DMIC_CLK0 */ PAD_CFG_NF(GPP_D19, NONE, DEEP, NF1), - /* LID_CAM_DMIC_CLK */ -/* DMIC_DATA0 */ PAD_CFG_NF(GPP_D20, NONE, DEEP, NF1), - /* LID_CAM_DMIC_DATA */ -/* SPI1_IO2 */ PAD_CFG_GPI(GPP_D21, NONE, DEEP), /* PCH_MEM_STRAP1 */ -/* SPI1_IO3 */ PAD_CFG_GPI(GPP_D22, NONE, DEEP), /* PCH_MEM_STRAP2 */ -/* I2S_MCLK */ -/* SATAXPCI0 */ PAD_NC(GPP_E0, NONE), /* PCH_TP_1 */ -/* SATAXPCIE1 */ PAD_NC(GPP_E1, NONE), /* PCH_TP_2 */ -/* SATAXPCIE2 */ PAD_NC(GPP_E2, NONE), /* PCH_TP_3 */ -/* CPU_GP0 */ PAD_NC(GPP_E3, NONE), -/* SATA_DEVSLP0 */ PAD_CFG_GPI(GPP_E4, NONE, DEEP), - /* PCIE_7_WWAN_WAKE_ODL */ -/* SATA_DEVSLP1 */ PAD_NC(GPP_E5, NONE), -/* SATA_DEVSLP2 */ PAD_NC(GPP_E6, NONE), -/* CPU_GP1 */ PAD_NC(GPP_E7, NONE), -/* SATALED# */ PAD_NC(GPP_E8, NONE), /* PCH_TP_4 */ -/* USB2_OCO# */ -/* USB2_OC1# */ -/* USB2_OC2# */ -/* USB2_OC3# */ -/* DDPB_HPD0 */ -/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* USB_C1_HPD */ -/* DDPD_HPD2 */ -/* DDPE_HPD3 */ PAD_NC(GPP_E16, NONE), -/* EDP_HPD */ -/* DDPB_CTRLCLK */ PAD_NC(GPP_E18, NONE), -/* DDPB_CTRLDATA */ PAD_CFG_GPI(GPP_E19, DN_20K, DEEP), /* GPP_E19_STRAP */ -/* DDPC_CTRLCLK */ PAD_NC(GPP_E20, NONE), -/* DDPC_CTRLDATA */ PAD_CFG_GPI(GPP_E21, DN_20K, DEEP), /* GPP_E21_STRAP */ -/* DDPD_CTRLCLK */ PAD_NC(GPP_E22, NONE), -/* DDPD_CTRLDATA */ PAD_CFG_GPI(GPP_E23, DN_20K, DEEP), /* I2S2_SCLK */ -/* I2S2_SFRM */ PAD_CFG_GPO(GPP_F1, 0, DEEP), - /* WWAN_RESET_1V8_ODL */ -/* I2S2_TXD */ PAD_NC(GPP_F2, NONE), -/* I2S2_RXD */ PAD_CFG_GPO(GPP_F3, 0, DEEP), /* CNV_RF_RESET_L */ -/* I2C2_SDA */ -/* I2C2_SCL */ -/* I2C3_SDA */ -/* I2C3_SCL */ -/* I2C4_SDA */ -/* I2C4_SCL */ -/* I2C5_SDA */ -/* I2C5_SCL */ -/* EMMC_CMD */ -/* EMMC_DATA0 */ -/* EMMC_DATA1 */ -/* EMMC_DATA2 */ -/* EMMC_DATA3 */ -/* EMMC_DATA4 */ -/* EMMC_DATA5 */ -/* EMMC_DATA6 */ -/* EMMC_DATA7 */ -/* EMMC_RCLK */ -/* EMMC_CLK */ -/* RSVD */ PAD_NC(GPP_F23, NONE), -/* SD_CMD */ -/* SD_DATA0 */ -/* SD_DATA1 */ -/* SD_DATA2 */ -/* SD_DATA3 */ -/* SD_CD# */ -/* SD_CLK */ -/* SD_WP */ PAD_CFG_NF(GPP_G7, NONE, DEEP, NF1), /* SD_CD_ODL */ -/* I2S2_SCLK */ PAD_NC(GPP_H0, NONE), /* I2S2_SCLK - TP75 */ -/* I2S2_SFRM */ PAD_NC(GPP_H1, NONE), /* I2S2_SFRM - TP74 */ -/* I2S2_TXD */ -/* I2S2_RXD */ PAD_NC(GPP_H3, NONE), /* I2S2_PCH_RX TP76 */ -/* I2C2_SDA */ -/* I2C2_SCL */ -/* I2C3_SDA */ -/* I2C3_SCL */ -/* I2C4_SDA */ -/* I2C4_SCL */ -/* I2C5_SDA */ -/* I2C5_SCL */ -/* M2_SKT2_CFG0 */ PAD_NC(GPP_H12, NONE), /* PCH_TP_5 - TP60 */ -/* M2_SKT2_CFG1 */ PAD_NC(GPP_H13, NONE), /* PCH_TP_6 - TP61 */ -/* M2_SKT2_CFG2 */ PAD_NC(GPP_H14, NONE), /* PCH_TP_7 - TP62 */ -/* M2_SKT2_CFG3 */ PAD_NC(GPP_H15, NONE), /* PCH_TP_8 - TP63 */ -/* DDPF_CTRLCLK */ PAD_NC(GPP_H16, NONE), -/* DPPF_CTRLDATA */ PAD_NC(GPP_H17, NONE), -/* CPU_C10_GATE# */ PAD_CFG_NF(GPP_H18, NONE, DEEP, NF1), - /* CPU_C10_GATE_PCH_L */ -/* TIMESYNC0 */ PAD_NC(GPP_H19, NONE), -/* IMGCLKOUT1 */ PAD_NC(GPP_H20, NONE), -/* GPP_H21 */ PAD_CFG_GPI(GPP_H21, DN_20K, DEEP), /* H21_STRAP */ -/* GPP_H22 */ -/* GPP_H23 */ PAD_NC(GPP_H23, DN_20K), /* H23_STRAP */ - -/* BATLOW# */ -/* ACPRESENT */ PAD_NC(GPD1, NONE), -/* LAN_WAKE# */ PAD_CFG_NF(GPD2, NONE, DEEP, NF1), /* EC_PCH_WAKE_ODL */ -/* PWRBTN# */ -/* SLP_S3# */ -/* SLP_S4# */ -/* SLP_A# */ PAD_NC(GPD6, NONE), -/* RSVD */ -/* SUSCLK */ -/* SLP_WLAN# */ PAD_NC(GPD9, NONE), -/* SLP_S5# */ PAD_NC(GPD10, NONE), -/* LANPHYC */ PAD_NC(GPD11, NONE), -}; - -/* Early pad configuration in bootblock */ -static const struct pad_config early_gpio_table[] = { -#if IS_ENABLED(CONFIG_ZOOMBINI_USE_SPI_TPM) -/* GSPI0_CS# */ PAD_CFG_NF(GPP_B15, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CS_L */ -/* GSPI0_CLK */ PAD_CFG_NF(GPP_B16, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CLK */ -/* GSPI0_MISO */ PAD_CFG_NF(GPP_B17, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MISO */ -/* GSPI0_MOSI */ PAD_CFG_NF(GPP_B18, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MOSI */ -#endif -#if IS_ENABLED(CONFIG_ZOOMBINI_USE_I2C_TPM) -/* I2C5_SDA */ -/* I2C5_SCL */ -#endif -/* Ensure UART pins are in native mode for H1. */ -/* UART0_RXD */ /* UART_PCH_RX_DEBUG_TX */ -/* UART0_TXD */ /* UART_PCH_RX_DEBUG_RX */ -/* UART1_RXD */ PAD_CFG_GPI_APIC(GPP_C12, NONE, DEEP, EDGE_SINGLE, - INVERT), /* H1_PCH_INT_ODL */ -}; - -const struct pad_config *__weak variant_gpio_table(size_t *num) -{ - *num = ARRAY_SIZE(gpio_table); - return gpio_table; -} - -const struct pad_config *__weak - variant_early_gpio_table(size_t *num) -{ - *num = ARRAY_SIZE(early_gpio_table); - return early_gpio_table; -} - -static const struct cros_gpio cros_gpios[] = { - CROS_GPIO_REC_AL(CROS_GPIO_VIRTUAL, CROS_GPIO_DEVICE_NAME), -}; - -const struct cros_gpio *__weak variant_cros_gpios(size_t *num) -{ - *num = ARRAY_SIZE(cros_gpios); - return cros_gpios; -} diff --git a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/acpi/dptf.asl b/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/acpi/dptf.asl deleted file mode 100644 index aba1385..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/acpi/dptf.asl +++ /dev/null @@ -1,86 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * Copyright (C) 2015 Intel Corporation. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#define DPTF_CPU_PASSIVE 95 -#define DPTF_CPU_CRITICAL 105 -#define DPTF_CPU_ACTIVE_AC0 90 -#define DPTF_CPU_ACTIVE_AC1 80 -#define DPTF_CPU_ACTIVE_AC2 70 -#define DPTF_CPU_ACTIVE_AC3 60 -#define DPTF_CPU_ACTIVE_AC4 50 - -#define DPTF_TSR0_SENSOR_ID 0 -#define DPTF_TSR0_SENSOR_NAME "Battery" -#define DPTF_TSR0_PASSIVE 120 -#define DPTF_TSR0_CRITICAL 125 - -#define DPTF_TSR1_SENSOR_ID 1 -#define DPTF_TSR1_SENSOR_NAME "Ambient" -#define DPTF_TSR1_PASSIVE 46 -#define DPTF_TSR1_CRITICAL 75 - -#define DPTF_TSR2_SENSOR_ID 2 -#define DPTF_TSR2_SENSOR_NAME "Charger" -#define DPTF_TSR2_PASSIVE 58 -#define DPTF_TSR2_CRITICAL 90 - -#define DPTF_ENABLE_CHARGER - -/* Charger performance states, board-specific values from charger and EC */ -Name (CHPS, Package () { - Package () { 0, 0, 0, 0, 255, 0xBB8, "mA", 0 }, /* 3A (MAX) */ - Package () { 0, 0, 0, 0, 24, 0x600, "mA", 0 }, /* 1.5A */ - Package () { 0, 0, 0, 0, 16, 0x400, "mA", 0 }, /* 1.0A */ - Package () { 0, 0, 0, 0, 8, 0x200, "mA", 0 }, /* 0.5A */ - Package () { 0, 0, 0, 0, 0, 0x000, "mA", 0 }, /* 0.0A */ -}) - -Name (DTRT, Package () { - /* CPU Throttle Effect on CPU */ - Package () { _SB.PCI0.TCPU, _SB.PCI0.TCPU, 100, 100, 0, 0, 0, 0 }, - - /* CPU Effect on Temp Sensor 0 */ - Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR0, 100, 1200, 0, 0, 0, 0 }, - -#ifdef DPTF_ENABLE_CHARGER - /* Charger Effect on Temp Sensor 2 */ - Package () { _SB.DPTF.TCHG, _SB.DPTF.TSR2, 200, 300, 0, 0, 0, 0 }, -#endif - - /* CPU Effect on Temp Sensor 1 */ - Package () { _SB.PCI0.TCPU, _SB.DPTF.TSR1, 100, 150, 0, 0, 0, 0 }, -}) - -Name (MPPC, Package () -{ - 0x2, /* Revision */ - Package () { /* Power Limit 1 */ - 0, /* PowerLimitIndex, 0 for Power Limit 1 */ - 3000, /* PowerLimitMinimum */ - 12000, /* PowerLimitMaximum */ - 1000, /* TimeWindowMinimum */ - 1000, /* TimeWindowMaximum */ - 200 /* StepSize */ - }, - Package () { /* Power Limit 2 */ - 1, /* PowerLimitIndex, 1 for Power Limit 2 */ - 8000, /* PowerLimitMinimum */ - 15000, /* PowerLimitMaximum */ - 1000, /* TimeWindowMinimum */ - 1000, /* TimeWindowMaximum */ - 1000 /* StepSize */ - } -}) diff --git a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/ec.h b/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/ec.h deleted file mode 100644 index 9766c1d..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/ec.h +++ /dev/null @@ -1,82 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __BASEBOARD_EC_H__ -#define __BASEBOARD_EC_H__ - -#include <ec/ec.h> -#include <ec/google/chromeec/ec_commands.h> - -#include "gpio.h" - -#define MAINBOARD_EC_SCI_EVENTS \ - (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_CLOSED) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_OPEN) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_CONNECTED) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_AC_DISCONNECTED) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_LOW) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_CRITICAL) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_STATUS) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_THRESHOLD) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_THROTTLE_START) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_THROTTLE_STOP) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_PD_MCU) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_MODE_CHANGE) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_MKBP)) - -#define MAINBOARD_EC_SMI_EVENTS \ - (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_CLOSED)) - -/* EC can wake from S5 with lid or power button */ -#define MAINBOARD_EC_S5_WAKE_EVENTS \ - (EC_HOST_EVENT_MASK(EC_HOST_EVENT_LID_OPEN) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_POWER_BUTTON)) - -/* - * EC can wake from S3 with lid or power button or key press or - * mode change event. - */ -#define MAINBOARD_EC_S3_WAKE_EVENTS \ - (MAINBOARD_EC_S5_WAKE_EVENTS |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_KEY_PRESSED) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_MODE_CHANGE)) - -/* Log EC wake events plus EC shutdown events */ -#define MAINBOARD_EC_LOG_EVENTS \ - (EC_HOST_EVENT_MASK(EC_HOST_EVENT_THERMAL_SHUTDOWN) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_BATTERY_SHUTDOWN) |\ - EC_HOST_EVENT_MASK(EC_HOST_EVENT_PANIC)) - -/* - * ACPI related definitions for ASL code. - */ - -/* Enable EC backed ALS device in ACPI */ -#define EC_ENABLE_ALS_DEVICE - -/* Enable EC backed PD MCU device in ACPI */ -#define EC_ENABLE_PD_MCU_DEVICE - -/* Enable LID switch and provide wake pin for EC */ -#define EC_ENABLE_LID_SWITCH -#define EC_ENABLE_WAKE_PIN GPE_EC_WAKE - -#define SIO_EC_MEMMAP_ENABLE /* EC Memory Map Resources */ -#define SIO_EC_HOST_ENABLE /* EC Host Interface Resources */ - -#define EC_ENABLE_MKBP_DEVICE /* Enable cros_ec_keyb device */ - -#endif diff --git a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/gpio.h b/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/gpio.h deleted file mode 100644 index f1460d2..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/gpio.h +++ /dev/null @@ -1,39 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the - * GNU General Public License for more details. - */ - -#ifndef __BASEBOARD_GPIO_H__ -#define __BASEBOARD_GPIO_H__ - -#include <soc/gpe.h> -#include <soc/gpio.h> - -/* Memory configuration board straps */ -#define GPIO_MEM_CONFIG_0 GPP_D3 -#define GPIO_MEM_CONFIG_1 GPP_D21 -#define GPIO_MEM_CONFIG_2 GPP_D22 -#define GPIO_MEM_CONFIG_3 GPP_D0 - -/* EC in RW */ -#define GPIO_EC_IN_RW GPP_A8 - -/* BIOS Flash Write Protect */ -#define GPIO_PCH_WP GPP_H12 - -/* EC wake is LAN_WAKE# which is a special DeepSX wake pin */ -#define GPE_EC_WAKE GPE0_LAN_WAK - -/* eSPI virtual wire reporting */ -#define EC_SCI_GPI GPE0_ESPI -#endif diff --git a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/variants.h deleted file mode 100644 index e8c7c20..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/include/baseboard/variants.h +++ /dev/null @@ -1,47 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * Copyright 2017 Intel Corporation. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __BASEBOARD_VARIANTS_H__ -#define __BASEBOARD_VARIANTS_H__ - -#include <soc/cnl_memcfg_init.h> -#include <soc/gpio.h> -#include <stdint.h> -#include <vendorcode/google/chromeos/chromeos.h> - -/* Return the board id for the current variant board. */ -int variant_board_id(void); - -/* - * The next set of functions return the gpio table and fill in the number of - * entries for each table. - */ -const struct pad_config *variant_gpio_table(size_t *num); -const struct pad_config *variant_early_gpio_table(size_t *num); - -const struct cros_gpio *variant_cros_gpios(size_t *num); - -/* Return LPDDR4 configuration structure. */ -const struct cnl_mb_cfg *variant_lpddr4_config(void); - -/* Return memory SKU for the board. */ -size_t variant_memory_sku(void); - -/* Seed the NHLT tables with the board specific information. */ -struct nhlt; -void variant_nhlt_init(struct nhlt *nhlt); - -#endif /*__BASEBOARD_VARIANTS_H__ */ diff --git a/src/mainboard/google/zoombini/variants/baseboard/nhlt.c b/src/mainboard/google/zoombini/variants/baseboard/nhlt.c deleted file mode 100644 index 84c1ec5..0000000 --- a/src/mainboard/google/zoombini/variants/baseboard/nhlt.c +++ /dev/null @@ -1,52 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Intel Corp. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/variants.h> -#include <console/console.h> -#include <nhlt.h> -#include <soc/nhlt.h> - -void __weak variant_nhlt_init(struct nhlt *nhlt) -{ - /* 1-dmic configuration */ - if (IS_ENABLED(CONFIG_NHLT_DMIC_1CH_16B) && - !nhlt_soc_add_dmic_array(nhlt, 1)) - printk(BIOS_DEBUG, "Added 1CH DMIC array.\n"); - /* 2-dmic configuration */ - if (IS_ENABLED(CONFIG_NHLT_DMIC_2CH_16B) && - !nhlt_soc_add_dmic_array(nhlt, 2)) - printk(BIOS_DEBUG, "Added 2CH DMIC array.\n"); - /* 4-dmic configuration */ - if (IS_ENABLED(CONFIG_NHLT_DMIC_4CH_16B) && - !nhlt_soc_add_dmic_array(nhlt, 4)) - printk(BIOS_DEBUG, "Added 4CH DMIC array.\n"); - - - if (IS_ENABLED(CONFIG_INCLUDE_SND_MAX98357_DA7219_NHLT)) { - /* Dialog for Headset codec. Headset codec is bi-directional - but uses the same configuration settings for render and - capture endpoints. */ - if (!nhlt_soc_add_da7219(nhlt, AUDIO_LINK_SSP2)) - printk(BIOS_DEBUG, "Added Dialog_7219 codec.\n"); - - /* MAXIM Smart Amps for left and right speakers. */ - if (!nhlt_soc_add_max98357(nhlt, AUDIO_LINK_SSP1)) - printk(BIOS_DEBUG, "Added Maxim_98357 codec.\n"); - } - - if (IS_ENABLED(CONFIG_INCLUDE_SND_MAX98373_NHLT) && - !nhlt_soc_add_max98373(nhlt, AUDIO_LINK_SSP1)) - printk(BIOS_DEBUG, "Added Maxim_98373 codec.\n"); -} diff --git a/src/mainboard/google/zoombini/variants/meowth/Makefile.inc b/src/mainboard/google/zoombini/variants/meowth/Makefile.inc deleted file mode 100644 index 38653f1..0000000 --- a/src/mainboard/google/zoombini/variants/meowth/Makefile.inc +++ /dev/null @@ -1,25 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright 2018 Google Inc. -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## - -SPD_SOURCES = Samsung_K4F8E304HB_1GB # 0b000 -SPD_SOURCES += Hynix_H9HCNNN8KUMLHR_1GB # 0b001 -SPD_SOURCES += Samsung_K4F6E3S4HM_2GB # 0b010 -SPD_SOURCES += Hynix_H9HCNNNCPUMLHR_4GB # 0b011 - -bootblock-y += gpio.c - -romstage-y += memory.c - -ramstage-y += gpio.c diff --git a/src/mainboard/google/zoombini/variants/meowth/devicetree.cb b/src/mainboard/google/zoombini/variants/meowth/devicetree.cb deleted file mode 100644 index b014353..0000000 --- a/src/mainboard/google/zoombini/variants/meowth/devicetree.cb +++ /dev/null @@ -1,204 +0,0 @@ -chip soc/intel/cannonlake - - # Deep Sx states - register "deep_s3_enable_ac" = "0" - register "deep_s3_enable_dc" = "0" - register "deep_s5_enable_ac" = "1" - register "deep_s5_enable_dc" = "1" - - # Debug Option - register "DebugConsent" = "DebugConsent_Disabled" - - # GPE configuration - # Note that GPE events called out in ASL code rely on this - # route. i.e. If this route changes then the affected GPE - # offset bits also need to be changed. - register "gpe0_dw0" = "PMC_GPP_A" - register "gpe0_dw1" = "PMC_GPP_B" - register "gpe0_dw2" = "PMC_GPP_C" - - # EC host command ranges are in 0x800-0x8ff & 0x200-0x20f - register "gen1_dec" = "0x00fc0801" - register "gen2_dec" = "0x000c0201" - # EC memory map range is 0x900-0x9ff - register "gen3_dec" = "0x00fc0901" - - device cpu_cluster 0 on - device lapic 0 on end - end - - # FSP configuration - register "SaGv" = "SaGv_Enabled" - register "ScsEmmcHs400Enabled" = "1" - - # Intel Common SoC Config - #+-------------------+---------------------------+ - #| Field | Value | - #+-------------------+---------------------------+ - #| GSPI0 | cr50 TPM. Early init is | - #| | required to set up a BAR | - #| | for TPM communication | - #| | before memory is up | - #| I2C0 | Touchscreen Digitizer | - #+-------------------+---------------------------+ - register "common_soc_config" = "{ - .gspi[0] = { - .speed_mhz = 1, - .early_init = 1, - }, - .i2c[0] = { - .speed = I2C_SPEED_FAST_PLUS, - .rise_time_ns = 98, - .fall_time_ns = 38, - }, - }" - - register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC2)" - register "usb2_ports[1]" = "USB2_PORT_TYPE_C(OC3)" - register "usb2_ports[2]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[3]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[4]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[5]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[6]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[7]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[8]" = "USB2_PORT_TYPE_C(OC_SKIP)" - register "usb2_ports[9]" = "USB2_PORT_TYPE_C(OC_SKIP)" - - register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC2)" - register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC3)" - - register "PchHdaDspEnable" = "1" - register "PchHdaAudioLinkSsp0" = "1" - register "PchHdaAudioLinkSsp1" = "1" - - # Enable cpufreq - register "speed_shift_enable" = "1" - - # Enable Root port 8 (PCIe port 9) for NVMe - register "PcieRpEnable[8]" = "1" - register "PcieClkSrcUsage[3]" = "8" - register "PcieClkSrcClkReq[3]" = "3" - - # Enable S0ix - register "s0ix_enable" = "1" - - device domain 0 on - device pci 00.0 on end # Host Bridge - device pci 02.0 on end # Integrated Graphics Device - device pci 04.0 on end # SA Thermal device - device pci 12.0 on end # Thermal Subsystem - device pci 12.5 off end # UFS SCS - device pci 12.6 off end # GSPI #2 - device pci 14.0 on end # USB xHCI - device pci 14.1 off end # USB xDCI (OTG) - chip drivers/intel/wifi - register "wake" = "PME_B0_EN_BIT" - device pci 14.3 on end # CNVi wifi - end - device pci 14.5 off end # SDCard - device pci 15.0 on - chip drivers/i2c/hid - register "generic.hid" = ""WCOM50C1"" - register "generic.desc" = ""WCOM Digitizer"" - register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C14_IRQ)" - register "generic.speed" = "I2C_SPEED_FAST_PLUS" - register "hid_desc_reg_offset" = "0x1" - device i2c 0a on end - end - end # I2C #0 - device pci 15.1 on - chip drivers/i2c/generic - register "hid" = ""STH9310"" - register "name" = ""SEMTECH SX9310"" - register "desc" = ""Left SAR Proximity Sensor"" - register "irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C3_IRQ)" - register "speed" = "I2C_SPEED_FAST_PLUS" - register "uid" = "1" - device i2c 28 on end - end - end # I2C #1 - device pci 15.2 on end # I2C #2 - device pci 15.3 on - chip drivers/i2c/max98373 - register "vmon_slot_no" = "4" - register "imon_slot_no" = "5" - register "uid" = "0" - register "desc" = ""RIGHT SPEAKER AMP"" - register "name" = ""MAXR"" - device i2c 31 on end - end - chip drivers/i2c/max98373 - register "vmon_slot_no" = "6" - register "imon_slot_no" = "7" - register "uid" = "1" - register "desc" = ""LEFT SPEAKER AMP"" - register "name" = ""MAXL"" - device i2c 32 on end - end - end # I2C #3 - device pci 16.0 on end # Management Engine Interface 1 - device pci 16.1 off end # Management Engine Interface 2 - device pci 16.2 off end # Management Engine IDE-R - device pci 16.3 off end # Management Engine KT Redirection - device pci 16.4 off end # Management Engine Interface 3 - device pci 16.5 off end # Management Engine Interface 4 - device pci 17.0 off end # SATA - device pci 19.0 on end # I2C #4 - device pci 19.1 on - chip drivers/i2c/generic - register "hid" = ""STH9310"" - register "name" = ""SEMTECH SX9310"" - register "desc" = ""Right SAR Proximity Sensor"" - register "irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C4_IRQ)" - register "speed" = "I2C_SPEED_FAST_PLUS" - register "uid" = "0" - device i2c 28 on end - end - end # I2C #5 - device pci 19.2 on end # UART #2 - device pci 1a.0 on end # eMMC - device pci 1c.0 on end # PCI Express Port 1 x4 SLOT1 - device pci 1c.4 on end # PCI Express Port 5 x1 SLOT2/LAN - device pci 1c.5 off end # PCI Express Port 6 - device pci 1c.6 off end # PCI Express Port 7 - device pci 1c.7 off end # PCI Express Port 8 - device pci 1d.0 on end # PCI Express Port 9 - device pci 1d.1 off end # PCI Express Port 10 - device pci 1d.2 off end # PCI Express Port 11 - device pci 1d.3 off end # PCI Express Port 12 - device pci 1d.4 off end # PCI Express Port 13 - device pci 1d.5 off end # PCI Express Port 14 - device pci 1d.6 off end # PCI Express Port 15 - device pci 1d.7 off end # PCI Express Port 16 - device pci 1e.0 on end # UART #0 - device pci 1e.1 off end # UART #1 - device pci 1e.2 on - chip drivers/spi/acpi - register "hid" = "ACPI_DT_NAMESPACE_HID" - register "compat_string" = ""google,cr50"" - register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_C12_IRQ)" - device spi 0 on end - end - end # GSPI #0 - device pci 1e.3 on - chip drivers/spi/acpi - register "hid" = "ACPI_DT_NAMESPACE_HID" - register "uid" = "1" - register "compat_string" = ""google,cros-ec-spi"" - register "irq" = "ACPI_IRQ_LEVEL_LOW(GPP_A22_IRQ)" - device spi 0 on end - end - end # GSPI #1 - device pci 1f.0 on - chip ec/google/chromeec - device pnp 0c09.0 on end - end - end # LPC Interface - device pci 1f.1 on end # P2SB - device pci 1f.2 on end # Power Management Controller - device pci 1f.3 on end # Intel HDA - device pci 1f.4 on end # SMBus - device pci 1f.5 on end # PCH SPI - device pci 1f.6 off end # GbE - end -end diff --git a/src/mainboard/google/zoombini/variants/meowth/gpio.c b/src/mainboard/google/zoombini/variants/meowth/gpio.c deleted file mode 100644 index 0f356e4..0000000 --- a/src/mainboard/google/zoombini/variants/meowth/gpio.c +++ /dev/null @@ -1,289 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the - * GNU General Public License for more details. - */ - -#include <baseboard/gpio.h> -#include <baseboard/variants.h> - -/* Pad configuration in ramstage */ -static const struct pad_config gpio_table[] = { -/* RCIN# */ PAD_NC(GPP_A0, NONE), /* PCH_CSI_GPIO1 */ -/* ESPI_IO0 */ PAD_CFG_NF(GPP_A1, NONE, DEEP, NF2), /* ESPI_IO0_R */ -/* ESPI_IO1 */ PAD_CFG_NF(GPP_A2, NONE, DEEP, NF2), /* ESPI_IO0_R */ -/* ESPI_IO2 */ PAD_CFG_NF(GPP_A3, NONE, DEEP, NF2), /* ESPI_IO2_R */ -/* ESPI_IO3 */ PAD_CFG_NF(GPP_A4, NONE, DEEP, NF2), /* ESPI_IO3_R */ -/* ESPI_CS# */ PAD_CFG_NF(GPP_A5, NONE, DEEP, NF2), /* ESPI_CS_L */ -/* SERIRQ */ PAD_NC(GPP_A6, NONE), -/* PIRQA# */ PAD_NC(GPP_A7, NONE), -/* CLKRUN# */ PAD_CFG_GPI(GPP_A8, NONE, DEEP), /* EC_IN_RW_OD */ -/* ESPI_CLK */ PAD_CFG_NF(GPP_A9, NONE, DEEP, NF2), /* ESPI_CLK_R */ -/* CLKOUT_LPC1 */ PAD_NC(GPP_A10, NONE), -/* PME# */ PAD_CFG_GPO(GPP_A11, 1, DEEP), /* PCH_FP_PWR_EN */ -/* BM_BUSY# */ PAD_CFG_GPI(GPP_A12, NONE, DEEP), /* FPMCU_INT */ -/* SUSWARN# */ PAD_CFG_NF(GPP_A13, NONE, DEEP, NF1), /* SUSWARN_L */ -/* ESPI_RESET# */ PAD_CFG_NF(GPP_A14, NONE, DEEP, NF2), /* ESPI_RESET_L */ -/* SUSACK# */ PAD_CFG_NF(GPP_A15, NONE, DEEP, NF1), /* SUSACK_L */ -/* SD_1P8_SEL */ PAD_NC(GPP_A16, NONE), -/* SD_PWR_EN# */ PAD_CFG_NF(GPP_A17, NONE, DEEP, NF1), -/* ISH_GP0 */ PAD_NC(GPP_A18, NONE), -/* ISH_GP1 */ PAD_NC(GPP_A19, NONE), -/* ISH_GP2 */ PAD_NC(GPP_A20, NONE), -/* ISH_GP3 */ PAD_CFG_GPO(GPP_A21, 0, DEEP), /* PCH_FPMCU_BOOT0 */ -/* ISH_GP4 */ PAD_CFG_GPI_APIC(GPP_A22, NONE, DEEP, LEVEL, - NONE), /* FPMCU_INT */ -/* ISH_GP5 */ PAD_CFG_GPO(GPP_A23, 1, DEEP), /* PCH_FPMCU_RST_ODL */ -/* CORE_VID0 */ PAD_CFG_NF(GPP_B0, NONE, DEEP, NF1), /* CORE_VID0 */ -/* CORE_VID1 */ PAD_CFG_NF(GPP_B1, NONE, DEEP, NF1), /* CORE_VID1 */ -/* VRALERT# */ PAD_NC(GPP_B2, NONE), -/* CPU_GP2 */ PAD_NC(GPP_B3, NONE), -/* CPU_GP3 */ PAD_NC(GPP_B4, NONE), -/* SRCCLKREQ0# */ PAD_NC(GPP_B5, NONE), -/* SRCCLKREQ1# */ PAD_NC(GPP_B6, NONE), -/* SRCCLKREQ2# */ PAD_NC(GPP_B7, NONE), -/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, - NF1), /* PCIE_NVME_CLKREQ_ODL */ -/* SRCCLKREQ4# */ PAD_NC(GPP_B9, NONE), -/* SRCCLKREQ5# */ PAD_NC(GPP_B10, NONE), -/* EXT_PWR_GATE# */ -/* SLP_S0# */ PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), /* SLP_SO_L */ -/* PLTRST# */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), /* PLT_RST_L */ -/* SPKR */ PAD_CFG_GPI(GPP_B14, NONE, DEEP), /* GPP_B14_STRAP */ -#if IS_ENABLED(CONFIG_ZOOMBINI_USE_SPI_TPM) -/* GSPI0_CS# */ PAD_CFG_NF(GPP_B15, NONE, DEEP, - NF1), /* H1_SLAVE_SPI_CS_L */ -/* GSPI0_CLK */ PAD_CFG_NF(GPP_B16, NONE, DEEP, - NF1), /* H1_SLAVE_SPI_CLK */ -/* GSPI0_MISO */ PAD_CFG_NF(GPP_B17, NONE, DEEP, - NF1), /* H1_SLAVE_SPI_MISO_R */ -/* GSPI0_MOSI */ PAD_CFG_NF(GPP_B18, NONE, DEEP, - NF1), /* H1_SLAVE_SPI_MOSI_R */ -#else -/* GSPI0_CS# */ PAD_NC(GPP_B15, NONE), -/* GSPI0_CLK */ PAD_NC(GPP_B16, NONE), -/* GSPI0_MISO */ PAD_NC(GPP_B17, NONE), -/* GSPI0_MOSI */ PAD_NC(GPP_B18, NONE), -#endif -/* GSPI1_CS# */ PAD_CFG_NF(GPP_B19, NONE, DEEP, - NF1), /* PCH_FPMCU_SPI_CS_L */ -/* GSPI1_CLK */ PAD_CFG_NF(GPP_B20, NONE, DEEP, - NF1), /* PCH_FPMCU_SPI_CLK */ -/* GSPI1_MISO */ PAD_CFG_NF(GPP_B21, NONE, DEEP, - NF1), /* PCH_FPMCU_SPI_MISO_R */ -/* GSPI1_MOSI */ PAD_CFG_NF(GPP_B22, NONE, DEEP, - NF1), /* PCH_FPMCU_SPI_MOSI_R */ -/* SML1ALERT# */ PAD_CFG_GPI(GPP_B23, NONE, DEEP), /* GPP_B23_STRAP */ -/* SMBCLK */ PAD_NC(GPP_C0, NONE), -/* SMBDATA */ PAD_NC(GPP_C1, NONE), -/* SMBALERT# */ PAD_CFG_GPI(GPP_C2, NONE, DEEP), /* GPP_C2_STRAP */ -/* SML0CLK */ PAD_CFG_GPI_APIC(GPP_C3, NONE, DEEP, LEVEL, - NONE), /* PCH_SAR1_INT_L */ -/* SML0DATA */ PAD_CFG_GPI_APIC(GPP_C4, NONE, DEEP, LEVEL, - NONE), /* PCH_SAR0_INT_L */ -/* SML0ALERT# */ PAD_CFG_GPI(GPP_C5, NONE, DEEP), /* GPP_C5_STRAP */ -/* SM1CLK */ PAD_NC(GPP_C6, NONE), -/* SM1DATA */ PAD_NC(GPP_C7, NONE), -/* UART0_RXD */ PAD_CFG_NF(GPP_C8, NONE, DEEP, - NF1), /* UART_PCH_RX_DEBUG_TX */ -/* UART0_TXD */ PAD_CFG_NF(GPP_C9, NONE, DEEP, - NF1), /* UART_PCH_TX_DEBUG_RX */ -/* UART0_RTS# */ PAD_CFG_GPO(GPP_C10, 1, DEEP), /* PP3300_TOUCH_EN */ -/* UART0_CTS# */ PAD_NC(GPP_C11, NONE), -/* Only P0 boards need an internal pullup */ -/* UART1_RXD */ PAD_CFG_GPI_APIC(GPP_C12, UP_20K, DEEP, EDGE_SINGLE, - INVERT), /* H1_PCH_INT_ODL */ -/* UART1_TXD */ PAD_NC(GPP_C13, NONE), -/* UART1_RTS# */ PAD_CFG_GPI_APIC(GPP_C14, NONE, DEEP, LEVEL, - NONE), /* TOUCHSCREEN_INT_ODL */ -/* UART1_CTS# */ PAD_NC(GPP_C15, NONE), -/* I2C0_SDA */ PAD_CFG_NF(GPP_C16, NONE, DEEP, - NF1), /* PCH_TOUCHSCREEN_I2C0_SDA */ -/* I2C0_SCL */ PAD_CFG_NF(GPP_C17, NONE, DEEP, - NF1), /* PCH_TOUCHSCREEN_I2C0_SCL */ -/* I2C1_SDA */ PAD_CFG_NF(GPP_C18, NONE, DEEP, - NF1), /* PCH_DISPLAY_SAR1_I2C1_SDA */ -/* I2C1_SCL */ PAD_CFG_NF(GPP_C19, NONE, DEEP, - NF1), /* PCH_DISPLAY_SAR1_I2C1_SCL */ -/* UART2_RXD */ PAD_NC(GPP_C20, NONE), -/* UART2_TXD */ PAD_NC(GPP_C21, NONE), -/* UART2_RTS# */ PAD_NC(GPP_C22, NONE), -/* UART2_CTS# */ PAD_NC(GPP_C23, NONE), -/* SPI1_CS# */ PAD_CFG_GPI(GPP_D0, NONE, DEEP), /* PCH_MEM_STRAP3 */ -/* SPI1_CLK */ PAD_NC(GPP_D1, NONE), -/* SPI1_MISO */ PAD_NC(GPP_D2, NONE), -/* SPI1_MOSI */ PAD_CFG_GPI(GPP_D3, NONE, DEEP), /* PCH_MEM_STRAP0 */ -/* FASHTRIG */ PAD_CFG_NF(GPP_D4, NONE, DEEP, NF1), /* FCAM_MCLK */ -/* ISH_I2C0_SDA */ PAD_NC(GPP_D5, NONE), -/* ISH_I2C0_SCL */ PAD_NC(GPP_D6, NONE), -/* ISH_I2C1_SDA */ PAD_CFG_GPO(GPP_D7, 1, DEEP), /* FCAM_RST_L */ -/* ISH_I2C1_SCL */ PAD_CFG_GPO(GPP_D8, 1, DEEP), /* DMIC_PWR_EN */ -/* ISH_SPI_CS# */ PAD_NC(GPP_D9, NONE), -/* ISH_SPI_CLK */ PAD_CFG_GPO(GPP_D10, 0, DEEP), /* FCAM_PWR_EN */ -/* ISH_SPI_MISO */ PAD_NC(GPP_D11, NONE), -/* ISH_SPI_MOSI */ PAD_CFG_GPI(GPP_D12, NONE, DEEP), /* GPP_D12_STRAP */ -/* ISH_UART0_RXD */ PAD_NC(GPP_D13, NONE), /* ISH_UART_RX */ -/* ISH_UART0_TXD */ PAD_NC(GPP_D14, NONE), /* ISH_UART_TX */ -/* ISH_UART0_RTS# */ PAD_CFG_GPO(GPP_D15, 1, DEEP), /* TOUCHSCREEN_RST_ODL */ -/* ISH_UART0_CTS# */ PAD_CFG_GPO(GPP_D16, 1, DEEP), /* SPKR_HWRST_L */ -/* DMIC_CLK1 */ PAD_CFG_NF(GPP_D17, NONE, DEEP, - NF1), /* DB0_PCH_DMIC_CLK_R */ -/* DMIC_DATA1 */ PAD_CFG_NF(GPP_D18, NONE, DEEP, - NF1), /* DB0TX_PCHRX_DMIC_DATA */ -/* DMIC_CLK0 */ PAD_NC(GPP_D19, NONE), -/* DMIC_DATA0 */ PAD_NC(GPP_D20, NONE), -/* SPI1_IO2 */ PAD_CFG_GPI(GPP_D21, NONE, DEEP), /* PCH_MEM_STRAP1 */ -/* SPI1_IO3 */ PAD_CFG_GPI(GPP_D22, NONE, DEEP), /* PCH_MEM_STRAP2 */ -/* I2S_MCLK */ -/* SATAXPCI0 */ PAD_CFG_GPO(GPP_E0, 0, DEEP), /* RCAM_PWR_EN */ -/* SATAXPCIE1 */ PAD_CFG_GPO(GPP_E1, 1, DEEP), /* RCAM_RST_L */ -/* SATAXPCIE2 */ PAD_NC(GPP_E2, NONE), -/* CPU_GP0 */ PAD_NC(GPP_E3, NONE), -/* SATA_DEVSLP0 */ PAD_NC(GPP_E4, NONE), -/* SATA_DEVSLP1 */ PAD_NC(GPP_E5, NONE), -/* SATA_DEVSLP2 */ PAD_NC(GPP_E6, NONE), -/* CPU_GP1 */ PAD_NC(GPP_E7, NONE), -/* SATALED# */ PAD_NC(GPP_E8, NONE), -/* USB2_OCO# */ PAD_NC(GPP_E9, NONE), -/* USB2_OC1# */ PAD_NC(GPP_E10, NONE), -/* USB2_OC2# */ PAD_CFG_NF(GPP_E11, NONE, DEEP, - NF1), /* USB_C0_OC_ODL */ -/* USB2_OC3# */ PAD_CFG_NF(GPP_E12, NONE, DEEP, - NF1), /* USB_C1_OC_ODL */ -/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, - NF1), /* EC_USB_C0_HPD */ -/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, - NF1), /* EC_USB_C1_HPD */ -/* DDPD_HPD2 */ PAD_CFG_NF(GPP_E15, NONE, DEEP, - NF1), /* EC_USB_C2_HPD */ -/* DDPE_HPD3 */ PAD_NC(GPP_E16, NONE), -/* EDP_HPD */ -/* DDPB_CTRLCLK */ PAD_NC(GPP_E18, NONE), -/* DDPB_CTRLDATA */ PAD_CFG_GPI(GPP_E19, NONE, DEEP), /* GPP_E19_STRAP */ -/* DDPC_CTRLCLK */ PAD_NC(GPP_E20, NONE), -/* DDPC_CTRLDATA */ PAD_CFG_GPI(GPP_E21, NONE, DEEP), /* GPP_E21_STRAP */ -/* DDPD_CTRLCLK */ PAD_NC(GPP_E22, NONE), -/* DDPD_CTRLDATA */ PAD_CFG_GPI(GPP_E23, NONE, DEEP), /* GPP_E23_STRAP */ -/* I2S2_SFRM */ PAD_CFG_GPO(GPP_F1, 0, DEEP), - /* WWAN_RESET_1V8_ODL */ -/* I2S2_TXD */ PAD_NC(GPP_F2, NONE), -/* I2S2_RXD */ PAD_NC(GPP_F3, NONE), -/* I2C2_SDA */ PAD_CFG_NF(GPP_F4, NONE, DEEP, NF1), /* CNV_BRI_DT_R */ -/* I2C2_SCL */ PAD_CFG_NF(GPP_F5, NONE, DEEP, NF1), /* CNV_BRI_RSP */ -/* I2C3_SDA */ PAD_CFG_NF(GPP_F6, NONE, DEEP, NF1), /* CNV_RGI_DT_R */ -/* I2C3_SCL */ PAD_CFG_NF(GPP_F7, NONE, DEEP, NF1), /* CNV_RGI_RSP */ -/* I2C4_SDA */ PAD_NC(GPP_F8, NONE), -/* I2C4_SCL */ PAD_NC(GPP_F9, NONE), -/* I2C5_SDA */ PAD_CFG_GPI(GPP_F10, NONE, - DEEP), /* OPVR_MCIVR_BREAK_L */ -/* I2C5_SCL */ PAD_CFG_NF(GPP_F11, NONE, DEEP, NF1), /* EMMC_CMD */ -/* EMMC_CMD */ PAD_CFG_NF(GPP_F12, NONE, DEEP, NF1), /* EMMC_DAT0 */ -/* EMMC_DATA0 */ PAD_CFG_NF(GPP_F13, NONE, DEEP, NF1), /* EMMC_DAT1 */ -/* EMMC_DATA1 */ PAD_CFG_NF(GPP_F14, NONE, DEEP, NF1), /* EMMC_DAT2 */ -/* EMMC_DATA2 */ PAD_CFG_NF(GPP_F15, NONE, DEEP, NF1), /* EMMC_DAT3 */ -/* EMMC_DATA3 */ PAD_CFG_NF(GPP_F16, NONE, DEEP, NF1), /* EMMC_DAT4 */ -/* EMMC_DATA4 */ PAD_CFG_NF(GPP_F17, NONE, DEEP, NF1), /* EMMC_DAT5 */ -/* EMMC_DATA5 */ PAD_CFG_NF(GPP_F18, NONE, DEEP, NF1), /* EMMC_DAT6 */ -/* EMMC_DATA6 */ PAD_CFG_NF(GPP_F19, NONE, DEEP, NF1), /* EMMC_DAT7 */ -/* EMMC_DATA7 */ PAD_CFG_NF(GPP_F20, NONE, DEEP, NF1), /* EMMC_RCLK */ -/* EMMC_RCLK */ PAD_CFG_NF(GPP_F21, NONE, DEEP, NF1), /* EMMC_CLK */ -/* EMMC_CLK */ PAD_CFG_NF(GPP_F22, NONE, DEEP, NF1), /* EMMC_RST_ODL */ -/* RSVD */ -/* SD_CMD */ PAD_NC(GPP_G0, NONE), -/* SD_DATA0 */ PAD_NC(GPP_G1, NONE), -/* SD_DATA1 */ PAD_NC(GPP_G2, NONE), -/* SD_DATA2 */ PAD_NC(GPP_G3, NONE), -/* SD_DATA3 */ PAD_NC(GPP_G4, NONE), -/* SD_CD# */ PAD_NC(GPP_G5, NONE), -/* SD_CLK */ PAD_NC(GPP_G6, NONE), -/* SD_WP */ PAD_NC(GPP_G7, NONE), -/* I2S2_SCLK */ PAD_NC(GPP_H0, NONE), -/* I2S2_SFRM */ PAD_CFG_NF(GPP_H1, NONE, DEEP, - NF3), /* CNV_RF_RESET_L */ -/* I2S2_TXD */ PAD_CFG_NF(GPP_H2, NONE, DEEP, NF3), /* WLAN_CLKREQ0 */ -/* I2S2_RXD */ PAD_NC(GPP_H3, NONE), -/* I2C2_SDA */ PAD_NC(GPP_H4, NONE), -/* I2C2_SCL */ PAD_NC(GPP_H5, NONE), -/* I2C3_SDA */ PAD_CFG_NF(GPP_H6, NONE, DEEP, - NF1), /* PCH_AUDIO_I2C3_SDA */ -/* I2C3_SCL */ PAD_CFG_NF(GPP_H7, NONE, DEEP, - NF1), /* PCH_AUDIO_I2C3_SCL */ -/* I2C4_SDA */ PAD_CFG_NF(GPP_H8, NONE, DEEP, - NF1), /* PCH_FCAM_I2C4_SDA */ -/* I2C4_SCL */ PAD_CFG_NF(GPP_H9, NONE, DEEP, - NF1), /* PCH_FCAM_I2C4_SCL */ -/* I2C5_SDA */ PAD_CFG_NF(GPP_H10, NONE, DEEP, - NF1), /* PCH_RCAM_SAR0_I2C5_SDA */ -/* I2C5_SCL */ PAD_CFG_NF(GPP_H11, NONE, DEEP, - NF1), /* PCH_RCAM_SAR0_I2C5_SCL */ -/* M2_SKT2_CFG0 */ PAD_CFG_GPI(GPP_H12, NONE, DEEP), /* PCH_WP_OD */ -/* M2_SKT2_CFG1 */ PAD_NC(GPP_H13, NONE), -/* M2_SKT2_CFG2 */ PAD_NC(GPP_H14, NONE), -/* M2_SKT2_CFG3 */ PAD_NC(GPP_H15, NONE), -/* DDPF_CTRLCLK */ -/* DPPF_CTRLDATA */ -/* CPU_C10_GATE# */ PAD_CFG_NF(GPP_H18, NONE, DEEP, - NF1), /* CPU_C10_GATE_PCH_L */ -/* TIMESYNC0 */ PAD_NC(GPP_H19, NONE), -/* IMGCLKOUT1 */ PAD_CFG_NF(GPP_H20, NONE, DEEP, NF1), /* RCAM_MCLK */ -/* GPP_H21 */ PAD_CFG_GPI(GPP_H21, NONE, DEEP), /* H21_STRAP */ -/* GPP_H22 */ PAD_NC(GPP_H22, NONE), -/* GPP_H23 */ PAD_CFG_GPI(GPP_H23, NONE, DEEP), /* GPP_H23 */ - -/* BATLOW# */ PAD_CFG_NF(GPD0, NONE, DEEP, NF1), /* BATLOW_L */ -/* ACPRESENT */ PAD_NC(GPD1, NONE), -/* LAN_WAKE# */ PAD_CFG_NF(GPD2, NONE, DEEP, NF1), /* EC_PCH_WAKE_ODL */ -/* PWRBTN# */ PAD_CFG_NF(GPD3, NONE, DEEP, - NF1), /* EC_PCH_PWR_BTN_ODL */ -/* SLP_S3# */ PAD_CFG_NF(GPD4, NONE, DEEP, NF1), /* SLP_S3_L */ -/* SLP_S4# */ PAD_CFG_NF(GPD5, NONE, DEEP, NF1), /* SLP_S4_L */ -/* SLP_A# */ PAD_NC(GPD6, NONE), -/* RSVD */ PAD_CFG_GPI(GPD7, NONE, DEEP), /* DPD7_Strap */ -/* SUSCLK */ PAD_CFG_NF(GPD8, NONE, DEEP, NF1), /* PCH_SUSCLK */ -/* SLP_WLAN# */ PAD_NC(GPD9, NONE), -/* SLP_S5# */ PAD_NC(GPD10, NONE), -/* LANPHYC */ PAD_NC(GPD11, NONE), -}; - -/* Early pad configuration in bootblock */ -static const struct pad_config early_gpio_table[] = { -#if IS_ENABLED(CONFIG_ZOOMBINI_USE_SPI_TPM) -/* GSPI0_CS# */ PAD_CFG_NF(GPP_B15, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CS_L */ -/* GSPI0_CLK */ PAD_CFG_NF(GPP_B16, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CLK */ -/* GSPI0_MISO */ PAD_CFG_NF(GPP_B17, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MISO */ -/* GSPI0_MOSI */ PAD_CFG_NF(GPP_B18, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MOSI */ -#else -/* GSPI0_CS# */ PAD_NC(GPP_B15, NONE), -/* GSPI0_CLK */ PAD_NC(GPP_B16, NONE), -/* GSPI0_MISO */ PAD_NC(GPP_B17, NONE), -/* GSPI0_MOSI */ PAD_NC(GPP_B18, NONE), -#endif -/* Only P0 boards need an internal pullup */ -/* UART1_RXD */ PAD_CFG_GPI_APIC(GPP_C12, UP_20K, DEEP, EDGE_SINGLE, - INVERT), /* H1_PCH_INT_ODL */ -}; - -const struct pad_config *variant_gpio_table(size_t *num) -{ - *num = ARRAY_SIZE(gpio_table); - return gpio_table; -} - -const struct pad_config *variant_early_gpio_table(size_t *num) -{ - *num = ARRAY_SIZE(early_gpio_table); - return early_gpio_table; -} diff --git a/src/mainboard/google/zoombini/variants/meowth/include/variant/acpi/dptf.asl b/src/mainboard/google/zoombini/variants/meowth/include/variant/acpi/dptf.asl deleted file mode 100644 index a9ec742..0000000 --- a/src/mainboard/google/zoombini/variants/meowth/include/variant/acpi/dptf.asl +++ /dev/null @@ -1,16 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/acpi/dptf.asl> diff --git a/src/mainboard/google/zoombini/variants/meowth/include/variant/ec.h b/src/mainboard/google/zoombini/variants/meowth/include/variant/ec.h deleted file mode 100644 index ef47d37..0000000 --- a/src/mainboard/google/zoombini/variants/meowth/include/variant/ec.h +++ /dev/null @@ -1,21 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __MAINBOARD_EC_H__ -#define __MAINBOARD_EC_H__ - -#include <baseboard/ec.h> - -#endif /* __MAINBOARD_EC_H__ */ diff --git a/src/mainboard/google/zoombini/variants/meowth/include/variant/gpio.h b/src/mainboard/google/zoombini/variants/meowth/include/variant/gpio.h deleted file mode 100644 index 136e11b..0000000 --- a/src/mainboard/google/zoombini/variants/meowth/include/variant/gpio.h +++ /dev/null @@ -1,21 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __MAINBOARD_GPIO_H__ -#define __MAINBOARD_GPIO_H__ - -#include <baseboard/gpio.h> - -#endif /* __MAINBOARD_GPIO_H__ */ diff --git a/src/mainboard/google/zoombini/variants/meowth/memory.c b/src/mainboard/google/zoombini/variants/meowth/memory.c deleted file mode 100644 index 02c9ab9..0000000 --- a/src/mainboard/google/zoombini/variants/meowth/memory.c +++ /dev/null @@ -1,92 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/variants.h> -#include <baseboard/gpio.h> -#include <gpio.h> -#include <soc/cnl_memcfg_init.h> - -static const struct cnl_mb_cfg meowth_lpddr4_cfg = { - .dq_map[DDR_CH0] = { - /* - * CLK0 goes to package 0 - Bytes[3:0], - * CLK1 goes to package 1 - Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* - * Cmd CAA goes to Bytes[3:0], - * Cmd CAB goes to Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* CTL (CS) goes to all bytes */ - { 0xFF, 0x00 }, - }, - - .dq_map[DDR_CH1] = { - /* - * CLK0 goes to package 0 - Bytes[3:0], - * CLK1 goes to package 1 - Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* - * Cmd CAA goes to Bytes[3:0], - * Cmd CAB goes to Bytes[7:4] - */ - { 0x0F, 0xF0 }, - - /* CTL (CS) goes to all bytes */ - { 0xFF, 0x00 }, - }, - - /* - * The dqs_map arrays map the lpddr4 pins to the SoC pins - * for both channels. - * - * On Intel's memory spreadsheet, enter the following: - * - * the index = dqs pin/set number on lpddr4 part - * the value = dqs pin/set number on SoC - * - * and it will translate that and display 8 values per channel. - * Those values are copied into the dqs_map arrays below. - */ - .dqs_map[DDR_CH0] = { 3, 1, 2, 0, 7, 5, 6, 4 }, - .dqs_map[DDR_CH1] = { 2, 3, 1, 0, 7, 5, 6, 4 }, - - /* Meowth uses three 100 Ohm rcomp resistors */ - .rcomp_resistor = { 100, 100, 100 }, - - /* - * Meowth Rcomp target values. - * Rcomp targets for zoombini should be - * { 80, 40, 40, 40, 30 }, but we need to - * nil out rcomp targets for now to avoid bug b:70896346 - */ - .rcomp_targets = { 0, 0, 0, 0, 0 }, - - /* Meowth is a non-interleaved design */ - .dq_pins_interleaved = 0, - - /* Enable Early Command Training */ - .ect = 1, -}; - -const struct cnl_mb_cfg *variant_lpddr4_config(void) -{ - return &meowth_lpddr4_cfg; -} diff --git a/src/mainboard/google/zoombini/variants/zoombini/Makefile.inc b/src/mainboard/google/zoombini/variants/zoombini/Makefile.inc deleted file mode 100644 index bfa1848..0000000 --- a/src/mainboard/google/zoombini/variants/zoombini/Makefile.inc +++ /dev/null @@ -1,18 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright 2018 Google Inc. -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## - -SPD_SOURCES = Hynix_H9HCNNN8KUMLHR_1GB # 0b000 -SPD_SOURCES += Micron_MT53B512M32D2_2GB # 0b001 -SPD_SOURCES += Micron_MT53B1024M32D4_4GB # 0b010 diff --git a/src/mainboard/google/zoombini/variants/zoombini/include/variant/acpi/dptf.asl b/src/mainboard/google/zoombini/variants/zoombini/include/variant/acpi/dptf.asl deleted file mode 100644 index 15c46e4..0000000 --- a/src/mainboard/google/zoombini/variants/zoombini/include/variant/acpi/dptf.asl +++ /dev/null @@ -1,16 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <baseboard/acpi/dptf.asl> diff --git a/src/mainboard/google/zoombini/variants/zoombini/include/variant/ec.h b/src/mainboard/google/zoombini/variants/zoombini/include/variant/ec.h deleted file mode 100644 index ef47d37..0000000 --- a/src/mainboard/google/zoombini/variants/zoombini/include/variant/ec.h +++ /dev/null @@ -1,21 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __MAINBOARD_EC_H__ -#define __MAINBOARD_EC_H__ - -#include <baseboard/ec.h> - -#endif /* __MAINBOARD_EC_H__ */ diff --git a/src/mainboard/google/zoombini/variants/zoombini/include/variant/gpio.h b/src/mainboard/google/zoombini/variants/zoombini/include/variant/gpio.h deleted file mode 100644 index 4f79495..0000000 --- a/src/mainboard/google/zoombini/variants/zoombini/include/variant/gpio.h +++ /dev/null @@ -1,21 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2017 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the - * GNU General Public License for more details. - */ - -#ifndef __MAINBOARD_GPIO_H__ -#define __MAINBOARD_GPIO_H__ - -#include <baseboard/gpio.h> - -#endif /* __MAINBOARD_GPIO_H__ */ diff --git a/util/release/genrelnotes b/util/release/genrelnotes index 42848a1..0cc8b08 100755 --- a/util/release/genrelnotes +++ b/util/release/genrelnotes @@ -313,7 +313,6 @@ get_log_dedupe "Siemens mc_apl1" "src/mainboard/siemens/mc_apl1" "mc_apl1" get_log_dedupe "Intel Apollolake" "src/soc/intel/apollolake" "apollolake|apollo.lake"
-get_log_dedupe "Google Zoombini / Intel cannonlake_rvp" "src/mainboard/google/zoombini src/mainboard/intel/cannonlake_rvp" "zoombini|cannonlake_rvp" get_log_dedupe "Intel CannonLake" "src/soc/intel/cannonlake src/mainboard/intel/cannonlake_rvp" "cannonlake"
get_log_dedupe "Intel Galileo" "src/mainboard/intel/galileo" "galileo"
