Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11956
commit 999fd19202b7514489e60b63bbf464584c4be5a4 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Sun May 10 04:37:56 2015 -0500
mainboard/asus/kgpe-d16: Set DDR3 memory voltage based on SPD data
Change-Id: I21777283ce0fd3c607951204a63ff67dc656c8cc Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kgpe-d16/Kconfig | 1 + src/mainboard/asus/kgpe-d16/cmos.default | 1 + src/mainboard/asus/kgpe-d16/cmos.layout | 5 +++ src/mainboard/asus/kgpe-d16/romstage.c | 76 +++++++++++++++++++++++++++++--- 4 files changed, 78 insertions(+), 5 deletions(-)
diff --git a/src/mainboard/asus/kgpe-d16/Kconfig b/src/mainboard/asus/kgpe-d16/Kconfig index f47e6a1..f5ff81c 100644 --- a/src/mainboard/asus/kgpe-d16/Kconfig +++ b/src/mainboard/asus/kgpe-d16/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_DDR3 select DIMM_REGISTERED # select QRANK_DIMM_SUPPORT + select DIMM_VOLTAGE_SET_SUPPORT select NORTHBRIDGE_AMD_AMDFAM10 select SOUTHBRIDGE_AMD_SR5650 select SOUTHBRIDGE_AMD_SB700 diff --git a/src/mainboard/asus/kgpe-d16/cmos.default b/src/mainboard/asus/kgpe-d16/cmos.default index 38b2ddf..d84c402 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.default +++ b/src/mainboard/asus/kgpe-d16/cmos.default @@ -6,6 +6,7 @@ iommu = Disable nmi = Disable hypertransport_speed_limit = Auto max_mem_clock = DDR3-1600 +minimum_memory_voltage = 1.5V ECC_memory = Enable ECC_redirection = Disable ecc_scrub_rate = 1.28us diff --git a/src/mainboard/asus/kgpe-d16/cmos.layout b/src/mainboard/asus/kgpe-d16/cmos.layout index 290c7c6..b6f4504 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.layout +++ b/src/mainboard/asus/kgpe-d16/cmos.layout @@ -41,6 +41,7 @@ entries 456 1 e 1 ECC_memory 457 1 e 1 ECC_redirection 458 4 e 11 hypertransport_speed_limit +462 2 e 12 minimum_memory_voltage 477 1 e 1 ieee1394_controller 728 256 h 0 user_data 984 16 h 0 check_sum @@ -129,6 +130,10 @@ enumerations 11 13 400MHz 11 14 300MHz 11 15 200MHz +12 0 1.5V +12 1 1.35V +12 2 1.25V +12 3 1.15V
checksums
diff --git a/src/mainboard/asus/kgpe-d16/romstage.c b/src/mainboard/asus/kgpe-d16/romstage.c index 29fffce..485bed1 100644 --- a/src/mainboard/asus/kgpe-d16/romstage.c +++ b/src/mainboard/asus/kgpe-d16/romstage.c @@ -135,7 +135,7 @@ static void activate_spd_rom(const struct mem_controller *ctrl) { */ static void set_ddr3_voltage(uint8_t node, uint8_t index) { uint8_t byte; - uint8_t value; + uint8_t value = 0;
if (index == 0) value = 0x0; @@ -161,6 +161,74 @@ static void set_ddr3_voltage(uint8_t node, uint8_t index) { byte = pci_read_config8(PCI_DEV(0, 0x14, 3), 0xd0); byte &= 0x0f; pci_write_config8(PCI_DEV(0, 0x14, 3), 0xd0, byte); + + printk(BIOS_DEBUG, "Node %02d DIMM voltage set to index %02x\n", node, index); +} + +void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, + struct DCTStatStruc *pDCTstatA) { + /* This mainboard allows the DIMM voltage to be set per-socket. + * Therefore, for each socket, iterate over all DIMMs to find the + * lowest supported voltage common to all DIMMs on that socket. + */ + uint8_t nvram; + uint8_t dimm; + uint8_t node; + uint8_t socket; + uint8_t allowed_voltages = 0xf; /* The mainboard VRMs allow 1.15V, 1.25V, 1.35V, and 1.5V */ + uint32_t set_voltage = 0; + + if (get_option(&nvram, "minimum_memory_voltage") == CB_SUCCESS) { + if (nvram == 2) + allowed_voltages = 0x7; /* Allow 1.25V, 1.35V, and 1.5V */ + if (nvram == 1) + allowed_voltages = 0x3; /* Allow 1.35V and 1.5V */ + if (nvram == 0) + allowed_voltages = 0x1; /* Allow 1.5V only */ + } + + for (node = 0; node < MAX_NODES_SUPPORTED; node++) { + socket = node / 2; + struct DCTStatStruc *pDCTstat; + pDCTstat = pDCTstatA + node; + if (pDCTstat->NodePresent) { + for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { + if (pDCTstat->DIMMValid & (1 << dimm)) { + allowed_voltages &= pDCTstat->DimmSupportedVoltages[dimm]; + } + } + } + + if (pDCTstat->NodePresent && (node & 0x1)) { + /* Set voltages */ + if (allowed_voltages & 0x8) { + set_voltage = 1150; + set_ddr3_voltage(socket, 3); + } else if (allowed_voltages & 0x4) { + set_voltage = 1250; + set_ddr3_voltage(socket, 2); + } else if (allowed_voltages & 0x2) { + set_voltage = 1350; + set_ddr3_voltage(socket, 1); + } else { + set_voltage = 1500; + set_ddr3_voltage(socket, 0); + } + + /* Save final DIMM voltages for SMBIOS use */ + if (pDCTstat->NodePresent) { + for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { + pDCTstat->DimmConfiguredVoltage[dimm] = set_voltage; + } + } + pDCTstat = pDCTstatA + (node - 1); + if (pDCTstat->NodePresent) { + for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { + pDCTstat->DimmConfiguredVoltage[dimm] = set_voltage; + } + } + } + } }
static void set_peripheral_control_lines(void) { @@ -355,10 +423,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) die("After soft_reset_x - shouldn't see this message!!!\n"); }
- /* Set DDR memory voltage - * FIXME - * This should be set based on the output of the DIMM SPDs - * For now it is locked to 1.5V + /* Set default DDR memory voltage + * This will be overridden later during RAM initialization */ set_lpc_sticky_ctl(1); /* Retain LPC/IMC GPIO configuration during S3 sleep */ if (!s3resume) { /* Avoid supply voltage glitches while the DIMMs are retaining data */
