Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13680
commit 0790aac02da4d11eaf4aef56c9341d2a0d1f06b0 Author: Aaron Durbin adurbin@chromium.org Date: Wed Feb 10 23:04:23 2016 -0600
arch/{arm64,riscv}: remove jmp_to_elf_entry() declaration
jmp_to_elf_entry() is not defined anywhere. Remove it.
Change-Id: I68f996a735f2ef3dd60cf69f9b72c3f1481cbb55 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/arch/arm64/include/arch/stages.h | 1 - src/arch/riscv/include/arch/stages.h | 1 - 2 files changed, 2 deletions(-)
diff --git a/src/arch/arm64/include/arch/stages.h b/src/arch/arm64/include/arch/stages.h index 3a3f56e..ce66cdd 100644 --- a/src/arch/arm64/include/arch/stages.h +++ b/src/arch/arm64/include/arch/stages.h @@ -21,6 +21,5 @@ extern void main(void);
void stage_entry(void); -void jmp_to_elf_entry(void *entry, unsigned long buffer, unsigned long size);
#endif diff --git a/src/arch/riscv/include/arch/stages.h b/src/arch/riscv/include/arch/stages.h index 9e2a378..07a72a4 100644 --- a/src/arch/riscv/include/arch/stages.h +++ b/src/arch/riscv/include/arch/stages.h @@ -19,6 +19,5 @@ extern void main(void);
void stage_entry(void) __attribute__((section(".text.stage_entry"))); -void jmp_to_elf_entry(void *entry, unsigned long buffer, unsigned long size);
#endif
