Gabe Black (gabeblack@chromium.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3942
commit 634dca04afb42afca600d859018db8ef7f95dcb3 Author: Gabe Black gabeblack@chromium.org Date: Tue Sep 24 01:36:08 2013 -0700
am335x: Add some code for manipulating GPIOs.
Add code for manipulating the GPIOs on the am335x. The API is patterned after the one used for the Exynos SOCs.
Change-Id: I275317304bd0682f348f72f1c77ed5613065af3f Signed-off-by: Gabe Black gabeblack@chromium.org --- src/cpu/ti/am335x/Makefile.inc | 3 +- src/cpu/ti/am335x/gpio.c | 88 ++++++++++++++++++++++++++++++++++++++++++ src/cpu/ti/am335x/gpio.h | 75 +++++++++++++++++++++++++++++++++++ 3 files changed, 165 insertions(+), 1 deletion(-)
diff --git a/src/cpu/ti/am335x/Makefile.inc b/src/cpu/ti/am335x/Makefile.inc index ff00733..690b2cf 100644 --- a/src/cpu/ti/am335x/Makefile.inc +++ b/src/cpu/ti/am335x/Makefile.inc @@ -1,5 +1,6 @@ -bootblock-y += dmtimer.c bootblock-y += bootblock_media.c +bootblock-y += dmtimer.c +bootblock-y += gpio.c bootblock-y += pinmux.c bootblock-$(CONFIG_EARLY_CONSOLE) += uart.c
diff --git a/src/cpu/ti/am335x/gpio.c b/src/cpu/ti/am335x/gpio.c new file mode 100644 index 0000000..d8264ae --- /dev/null +++ b/src/cpu/ti/am335x/gpio.c @@ -0,0 +1,88 @@ +/* + * Copyright 2013 Google Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <arch/io.h> +#include <console/console.h> +#include <cpu/ti/am335x/gpio.h> +#include <stdint.h> +#include <stdlib.h> + +static struct am335x_gpio_regs *gpio_regs_and_bit(unsigned gpio, uint32_t *bit) +{ + unsigned bank = gpio / AM335X_GPIO_BITS_PER_BANK; + if (bank > ARRAY_SIZE(am335x_gpio_banks)) { + printk(BIOS_ERR, "Bad gpio index %d.\n", gpio); + return NULL; + } + *bit = 1 << (gpio % 32); + return am335x_gpio_banks[bank]; +} + +void am335x_disable_gpio_irqs(void) +{ + int i; + for (i = 0; i < ARRAY_SIZE(am335x_gpio_banks); i++) + writel(0xffffffff, &am335x_gpio_banks[i]->irqstatus_clr_0); +} + +int gpio_direction_input(unsigned gpio) +{ + uint32_t bit; + struct am335x_gpio_regs *regs = gpio_regs_and_bit(gpio, &bit); + if (!regs) + return -1; + setbits_le32(®s->oe, bit); + return 0; +} + +int gpio_direction_output(unsigned gpio, int value) +{ + uint32_t bit; + struct am335x_gpio_regs *regs = gpio_regs_and_bit(gpio, &bit); + if (!regs) + return -1; + if (value) + writel(bit, ®s->setdataout); + else + writel(bit, ®s->cleardataout); + clrbits_le32(®s->oe, bit); + return 0; +} + +int gpio_get_value(unsigned gpio) +{ + uint32_t bit; + struct am335x_gpio_regs *regs = gpio_regs_and_bit(gpio, &bit); + if (!regs) + return -1; + return (readl(®s->datain) & bit) ? 1 : 0; +} + +int gpio_set_value(unsigned gpio, int value) +{ + uint32_t bit; + struct am335x_gpio_regs *regs = gpio_regs_and_bit(gpio, &bit); + if (!regs) + return -1; + if (value) + writel(bit, ®s->setdataout); + else + writel(bit, ®s->cleardataout); + return 0; +} diff --git a/src/cpu/ti/am335x/gpio.h b/src/cpu/ti/am335x/gpio.h new file mode 100644 index 0000000..a828b96 --- /dev/null +++ b/src/cpu/ti/am335x/gpio.h @@ -0,0 +1,75 @@ +/* + * Copyright 2013 Google Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CPU_TI_AM335X_GPIO_H__ +#define __CPU_TI_AM335X_GPIO_H__ + +#include <stdint.h> + +enum { + AM335X_GPIO_BITS_PER_BANK = 32 +}; + +struct am335x_gpio_regs { + uint32_t revision; // 0x0 + uint8_t _rsv0[0xc]; // 0x4-0xf + uint32_t sysconfig; // 0x10 + uint8_t _rsv1[0xc]; // 0x14-0x1f + uint32_t eoi; // 0x20 + uint32_t irqstatus_raw_0; // 0x24 + uint32_t irqstatus_raw_1; // 0x28 + uint32_t irqstatus_0; // 0x2c + uint32_t irqstatus_1; // 0x30 + uint32_t irqstatus_set_0; // 0x34 + uint32_t irqstatus_set_1; // 0x38 + uint32_t irqstatus_clr_0; // 0x3c + uint32_t irqstatus_clk_1; // 0x40 + uint32_t irqwaken_0; // 0x44 + uint32_t irqwaken_1; // 0x48 + uint8_t _rsv2[0xc8]; // 0x4c-0x113 + uint32_t sysstatus; // 0x114 + uint8_t _rsv3[0x18]; // 0x118-0x12f + uint32_t ctrl; // 0x130 + uint32_t oe; // 0x134 + uint32_t datain; // 0x138 + uint32_t dataout; // 0x13c + uint32_t leveldetect0; // 0x140 + uint32_t leveldetect1; // 0x144 + uint32_t risingdetect; // 0x148 + uint32_t fallingdetect; // 0x14c + uint32_t debouncenable; // 0x150 + uint32_t debouncingtime; // 0x154 + uint8_t _rsv4[0x38]; // 0x158-0x18f + uint32_t cleardataout; // 0x190 + uint32_t setdataout; // 0x194 +} __attribute__((packed)); + +static struct am335x_gpio_regs * const am335x_gpio_banks[] = { + (void *)0x44e07000, (void *)0x4804c000, + (void *)0x481ac000, (void *)0x481ae000 +}; + +void am335x_disable_gpio_irqs(void); + +int gpio_direction_input(unsigned gpio); +int gpio_direction_output(unsigned gpio, int value); +int gpio_get_value(unsigned gpio); +int gpio_set_value(unsigned gpio, int value); + +#endif /* __CPU_TI_AM335X_CLOCK_H__ */
