Nico Huber (nico.h@gmx.de) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16339
commit 7c9c22a21eaeda7992624a513f1bf9e318b95b89 Author: Swift Geek (Sebastian Grzywna) swiftgeek@gmail.com Date: Sat Aug 27 13:24:53 2016 +0200
intel/gma: Use defines for registers and values in edid.c
Replaces magic values with defines without changing any value.
Change-Id: I332442045aa4a28ffed88fc52a99a4364684f00c Signed-off-by: Swift Geek (Sebastian Grzywna) swiftgeek@gmail.com --- src/drivers/intel/gma/edid.c | 54 ++++++++++++++++++++++++++++---------------- 1 file changed, 34 insertions(+), 20 deletions(-)
diff --git a/src/drivers/intel/gma/edid.c b/src/drivers/intel/gma/edid.c index 9bde9b5..3902094 100644 --- a/src/drivers/intel/gma/edid.c +++ b/src/drivers/intel/gma/edid.c @@ -2,6 +2,7 @@ * This file is part of the coreboot project. * * Copyright (C) 2014 Vladimir Serbinenko phcoder@gmail.com + * Copyright (C) 2016 Sebastian Grzywna swiftgeek@gmail.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -20,13 +21,19 @@
#include "i915_reg.h" #include "edid.h" +#define GMBUS0_ADDR (mmio + 4 * 0) +#define GMBUS1_ADDR (mmio + 4 * 1) +#define GMBUS2_ADDR (mmio + 4 * 2) +#define GMBUS3_ADDR (mmio + 4 * 3) +#define GMBUS5_ADDR (mmio + 4 * 8) +#define AT24_ADDR 0x50 /* EDID EEPROM */
static void wait_rdy(u8 *mmio) { unsigned try = 100;
while (try--) { - if (read32(mmio + 8) & (1 << 11)) + if (read32(GMBUS2_ADDR) & GMBUS_HW_RDY) return; udelay(10); } @@ -35,19 +42,22 @@ static void wait_rdy(u8 *mmio) static void intel_gmbus_stop_bus(u8 * mmio, u8 bus) { wait_rdy(mmio); - write32(mmio + 4 * 0, bus); + write32(GMBUS0_ADDR, bus); wait_rdy(mmio); - write32(mmio + 4 * 8, 0); - write32(mmio + 4 * 1, 0x4e0400a1); + write32(GMBUS5_ADDR, 0); + write32(GMBUS1_ADDR, GMBUS_SW_RDY | GMBUS_CYCLE_WAIT | GMBUS_CYCLE_INDEX + | GMBUS_CYCLE_STOP | ( 0x4 << GMBUS_BYTE_COUNT_SHIFT ) + | GMBUS_SLAVE_READ | (AT24_ADDR << 1) ); wait_rdy(mmio); - write32(mmio + 4 * 8, 0); - write32(mmio + 4 * 1, 0x80000000); - write32(mmio + 4 * 1, 0x00000000); + write32(GMBUS5_ADDR, 0); + write32(GMBUS1_ADDR, GMBUS_SW_CLR_INT); + write32(GMBUS1_ADDR, 0); wait_rdy(mmio); - write32(mmio + 4 * 1, 0x480000a0); + write32(GMBUS1_ADDR, GMBUS_SW_RDY | GMBUS_CYCLE_STOP | GMBUS_SLAVE_WRITE + | (AT24_ADDR << 1) ); wait_rdy(mmio); - write32(mmio + 4 * 0, 0x48000000); - write32(mmio + 4 * 2, 0x00008000); + write32(GMBUS0_ADDR, GMBUS_SW_RDY | GMBUS_CYCLE_STOP); + write32(GMBUS2_ADDR, GMBUS_INUSE); }
void intel_gmbus_stop(u8 *mmio) @@ -65,30 +75,34 @@ void intel_gmbus_read_edid(u8 *mmio, u8 bus, u8 slave, u8 *edid, u32 edid_size)
wait_rdy(mmio); /* 100 KHz, hold 0ns, */ - write32(mmio + 4 * 0, bus); + write32(GMBUS0_ADDR, bus); wait_rdy(mmio); /* Ensure index bits are disabled. */ - write32(mmio + 4 * 8, 0); - write32(mmio + 4 * 1, 0x46000000 | (slave << 1)); + write32(GMBUS5_ADDR, 0); + write32(GMBUS1_ADDR, GMBUS_SW_RDY | GMBUS_CYCLE_WAIT | GMBUS_CYCLE_INDEX + | (slave << 1) ); wait_rdy(mmio); /* Ensure index bits are disabled. */ - write32(mmio + 4 * 8, 0); - write32(mmio + 4 * 1, 0x4a000001 | (slave << 1) - | (edid_size << 16)); + write32(GMBUS5_ADDR, 0); + write32(GMBUS1_ADDR, GMBUS_SW_RDY | GMBUS_SLAVE_READ | GMBUS_CYCLE_WAIT + | GMBUS_CYCLE_STOP + | (edid_size << GMBUS_BYTE_COUNT_SHIFT) | (slave << 1) ); for (i = 0; i < edid_size / 4; i++) { u32 reg32; wait_rdy(mmio); - reg32 = read32(mmio + 4 * 3); + reg32 = read32(GMBUS3_ADDR); edid[4 * i] = reg32 & 0xff; edid[4 * i + 1] = (reg32 >> 8) & 0xff; edid[4 * i + 2] = (reg32 >> 16) & 0xff; edid[4 * i + 3] = (reg32 >> 24) & 0xff; } wait_rdy(mmio); - write32(mmio + 4 * 1, 0x4a800000 | (slave << 1)); + write32(GMBUS1_ADDR, GMBUS_SW_RDY + | GMBUS_SLAVE_WRITE | GMBUS_CYCLE_WAIT | GMBUS_CYCLE_STOP + | (128 << GMBUS_BYTE_COUNT_SHIFT) | (slave << 1) ); wait_rdy(mmio); - write32(mmio + 4 * 0, 0x48000000); - write32(mmio + 4 * 2, 0x00008000); + write32(GMBUS0_ADDR, GMBUS_SW_RDY | GMBUS_CYCLE_STOP ); + write32(GMBUS2_ADDR, GMBUS_INUSE);
printk (BIOS_SPEW, "EDID:\n"); for (i = 0; i < 128; i++) {
