Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/61657 )
Change subject: mb/google/brask: Add more gpios to lock ......................................................................
Add rest of soc sensitive gpios to lock for brask.
BUG=b:216583542 TEST='emerge-brya coreboot chromeos-bootimage', flash and verify that brask boots successfully to kernel.
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: Iad87d13d3df0ad87c075027e3fcc4c75aa711159 Reviewed-on: https://review.coreboot.org/c/coreboot/+/61657 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nick Vaccaro nvaccaro@google.com Reviewed-by: Subrata Banik subratabanik@google.com --- M src/mainboard/google/brya/variants/baseboard/brask/gpio.c 1 file changed, 40 insertions(+), 40 deletions(-)
Approvals: build bot (Jenkins): Verified Nick Vaccaro: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/baseboard/brask/gpio.c b/src/mainboard/google/brya/variants/baseboard/brask/gpio.c index 5383aa7..ed0416b 100644 --- a/src/mainboard/google/brya/variants/baseboard/brask/gpio.c +++ b/src/mainboard/google/brya/variants/baseboard/brask/gpio.c @@ -35,7 +35,7 @@ /* A15 : USB_OC2# ==> USB_C2_OC_ODL */ PAD_CFG_NF(GPP_A15, NONE, DEEP, NF1), /* A16 : USB_OC3# ==> USB_A0_OC_ODL */ - PAD_CFG_NF(GPP_A16, NONE, DEEP, NF1), + PAD_CFG_NF_LOCK(GPP_A16, NONE, NF1, LOCK_CONFIG), /* A17 : DISP_MISCC ==> NC */ PAD_NC(GPP_A17, NONE), /* A18 : DDSP_HPDB ==> HDMI_HPD */ @@ -58,17 +58,17 @@ /* B2 : VRALERT# ==> M2_SSD_PLA_L */ PAD_CFG_GPO(GPP_B2, 1, PLTRST), /* B3 : PROC_GP2 ==> NC */ - PAD_NC(GPP_B3, NONE), + PAD_NC_LOCK(GPP_B3, NONE, LOCK_CONFIG), /* B4 : PROC_GP3 ==> SSD_PERST_L */ - PAD_CFG_GPO(GPP_B4, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_B4, 1, LOCK_CONFIG), /* B5 : ISH_I2C0_SDA ==> PCH_I2C_MISC_SDA */ - PAD_CFG_NF(GPP_B5, NONE, DEEP, NF2), + PAD_CFG_NF_LOCK(GPP_B5, NONE, NF2, LOCK_CONFIG), /* B6 : ISH_I2C0_SCL ==> PCH_I2C_MISC_SCL */ - PAD_CFG_NF(GPP_B6, NONE, DEEP, NF2), + PAD_CFG_NF_LOCK(GPP_B6, NONE, NF2, LOCK_CONFIG), /* B7 : ISH_12C1_SDA ==> NC */ - PAD_NC(GPP_B7, NONE), + PAD_NC_LOCK(GPP_B7, NONE, LOCK_CONFIG), /* B8 : ISH_I2C1_SCL ==> NC */ - PAD_NC(GPP_B8, NONE), + PAD_NC_LOCK(GPP_B8, NONE, LOCK_CONFIG), /* B9 : NC */ PAD_NC(GPP_B9, NONE), /* B10 : NC */ @@ -80,13 +80,13 @@ /* B13 : PLTRST# ==> PLT_RST_L */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), /* B14 : SPKR ==> PWM_PP3300_BUZZER */ - PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), + PAD_CFG_NF_LOCK(GPP_B14, NONE, NF1, LOCK_CONFIG), /* B15 : TIME_SYNC0 ==> TP159 */ - PAD_NC(GPP_B15, NONE), + PAD_NC_LOCK(GPP_B15, NONE, LOCK_CONFIG), /* B16 : I2C5_SDA ==> NC */ - PAD_NC(GPP_B16, NONE), + PAD_NC_LOCK(GPP_B16, NONE, LOCK_CONFIG), /* B17 : I2C5_SCL ==> NC */ - PAD_NC(GPP_B17, NONE), + PAD_NC_LOCK(GPP_B17, NONE, LOCK_CONFIG), /* B18 : ADR_COMPLETE ==> GPP_B18_STRAP */ PAD_NC(GPP_B18, NONE), /* B19 : NC */ @@ -118,13 +118,13 @@ PAD_NC(GPP_C7, NONE),
/* D0 : ISH_GP0 ==> PCH_FP_BOOT0 */ - PAD_NC(GPP_D0, NONE), + PAD_NC_LOCK(GPP_D0, NONE, LOCK_CONFIG), /* D1 : ISH_GP1 ==> FP_RST_ODL */ - PAD_CFG_GPO(GPP_D1, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_D1, 1, LOCK_CONFIG), /* D2 : ISH_GP2 ==> EN_FP_PWR */ - PAD_CFG_GPO(GPP_D2, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_D2, 1, LOCK_CONFIG), /* D3 : ISH_GP3 ==> EN_NFC_PWR */ - PAD_CFG_GPO(GPP_D3, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_D3, 1, LOCK_CONFIG), /* D4 : IMGCLKOUT0 ==> BT_DISABLE_L */ PAD_CFG_GPO(GPP_D4, 1, DEEP), /* D5 : SRCCLKREQ0# ==> SSD_CLKREQ_ODL */ @@ -136,34 +136,34 @@ /* D8 : SRCCLKREQ3# ==> SD_CLKREQ_ODL */ PAD_CFG_NF(GPP_D8, NONE, DEEP, NF1), /* D9 : ISH_SPI_CS# ==> USB_C2_LSX_TX */ - PAD_CFG_NF(GPP_D9, NONE, DEEP, NF4), + PAD_CFG_NF_LOCK(GPP_D9, NONE, NF4, LOCK_CONFIG), /* D10 : ISH_SPI_CLK ==> USB_C2_LSX_RX_STRAP */ - PAD_CFG_NF(GPP_D10, NONE, DEEP, NF4), + PAD_CFG_NF_LOCK(GPP_D10, NONE, NF4, LOCK_CONFIG), /* D11 : ISH_SPI_MISO ==> DDIA_DP_CTRLCLK */ - PAD_CFG_NF(GPP_D11, NONE, DEEP, NF2), + PAD_CFG_NF_LOCK(GPP_D11, NONE, NF2, LOCK_CONFIG), /* D12 : ISH_SPI_MOSI ==> DDIA_DP_CTRLDATA */ - PAD_CFG_NF(GPP_D12, NONE, DEEP, NF2), + PAD_CFG_NF_LOCK(GPP_D12, NONE, NF2, LOCK_CONFIG), /* D13 : ISH_UART0_RXD ==> TP97 */ - PAD_NC(GPP_D13, NONE), + PAD_NC_LOCK(GPP_D13, NONE, LOCK_CONFIG), /* D14 : ISH_UART0_TXD ==> TP93 */ - PAD_NC(GPP_D14, NONE), + PAD_NC_LOCK(GPP_D14, NONE, LOCK_CONFIG), /* D15 : ISH_UART0_RTS# ==> NC */ - PAD_NC(GPP_D15, NONE), + PAD_NC_LOCK(GPP_D15, NONE, LOCK_CONFIG), /* D16 : ISH_UART0_CTS# ==> NC */ - PAD_NC(GPP_D16, NONE), + PAD_NC_LOCK(GPP_D16, NONE, LOCK_CONFIG), /* D17 : UART1_RXD ==> SD_PE_PRSNT_L */ - PAD_CFG_GPI(GPP_D17, NONE, DEEP), + PAD_CFG_GPI_LOCK(GPP_D17, NONE, LOCK_CONFIG), /* D18 : UART1_TXD ==> SD_PE_RST_L */ - PAD_CFG_GPO(GPP_D18, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_D18, 1, LOCK_CONFIG), /* D19 : I2S_MCLK1_OUT ==> I2S_MCLK_R */ PAD_CFG_NF(GPP_D19, NONE, DEEP, NF1),
/* E0 : SATAXPCIE0 ==> CLKREQ_9 */ PAD_NC(GPP_E0, NONE), /* E1 : THC0_SPI1_IO2 ==> NC */ - PAD_NC(GPP_E1, NONE), + PAD_NC_LOCK(GPP_E1, NONE, LOCK_CONFIG), /* E2 : THC0_SPI1_IO3 ==> NC */ - PAD_NC(GPP_E2, NONE), + PAD_NC_LOCK(GPP_E2, NONE, LOCK_CONFIG), /* E3 : PROC_GP0 ==> TP94644 */ PAD_NC(GPP_E3, NONE), /* E4 : SATA_DEVSLP0 ==> USB4_BB_RT_FORCE_PWR */ @@ -171,21 +171,21 @@ /* E5 : SATA_DEVSLP1 ==> NC */ PAD_NC(GPP_E5, NONE), /* E6 : THC0_SPI1_RST# ==> GPPE6_STRAP */ - PAD_NC(GPP_E6, NONE), + PAD_NC_LOCK(GPP_E6, NONE, LOCK_CONFIG), /* E7 : PROC_GP1 ==> TP94643 */ PAD_NC(GPP_E7, NONE), /* E8 : SLP_DRAM# ==> WIFI_DISABLE_L */ PAD_CFG_GPO(GPP_E8, 1, DEEP), /* E9 : USB_OC0# ==> USB_C0_OC_ODL */ - PAD_CFG_NF(GPP_E9, NONE, DEEP, NF1), + PAD_CFG_NF_LOCK(GPP_E9, NONE, NF1, LOCK_CONFIG), /* E10 : THC0_SPI1_CS# ==> NC */ - PAD_NC(GPP_E10, NONE), + PAD_NC_LOCK(GPP_E10, NONE, LOCK_CONFIG), /* E11 : THC0_SPI1_CLK ==> NC */ - PAD_NC(GPP_E11, NONE), + PAD_NC_LOCK(GPP_E11, NONE, LOCK_CONFIG), /* E12 : THC0_SPI1_IO1 ==> NC */ - PAD_NC(GPP_E12, NONE), + PAD_NC_LOCK(GPP_E12, NONE, LOCK_CONFIG), /* E13 : THC0_SPI1_IO2 ==> NC */ - PAD_NC(GPP_E13, NONE), + PAD_NC_LOCK(GPP_E13, NONE, LOCK_CONFIG), /* E14 : DDSP_HPDA ==> SOC_DP_HPD */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* E15 : RSVD_TP ==> PCH_WP_OD */ @@ -193,7 +193,7 @@ /* E16 : RSVD_TP ==> CLKREQ_8 */ PAD_NC(GPP_E16, NONE), /* E17 : THC0_SPI1_INT# ==> TP102 */ - PAD_NC(GPP_E17, NONE), + PAD_NC_LOCK(GPP_E17, NONE, LOCK_CONFIG), /* E18 : DDP1_CTRLCLK ==> USB_C0_LSX_TX */ PAD_CFG_NF(GPP_E18, NONE, DEEP, NF4), /* E19 : DDP1_CTRLDATA ==> USB0_C0_LSX_RX_STRAP */ @@ -236,15 +236,15 @@ /* F13 : GSXDOUT ==> GSPI_PCH_DI_FPMCU_DO */ PAD_CFG_NF_LOCK(GPP_F13, NONE, NF4, LOCK_CONFIG), /* F14 : GSXDIN ==> EN_PP3300_SSD */ - PAD_CFG_GPO(GPP_F14, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_F14, 1, LOCK_CONFIG), /* F15 : GSXSRESET# ==> FPMCU_INT_L */ PAD_CFG_GPI_IRQ_WAKE_LOCK(GPP_F15, NONE, LEVEL, INVERT, LOCK_CONFIG), /* F16 : GSXCLK ==> GSPI_PCH_CS_FPMCU_R_L */ PAD_CFG_NF_LOCK(GPP_F16, NONE, NF4, LOCK_CONFIG), /* F17 : THC1_SPI2_RST# ==> EC_PCH_INT_ODL */ - PAD_CFG_GPI_IRQ_WAKE(GPP_F17, NONE, DEEP, LEVEL, INVERT), + PAD_CFG_GPI_IRQ_WAKE_LOCK(GPP_F17, NONE, LEVEL, INVERT, LOCK_CONFIG), /* F18 : THC1_SPI2_INT# ==> EC_IN_RW_OD */ - PAD_CFG_GPI(GPP_F18, NONE, DEEP), + PAD_CFG_GPI_LOCK(GPP_F18, NONE, LOCK_CONFIG), /* F19 : SRCCLKREQ6# ==> LAN_CLKREQ_ODL */ PAD_CFG_NF(GPP_F19, NONE, DEEP, NF1), /* F20 : EXT_PWR_GATE# ==> TP94669 */ @@ -263,7 +263,7 @@ /* H2 : GPPH2_BOOT_STRAP3 */ PAD_NC(GPP_H2, NONE), /* H3 : SX_EXIT_HOLDOFF# ==> WLAN_PCIE_WAKE_ODL */ - PAD_CFG_GPI(GPP_H3, NONE, DEEP), + PAD_CFG_GPI_LOCK(GPP_H3, NONE, LOCK_CONFIG), /* H4 : I2C0_SDA ==> PCH_I2C_AUD_SDA */ PAD_CFG_NF(GPP_H4, NONE, DEEP, NF1), /* H5 : I2C0_SCL ==> PCH_I2C_AUD_SCL */ @@ -281,9 +281,9 @@ /* H11 : UART0_TXD ==> UART_PCH_TX_DBG_RX */ PAD_CFG_NF(GPP_H11, NONE, DEEP, NF2), /* H12 : I2C7_SDA ==> SD_PE_WAKE_ODL */ - PAD_CFG_GPI(GPP_H12, NONE, DEEP), + PAD_CFG_GPI_LOCK(GPP_H12, NONE, LOCK_CONFIG), /* H13 : I2C7_SCL ==> EN_PP3300_SD */ - PAD_CFG_GPO(GPP_H13, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_H13, 1, LOCK_CONFIG), /* H14 : NC */ PAD_NC(GPP_H14, NONE), /* H15 : DDPB_CTRLCLK ==> DDIB_HDMI_CTRLCLK */
