Maxim Polyakov has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/44468 )
Change subject: mb/google/fizz/endeavour/gpio: Fix code style ......................................................................
Use the 96 character limit.
Change-Id: I865288051869e50602a579a6999b1b23ef68ec2f Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com --- M src/mainboard/google/fizz/variants/endeavour/gpio.c 1 file changed, 30 insertions(+), 60 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/44468/1
diff --git a/src/mainboard/google/fizz/variants/endeavour/gpio.c b/src/mainboard/google/fizz/variants/endeavour/gpio.c index 716be3f..13f3b26 100644 --- a/src/mainboard/google/fizz/variants/endeavour/gpio.c +++ b/src/mainboard/google/fizz/variants/endeavour/gpio.c @@ -14,15 +14,13 @@ /* ESPI_IO3 */ /* ESPI_CS# */ /* SERIRQ */ PAD_CFG_NC(GPP_A6), /* TP331 */ -/* PIRQA# */ PAD_CFG_GPI_INT(GPP_A7, 20K_PU, DEEP, - EDGE), /* SD_CDZ */ +/* PIRQA# */ PAD_CFG_GPI_INT(GPP_A7, 20K_PU, DEEP, EDGE), /* SD_CDZ */ /* CLKRUN# */ PAD_CFG_NC(GPP_A8), /* TP329 */ /* ESPI_CLK */ /* CLKOUT_LPC1 */ PAD_CFG_NC(GPP_A10), /* TP188 */ /* PME# */ PAD_CFG_NC(GPP_A11), /* TP149 */ /* BM_BUSY# */ PAD_CFG_NC(GPP_A12), -/* SUSWARN# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_A13, NONE, - DEEP), /* eSPI mode */ +/* SUSWARN# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_A13, NONE, DEEP), /* eSPI mode */ /* ESPI_RESET# */ /* SUSACK# */ PAD_CFG_NC(GPP_A15), /* TP150 */ /* SD_1P8_SEL */ PAD_CFG_NF(GPP_A16, NONE, DEEP, NF1), @@ -39,30 +37,20 @@ /* VRALERT# */ PAD_CFG_NC(GPP_B2), /* TP152 */ /* CPU_GP2 */ PAD_CFG_NC(GPP_B3), /* CPU_GP3 */ PAD_CFG_NC(GPP_B4), -/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, - NF1), /* CLK_PCIE_LAN_REQ# */ -/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, - NF1), /* PCIE_CLKREQ_SSD# */ -/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, - NF1), /* PCIE_CLKREQ_TPU# */ -/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, - NF1), /* PCIE_CLKREQ_POE# */ -/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, - NF1), /* PCIE_CLKREQ_TPU1# */ -/* SRCCLKREQ5# */ PAD_CFG_NF(GPP_B10, NONE, DEEP, - NF1), /* PCIE_CLKREQ_WLAN# */ +/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, NF1), /* CLK_PCIE_LAN_REQ# */ +/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, NF1), /* PCIE_CLKREQ_SSD# */ +/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, NF1), /* PCIE_CLKREQ_TPU# */ +/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, NF1), /* PCIE_CLKREQ_POE# */ +/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, NF1), /* PCIE_CLKREQ_TPU1# */ +/* SRCCLKREQ5# */ PAD_CFG_NF(GPP_B10, NONE, DEEP, NF1), /* PCIE_CLKREQ_WLAN# */ /* EXT_PWR_GATE# */ PAD_CFG_NF(GPP_B11, NONE, DEEP, NF1), /* MPHY_EXT_PWR */ /* SLP_S0# */ PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), /* PM_SLP_S0# */ /* PLTRST# */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), /* PCI_PLTRST# */ /* SPKR */ PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), /* SPKR */ -/* GSPI0_CS# */ PAD_CFG_NF(GPP_B15, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CS_L */ -/* GSPI0_CLK */ PAD_CFG_NF(GPP_B16, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CLK */ -/* GSPI0_MISO */ PAD_CFG_NF(GPP_B17, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MISO */ -/* GSPI0_MOSI */ PAD_CFG_NF(GPP_B18, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MOSI */ +/* GSPI0_CS# */ PAD_CFG_NF(GPP_B15, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_CS_L */ +/* GSPI0_CLK */ PAD_CFG_NF(GPP_B16, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_CLK */ +/* GSPI0_MISO */ PAD_CFG_NF(GPP_B17, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_MISO */ +/* GSPI0_MOSI */ PAD_CFG_NF(GPP_B18, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_MOSI */ /* GSPI1_CS# */ PAD_CFG_NC(GPP_B19), /* TP98 */ /* GSPI1_CLK */ PAD_CFG_NC(GPP_B20), /* GSPI1_MISO */ PAD_CFG_NC(GPP_B21), @@ -75,21 +63,16 @@ /* SML0CLK */ PAD_CFG_NC(GPP_C3), /* SML0DATA */ PAD_CFG_NC(GPP_C4), /* SML0ALERT# */ PAD_CFG_NF(GPP_C5, NONE, DEEP, NF1), -/* SM1CLK */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C6, 20K_PU, - DEEP), /* EC_IN_RW */ +/* SM1CLK */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C6, 20K_PU, DEEP), /* EC_IN_RW */ /* SM1DATA */ PAD_CFG_NC(GPP_C7), /* TP99 */ /* UART0_RXD */ PAD_CFG_NC(GPP_C8), /* UART0_TXD */ PAD_CFG_NC(GPP_C9), /* UART0_RTS# */ PAD_CFG_NC(GPP_C10), /* UART0_CTS# */ PAD_CFG_NC(GPP_C11), -/* UART1_RXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C12, NONE, - DEEP), /* SKU_ID0 */ -/* UART1_TXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C13, NONE, - DEEP), /* SKU_ID1 */ -/* UART1_RTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C14, NONE, - DEEP), /* SKU_ID2 */ -/* UART1_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C15, NONE, - DEEP), /* SKU_ID3 */ +/* UART1_RXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C12, NONE, DEEP), /* SKU_ID0 */ +/* UART1_TXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C13, NONE, DEEP), /* SKU_ID1 */ +/* UART1_RTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C14, NONE, DEEP), /* SKU_ID2 */ +/* UART1_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C15, NONE, DEEP), /* SKU_ID3 */ /* I2C0_SDA */ PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), /* PCH_I2C_TPU_SDA */ /* I2C0_SCL */ PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), /* PCH_I2C_TPU_SCL */ /* I2C1_SDA */ PAD_CFG_NF(GPP_C18, NONE, DEEP, NF1), /* PCH_I2C1_H1_3V3_SDA */ @@ -97,8 +80,7 @@ /* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVO */ /* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVO */ /* UART2_RTS# */ PAD_CFG_NC(GPP_C22), /* TP93 */ -/* UART2_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C23, NONE, - DEEP), /* SCREW_SPI_WP_STATUS */ +/* UART2_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C23, NONE, DEEP), /* SCREW_SPI_WP_STATUS */
/* SPI1_CS# */ PAD_CFG_NC(GPP_D0), /* TP106 */ /* SPI1_CLK */ PAD_CFG_NC(GPP_D1), /* TP102 */ @@ -109,14 +91,10 @@ /* ISH_I2C0_SCL */ PAD_CFG_NC(GPP_D6), /* ISH_I2C1_SDA */ PAD_CFG_NC(GPP_D7), /* ISH_I2C1_SCL */ PAD_CFG_NC(GPP_D8), -/* ISH_SPI_CS# */ PAD_CFG_GPI_INT(GPP_D9, NONE, - PLTRST, EDGE), /* HP_IRQ_GPIO */ -/* ISH_SPI_CLK */ PAD_CFG_GPI_GPIO_DRIVER(GPP_D10, NONE, - DEEP), /* OEM_ID1 */ -/* ISH_SPI_MISO */ PAD_CFG_GPI_GPIO_DRIVER(GPP_D11, NONE, - DEEP), /* OEM_ID2 */ -/* ISH_SPI_MOSI */ PAD_CFG_GPI_GPIO_DRIVER(GPP_D12, NONE, - DEEP), /* OEM_ID3 */ +/* ISH_SPI_CS# */ PAD_CFG_GPI_INT(GPP_D9, NONE, PLTRST, EDGE), /* HP_IRQ_GPIO */ +/* ISH_SPI_CLK */ PAD_CFG_GPI_GPIO_DRIVER(GPP_D10, NONE, DEEP), /* OEM_ID1 */ +/* ISH_SPI_MISO */ PAD_CFG_GPI_GPIO_DRIVER(GPP_D11, NONE, DEEP), /* OEM_ID2 */ +/* ISH_SPI_MOSI */ PAD_CFG_GPI_GPIO_DRIVER(GPP_D12, NONE, DEEP), /* OEM_ID3 */ /* ISH_UART0_RXD */ PAD_CFG_NC(GPP_D13), /* ISH_UART0_TXD */ PAD_CFG_NC(GPP_D14), /* ISH_UART0_RTS# */ PAD_CFG_NC(GPP_D15), @@ -129,10 +107,8 @@ /* SPI1_IO3 */ PAD_CFG_NC(GPP_D22), /* TP94 */ /* I2S_MCLK */ PAD_CFG_NF(GPP_D23, NONE, DEEP, NF1), /* I2S_MCLK */
-/* SATAXPCI0 */ PAD_CFG_GPI_APIC_INVERT(GPP_E0, NONE, - PLTRST), /* H1_PCH_INT_ODL */ -/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, - NF1), /* MB_PCIE_SATA#_DET */ +/* SATAXPCI0 */ PAD_CFG_GPI_APIC_INVERT(GPP_E0, NONE, PLTRST), /* H1_PCH_INT_ODL */ +/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, NF1), /* MB_PCIE_SATA#_DET */ /* SATAXPCIE2 */ PAD_CFG_NC(GPP_E2), /* CPU_GP0 */ PAD_CFG_GPO(GPP_E3, 0, DEEP), /* TPU_RST_PIN40 */ /* SATA_DEVSLP0 */ PAD_CFG_NC(GPP_E4), /* TP103 */ @@ -142,14 +118,10 @@ /* SATALED# */ PAD_CFG_NC(GPP_E8), /* TP96 */ /* USB2_OCO# */ PAD_CFG_NC(GPP_E9), /* T1037 */ /* USB2_OC1# */ PAD_CFG_NC(GPP_E10), /* T1025 */ -/* USB2_OC2# */ PAD_CFG_NF(GPP_E11, NONE, DEEP, - NF1), /* Rear Dual-Stack USB Ports */ -/* USB2_OC3# */ PAD_CFG_NF(GPP_E12, NONE, DEEP, - NF1), /* Rear Single USB Port */ -/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, - NF1), /* DDI1_HDMI_HPD */ -/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, - NF1), /* DDI2_HDMI_HPD */ +/* USB2_OC2# */ PAD_CFG_NF(GPP_E11, NONE, DEEP, NF1), /* Rear Dual-Stack USB Ports */ +/* USB2_OC3# */ PAD_CFG_NF(GPP_E12, NONE, DEEP, NF1), /* Rear Single USB Port */ +/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, NF1), /* DDI1_HDMI_HPD */ +/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* DDI2_HDMI_HPD */ /* DDPD_HPD2 */ PAD_CFG_GPI_APIC(GPP_E15, NONE, DEEP), /* PCH_TYPEC_UPFB */ /* DDPE_HPD3 */ PAD_CFG_NC(GPP_E16), /* TP1021 */ /* EDP_HPD */ PAD_CFG_NF(GPP_E17, NONE, DEEP, NF1), @@ -170,10 +142,8 @@ /* I2C3_SCL */ PAD_CFG_NF(GPP_F7, NONE, DEEP, NF1), /* DDI1_I2C_7322_SCL */ /* I2C4_SDA */ PAD_CFG_NC(GPP_F8), /* I2C4_SCL */ PAD_CFG_NC(GPP_F9), -/* I2C5_SDA */ PAD_CFG_NF_1V8(GPP_F10, NONE, DEEP, - NF1), /* PCH_I2C2_AUDIO_1V8_SDA */ -/* I2C5_SCL */ PAD_CFG_NF_1V8(GPP_F11, NONE, DEEP, - NF1), /* PCH_I2C2_AUDIO_1V8_SCL */ +/* I2C5_SDA */ PAD_CFG_NF_1V8(GPP_F10, NONE, DEEP, NF1), /* PCH_I2C2_AUDIO_1V8_SDA */ +/* I2C5_SCL */ PAD_CFG_NF_1V8(GPP_F11, NONE, DEEP, NF1), /* PCH_I2C2_AUDIO_1V8_SCL */ /* EMMC_CMD */ PAD_CFG_NC(GPP_F12), /* EMMC_DATA0 */ PAD_CFG_NC(GPP_F13), /* EMMC_DATA1 */ PAD_CFG_NC(GPP_F14),
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44468 )
Patch Set 1: Code-Review+2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44468 )
https://review.coreboot.org/c/coreboot/+/44468/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/44468/1//COMMIT_MSG@7 PS1, Line 7: Fix code style I'd avoid `fix`. I'd say `Reflow long lines` instead.
Hello build bot (Jenkins), Angel Pons, Michael Niewöhner,
Change subject: mb/google/fizz/endeavour/gpio: Reflow long lines ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/44468/2
Maxim Polyakov has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44468 )
Patch Set 2:
Thanks for the review!
Done
Michael Niewöhner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/44468 )
Change-Id: I865288051869e50602a579a6999b1b23ef68ec2f Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/44468 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Michael Niewöhner foss@mniewoehner.de Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/google/fizz/variants/endeavour/gpio.c 1 file changed, 30 insertions(+), 60 deletions(-)
Approvals: build bot (Jenkins): Verified Angel Pons: Looks good to me, approved Michael Niewöhner: Looks good to me, approved
diff --git a/src/mainboard/google/fizz/variants/endeavour/gpio.c b/src/mainboard/google/fizz/variants/endeavour/gpio.c index 432a180..d4be35f 100644 --- a/src/mainboard/google/fizz/variants/endeavour/gpio.c +++ b/src/mainboard/google/fizz/variants/endeavour/gpio.c @@ -14,15 +14,13 @@ /* ESPI_IO3 */ /* ESPI_CS# */ /* SERIRQ */ PAD_CFG_NC(GPP_A6), /* TP331 */ -/* PIRQA# */ PAD_CFG_GPI_INT(GPP_A7, 20K_PU, DEEP, - EDGE), /* SD_CDZ */ +/* PIRQA# */ PAD_CFG_GPI_INT(GPP_A7, 20K_PU, DEEP, EDGE), /* SD_CDZ */ /* CLKRUN# */ PAD_CFG_NC(GPP_A8), /* TP329 */ /* ESPI_CLK */ /* CLKOUT_LPC1 */ PAD_CFG_NC(GPP_A10), /* TP188 */ /* PME# */ PAD_CFG_NC(GPP_A11), /* TP149 */ /* BM_BUSY# */ PAD_CFG_NC(GPP_A12), -/* SUSWARN# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_A13, NONE, - DEEP), /* eSPI mode */ +/* SUSWARN# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_A13, NONE, DEEP), /* eSPI mode */ /* ESPI_RESET# */ /* SUSACK# */ PAD_CFG_NC(GPP_A15), /* TP150 */ /* SD_1P8_SEL */ PAD_CFG_NF(GPP_A16, NONE, DEEP, NF1), @@ -39,30 +37,20 @@ /* VRALERT# */ PAD_CFG_NC(GPP_B2), /* TP152 */ /* CPU_GP2 */ PAD_CFG_NC(GPP_B3), /* CPU_GP3 */ PAD_CFG_NC(GPP_B4), -/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, - NF1), /* CLK_PCIE_LAN_REQ# */ -/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, - NF1), /* PCIE_CLKREQ_SSD# */ -/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, - NF1), /* PCIE_CLKREQ_TPU# */ -/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, - NF1), /* PCIE_CLKREQ_POE# */ -/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, - NF1), /* PCIE_CLKREQ_TPU1# */ -/* SRCCLKREQ5# */ PAD_CFG_NF(GPP_B10, NONE, DEEP, - NF1), /* PCIE_CLKREQ_WLAN# */ +/* SRCCLKREQ0# */ PAD_CFG_NF(GPP_B5, NONE, DEEP, NF1), /* CLK_PCIE_LAN_REQ# */ +/* SRCCLKREQ1# */ PAD_CFG_NF(GPP_B6, NONE, DEEP, NF1), /* PCIE_CLKREQ_SSD# */ +/* SRCCLKREQ2# */ PAD_CFG_NF(GPP_B7, NONE, DEEP, NF1), /* PCIE_CLKREQ_TPU# */ +/* SRCCLKREQ3# */ PAD_CFG_NF(GPP_B8, NONE, DEEP, NF1), /* PCIE_CLKREQ_POE# */ +/* SRCCLKREQ4# */ PAD_CFG_NF(GPP_B9, NONE, DEEP, NF1), /* PCIE_CLKREQ_TPU1# */ +/* SRCCLKREQ5# */ PAD_CFG_NF(GPP_B10, NONE, DEEP, NF1), /* PCIE_CLKREQ_WLAN# */ /* EXT_PWR_GATE# */ PAD_CFG_NF(GPP_B11, NONE, DEEP, NF1), /* MPHY_EXT_PWR */ /* SLP_S0# */ PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), /* PM_SLP_S0# */ /* PLTRST# */ PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), /* PCI_PLTRST# */ /* SPKR */ PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), /* SPKR */ -/* GSPI0_CS# */ PAD_CFG_NF(GPP_B15, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CS_L */ -/* GSPI0_CLK */ PAD_CFG_NF(GPP_B16, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_CLK */ -/* GSPI0_MISO */ PAD_CFG_NF(GPP_B17, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MISO */ -/* GSPI0_MOSI */ PAD_CFG_NF(GPP_B18, NONE, DEEP, - NF1), /* PCH_SPI_H1_3V3_MOSI */ +/* GSPI0_CS# */ PAD_CFG_NF(GPP_B15, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_CS_L */ +/* GSPI0_CLK */ PAD_CFG_NF(GPP_B16, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_CLK */ +/* GSPI0_MISO */ PAD_CFG_NF(GPP_B17, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_MISO */ +/* GSPI0_MOSI */ PAD_CFG_NF(GPP_B18, NONE, DEEP, NF1), /* PCH_SPI_H1_3V3_MOSI */ /* GSPI1_CS# */ PAD_CFG_NC(GPP_B19), /* TP98 */ /* GSPI1_CLK */ PAD_CFG_NC(GPP_B20), /* GSPI1_MISO */ PAD_CFG_NC(GPP_B21), @@ -75,21 +63,16 @@ /* SML0CLK */ PAD_CFG_NC(GPP_C3), /* SML0DATA */ PAD_CFG_NC(GPP_C4), /* SML0ALERT# */ PAD_CFG_NF(GPP_C5, NONE, DEEP, NF1), -/* SM1CLK */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C6, 20K_PU, - DEEP), /* EC_IN_RW */ +/* SM1CLK */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C6, 20K_PU, DEEP), /* EC_IN_RW */ /* SM1DATA */ PAD_CFG_NC(GPP_C7), /* TP99 */ /* UART0_RXD */ PAD_CFG_NC(GPP_C8), /* UART0_TXD */ PAD_CFG_NC(GPP_C9), /* UART0_RTS# */ PAD_CFG_NC(GPP_C10), /* UART0_CTS# */ PAD_CFG_NC(GPP_C11), -/* UART1_RXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C12, NONE, - DEEP), /* SKU_ID0 */ -/* UART1_TXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C13, NONE, - DEEP), /* SKU_ID1 */ -/* UART1_RTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C14, NONE, - DEEP), /* SKU_ID2 */ -/* UART1_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C15, NONE, - DEEP), /* SKU_ID3 */ +/* UART1_RXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C12, NONE, DEEP), /* SKU_ID0 */ +/* UART1_TXD */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C13, NONE, DEEP), /* SKU_ID1 */ +/* UART1_RTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C14, NONE, DEEP), /* SKU_ID2 */ +/* UART1_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C15, NONE, DEEP), /* SKU_ID3 */ /* I2C0_SDA */ PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), /* PCH_I2C_TPU_SDA */ /* I2C0_SCL */ PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), /* PCH_I2C_TPU_SCL */ /* I2C1_SDA */ PAD_CFG_NF(GPP_C18, NONE, DEEP, NF1), /* PCH_I2C1_H1_3V3_SDA */ @@ -97,8 +80,7 @@ /* UART2_RXD */ PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* SERVO */ /* UART2_TXD */ PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* SERVO */ /* UART2_RTS# */ PAD_CFG_NC(GPP_C22), /* TP93 */ -/* UART2_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C23, NONE, - DEEP), /* SCREW_SPI_WP_STATUS */ +/* UART2_CTS# */ PAD_CFG_GPI_GPIO_DRIVER(GPP_C23, NONE, DEEP), /* SCREW_SPI_WP_STATUS */
-/* SATAXPCI0 */ PAD_CFG_GPI_APIC_INVERT(GPP_E0, NONE, - PLTRST), /* H1_PCH_INT_ODL */ -/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, - NF1), /* MB_PCIE_SATA#_DET */ +/* SATAXPCI0 */ PAD_CFG_GPI_APIC_INVERT(GPP_E0, NONE, PLTRST), /* H1_PCH_INT_ODL */ +/* SATAXPCIE1 */ PAD_CFG_NF(GPP_E1, NONE, DEEP, NF1), /* MB_PCIE_SATA#_DET */ /* SATAXPCIE2 */ PAD_CFG_NC(GPP_E2), /* CPU_GP0 */ PAD_CFG_GPO_GPIO_DRIVER(GPP_E3, 0, DEEP, NONE), /* TPU_RST_PIN40 */ @@ -144,14 +120,10 @@ /* SATALED# */ PAD_CFG_NC(GPP_E8), /* TP96 */ /* USB2_OCO# */ PAD_CFG_NC(GPP_E9), /* T1037 */ /* USB2_OC1# */ PAD_CFG_NC(GPP_E10), /* T1025 */ -/* USB2_OC2# */ PAD_CFG_NF(GPP_E11, NONE, DEEP, - NF1), /* Rear Dual-Stack USB Ports */ -/* USB2_OC3# */ PAD_CFG_NF(GPP_E12, NONE, DEEP, - NF1), /* Rear Single USB Port */ -/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, - NF1), /* DDI1_HDMI_HPD */ -/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, - NF1), /* DDI2_HDMI_HPD */ +/* USB2_OC2# */ PAD_CFG_NF(GPP_E11, NONE, DEEP, NF1), /* Rear Dual-Stack USB Ports */ +/* USB2_OC3# */ PAD_CFG_NF(GPP_E12, NONE, DEEP, NF1), /* Rear Single USB Port */ +/* DDPB_HPD0 */ PAD_CFG_NF(GPP_E13, NONE, DEEP, NF1), /* DDI1_HDMI_HPD */ +/* DDPC_HPD1 */ PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), /* DDI2_HDMI_HPD */ /* DDPD_HPD2 */ PAD_CFG_GPI_APIC(GPP_E15, NONE, DEEP), /* PCH_TYPEC_UPFB */ /* DDPE_HPD3 */ PAD_CFG_NC(GPP_E16), /* TP1021 */ /* EDP_HPD */ PAD_CFG_NF(GPP_E17, NONE, DEEP, NF1), @@ -172,10 +144,8 @@ /* I2C3_SCL */ PAD_CFG_NF(GPP_F7, NONE, DEEP, NF1), /* DDI1_I2C_7322_SCL */ /* I2C4_SDA */ PAD_CFG_NC(GPP_F8), /* I2C4_SCL */ PAD_CFG_NC(GPP_F9), -/* I2C5_SDA */ PAD_CFG_NF_1V8(GPP_F10, NONE, DEEP, - NF1), /* PCH_I2C2_AUDIO_1V8_SDA */ -/* I2C5_SCL */ PAD_CFG_NF_1V8(GPP_F11, NONE, DEEP, - NF1), /* PCH_I2C2_AUDIO_1V8_SCL */ +/* I2C5_SDA */ PAD_CFG_NF_1V8(GPP_F10, NONE, DEEP, NF1), /* PCH_I2C2_AUDIO_1V8_SDA */ +/* I2C5_SCL */ PAD_CFG_NF_1V8(GPP_F11, NONE, DEEP, NF1), /* PCH_I2C2_AUDIO_1V8_SCL */ /* EMMC_CMD */ PAD_CFG_NC(GPP_F12), /* EMMC_DATA0 */ PAD_CFG_NC(GPP_F13), /* EMMC_DATA1 */ PAD_CFG_NC(GPP_F14),
