Attention is currently required from: Bao Zheng, Martin Roth, Zheng Bao. Hello build bot (Jenkins), Zheng Bao,
https://review.coreboot.org/c/coreboot/+/57131
to look at the new patch set (#38).
Change subject: amdfwtool: Add support for AMD's BIOS recovery feature ......................................................................
The BIOS recovery feature helps recover the computer from a Power On Self-Test (POST) or a boot failure that is caused by a corrupt BIOS. The system in BIOS recovery mode goes a different route, uses different FWs and different AMD FW layout. So the amdfwtool needs to change.
Change-Id: I2671b95fe089aafdaf61b55bc9d2e8dcf6a66dbc Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M util/amdfwtool/amdfwtool.c M util/amdfwtool/amdfwtool.h M util/amdfwtool/data_parse.c 3 files changed, 41 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/31/57131/38
