Attention is currently required from: Kangheui Won. Hello Reka Norman, Kangheui Won,
https://review.coreboot.org/c/coreboot/+/63563
Change subject: drivers/i2c/designware/dw_i2c: Remove unnecessary tabs in debug log ......................................................................
Before: [DEBUG] dw_i2c: SoC 400/3000 ns Bus: 400/1000000 ns [DEBUG] dw_i2c: period 334 rise 13 fall 2 tlow 174 thigh 80 spk 7 [DEBUG] dw_i2c: hcnt = 104 lcnt = 202 sda hold = 7
After: [DEBUG] dw_i2c: SoC 400/3000 ns Bus: 400/1000000 ns [DEBUG] dw_i2c: period 334 rise 13 fall 2 tlow 174 thigh 80 spk 7 [DEBUG] dw_i2c: hcnt = 104 lcnt = 202 sda hold = 7
BUG=None TEST=Check that the formatting looks correct, as above.
Change-Id: I6703a5d6512cee7848edae27afcfd82eb89bcacb Signed-off-by: Reka Norman rekanorman@chromium.org --- M src/drivers/i2c/designware/dw_i2c.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/63563/2
