Attention is currently required from: Angel Pons, Maximilian Brune, Michał Żygowski, Paul Menzel.
Hello Krystian Hebel, Sean Rhodes, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/69870?usp=email
Change subject: intel/cmn/smm: Introduce PERIODIC_SMI_RATE_SELECTION_IN_GEN_PMCON_B ......................................................................
Certain chipsets/SoCs like Apollo Lake use GEN_PMCON_B for periodic SMI rate selection unlike other chipsets which use GEN_PMCON_A. Introduce new Kconfig option PERIODIC_SMI_RATE_SELECTION_IN_GEN_PMCON_B to indicate the register difference.
Based on Apollo Lake datasheet Vol. 3 Revision 005: https://cdrdv2.intel.com/v1/dl/getContent/334819
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: I11241836ecc9066d323977b030686567c87ed256 --- M src/soc/intel/common/block/smm/Kconfig 1 file changed, 9 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/69870/7
