Lean Sheng Tan has submitted this change. ( https://review.coreboot.org/c/coreboot/+/76090?usp=email )
Change subject: allocator_v4: Fix top-level allocations w/o IORESOURCE_ABOVE_4G ......................................................................
When moving the code to allocate at the top level in commit 9260ea60bfa4 (allocator_v4: Use memranges only for toplevel), a call to restrict the limit of the resource was dropped. Probably by accident in one of the earliest rebases. Without this call to effective_limit(), 64-bit resour- ces at the top level, i.e. PCI bus 0, were always placed above 4G. Even when this was not requested with the IORESOURCE_ABOVE_4G flag.
Tested on kontron/ktqm77 where the issue could be reproduced with x86_64. Without the fix, boot hangs when trying to access the GMA MMIO registers of PCI 00:02.0, which were placed above 4G.
Change-Id: Ied3a0695ef5e91f092bf2d442c1c482057643483 Signed-off-by: Nico Huber nico.h@gmx.de Found-by: 9elements QA Reviewed-on: https://review.coreboot.org/c/coreboot/+/76090 Reviewed-by: Felix Singer service+coreboot-gerrit@felixsinger.de Reviewed-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-by: Eric Lai eric_lai@quanta.corp-partner.google.com Reviewed-by: Paul Menzel paulepanter@mailbox.org Reviewed-by: Lean Sheng Tan sheng.tan@9elements.com Reviewed-by: Arthur Heymans arthur@aheymans.xyz Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/device/resource_allocator_v4.c 1 file changed, 2 insertions(+), 2 deletions(-)
Approvals: Arthur Heymans: Looks good to me, approved Lean Sheng Tan: Looks good to me, approved Paul Menzel: Looks good to me, but someone else must approve build bot (Jenkins): Verified Kyösti Mälkki: Looks good to me, approved Felix Singer: Looks good to me, but someone else must approve Eric Lai: Looks good to me, but someone else must approve
diff --git a/src/device/resource_allocator_v4.c b/src/device/resource_allocator_v4.c index e64d8ad..96d4488 100644 --- a/src/device/resource_allocator_v4.c +++ b/src/device/resource_allocator_v4.c @@ -401,8 +401,8 @@ if (!res->size) continue;
- if (!memranges_steal(&ranges, res->limit, res->size, res->align, type, &base, - CONFIG(RESOURCE_ALLOCATION_TOP_DOWN))) { + if (!memranges_steal(&ranges, effective_limit(res), res->size, res->align, + type, &base, CONFIG(RESOURCE_ALLOCATION_TOP_DOWN))) { printk(BIOS_ERR, "Resource didn't fit!!!\n"); print_failed_res(dev, res); continue;
