Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/23517
Change subject: lib/stage_cache: Add debug messages for failures ......................................................................
Communicate additional status to the console when the save and load functions do not function as expected. The most likely scenario for an error is when using a cache that is external to cbmem, and restricted in size.
Change-Id: Ic9a709c11152b3b9cb40abfc204151f9636b5a4c Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com --- M src/lib/cbmem_stage_cache.c M src/lib/ext_stage_cache.c 2 files changed, 32 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/17/23517/1
diff --git a/src/lib/cbmem_stage_cache.c b/src/lib/cbmem_stage_cache.c index 2947972..cc4832f 100644 --- a/src/lib/cbmem_stage_cache.c +++ b/src/lib/cbmem_stage_cache.c @@ -25,15 +25,21 @@ void *c;
meta = cbmem_add(CBMEM_ID_STAGEx_META + stage_id, sizeof(*meta)); - if (meta == NULL) + if (meta == NULL) { + printk(BIOS_ERR, "Error: Can't add %x metadata to cbmem\n", + CBMEM_ID_STAGEx_META + stage_id); return; + } meta->load_addr = (uintptr_t)prog_start(stage); meta->entry_addr = (uintptr_t)prog_entry(stage); meta->arg = (uintptr_t)prog_entry_arg(stage);
c = cbmem_add(CBMEM_ID_STAGEx_CACHE + stage_id, prog_size(stage)); - if (c == NULL) + if (c == NULL) { + printk(BIOS_ERR, "Error: Can't add stage_cache %x to cbmem\n", + CBMEM_ID_STAGEx_CACHE + stage_id); return; + }
memcpy(c, prog_start(stage), prog_size(stage)); } @@ -49,13 +55,19 @@ prog_set_entry(stage, NULL, NULL);
meta = cbmem_find(CBMEM_ID_STAGEx_META + stage_id); - if (meta == NULL) + if (meta == NULL) { + printk(BIOS_ERR, "Error: Can't find %x metadata in cbmem\n", + CBMEM_ID_STAGEx_META + stage_id); return; + }
e = cbmem_entry_find(CBMEM_ID_STAGEx_CACHE + stage_id);
- if (e == NULL) + if (e == NULL) { + printk(BIOS_ERR, "Error: Can't find stage_cache %x in cbmem\n", + CBMEM_ID_STAGEx_CACHE + stage_id); return; + }
c = cbmem_entry_start(e); size = cbmem_entry_size(e); diff --git a/src/lib/ext_stage_cache.c b/src/lib/ext_stage_cache.c index 2a99188..cea9f52 100644 --- a/src/lib/ext_stage_cache.c +++ b/src/lib/ext_stage_cache.c @@ -68,8 +68,11 @@ imd = imd_get(); e = imd_entry_add(imd, CBMEM_ID_STAGEx_META + stage_id, sizeof(*meta));
- if (e == NULL) + if (e == NULL) { + printk(BIOS_DEBUG, "Error: Can't add %x metadata to imd\n", + CBMEM_ID_STAGEx_META + stage_id); return; + }
meta = imd_entry_at(imd, e);
@@ -79,8 +82,11 @@ e = imd_entry_add(imd, CBMEM_ID_STAGEx_CACHE + stage_id, prog_size(stage));
- if (e == NULL) + if (e == NULL) { + printk(BIOS_DEBUG, "Error: Can't add stage_cache %x to imd\n", + CBMEM_ID_STAGEx_CACHE + stage_id); return; + }
c = imd_entry_at(imd, e);
@@ -97,15 +103,21 @@
imd = imd_get(); e = imd_entry_find(imd, CBMEM_ID_STAGEx_META + stage_id); - if (e == NULL) + if (e == NULL) { + printk(BIOS_DEBUG, "Error: Can't find %x metadata in imd\n", + CBMEM_ID_STAGEx_META + stage_id); return; + }
e = imd_entry_find(imd, CBMEM_ID_STAGEx_CACHE + stage_id);
- if (e == NULL) + if (e == NULL) { + printk(BIOS_DEBUG, "Error: Can't find stage_cache %x in imd\n", + CBMEM_ID_STAGEx_CACHE + stage_id); return; + }
c = imd_entry_at(imd, e); size = imd_entry_size(imd, e);
