Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9394
commit 4aa74268c94b4c1daec8c5b591b791a5ae3c76c3 Author: Aaron Durbin adurbin@chromium.org Date: Wed Nov 5 10:23:33 2014 -0600
arm64: secmon: wait for all CPUs to enter secmon
There is state within the system that relies on having all CPUs present in order to proceed with initialization. The current expectation is that all CPUs are online and entering the secure monitor. Therefore, wait until all CONFIG_MAX_CPUs show up.
BUG=chrome-os-partner:32112 BRANCH=None TEST=Can get all CPUs up in kernel using PSCI.
Change-Id: I741a09128e99e0cb0c9f4046b1c0d27582fda963 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 030535b7c9821b40bf4a51f88e289eab8af9aa13 Original-Change-Id: Ia0f744c93766efc694b522ab0af9aedf7329ac43 Original-Signed-off-by: Aaron Durbin adurbin@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/227547 Original-Reviewed-by: Furquan Shaikh furquan@chromium.org --- src/arch/arm64/armv8/secmon/secmon_init.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/src/arch/arm64/armv8/secmon/secmon_init.c b/src/arch/arm64/armv8/secmon/secmon_init.c index 2ec2f13..fb3422f 100644 --- a/src/arch/arm64/armv8/secmon/secmon_init.c +++ b/src/arch/arm64/armv8/secmon/secmon_init.c @@ -53,6 +53,24 @@ static void cpu_init(int bsp) cpu_set_bsp(); }
+static void wait_for_all_cpus(void) +{ + int all_online; + + while (1) { + int i; + + all_online = 1; + for (i = 0; i < CONFIG_MAX_CPUS; i++) { + if (!cpu_online(cpu_info_for_cpu(i))) + all_online = 0; + } + + if (all_online) + break; + } +} + static void secmon_init(struct secmon_params *params, int bsp) { struct cpu_action action = { @@ -67,6 +85,9 @@ static void secmon_init(struct secmon_params *params, int bsp) if (!cpu_is_bsp()) secmon_wait_for_action();
+ /* Wait for all CPUs to enter secmon. */ + wait_for_all_cpus(); + smc_init(); psci_init();
