Attention is currently required from: Wonkyu Kim, Maulik V Vaghela, Tim Wawrzynczak, Angel Pons, Nick Vaccaro, Patrick Rudolph, EricR Lai, Karthik Ramasubramanian. Hello Wonkyu Kim, build bot (Jenkins), Maulik V Vaghela, Tim Wawrzynczak, Angel Pons, Nick Vaccaro, Patrick Rudolph, EricR Lai, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/61457
Change subject: soc/intel/tigerlake: Use PMC IPC to disable HECI1 ......................................................................
This patch allows common CSE block to make HECI1 function disable using PMC IPC command `0xA9`.
Select SOC_INTEL_COMMON_BLOCK_HECI1_DISABLE_USING_PMC_IPC config for tigerlake to disable HECI1 device using PMC IPC.
Additionally, drop HECI_DISABLE_USING_SMM config from TGL SoC as HECI1 disabling using PMC IPC is more scalable as it can operate outside SMM.
BUG=none TEST=None
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: Id5f1e3f622f65cd0f892c0dc541625bfd50d038e --- M src/soc/intel/tigerlake/Kconfig M src/soc/intel/tigerlake/smihandler.c 2 files changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/57/61457/3
