Jonathan Neuschäfer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/30165
Change subject: Documentation/lesson2: Add quotes to increase readability ......................................................................
Change-Id: Ibb041965bb9a97d153ace1f697607e524a6f50ac Signed-off-by: Jonathan Neuschäfer j.neuschaefer@gmx.net --- M Documentation/lessons/lesson2.md 1 file changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/30165/1
diff --git a/Documentation/lessons/lesson2.md b/Documentation/lessons/lesson2.md index a95dd80..d3e0d8c 100644 --- a/Documentation/lessons/lesson2.md +++ b/Documentation/lessons/lesson2.md @@ -65,8 +65,8 @@ to click the next page arrow at the bottom a few times to find it.
If you are using SSH keys, select **ssh** from the tabs under "Project -coreboot" and run the clone with commit-msg hook command that's provided. This -should prompt you for your id_rsa passphrase, if you previously set one. +coreboot" and run the "clone with commit-msg hook" command that's provided. +This should prompt you for your id_rsa passphrase, if you previously set one.
If you are using HTTP, instead, select **http** from the tabs under "Project coreboot" and run the command that appears
