Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/30356 )
Change subject: Documentation/nb/intel: Add Haswell documentation ......................................................................
At the moment, this just gives some details on the MRC.
Change-Id: I84e8ca2543b2e19b84a24f7d7032a4aedb6e9272 Signed-off-by: Tristan Corrick tristan@corrick.kiwi Reviewed-on: https://review.coreboot.org/c/30356 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nico Huber nico.h@gmx.de --- M Documentation/mainboard/asrock/h81m-hds.md A Documentation/northbridge/intel/haswell/index.md A Documentation/northbridge/intel/haswell/mrc.bin.md M Documentation/northbridge/intel/index.md 4 files changed, 46 insertions(+), 16 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved
diff --git a/Documentation/mainboard/asrock/h81m-hds.md b/Documentation/mainboard/asrock/h81m-hds.md index 0338aa1..460af8f 100644 --- a/Documentation/mainboard/asrock/h81m-hds.md +++ b/Documentation/mainboard/asrock/h81m-hds.md @@ -4,24 +4,10 @@
## Required proprietary blobs
-This board currently requires a proprietary blob in order to initialise -the RAM and a few other components. The blob largely consists of Intel's -Memory Reference Code (shortened to mrc), and is just under 200 KiB -in size. It is also known as a system agent binary. Unfortunately, -it is not currently possible to distribute this as part of coreboot. -However, the mrc can be obtained from a Haswell Chromebook firmware -image, and you might find one online. The mrc from a ChromeOS image can -be extracted with the following command. If extracting from a "standard" -coreboot image, omit `-r RO_SECTION`. - -```bash -cbfstool coreboot.rom extract -f mrc.bin -n mrc.bin -r RO_SECTION +```eval_rst +Please see :doc:`../../northbridge/intel/haswell/mrc.bin`. ```
-Now, place mrc.bin in the root of the coreboot directory. -Alternatively, place it anywhere you want, and set `MRC_FILE` to its -location when building coreboot. - ## Building coreboot
A fully working image should be possible just by setting your MAC diff --git a/Documentation/northbridge/intel/haswell/index.md b/Documentation/northbridge/intel/haswell/index.md new file mode 100644 index 0000000..3eb8059 --- /dev/null +++ b/Documentation/northbridge/intel/haswell/index.md @@ -0,0 +1,8 @@ +# Intel Haswell documentation + +This section describes the Intel Haswell architecture as it relates to +coreboot. + +## Proprietary blobs + +- [mrc.bin](mrc.bin.md) diff --git a/Documentation/northbridge/intel/haswell/mrc.bin.md b/Documentation/northbridge/intel/haswell/mrc.bin.md new file mode 100644 index 0000000..e27e9d6 --- /dev/null +++ b/Documentation/northbridge/intel/haswell/mrc.bin.md @@ -0,0 +1,35 @@ +# mrc.bin + +All Haswell boards supported by coreboot currently require a proprietary +blob in order to initialise the DRAM and a few other components. The +blob, named `mrc.bin`, largely consists of Intel's memory reference code +(MRC), but it has been tailored specifically for Chrome OS. It is just +under 200 KiB in size. Another name for `mrc.bin` is the system agent +binary. + +Having a replacement for `mrc.bin` using native coreboot code is very +much desired, but it is not an easy task. + +## Obtaining mrc.bin + +Unfortunately, it is not currently possible to distribute `mrc.bin` as +part of coreboot. Though, it can be obtained from a Haswell Chromebook +or Chromebox firmware image, and you might find one online. `mrc.bin` +can be extracted with the following command. If extracting from a +"standard" coreboot image, omit `-r RO_SECTION`. + +```bash +cbfstool coreboot.rom extract -f mrc.bin -n mrc.bin -r RO_SECTION +``` + +Now, place `mrc.bin` in the root of the coreboot directory. +Alternatively, place `mrc.bin` anywhere you want, and set `MRC_FILE` to +its location when building coreboot. + +## ECC DRAM + +When `mrc.bin` has finished executing, ECC is active on the channels +populated with ECC DIMMs. However, `mrc.bin` was tailored specifically +for Haswell Chromebooks and Chomeboxes, none of which support ECC DRAM. +While ECC likely functions correctly, it is advised to further validate +the correct operation of ECC if data integrity is absolutely critical. diff --git a/Documentation/northbridge/intel/index.md b/Documentation/northbridge/intel/index.md index 6cca1da..da7634b 100644 --- a/Documentation/northbridge/intel/index.md +++ b/Documentation/northbridge/intel/index.md @@ -4,4 +4,5 @@
## Platforms
+- [Haswell](haswell/index.md) - [Sandy Bridge](sandybridge/index.md)
