Attention is currently required from: Henry Sun, Stanley Wu, Karthik Ramasubramanian. Hello build bot (Jenkins), Henry Sun, Paul Menzel, Paul Fagerburg, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/57310
Change subject: mb/google/dedede/var/gooey: Add MT53E512M32D1NP-046 as supported mem module ......................................................................
Add MT53E512M32D1NP-046 WT:B supported memory part in the mem_parts_used.txt and generate the SPD ID for the part. Manufacturer is Micron, and the memory part is 1anm Tech, difference to 1xnm Tech on MT53E512M32D2NP-046.
BUG=b:194223174 BRANCH=dedede TEST=Build the gooey board.
Change-Id: I7b83126a2bf98bb9d0ca05d397c288e0d99ed781 Signed-off-by: Stanley Wu stanley1.wu@lcfc.corp-partner.google.com --- M src/mainboard/google/dedede/variants/gooey/memory/Makefile.inc M src/mainboard/google/dedede/variants/gooey/memory/dram_id.generated.txt M src/mainboard/google/dedede/variants/gooey/memory/mem_list_variant.txt 3 files changed, 3 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/10/57310/3
