Attention is currently required from: Christian Walter, Felix Held, Fred Reitberger, Jason Glenesk, Julius Werner, Jérémy Compostella, Krystian Hebel, Matt DeVillier, Michał Żygowski, Raul Rangel, Sergii Dmytruk.
Hello Christian Walter, Felix Held, Fred Reitberger, Jason Glenesk, Julius Werner, Jérémy Compostella, Krystian Hebel, Matt DeVillier, Michał Żygowski, Raul Rangel, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/69162?usp=email
to look at the new patch set (#30).
Change subject: security/tpm: support compiling in multiple TPM drivers ......................................................................
Starting from here CONFIG_TPM1 and CONFIG_TPM2 are no longer mutually exclusive.
Making probe functions static and always using them uncovered that bootblock stage included TPM driver which it didn't use. This is why Makefile.inc files were updated to replace `all-*` with romstage, ramstage and verstage.
Change-Id: I44c5a1d825afe414c2f5c2c90f4cfe41ba9bef5f Ticket: https://ticket.coreboot.org/issues/433 Signed-off-by: Sergii Dmytruk sergii.dmytruk@3mdeb.com --- M src/drivers/crb/Makefile.mk M src/drivers/crb/tis.c M src/drivers/i2c/tpm/Makefile.mk M src/drivers/i2c/tpm/tis.c M src/drivers/i2c/tpm/tis_atmel.c M src/drivers/pc80/tpm/Makefile.mk M src/drivers/pc80/tpm/tis.c M src/drivers/spi/tpm/Makefile.mk M src/drivers/spi/tpm/tis.c M src/lib/program.ld M src/security/tpm/Kconfig M src/security/tpm/tis.h M src/security/tpm/tss/tss.c M src/soc/amd/common/block/cpu/noncar/memlayout_psp_verstage.ld 14 files changed, 81 insertions(+), 34 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/69162/30
