Dave Frodin (dave.frodin@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6064
commit ddbe4ef2b0ee35337180a8c03dc82bd5df90d131 Author: Dave Frodin dave.frodin@se-eng.com Date: Thu Jun 12 16:28:21 2014 -0600
superio/nuvoton: Add chip support for setting IRQs to edge/level
Change-Id: I08b9eef9d6b0f120c17c3293f1f90b847742dc06 Signed-off-by: Dave Frodin dave.frodin@se-eng.com --- src/superio/nuvoton/nct5104d/chip.h | 28 ++++++++++++++ src/superio/nuvoton/nct5104d/nct5104d.h | 6 +++ src/superio/nuvoton/nct5104d/superio.c | 66 ++++++++++++++++++++++++++++++++- 3 files changed, 99 insertions(+), 1 deletion(-)
diff --git a/src/superio/nuvoton/nct5104d/chip.h b/src/superio/nuvoton/nct5104d/chip.h new file mode 100644 index 0000000..4fe8e87 --- /dev/null +++ b/src/superio/nuvoton/nct5104d/chip.h @@ -0,0 +1,28 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef SUPERIO_NUVOTON_NCT5104D_CHIP_H +#define SUPERIO_NUVOTON_NCT5104D_CHIP_H + +struct superio_nuvoton_nct5104d_config { + u8 irq_trigger_type; +}; + +#endif diff --git a/src/superio/nuvoton/nct5104d/nct5104d.h b/src/superio/nuvoton/nct5104d/nct5104d.h index b72dda0..a162cc3 100644 --- a/src/superio/nuvoton/nct5104d/nct5104d.h +++ b/src/superio/nuvoton/nct5104d/nct5104d.h @@ -22,6 +22,12 @@ #ifndef SUPERIO_NUVOTON_NCT5104D_NCT5104D_H #define SUPERIO_NUVOTON_NCT5104D_NCT5104D_H
+/* SIO global configuration */ +#define IRQ_TYPE_SEL_CR10 0x10 /* UARTA,UARTB */ +#define IRQ_TYPE_SEL_CR11 0x11 /* SMI,UARTC,UARTD,WDTO */ +#define GLOBAL_OPTION_CR26 0x26 +#define CR26_LOCK_REG (1 << 4) /* required to access CR10/CR11 */ + /* Logical Device Numbers (LDN). */ #define NCT5104D_FDC 0x00 /* FDC - not pinned out */ #define NCT5104D_SP1 0x02 /* UARTA */ diff --git a/src/superio/nuvoton/nct5104d/superio.c b/src/superio/nuvoton/nct5104d/superio.c index 5eb8991..c2a744f 100644 --- a/src/superio/nuvoton/nct5104d/superio.c +++ b/src/superio/nuvoton/nct5104d/superio.c @@ -23,9 +23,69 @@ #include <superio/conf_mode.h> #include <stdlib.h> #include "nct5104d.h" +#include "chip.h"
static void nct5104d_init(device_t dev) { + struct superio_nuvoton_nct5104d_config *conf = dev->chip_info; + u8 reg10, reg11, reg26; + + if (!dev->enabled) + return; + + pnp_enter_conf_mode(dev); + + //Before accessing CR10 OR CR11 Bit 4 in CR26 must be set to 1 + reg26 = pnp_read_config(dev, GLOBAL_OPTION_CR26); + reg26 |= CR26_LOCK_REG; + pnp_write_config(dev, GLOBAL_OPTION_CR26, reg26); + + switch(dev->path.pnp.device) { + //SP1 (UARTA) IRQ type selection (1:level,0:edge) is controlled by CR 10, bit 5 + case NCT5104D_SP1: + reg10 = pnp_read_config(dev, IRQ_TYPE_SEL_CR10); + if (conf->irq_trigger_type) + reg10 |= (1 << 5); + else + reg10 &= ~(1 << 5); + pnp_write_config(dev, IRQ_TYPE_SEL_CR10, reg10); + break; + //SP2 (UARTB) IRQ type selection (1:level,0:edge) is controlled by CR 10, bit 4 + case NCT5104D_SP2: + reg10 = pnp_read_config(dev, IRQ_TYPE_SEL_CR10); + if (conf->irq_trigger_type) + reg10 |= (1 << 4); + else + reg10 &= ~(1 << 4); + pnp_write_config(dev, IRQ_TYPE_SEL_CR10, reg10); + break; + //SP3 (UARTC) IRQ type selection (1:level,0:edge) is controlled by CR 11, bit 5 + case NCT5104D_SP3: + reg11 = pnp_read_config(dev,IRQ_TYPE_SEL_CR11); + if (conf->irq_trigger_type) + reg11 |= (1 << 5); + else + reg11 &= ~(1 << 5); + pnp_write_config(dev, IRQ_TYPE_SEL_CR11, reg11); + break; + //SP4 (UARTD) IRQ type selection (1:level,0:edge) is controlled by CR 11, bit 4 + case NCT5104D_SP4: + reg11 = pnp_read_config(dev,IRQ_TYPE_SEL_CR11); + if (conf->irq_trigger_type) + reg11 |= (1 << 4); + else + reg11 &= ~(1 << 4); + pnp_write_config(dev, IRQ_TYPE_SEL_CR11, reg11); + break; + default: + break; + } + + //Clear access control register + reg26 = pnp_read_config(dev, GLOBAL_OPTION_CR26); + reg26 &= ~CR26_LOCK_REG; + pnp_write_config(dev, GLOBAL_OPTION_CR26, reg26); + pnp_exit_conf_mode(dev); }
static struct device_operations ops = { @@ -38,13 +98,17 @@ static struct device_operations ops = { };
static struct pnp_info pnp_dev_info[] = { - { &ops, NCT5104D_SP2, PNP_IO0 | PNP_IRQ0, {0x07f8, 0}, }, + { &ops, NCT5104D_FDC, PNP_IO0 | PNP_IRQ0, {0x07f8, 0}, }, { &ops, NCT5104D_SP1, PNP_IO0 | PNP_IRQ0, {0x07f8, 0}, }, + { &ops, NCT5104D_SP2, PNP_IO0 | PNP_IRQ0, {0x07f8, 0}, }, + { &ops, NCT5104D_SP3, PNP_IO0 | PNP_IRQ0, {0x07f8, 0}, }, + { &ops, NCT5104D_SP4, PNP_IO0 | PNP_IRQ0, {0x07f8, 0}, }, { &ops, NCT5104D_GPIO_WDT}, { &ops, NCT5104D_GPIO_PP_OD}, { &ops, NCT5104D_GPIO0}, { &ops, NCT5104D_GPIO1}, { &ops, NCT5104D_GPIO6}, + { &ops, NCT5104D_PORT80}, };
static void enable_dev(struct device *dev)
