Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12714
commit 3affd4c788adf11dc5d391b47e2261bc4a2c77f8 Author: Martin Roth martinroth@google.com Date: Fri Dec 11 12:24:33 2015 -0700
Payloads: Add U-Boot as a coreboot-payload
- Add Kconfig and Makefile options to use U-Boot as a payload. - Add Kconfig option for extra cbfstool command line arguments. - Add Kconfig & Makefile option to load the payload as a flat binary. - Add u-boot directory to .gitignore.
This is currently working for X-86 only.
Graphics worked in U-Boot correctly by initializing the VBIOS and setting up a console mode.
Tested in QEMU and on Minnowboard Max. Got into U-Boot, have not booted an OS yet.
Change-Id: Ia122a4ad7cd7d96107c1552b0376c8106ca8fb92 Signed-off-by: Martin Roth martinroth@google.com Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- .gitignore | 1 + Makefile.inc | 15 ++++++- payloads/Kconfig | 12 +++++ payloads/external/Makefile.inc | 5 +++ payloads/external/U-Boot/Kconfig | 40 +++++++++++++++++ payloads/external/U-Boot/Kconfig.name | 11 +++++ payloads/external/U-Boot/Makefile.inc | 82 +++++++++++++++++++++++++++++++++++ 7 files changed, 164 insertions(+), 2 deletions(-)
diff --git a/.gitignore b/.gitignore index 114d78f..581c4a4 100644 --- a/.gitignore +++ b/.gitignore @@ -11,6 +11,7 @@ coreboot-builds/ payloads/external/FILO/filo/ payloads/external/GRUB2/grub2/ payloads/external/SeaBIOS/seabios/ +payloads/external/U-Boot/u-boot/ util/crossgcc/acpica-unix-*/ util/crossgcc/binutils-*/ util/crossgcc/build-*BINUTILS/ diff --git a/Makefile.inc b/Makefile.inc index 8f45fc2..b8cba07 100644 --- a/Makefile.inc +++ b/Makefile.inc @@ -448,6 +448,7 @@ clean-for-update-target: rm -f $(obj)/mainboard/$(MAINBOARDDIR)/bootblock.* $(obj)/dsdt.* rm -f $(obj)/cpu/x86/smm/smm_bin.c $(obj)/cpu/x86/smm/smm.* $(obj)/cpu/x86/smm/smm $(MAKE) -C payloads/external/SeaBIOS -f Makefile.inc clean + $(MAKE) -C payloads/external/U-Boot -f Makefile.inc clean
clean-target: rm -f $(obj)/coreboot* @@ -590,10 +591,13 @@ endif # $(call cbfs-add-cmd-for-region,file in extract_nth format,region name) define cbfs-add-cmd-for-region $(CBFSTOOL) $@.tmp \ - add$(if $(filter stage,$(call extract_nth,3,$(1))),-stage)$(if $(filter payload,$(call extract_nth,3,$(1))),-payload) \ + add$(if $(filter stage,$(call extract_nth,3,$(1))),-stage)$(if \ + $(filter payload,$(call extract_nth,3,$(1))),-payload)$(if \ + $(filter flat-binary,$(call extract_nth,3,$(1))),-flat-binary) \ -f $(call extract_nth,1,$(1)) \ -n $(call extract_nth,2,$(1)) \ - $(if $(filter-out stage,$(call extract_nth,3,$(1))),-t $(call extract_nth,3,$(1))) \ + $(if $(filter-out flat-binary,$(filter-out stage,$(call \ + extract_nth,3,$(1)))),-t $(call extract_nth,3,$(1))) \ $(if $(call extract_nth,4,$(1)),-c $(call extract_nth,4,$(1))) \ $(cbfs-autogen-attributes) \ -r $(2) \ @@ -730,6 +734,9 @@ ifneq ($(strip $(call strip_quotes,$(CONFIG_LINUX_INITRD))),) ADDITIONAL_PAYLOAD_CONFIG+=-I $(CONFIG_LINUX_INITRD) endif endif +ifneq ($(strip $(call strip_quotes,$(CONFIG_PAYLOAD_OPTIONS))),) + ADDITIONAL_PAYLOAD_CONFIG+=$(strip $(call strip_quotes,$(CONFIG_PAYLOAD_OPTIONS))) +endif
ifeq ($(CONFIG_HAVE_REFCODE_BLOB),y) REFCODE_BLOB=$(obj)/refcode.rmod @@ -790,7 +797,11 @@ $(CONFIG_CBFS_PREFIX)/ramstage-compression := $(CBFS_COMPRESS_FLAG)
cbfs-files-y += $(CONFIG_CBFS_PREFIX)/payload $(CONFIG_CBFS_PREFIX)/payload-file := $(CONFIG_PAYLOAD_FILE) +ifeq ($(CONFIG_PAYLOAD_IS_FLAT_BINARY),y) +$(CONFIG_CBFS_PREFIX)/payload-type := flat-binary +else $(CONFIG_CBFS_PREFIX)/payload-type := payload +endif $(CONFIG_CBFS_PREFIX)/payload-compression := $(CBFS_PAYLOAD_COMPRESS_FLAG) $(CONFIG_CBFS_PREFIX)/payload-options := $(ADDITIONAL_PAYLOAD_CONFIG)
diff --git a/payloads/Kconfig b/payloads/Kconfig index 51c89ea..9037b30 100644 --- a/payloads/Kconfig +++ b/payloads/Kconfig @@ -47,5 +47,17 @@ config COMPRESSED_PAYLOAD_LZMA In order to reduce the size payloads take up in the ROM chip coreboot can compress them using the LZMA algorithm.
+config PAYLOAD_OPTIONS + string + default "" + help + Additional cbfstool options for the payload + +config PAYLOAD_IS_FLAT_BINARY + def_bool n + help + Add the payload to cbfs as a flat binary type instead of as an + elf payload + endmenu
diff --git a/payloads/external/Makefile.inc b/payloads/external/Makefile.inc index 3743507..6a76020 100644 --- a/payloads/external/Makefile.inc +++ b/payloads/external/Makefile.inc @@ -77,3 +77,8 @@ grub2: CONFIG_GRUB2_MASTER=$(CONFIG_GRUB2_MASTER)
payloads/external/GRUB2/grub2/build/default_payload.elf: grub2 + +payloads/external/U-Boot/u-boot/u-boot-dtb.bin u-boot: $(top)/$(DOTCONFIG) + $(MAKE) -C payloads/external/U-Boot -f Makefile.inc \ + CONFIG_UBOOT_MASTER=$(CONFIG_UBOOT_MASTER) \ + CONFIG_UBOOT_STABLE=$(CONFIG_UBOOT_STABLE) diff --git a/payloads/external/U-Boot/Kconfig b/payloads/external/U-Boot/Kconfig new file mode 100644 index 0000000..2afe1cd --- /dev/null +++ b/payloads/external/U-Boot/Kconfig @@ -0,0 +1,40 @@ +if PAYLOAD_UBOOT + +config PAYLOAD_SPECIFIC_OPTIONS # dummy + def_bool y + select PAYLOAD_IS_FLAT_BINARY + +choice + prompt "U-Boot version" + default UBOOT_STABLE + +config UBOOT_STABLE + bool "v2016.1" + help + Stable U-Boot version + +config UBOOT_MASTER + bool "master" + help + Newest U-Boot version + +endchoice + +config PAYLOAD_CONFIGFILE + string "U-Boot config file" + default "" + help + This option allows a platform to set Kconfig options for a basic + U-Boot payload. In general, if the option is used, the default + would be "$(top)/src/mainboard/$(MAINBOARDDIR)/config_uboot" + for a config stored in the coreboot mainboard directory, or + "$(project_dir)/configs/coreboot-x86_defconfig" to use a config + from the U-Boot config directory + +config PAYLOAD_FILE + default "payloads/external/U-Boot/u-boot/u-boot-dtb.bin" + +config PAYLOAD_OPTIONS + default "-l 0x1110000 -e 0x1110015" + +endif diff --git a/payloads/external/U-Boot/Kconfig.name b/payloads/external/U-Boot/Kconfig.name new file mode 100644 index 0000000..2e6a64c --- /dev/null +++ b/payloads/external/U-Boot/Kconfig.name @@ -0,0 +1,11 @@ +config PAYLOAD_UBOOT + bool "U-Boot (Experimental)" + depends on ARCH_X86 + help + Select this option if you want to build a coreboot image + with a U-Boot payload. + + See http://coreboot.org/Payloads and U-Boot's documentation + at http://git.denx.de/?p=u-boot.git;a=blob;f=doc/README.x86 + for more information. + diff --git a/payloads/external/U-Boot/Makefile.inc b/payloads/external/U-Boot/Makefile.inc new file mode 100644 index 0000000..f0abee1 --- /dev/null +++ b/payloads/external/U-Boot/Makefile.inc @@ -0,0 +1,82 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2015 Google Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +# 2016-1 tag +STABLE_COMMIT_ID=fa85e826c16b9ce1ad302a57e9c4b24db0d8b930 + +TAG-$(CONFIG_UBOOT_MASTER)=origin/master +TAG-$(CONFIG_UBOOT_STABLE)=$(STABLE_COMMIT_ID) + +project_name=U-Boot +project_dir=u-boot +project_git_repo=http://git.denx.de/u-boot.git +project_config_file=$(project_dir)/.config + +unexport KCONFIG_AUTOHEADER +unexport KCONFIG_AUTOCONFIG +unexport KCONFIG_DEPENDENCIES +unexport KCONFIG_SPLITCONFIG +unexport KCONFIG_TRISTATE +unexport KCONFIG_NEGATIVES + +all: build + +$(project_dir): + echo " Cloning $(project_name) from Git" + git clone $(project_git_repo) $(project_dir) + +fetch: $(project_dir) +ifeq ($(CONFIG_UBOOT_MASTER),y) + echo " Fetching new commits from the $(project_name) git repo" + git fetch + + #master doesn't get a file, so it's continuously updated + rm -f $(project_dir)/$(STABLE_COMMIT_ID) +else + cd $(project_dir); git show $(TAG-y) >/dev/null 2>&1 ; if [ $$? -ne 0 ]; \ + then echo " Fetching new commits from the $(project_name) git repo"; git fetch; fi + touch $(project_dir)/$(STABLE_COMMIT_ID) +endif + +$(project_dir)/$(TAG-y): fetch + echo " Checking out $(project_name) revision $(TAG-y)" + cd $(project_dir); git checkout master; git branch -D coreboot 2>/dev/null; git checkout -b coreboot $(TAG-y) + +config: $(project_dir)/$(TAG-y) + rm -f $(project_config_file) +ifneq ($(CONFIG_PAYLOAD_CONFIGFILE),) +ifneq ("$(wildcard $(CONFIG_PAYLOAD_CONFIGFILE))","") + cat $(CONFIG_PAYLOAD_CONFIGFILE)" > $(project_config_file) +else + echo "Error: File $(CONFIG_PAYLOAD_CONFIGFILE) does not exist" + false +endif +else + cat $(project_dir)/configs/coreboot-x86_defconfig >> $(project_config_file) +endif + + $(MAKE) -C $(project_dir) olddefconfig + +build: config + echo " MAKE $(project_name) $(TAG-y)" + $(MAKE) -C $(project_dir) + +clean: + test -d $(project_dir) && $(MAKE) -C $(project_dir) clean || exit 0 + +distclean: + rm -rf $(project_dir) + +.PHONY: config build clean distclean fetch
