the following patch was just integrated into master: commit 801471436efd7cfa4cefc7af40c6db015e49a450 Author: Patrick Rudolph siro@das-labor.org Date: Sat Feb 6 13:03:21 2016 +0100
southbridge/intel/bd82x6x/acpi: Fix IRQ warnings
The PCIe slot uses Message Signaled Interrupts (MSI) as the IGD does and doesn't use hardware INT lines. Adding the IRQ entry for PEG slot fixes a warning showing up in GNU/Linux dmesg.
Test system: * Intel IvyBridge * Gigabyte GA-B75M-D3H
Change-Id: I5ac40e7bea9a659c6c89262aac4552bc8177a9e5 Signed-off-by: Patrick Rudolph siro@das-labor.org Reviewed-on: https://review.coreboot.org/13612 Tested-by: build bot (Jenkins) Reviewed-by: Stefan Reinauer stefan.reinauer@coreboot.org
See https://review.coreboot.org/13612 for details.
