Lean Sheng Tan has submitted this change. ( https://review.coreboot.org/c/coreboot/+/74339 )
Change subject: soc/intel/xeon_sp: Drop Kconfig MAX_SOCKET_UPD ......................................................................
The Kconfig is only used in common code to gather the build time maximum socket number FSP support. The same information is available in FSP header as MAX_SOCKET, thus use the FSP as truth of source.
Currently MAX_SOCKET is 4.
Change-Id: I10282c79dbf5d612c37b7e45b900af105bb83c36 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/74339 Reviewed-by: Paul Menzel paulepanter@mailbox.org Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz Reviewed-by: Johnny Lin Johnny_Lin@wiwynn.com Reviewed-by: Lean Sheng Tan sheng.tan@9elements.com --- M src/soc/intel/xeon_sp/spr/Kconfig M src/soc/intel/xeon_sp/spr/romstage.c 2 files changed, 28 insertions(+), 14 deletions(-)
Approvals: build bot (Jenkins): Verified Paul Menzel: Looks good to me, but someone else must approve Arthur Heymans: Looks good to me, approved Lean Sheng Tan: Looks good to me, approved Johnny Lin: Looks good to me, approved
diff --git a/src/soc/intel/xeon_sp/spr/Kconfig b/src/soc/intel/xeon_sp/spr/Kconfig index 832aab5..15b915d 100644 --- a/src/soc/intel/xeon_sp/spr/Kconfig +++ b/src/soc/intel/xeon_sp/spr/Kconfig @@ -27,14 +27,6 @@ string default "\_SB.C%03X"
-config MAX_SOCKET_UPD - int - default 2 - help - This is used for configuring common SPR UPD tables which their sizes - depend on the socket number. Since it's the maximal socket number for - the common UPD tables, mainboard should not overwrite it. - config SIPI_FINAL_TIMEOUT int default 400000 diff --git a/src/soc/intel/xeon_sp/spr/romstage.c b/src/soc/intel/xeon_sp/spr/romstage.c index aacc3ab..f36e5cc 100644 --- a/src/soc/intel/xeon_sp/spr/romstage.c +++ b/src/soc/intel/xeon_sp/spr/romstage.c @@ -23,8 +23,8 @@ #include "chip.h"
/* Initialize to all zero first */ -static UPD_IIO_PCIE_PORT_CONFIG spr_iio_bifur_table[CONFIG_MAX_SOCKET_UPD]; -static UINT8 deemphasis_list[CONFIG_MAX_SOCKET_UPD * MAX_IIO_PORTS_PER_SOCKET]; +static UPD_IIO_PCIE_PORT_CONFIG spr_iio_bifur_table[MAX_SOCKET]; +static UINT8 deemphasis_list[MAX_SOCKET * MAX_IIO_PORTS_PER_SOCKET];
void __weak mainboard_memory_init_params(FSPM_UPD *mupd) { @@ -119,12 +119,12 @@ unsigned int port, socket;
mupd->FspmConfig.IioPcieConfigTablePtr = (UINT32)spr_iio_bifur_table; - mupd->FspmConfig.IioPcieConfigTableNumber = CONFIG_MAX_SOCKET_UPD; + mupd->FspmConfig.IioPcieConfigTableNumber = MAX_SOCKET; UPD_IIO_PCIE_PORT_CONFIG *PciePortConfig = (UPD_IIO_PCIE_PORT_CONFIG *)spr_iio_bifur_table;
/* Initialize non-zero default UPD values */ - for (socket = 0; socket < CONFIG_MAX_SOCKET_UPD; socket++) { + for (socket = 0; socket < MAX_SOCKET; socket++) { for (port = 0; port < MAX_IIO_PORTS_PER_SOCKET; port++) { PciePortConfig[socket].PcieMaxPayload[port] = 0x7; /* Auto */ PciePortConfig[socket].DfxDnTxPresetGen3[port] = 0xff; /* Auto */ @@ -134,10 +134,10 @@ }
mupd->FspmConfig.DeEmphasisPtr = (UINT32)deemphasis_list; - mupd->FspmConfig.DeEmphasisNumber = CONFIG_MAX_SOCKET_UPD * MAX_IIO_PORTS_PER_SOCKET; + mupd->FspmConfig.DeEmphasisNumber = MAX_SOCKET * MAX_IIO_PORTS_PER_SOCKET; UINT8 *DeEmphasisConfig = (UINT8 *)deemphasis_list;
- for (port = 0; port < CONFIG_MAX_SOCKET_UPD * MAX_IIO_PORTS_PER_SOCKET; port++) + for (port = 0; port < MAX_SOCKET * MAX_IIO_PORTS_PER_SOCKET; port++) DeEmphasisConfig[port] = 0x1; }
